Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Retrofitting TTRS Steering Wheel , Virtual Cockpit, and MIB 2 in 8V S3 PFL
    Verified VCDS User Sweaty Sweater's Avatar
    Oct 2018
    Ohio
    I am attempting to retrofit a MK3 TTRS steering wheel, with FULL functionality into my Pre Face Lift, S3 8V. This is just the beginning of what will be a full retrofit of the Virtual Cockpit and MIB2 system with CarPlay enabled.
    The updated steering wheel is necessary to have access to the "VIEW" button, to change display settings on the VC.
    I will pre-face this by saying that I haven't found another thread with a car in the US, that has been capable of retrofitting the VC, or even attempted. I know there are a few guys in EU that have done this, and now MK7 Active Display retrofits are popping up here in the US as well. I have seen a couple of people that have retrofitted the TTRS wheel into the MQB cars with only partial functions. I am hoping that we can have the wheel work 100%.
    My first challenge was to find a MIB2 Unit that could have NAR maps installed, and them work correctly, and also have CarPlay. Sirius and DAB (Digital Radio) aren't really a huge concern of mine. I created a list of part numbers of MIB2 units from US MQB cars with Parts Link. Unfortunately with it only being around for a couple of years so far, the cheapest NAR MIB2 unit I could find was still $4k +. This simply is not an option due to the total cost that the project would come to. After speaking with multiple companies over sea, I ended up working with APG in Poland who specializes in retrofitting MIB/Clusters.
    They say they are able to source me a MIB2 unit, with NAR maps installed, CarPlay enabled, Sirius, and DAB. For those not familiar, Audi and VW now uses SwaP codes to unlock these features on cars that wish to upgrade. After researching, even though my S3 came with NAV, it is not the Google Maps style of Nav on the new cars. My VIN also isn't eligible for the CarPlay FEC code due to it not being available during my production or MIB1. It seemed as though my only option was to get an unlocked unit.
    And here we are, at the beginning of this long road. I will say again, I am not sure that the VC will work 100% but I want to get it as close as possible and have this serve as the guide to help people who wish to do this in the future.
    Parts that have been ordered so far:
    -TTRS Steering wheel with airbag and harness
    -LCD Instrument Cluster: 8V0-920-790-A
    -MIB 2 Unit: 8V1-035-035 (There are multiple part numbers for this, depending on features and it is region specific)
    -LCD Trim: 8V0-857-115
    -HSD and MOST cables to run from the back of the MIB2 to the LCD
    -Adapter harness for Cluster (Original is 18 pin, new cluster is 32 pin)
    -Bracket for mounting LCD
    -USB port for CarPlay and wiring
    While we wait for the VC parts to arrive, the steering wheel needs to be installed.
    Plug and play does work with the new steering wheel. The airbag connectors are different, but can easily be swapped. Both airbags are however, 1 stage airbags.
    Here is where I ask for the first bit of help. The S3/A3 has a clockspring F350, separate from the the Steering Column Control Module J527. The TTRS using a 1 piece design that houses the clockspring, wiper stalk, and cruise control stalk. Here is the wiring layout for the yellow 12 pin connector on the clockspring from both steering wheels.
    S3:
    Pin 1:
    Pin 2:
    Pin 3: Black wire, Ground for N95 Igniter
    Pin 4: Green wire, Power for N95 Igniter
    Pin 5:
    Pin 6:
    Pin 7: Brown wire, Ground Connection that also goes to the Horn, and pin 3 of T4 connector on steering wheel.
    Pin 8: Blue wire, Power for horn function, constant B+
    Pin 9: Purple wire, LIN Bus, goes to Pin 1 of T4 on steering wheel.
    Pin 10: White wire, constant B+ for steering wheel, goes to Pin 2 of T4 on steering wheel.
    Pin 11: (Has pin on Clockspring, but no wire from steering wheel)
    Pin 12:
    TTRS:
    Pin 1: Gray wire, goes to Pin 2 of T4 connector for Start/Stop and Drive Select Buttons (Unknown Function)
    Pin 2: Light gray wire, goes to Pin 1 of T4 connector for Start/Stop and Drive Select Buttons (Unknown Function)
    Pin 5:
    Pin 6:
    Pin 7:
    Pin 8: Brown wire, Ground Connection that also goes to the Horn, and pin 3 of T6 connector on steering wheel.
    Pin 9: Purple wire, LIN Bus, goes to Pin 1 of T6 on steering wheel.
    Pin 10: Red wire, constant B+ for steering wheel, goes to Pin 2 of T6 on steering wheel.
    Pin 11: Gray w/ Red Stripe wire, goes to Pin 3 of T4 connector for Start/Stop and Drive Select Buttons
    Pin 12:
    I was able to get basic functions working on the wheel. 80% of the buttons, the lights, and the horn.
    Using the harness from the TTRS wheel:
    Move the brown wire from Pin 8 to Pin 7. Its that simple.
    This gives you Purple, Red, and Brown on the T6 Connector at the top of the wheel. This provides all the basic functions.
    The wheel has a T4 connector with 3 wires for the Start/ Stop and Drive select Buttons. Only 3 wires. The S3 clockspring only has 2 remaining pins though.
    Pin 8, and Pin 11. Both of which have B+ when the key is on, and again, I am left with 3 wires for those two buttons.
    Are these wires Power, Ground, and LIN?
    Signal, signal, and ground?
    The wiring diagram is very vague and only has the wires listed as black. No colors are listed. Another fun fact, is the Start/Stop button currently also activates the horn
    Here is the new harness once adjusted. Note, there is 1 gray Power wire going to the T4 connector at this time. I am unsure of the purpose of this wire at this time.
    And here is a photo of the wheel installed with no airbag. You can see the clockspring with 2 pins on the top row, and 5 on the bottom, as well as the T6 connector above it.
    And here is the T4 connector that is simply for the Start / Stop and Drive Select Buttons.
    And for reference, here is the wiring diagram for the S3 followed by the diagram for the TTRS. If anyone would like to chime in and help solve this, that would be great. You can see all the black wires that are built within the TTRS wheel in the 3rd and 4th photo.
    and the TTRS
    There will be more updates as this progresses, and as parts arrive for the MIB and Virtual Cockpit! Any info, help, tips, etc, are greatly appreciated! I look forward to seeing this progress!
    and here is an AutoScan just because.
    Thursday,11,October,2018,13:33:26:16731
    VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
    VIN: WAUBFGFF8F1xxxxxx   License Plate:
    Mileage: 69245km-43026mi   Repair Order:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F A9 BB BC
    VIN: WAUBFGFF8F1xxxxxx   Mileage: 69245km-43026miles
    Address 01: Engine
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H52 4521
       Revision: 05852204    Serial number: TFK01405260976
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1F0E0B4706FC87B2CC-804A
       Revision: 00000000    Serial number: 61574000002972
       Coding: 31FF6B9254230A70017F030341C4698CD62A5080C08296B6024100588608
       Shop #: WSC 06385 790 00016
       ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
       VCID: 45C2B92FC4E0BD62A6-8010
       Revision: 00021000    Serial number: 0337502114
       Coding: 030C0C
       VCID: 3A38DAD3BD1EC29ADB-806E
       Revision: 20026000    Serial number: 00000000352798
       Coding: 03000014010000000000000000001400
       VCID: 3326F7F79A7433D218-8066
       Serial number: 8E28C137000000000001
       Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
       Component: BCM MQBAB HNA H18 0134
       Serial number: 01011415600179
       Coding: 04151A46C04122F541C04004511807A00800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7AB81AD3FD9E029A9B-802E
       Component: WWS371 140607  042 0585
       Serial number:         140616050335
       Coding: 0A47F7
       Serial number: 22746941
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
       Serial number: 13 04 2014  00001159
       Serial number: 00000000000030053299
       Sun Roof:
       Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO30038644
       Coding: 101F00
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [009] - Electrical Failure
                        Reset counter: 195
                        Time: 00:00:00
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 195
                        Mileage: 69245 km
                        Date: 2018.10.11
                        Time: 13:27:30
       Serial number: 003GCR00FAC9
       Coding: 9DCCFCC0000000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47DEB327FEECAF7254-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34178311A16061440949
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34178312A16061440726
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 6940000Y1400015LZP0G
       Coding: 303230
       Subsystem 4 - Part No SW: -----------    HW: 480 001 106 14
       Serial number: 35700000000EB8309F0W
       Subsystem 5 - Part No SW: -----------    HW: 480 001 106 14
       Serial number: 358000000006B8309F0P
       Subsystem 6 - Part No SW: -----------    HW: 480 400 406 14
       Serial number: 3510002B5156EA05B171
       Subsystem 7 - Part No SW: -----------    HW: 480 400 406 14
       Serial number: 3520002C3156EA01B1C2
       Subsystem 8 - Part No SW: -----------    HW: 480 401 004 14
       Serial number: 3550002C31529DF1C248
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 401 004 14
       Serial number: 3560002C31529DF2E24C
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 18061408490796
       Coding: A218
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 0A584A13AD7E121A8B-805E
    227387 - Windshield Wiper/Washer Switch
              B1149 13 [009] - Open Circuit
                        Reset counter: 194
                        Mileage: 69245 km
                        Date: 2018.10.11
                        Time: 13:02:24
                        Operating time: 87989 min
                        Supply voltage: Terminal 30: 12.4 V
                        Voltage at switch: 4.98 V
                        Terminal 15 status: active
                        System status: 30
                        FF U Wischer AD value: 230
                        FF U Wish Wash AD value: 229
                        FF U Intervall Poti AD value: 61
                        FF U MFA AD value: 252
       Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
       Component: KOMBI         H02 4291
       Coding: 0BED181B2B80D7050201E8001800000000000000
       VCID: 4CD48C0BE78A4C2A79-8018
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 11061410800771
       Coding: 0101000820085A005B00022C180B00000001010000000000000000000000
       ROD: EV_GatewConti_011_VW37.rod
       VCID: 42C8A233D5CE8A5A83-8016
       Subsystem 2 - Part No SW: 8S0 951 523 K    HW: 8S0 951 523 K
       Component: J453 MFL  H01 0002
       Serial number: 20170220132047 RD128
       Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
       Component: Haldex4Motion H52 7076
       Serial number: HA1-00013.05.14
       Coding: 0001
       VCID: 46C0BE23F9E6B67AAF-8012
       Revision: 00000000    Serial number: 14000152811004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424F4EB9F7A34EA01-8060
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 30051402090339
       Coding: 00101F204000048000000002
       VCID: 3E30D6C3A136EEBAE7-806A
       Coding: 8102
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 3522C9EF94002DE236-8060
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 01061401101471
       Coding: 001017204000048000000002
       VCID: 3D32D1CFAC30F5A2FE-8068
       Coding: 012A000101000000
       VCID: 75A209EFD4806DE2F6-8020
       Part No SW: 8V0 035 039 C    HW: 8V0 035 039 B
       Component: MU-H-LNS-US   H44 0403
       Serial number: A539A0J7505175
       Coding: 01730102FF0A000021220001041A00102F000205010001047E
       Shop #: WSC 29707 001 1048576
       ROD: EV_MUHig6C3HBAS_AU37.rod
       Subsystem 1 - Part No SW: V03 959 800 T    HW: -----------
       Component: NAR 2016  --- 0048
       Component: DU High  H49 0013
       Serial number: AUZ8Z9EY201511
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 S    HW: 8V0 919 614 E
       Component: ControlUnit_H  H64 0766
       Serial number: C1000022051400020165
       Component: Gracenote  --- 3006
              B11CF 53 [009] - Deactivated
                        Reset counter: 124
                        Mileage: 54940 km
                        Date: 2018.02.22
                        Time: 13:58:48
                        Voltage terminal 30: 12.6 V
                        Satellite radio tuner status-Reception quality: No_signal
    3084 - GSM antenna 2
              B1533 13 [009] - Open Circuit
                        Fault Frequency: 19
                        Reset counter: 129
                        Mileage: 54940 km
                        Date: 2018.02.22
                        Time: 13:58:49
                        Voltage terminal 30: 12.5 V
    6708 - Databus
              [Engine: no communication]
                        Reset counter: 235
                        Mileage: 67082 km
                        Date: 2018.08.31
                        Time: 17:50:52
                        Voltage terminal 30: 14.6 V
       Part No SW: 8V0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0012
       Serial number: 140521201825
       VCID: 7DB211CFECB035A2BE-8028
       Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0025
       Serial number: 10061404081400
       Coding: 000017204000048000000002
       VCID: 40CCA83BDBC2984A95-8014
       Component: TSG HBFS      020 0025
       Serial number: 10061403111400
    End----------(Elapsed Time: 01:57, VBatt start/end: 12.6V/12.6V)-----------
    Address 16: DTCs cleared
  2. Likes m87a, Uwe, darkchina811, D-Dub, stefano82, iichel liked this post
  3. #2
    May 2017
    Nice retrofit!
    Did you have drive select on your car before you started the retrofit? Reason I'm asking is that it's a SWAP function in MQB cars and requires you to buy the kit from Audi aftersales, or get someone with tools and skills to hack the FeC into your car. And I'm not exactly sure if it's available for Audi as aftersale part. For VW it is, but not for Skoda or Seat. Audi, don't know for sure.
    Oct 2018
    Ohio
    Nice retrofit!
    I do have Drive Select as well as Kessy and Push Button Start. I feel that it has to be possible to get both of these buttons working properly.
    Unfortunately the wiring diagram isn't very specific as to what the 3 wires are, that control those two buttons on the wheel.
    Oct 2018
    Ohio
    If someone could attempt to help me figure out what these 3 wires could be, that would be excellent.
    They say they are all black, but in fact we have a Gray, White, and Gray/Red Stripe wire. All 3 of them go to the Push Start/Drive Select Buttons.
    On the S3, the Push Button start goes via 2 wires straight to J764 Steering Column Electronics, and then it is sent via CAN to the J518 Access Start Module.
    On the TTRS, which the wheel is from, there are 2 wires, same color as the Push Button on the S3, that go from the J527 Steering Colum Module/Clockspring, right to the J518 Access Start Module.
    Mar 2014
    France
    you make an amazing job man
    i will follow you cause i try to do the same on my AUDI S8 2013
    il live in france and if you need some european part just tell me if i can help
  7. Likes Uwe liked this post
    Oct 2018
    Ohio
    Quote Originally Posted by lclerc69 View Post
    Thanks man! I am hoping to make some more progress on this at some point today!
    Still waiting on the Virtual Cockpit and MIB2 parts to arrive.
    Võru, Estonia
    The world is my oyster...
  10. #8
    Oct 2018
    Ohio
    This is actually really helpful. Thank you so much. I know the A4 / A5 / C7 etc is based on a different platform, but this may still work!
  11. #9
    Võru, Estonia
    Another thing:
    Are you certain that TT SWCM supports DriveSelect input?
    One thing i noticed from a TTRS scan is that Byte 1 Bit 6 is enabled on this car. This would set Your coding to: A258
  12. #10
    Oct 2018
    Ohio
    Another thing:
    I have reached out to that company to see if they make the adapter harness for a MQB based car.
    The TTRS SWCM does support DriveSelect from the steering wheel as this is the car the wheel came from, and there is no other button in the vehicle to toggle this other than the MMI. If I am understanding your question correctly.
    I also know that my SWCM in the S3 can support DriveSelect through the steering wheel. You can adjust what you want the * button to do, and I currently have that button set to adjust DriveSelect. Seems silly that one button on the wheel will send the signal, but the dedicated button will not.
