VW Up aircon not working
RyMar
South Africa
C?ID=133909
Up was in accident. Serviced and regassed aircon. Compressor will kick in for a while and then stops working.
Under what control unit can I check the MVB`s?
Tuesday,16,October,2018,10:18:04:48706
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: RyMar Auto
Workshop Code: 000 00000 001753
VIN: WVWZZZAAZHD078844   License Plate: DVW963L
Mileage: 2120km-1317mi   Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 09 15 17 19 25 44 5F
VIN: WVWZZZAAZHD078844   Mileage: 2120km-1317miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 EJ    HW: 04C 907 309 N
   Component: R3 1.0l MPI   H24 3168
   Revision: UOH24---
   Coding: 00110014020400000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10MPI01104C906020EJ 002002
   ROD: EV_ECM10MPI01104C906020EJ_002.rod
   VCID: 679E5E719ED3967274-8032
7786 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [032] - Malfunction
                    Mileage: 1815 km
                    Date: 2018.09.29
                    Time: 22:35:17
                    Engine speed: 859.50 /min
                    Normed load value: 25.9 %
                    Coolant temperature: 86 °C
                    Intake air temperature: 34 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 13.900 V
                    Unlearning counter according OBD: 7
                    Outside air temperature: 215 °C
                    Absolute intake pressure: 34 kPa abs
                    Engine torque: 17.8 Nm
                    Fuel level: 19.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Overrun cut-off-Bits 0-7: 0
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 L    HW: 1S0 614 517 L
   Component: EBC 460 ESP   H16 0023
   Serial number: A01GNLA
   Coding: 11BF247129B402F9880224F994AD40805B0100
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
   ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
   VCID: 383CCD0D83EDC98A2D-806C
0347 - Please Check Fault Codes in Instrument Cluster
          U1024 00 [008] - -
          [MSG_KO2_AUSSEN_T_INVALID]
                    Reset counter: 10
                    Mileage: 1815 km
                    Date: 2018.09.29
                    Time: 22:35:15
                    DTC: 00 01 5B
0459 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 14
                    Mileage: 1832 km
                    Date: 2018.09.23
                    Time: 00:53:13
                    DTC: 00 01 CB
0464 - Display for Tire Pressure Monitoring
                    Reset counter: 10
                    Mileage: 1815 km
                    Date: 2018.09.29
                    Time: 22:35:25
                    DTC: 00 01 D0
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 1S0 937 086 H    HW: 1S0 937 086
   Component: BCM PQ25 Med4 H41 0444
   Revision: BD041001    Serial number: 0979 093170143
   Coding: 6AB82B00000100000000000024A9AC800040500C60022C20200100000000
   Shop #: WSC 12599 026 411142
   VCID: 3D32DC19A4CFECA2FE-8068
   Part No SW: 1S0 959 655 C    HW: 1S0 959 655 C
   Component: VW10Airbag02R H03 0007
   Revision: --------    Serial number: 003UB001F8YG
   Coding: 000000000000000000000000000000003252
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   VCID: 3E30DB15A1C9F7BAE7-806A
   Serial number: 3497ARB405H4ND92411P
   Serial number: 3507ARB405H4ND92H14X
   Serial number: 3557BRB40594AVKIA23D
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 850 H    HW: 1S0 920 850 H
   Component: KOMBI         H63 0502
   Revision: X0063001    Serial number: 00000000000000
   Coding: 1142010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 3424F93D9F852DEA01-8060
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Reset counter: 10
                    Mileage: 1815 km
                    Date: 2018.09.29
                    Time: 22:35:13
   Part No SW: 1S0 909 901     HW: 1S0 937 086
   Component: GW-K-CAN TP20 H41 0444
   Revision: BD041001
   Coding: 001300
   VCID: 70AC352DA31D51CA25-8024
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 1S0 920 850 H
   Component: IMMO          H63 0502
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6A9827458DC1AB1A6B-803E
   Part No SW: 6R2 909 144 AM    HW: 6R2 909 144 E
   Component: EPS_TRW_ALow  323 3142
   Serial number: CH451175
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 03466AE18AAB5A52C8-8056
   Part No SW: 1S0 035 867     HW: 1S0 035 867
   Component: MU-E--EU      068 7298
   Serial number: 13031700021585
   Coding: 02210000280000004011000100011000000000060000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 71AA3029A01758C22A-8024
End----(Elapsed Time: 00:26, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
iichel
Netherlands, eastern part
C?ID=284912
My gut feeling would say, check address 08 HVAC but that doesn't seem to be available in any Up! on the net.
Checking the wiring diagrams, it seems to be a non-diagnostic control module that is (semi) hard wired.
You could have a look at the high pressure sender G65 in the engine ECU. G65 should be connected to it.
A theory:
Your outside temperature sensor seems to be broken (or its wiring). This way, the HVAC doesn't know the temperature and will go into safety shut off (like it does with very low temps, to prevent the compressor from freezing).
Check the sensor and its wiring, it's from T32 (instrument cluster) pins 19 and 20. I suspect, when it's the wiring, it's wire 19 (yellow/brown) since 20 is a common ground with the coolant level sender.
I don't know where the sensor is, typically it's behind the front bumper on the left hand side, just in front of the radiator.
NEtech
C?ID=56995
Is it possible that you can make Controller Map files from [09] ?
And post them here.
[Applications]
[Controller Channel Map]
- Controller Address = 09
- Login or security code: Leave blank
- Function: Measuring values and Adaptations
- Output: CSV file
[Go]
Jef
HQ
Thanks for the Auto-Scan! :thumbs:
Vehicle Identification No. WVWZZZAAZHD078844
Model up! 1.0
UP
Date of production 21.04.2017
Year 2017
Sales type 1222D1
Engine Code CHYB
Transmission Code RNY
Heating and air-conditioning system - 9AB - Manually controlled air conditioning system
A bit of an odd system, or to me at least it is... so there is a J301 "Control Unit for AC", but it seems to be dumb as rocks and doesn't talk. There is a V454 that is the "air compressor" and it is operated by a J32 "relay for air conditioning"... this relay is operated by the J623 Engine Control Module. So the ECM runs the AC.
The G17 is wired up to the cluster, T32/19 and T32/20. Note that T32/20 is a shared ground with the G32. Check your wiring for the G17, if to factory design, replace G17 temp sensor with new unit from dealer.
