Results 21 to 30 of 37
Thread: Retrofitting TTRS Steering Wheel , Virtual Cockpit, and MIB 2 in 8V S3 PFL
  1. #21
    Verified VCDS User Sweaty Sweater's Avatar
    Oct 2018
    Ohio
    Quote Originally Posted by vastechnics View Post
    Ok so first you have to set the dials and then mileage etc?
    Only the variant selection if you want the center dial.
    You can change the boot screens and car graphics later.
  2. #22
    May 2016
    Clear story. Have you got the steering wheel fully working?
  3. #23
    Oct 2018
    Ohio
    Unfortunately no. With the holiday's and whatnot, I haven't messed with it much. I did however get the CarPlay fully installed and working.
  4. #24
    May 2016
    Ok I see. Yes i see carplay etc functions were activated by APG. Very good company. Do a lot bussiness with them.
    I try to figure out how to get the steering wheel working. Maybe need clockspring from TTRS?
  5. #25
    Verified VCDS User cilitkas's Avatar
    May 2016
    LT
    Clock spring from ttrs wont fit, its totally different.
    All retrofitters who know how to do it, need to modify steering wheel and its wiring.
    You dont need to mess with coding or clock spring.
    I guess that module from Ali is the answer.
  6. #26
    May 2016
    I have asked the supplier from Ali. He cannot confirm if work.
  7. #27
    Oct 2018
    Ohio
    I already ordered that module from Ali and it does not work. The only option is modifying the wheel and clockspring.
  8. #28
    Oct 2018
    Ohio
    Little bit of an update here. I finally got around to installing the USB ports for CarPlay and Android Auto in the center console.
    Step one was to remove the glove box so I could route the wiring from behind the MIB into the center console.
    Here you can see where the MOST (orange) and Info cables are going to the cluster, and the new USB port cables(red, black) are headed towards the center console.
    Here is the routing of the USB port cables before being wrapped into the loom.
    And then wrapped with the factory loom.
    The cubby in the center console has to be replaced as well, due to the USB port box being larger than the original MDI cable interface.
    While I had the console out, I also added in the LED cupholder ring. This was tapped into the ground and 12v illumination wire for the 12v outlet.
    and wrapped....
    And then a few pictures after install with CarPlay working, and Google Maps.
  9. Likes m87a, Uwe, downtime liked this post
  10. #29
    May 2016
    Looks awesome! Nice job.
  11. #30
    Oct 2018
    Ohio
    Thank you!
    Now just have to figure out the start button and I'll be all set!
