Label File for 6C
DaveN
Ireland
C?ID=62381
Hi, I've just installed a 6C backup camera in my A6 C7 saloon, there doesnt seems to be a label file for the camera.
I have a fault as I have not run the calibration but I would like to see the additional coding options.
Is a development one available?
Dave N
Saturday,13,October,2018,16:06:19:21606
VCDS Version: 18.9.0.2 (x64)
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 4S0 980 556 A HW: 5Q0 980 556 B
Component: RVC Compact H12 0201
Coding: 0275010100002007000040
Shop #: WSC 17873 123 50804
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_002.rod
VCID: 397302E3B80DF482D2-806C
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 212
Mileage: 27891 km
Date: 2018.10.13
Time: 16:00:55
passive
NEtech
C?ID=56995
DaveN
Ireland
C?ID=62381
VIN: WAUZZZ4GXHN088186   License Plate: 171+RVCWORKING
Mileage: 27891km-17330mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
          5F 62 6C 72 AC
VIN: WAUZZZ4GXHN088186   Mileage: 27891km-17330miles
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
   Component: R4 2.0l TDI   H20 3830
   Revision: 8DH20---
   Coding: 0A254012242401080000
   ASAM Dataset: EV_ECM20TDI01104L906021HA 004003
   ROD: EV_ECM20TDI01104L906021HA_004.rod
   VCID: 6BDFE8AB82D1961210-803E
   Part No SW: 4G1 927 153 B    HW: 0CJ 927 156
   Component: 0CK 20TDI RdW H03 0004
   Revision: --H03---    Serial number: 0000001066
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 2953D2A348AD4402A2-807C
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071160363001574
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41836A03D0DDAC429A-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01B8704E000000000000
   VCID: 7CFDDBF7FFBF01AA89-8028
   Serial number: 3216000310830004
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 10011700041460
   Coding: 34210978210000
   VCID: 63CF808B6A01DE52A8-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001560597301
   Coding: 0105001440349FE041014083800018004F9DC3082F08020100000894E100140200400034030000
   VCID: 74EDF3D7D7EF49EAC1-8020
   Component: WWS57X 161106  H38 0080
   Serial number:         161118210045
   Coding: 004DF7
   Serial number: 20055425X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 11 01 2017  00000991
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 7668426800PAG0MUFU03
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100CC86O
   Coding: 30333130313630323639554A305234473053
   VCID: 3B7F18EBB231C692C0-806E
   Serial number: 3575HRB405N492DA7OOS
   Serial number: 3585HRB405P480GQEGP4
   Serial number: 3515JRB400257HS4LGSV
   Serial number: 3525JRB400257HS4F28Z
   Serial number: 3554VRB400A57J2CJ8BB
   Serial number: 3564VRB400A57J2CL9MQ
   Revision: C0068538    Serial number: 91560QA3001OD
   Coding: 000034
   VCID: 3B7F18EBBA31C692C0-806E
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 09 01 2017  D0004873
   Part No SW: 4G8 920 987 R    HW: 4G8 920 987 R
   Component: TDieGb        H15 0225
   Revision: 15001308    Serial number: 658131216596000
   Coding: 33AF0D000B410008010000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   VCID: 48957727F3E79D0A5D-801C
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Component: J533--Gateway H15 0096
   Revision: --------    Serial number: 00000002488565
   Coding: C0CD074418
   VCID: 3D7B16F3AC25C8A2FE-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 4087662504
   Voltage stabilizer:
   Serial number: 16070500000000000796
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 67D7949B9639B27274-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 17011700040604
   Coding: 22
   Revision: AA000000    Serial number: 00000226698609
   VCID: 77F7C4DBC69922F2E4-8022
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720UVBF4
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336F30CB9A610ED218-8066
   Coding: 011C16015E01620002080002
   VCID: 4797741BF6F9927254-8012
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000537238
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A711DEFBD0BFF9ADB-806E
   Revision: 00002001    Serial number: 0428730909
   Coding: 011B062280B90080C320088400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00027728635
   VCID: 4689791FF1F38B7AAF-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002062700
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 326135CF657B07DA13-8066
   Coding: 04FE02102A630200
   VCID: 346D33D79F6F09EA01-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 G    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   053 0910
   Serial number: A733A0H7531579
   Coding: 017501010000040013111102000A00332F0006E7F1700100DF
   VCID: 1E39F17F01E3B3BAC7-804A
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Serial number: AUZ8Z9GY806V42
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349QAG000C5
   Component: Gracenote2  --- 1015
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 212
                    Mileage: 27891 km
                    Date: 2018.10.13
                    Time: 16:00:32
                    Voltage terminal 30: 14.8 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: ERROR
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
   VCID: 49937223E0ED640242-801C
          B2010 00 [009] -  -
                    Reset counter: 212
                    Mileage: 27891 km
                    Date: 2018.10.13
                    Time: 16:00:55
                    passive
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 163200969
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F673CBB76492A327C-807A
End-------------------------(Elapsed Time: 04:50)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Should have something for you later today.
DaveN
Ireland
C?ID=62381
Hi, any update on the label file availablility?
DaveN
Ireland
C?ID=62381
Great thanks, works well, will this be merged in to future releases?
