VW Jetta 2009 2.5l
Car is stock, except for this module, which was recently replaced.
Car was recently in an accident and the ABS controller was replaced by the autobody during repair. They turned it over to the customer because they couldn't recode it and now they are refusing to have it done and the insurance company told the customer they shouldn't have taken the car with the light on.... Meanwhile they just dropped the car off at thier home in the driveway. Insurance companies suck! I chased out every wire to module and checked all connections to be sure there was no broken, frayed, or corrupt connectors and wires.
It looks like the unit is an oem that was purchased from an auto recycler.
ABS coding chimes as long as the key is on. All fuses checked, all wires to the module checked. I can connect and stay connected to the module with no drops at all, so it looks like the intermittent connection above is a coding issue.
Any help with this coding would be awesome, Im also curious how the coding is calculated, I'd love to write an app to actually help address these problems in the future for others.
Thanks folks !
-Joe
Saturday,13,October,2018,15:03:15:02246
VCDS Version: 18.9.0.2 (x64)
VIN: 3VWRZ71KX9M****** License Plate:
Mileage: 121000km-75185mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
77
VIN: 3VWRZ71KX9M****** Mileage: 121000km-75185miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 M HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H02--- Serial number: VWX7Z0HD24A0KF
Coding: 0000075
Shop #: WSC 01016 444 124779
VCID: 387F3AF04B5B4D8A2D-806C
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Mileage: 120687 km
Time: 04:13:59
RPM: 1748 /min
Load: 28.6 %
Temperature: 35.0∞C
Temperature: 22.0∞C
Absolute Pres.: 1020.0 mbar
Voltage: 11.303 V
Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
Component: AQ 250 6F 1377
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 7DF1EBE424F9A8A2BE-8028
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Shop #: WSC 39828 001 1048576
VCID: 76E3F4C8C1CFFBFAFF-8022
03306 - Coding Not Valid
Reset counter: 246
Mileage: 121000 km
Count: 3
Count: 14
Count: 12800
Count: 4161
Count: 50432
Count: 65024
Fault Status: 01100101
Reset counter: 246
Mileage: 121000 km
Count: 16391
Count: 12
Count: 8192
Count: 279
Count: 47872
Count: 65024
Count: 6144
Reset counter: 246
Mileage: 121000 km
Count: 16391
Count: 12
Count: 8192
Count: 295
Count: 47872
Count: 65024
Count: 6144
Reset counter: 246
Mileage: 121000 km
Count: 16391
Count: 12
Count: 8192
Count: 270
Count: 47872
Count: 65024
Count: 6144
Reset counter: 246
Mileage: 121000 km
Count: 16391
Count: 12
Count: 8192
Count: 195
Count: 47872
Count: 65024
Count: 6144
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78FFFAF00BDB8D8AED-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001158230
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
VCID: 326B08D8AD27A7DA13-8066
Component: Wischer 161208 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 0F: Digital Radio Labels: None
Part No SW: 8E0 035 593 Q HW: 8E0 035 593 Q
Component: SDAR SIRIUS H08 0160
Revision: 00000000 Serial number: AUZ4Z7M0617947
Coding: 0000000
VCID: 377D39CC464542F224-8062
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 21 AIRBAG VW8R 038 8600
Revision: 07038600 Serial number: 003E7M086Z7G
Coding: 0012849
VCID: 6DD1DBA4749938220E-8038
Subsystem 2 - Serial number: 6332MSME4233023D1
Subsystem 3 - Serial number: 6342MSME42322F538
Subsystem 4 - Serial number: 6351HSME1A495C54H
Subsystem 5 - Serial number: 6361HSME1A4C0A60B
Subsystem 6 - Serial number: 63727SME19603275-
Subsystem 7 - Serial number: 63827SME186C1171+
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0001131
VCID: 76E3F4C801CFFBFAFF-8022
Component: E0221 002 0010
Part No SW: 1K0 920 974 Q HW: 1K0 920 974 Q
Component: KOMBIINSTRUMENT 3HL 2416
Revision: V0003000 Serial number: VWX7Z0HD24A0KF
Coding: 0023203
VCID: 3C7726E07F6361AAC9-8068
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 051108F2000033
Coding: ED807F07001702001002
Shop #: WSC 61018 002 1048576
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T3R7Z04
Coding: 0000003
VCID: 39793FF470515482D2-806C
Component: IMMO 3HL 2416
Shop #: WSC 43852 001 1048576
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000518489113
Coding: 0001205
VCID: 6FEDC1AC7E95CA323C-803A
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A5B10B885F7EF1AAB-807E
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
VCID: 04079E004713D96AF1-8050
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08102704215201
Coding: 0001204
VCID: 70EFC2D063ABD5CA25-8024
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2263131
Coding: 0040401
VCID: 2959EFB480F1E402A2-807C
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003685133
Coding: 0001168
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003660155
Coding: 0001168
VCID: 77FDF9CC06C582F2E4-8022
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 051 730 B HW: 1K8 051 730 B
Component: Telefon H02 5400
Revision: 00002000 Serial number: 20389520241363
Coding: 402120
VCID: 2643E48851EFCB7A8F-8072
End-------------------------(Elapsed Time: 02:16)--------------------------
Thanks folks !
-Joe
