MK7 Golf Control Module for Front Belt Tensioner Not configured
sasha
Australia
C?ID=287611
I was hoping to confirm that the below page with instructions to perform a seat belt tensioner control module reset will work with a wrecker sourced (second hand) left/right seatbelts?
Thanks in advance!
http://wiki.ross-tech.com/wiki/index.php/AirbagVW20#Seat_Belt_Tensioner_Control_Module_Reset
Tuesday,16,October,2018,21:36:41:15919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 18.9.0.1
VIN: WVWZZZAUZHW390051   License Plate:
Mileage: 7994km-4967mi   Repair Order:
                Address 15: Airbags       Labels: 5Q0-959-655.clb
Control Module Part Number: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
  Component and/or Version: AirbagVW21    003 0318
           Software Coding: 98CCC000000000005C000000008800000065
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_AirbaVW20SMEVW37X 002154 (VW37)
                       ROD: EV_AirbaVW20SMEVW37X.rod
                      VCID: 102E3536CB5D5CCA46-8045
9634901 - Control Module for Front Left Belt Tensioner
          B1304 55 [009] - Not configured
                    Reset counter: 97
                    Mileage: 7994 km
                    Date: 2018.10.08
                    Time: 02:37:24
9635157 - Control Module for Front Right Belt Tensioner
          B1305 55 [009] - Not configured
                    Reset counter: 97
                    Mileage: 7994 km
                    Date: 2018.10.08
                    Time: 02:37:24
myounus
Northwest UK
C?ID=321059
It should work although a full autoscan would help to see if there's other faults.
sasha
Australia
C?ID=287611
Update: steps in the wiki performed this afternoon and the result is positive. Attaching full scan for reference.
Wednesday,17,October,2018,19:59:10:15919
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 5F A5
VIN: WVWZZZAUZHW390051   Mileage: 7994km-4967miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---
   Coding: 0119003224441D082000
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6DD04CC2BCAFD1220D-8039
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 90977000015683
   Coding: 01FA8AA12429216C4777060540C42980512484E26002947334205038C0A2430000000012121212B835351919323200
   VCID: 78FE6D96C3ED648AEE-802D
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00120004200100001100000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 7AFA779EFDE1769A98-802F
   Part No SW: 5Q0 937 084 CD    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H34 0236
   Serial number: 01001713101502
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7CF67186F7D548AA8A-8029
   Component: WWS    170414  042 0551
   Serial number:         170503235341
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S2Y17M05D15H03M21S08
   Coding: 00A8DD
   Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0038
   Serial number: 000308417617126
   Coding: 0371167041
   ASAM Dataset: EV_EPHVA2CAU3700000 009032
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 4FACF64A16E303321F-801B
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0620
   Coding: 2B0060C111FFC428949C810560300600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002005
   VCID: 3C76B186B75588AACA-8069
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0318
   Serial number: 003TDR2YJ95C
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169677E18081750384
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169676E18081781117
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 305 17
   Serial number: 3570000000039709442A
   Subsystem 4 - Part No SW: -----------    HW: 480 002 308 17
   Serial number: 35800000000C2D79072P
   Subsystem 5 - Part No SW: -----------    HW: 480 400 905 17
   Serial number: 3510001A3253734517FW
   Subsystem 6 - Part No SW: -----------    HW: 480 400 905 17
   Serial number: 3520001AB2517A0216AX
   Subsystem 7 - Part No SW: -----------    HW: 480 401 105 17
   Serial number: 3550001A72502B24B24V
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 29041708490701
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 05001462841F0962E5-8051
   Part No SW: 5G1 920 740 B    HW: 5G1 920 740 B
   Component: KOMBI         204 8311
   Coding: 27A429006788000801882B0B5401000000000000
   VCID: 254074E224DF296285-8071
   Component: GW MQB High   515 5286
   Serial number: 29041710522330
   Coding: 030100347F085700FB00005C080F00010001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F6C96CA762363327F-807B
   Serial number: 29170001823560057337
   Coding: 2CFFFF
   Serial number: 2746453804
   Component: HRE_Master    H12 0071
   Serial number: 0438593602
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0071
   Serial number: 0438633642
   Coding: 020112
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 160417EDG01048
   Coding: 003003208001048000001000
   VCID: 4188C072D0B7E54299-8015
   Serial number: 00000000000014584075
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4580D462C49FC962A5-8011
   Serial number: 020517EE220676
   Coding: 003001208E01048000801000
   VCID: 428ACF7ED5B1FE5A80-8017
   Serial number: 00000000000001963363
   Coding: 050000
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0753
   Coding: 02731000FF00000051510001000808001F0500D60120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2C5681C64735182A5A-8079
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8120
   Serial number: VWZ6ZHT1261242
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 12051711P22970
   Coding: 000307000000010100020054C050490084000E000000
   VCID: 3B74B29AB25B8F92C3-806F
End-------------------------(Elapsed Time: 04:42)--------------------------
John ler
C?ID=144693
i have a similar problem, Im fitting 2 used belts and after basic settings and access code 12345, Im getting error 37, I'm a little stuck where it says, do not plug in seat belt, is this meaning the buckle/clip, or the airbag igniter wire plug behind the interior panel, any help would be great thanks, sorry forgotten how to put autoscan up,
Monday,13,April,2020,14:40:26:52681
VIN: WVWZZZAUZGW286922   License Plate:
Mileage: 63456km-39429mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW286922   Mileage: 63456km-39429miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H23 2489
   Revision: R6H23---
   Coding: 0119003223441D082000
   ASAM Dataset: EV_ECM14TFS01104E906027HF 001005
   ROD: EV_ECM14TFS01104E906027HF.rod
   VCID: 6FB8DBB43711D0E3BA8-803A
   CAN Converter 01:
18065 - Coolant Pump 2
          P261C 00 [039] - Short to GND
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:57:14
                    Coolant temperature: 73 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 12.415 V
                    Outside air temperature: 12 °C
                    Absolute intake pressure: 102 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 10.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 60676000003389
   Coding: 01FA8AA1242829720780060241C52980512494E0608294F314205078C002
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 7EA6F6F0607BA96B21E-802A
4410 - Indicator Lamp in Auto-Hold Switch
          C1156 14 [009] - Open or Short to Ground
                    Reset counter: 37
                    Date: 2020.04.08
                    Time: 19:32:31
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 00120004200100001000000000000002
   VCID: 3C223CF836E77B7B4FA-8068
262658 - High Pressure Sensor
          B10AE 31 [009] - No Signal
                    Reset counter: 37
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:32:47
                    Outside air temperature: 11.0 °C
                    Engine speed: 700 /min
                    Temperature after evaporator: 25.3 °C
                    System run time-Engine running time: 33 s
                    System run time-Terminal 15 on: 80 s
   Part No SW: 5Q0 937 084 CJ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0175
   Serial number: 01061607000804
   Coding: 03100842C201027B0B244080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 025E82001483CD8B456-8056
   Component: WWS    160309  042 0551
   Serial number:         160311131736
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y16M03D13H23M40S06
   Coding: 90A8DD
   Serial number: 000000000ZY160325UG7
   Serial number: 00000000000034893624
   Sun Roof:
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST000U5Q5U00000
   Coding: 181901
17162 - Bulb for Left DRL and Parking Lamp
          B12EA 15 [009] - Open or Short to Plus
                    Reset counter: 37
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:33:05
395273 - Control Circuit for Signal Horn
          B1344 14 [009] - Open or Short to Ground
                    Reset counter: 37
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:33:05
   Revision: --------    Serial number: 39391608203603
   Coding: 0071051001
   VCID: 43D047044B1904830E0-8016
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [009] - Open or Short to Ground
                    Reset counter: 37
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:57:46
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 13021603212374
   Coding: 00000300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A2E3AE03CD3454B5D6-806E
1540 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_MISALIGNMENT_HORIZONTAL]
                    Reset counter: 37
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:33:29
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.8 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1043 - Automatic Distance Control
          B10E7 F0 [008] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 77
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:33:29
   Serial number: 003MLR1JLHLN
   VCID: 7F580BF46771A0632A8-802A
   Component: BeltPretRevFL  H36 0350
   Serial number: 34169677B26021540999
   Coding: 333135
   Component: BeltPretRevFR  H36 0350
   Serial number: 34169676B27021570331
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 503 16
   Serial number: 357670000009FA811A1/
   Subsystem 4 - Part No SW: -----------    HW: 480 001 603 16
   Serial number: 35867000000EA6501A1X
   Subsystem 5 - Part No SW: -----------    HW: 480 401 703 16
   Serial number: 3516502B7200CA0150A.
   Subsystem 6 - Part No SW: -----------    HW: 480 401 703 16
   Serial number: 3526502A5200CA05336-
   Subsystem 7 - Part No SW: -----------    HW: 480 401 703 16
   Serial number: 35565029B200CA0451E8
                    Reset counter: 37
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:55:37
                    Reset counter: 37
                    Mileage: 63456 km
                    Date: 2020.04.08
                    Time: 19:55:37
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 18031604221138
   Coding: 0400
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0D44A13C5DDD82F3284-8058
   Part No SW: 5G1 920 940 A    HW: 5G1 920 940 A
   Component: KOMBI         202 6420
   Coding: 27A401002780260001886A011400000000000000
   VCID: 2616FE90D86BD1AB09E-8072
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004630257
   Coding: 030100043F085700FB00005C080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79ACE5EC79558E5314C-802C
   Serial number: 29160000512100066111
   Coding: 2CFFFF
   Serial number: 9049929503
   Serial number: 180216EBG00471
   Coding: 003B0220D001048100001000
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 8103
   VCID: 44D244184E1703BB37A-8010
   Serial number: 190216EBH12457
   Coding: 003B0020DE01048100801000
   VCID: 42DE420054030D8B056-8016
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0624
   Coding: 02730001FF00000051111101008808001F0206C601200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 303A18C8EAAF8F1BE32-8064
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJU00PNE
End----(Elapsed Time: 01:21, VBatt start/end: 12.5V/12.5V. VIgn 0.0V)------
myounus
Northwest UK
C?ID=321059
In the buckle clip, however, clear all your other faults first!
John ler
C?ID=144693
Many thanks for reply, I have a acc one o can’t do anything with, was hoping I could code it out, to make car think I don’t have it fitted, not sure if this is possible, I don’t want car thinking it’s in right place when it must not be, are there’s other faults, making seatbelts not configured? Thanks again
Dana
Western PA, USA
I don't know if you are going to succeed with used belts but 12345 is not one of the Airbag SA codes for this module. You might wan to try: 11091
If that was the code you were already using I would take a look at the original scan with the old belts installed to see if the (subsystem) slave part numbers match.
siLc
Tallinn, Estonia
C?ID=330192
By the looks of it, the ACC radar is still intact - why not replace its bracket (if applicable) and have it calibrated?
myounus
Northwest UK
C?ID=321059
The ACC is a safety feature, why would you want to code it out? It’s not expensive to fix, the biggest cost is recalibration £200 at the dealers and you can’t escape it!
downtime
C?ID=280813
Also you would not have any form of cruise after that. You cannot code ACC out and code conventional cruise. Won’t work as both have different feature enable codes.
John ler
C?ID=144693
I dont want the car to have cruise on it, it’s for my son and I wouldn't want him using it , the acc radar has lost its alignment some how, but it’s an expense I don’t want at the moment, plus wouldn’t want him to start to relying on it, but I’ve been quoted £360pls at for the alignment. From 2 dealers, with is cvid19 thing. I’ve lost a years worth of work, and money is now a problem, so just want to code it out
every this is there and was all fine, just one day it had stopped working , I might add it back agin later when I trust him ,
Dana thanks I’ll try that
downtime
C?ID=280813
But the radar has other function, pre-crash or autonomous braking. This especially is great safety feature for young drivers. I would definitely keep it enabled if my child would be driving.
I can’t understand people sometimes
John ler
C?ID=144693
Yes it has great benefits, but I don’t have spare cash to pay £360 or so to pay for it to be set up, that’s if that’s all it needs, could need new parts diagnostic etc, plus at this time been self employed I don’t have an income coins in and have 2 kids plus another kind that was been abused that we look after, covid19, is killing me money wise, only wage earner, so don’t have funds for this atm, and I don’t want my lad thinking he can rely on it, thinking car will break for its self, I’ve seen people try this and car not breaking, it’s something I don’t want on the car, any no how I can code it out please,
