Results 1 to 10 of 20
Thread: ACC and Audi breaking guard: Unavailable
    Oct 2018
    Norway
    This is my first post here. I have had a lot of help from previous posts on this forum during my 10 year as a user of VCDS and various A6s. However, this issue is too tricky to solve without asking you experts here. So I hope you have any hints on what to look for next.
    A couple of weeks ago I saw this ACC warning for the first time in the dashboard. But this last week it has become a nightmare as it pops up maybe 10-20 times during a mile drive. So today I finally had time to connect my old VAG-COM cable and take a look.
    What I have found out so far is that the "open circuit" GPS antenna (more than a year old issue) did not cause any problems with the ACC earlier. However I have had speed limit detection very limited the last half year at least, but I have concluded that was because the car thought it was in the middle of the ocean due to the accelerometer calculated location after a while driving without GPS. The other thing I discovered today was that when I just leave the car on idle not touching anything, there is very rarely any ACC alarms. But as soon as I start fiddling with the menus, handles, pedals, etc, alarms starts coming rushing in. After clearing the fault codes during my troubleshooting, VCDS also lost connection to several controllers, but on next scan those were back again. So I have a feeling that is related to the problem and not to the my computer or interface.
    I suspect some kind of "traffic rush" in the MOST whenever I touch things, and that could of course be due to a poor fiberoptic connection. Other than a broken GPS, poor speed limit sign detection for a while and a fuel cap that stopped working some months ago (but actually does not show on the fault codes now even if it is not locking anylonger), everything else is normal as far as I can see. The other thing is that it has been raining more than I can ever remember the last couple of months, but no signs of humidity or water in the car (but it is always outside parked).
    After clearing the fault codes, this is the last scan I did:
    Friday,12,October,2018,14:22:32:23964
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VirtualBox)
    VCDS Version 18.9.0.2
    VIN: WAUZZZ4G8CN119797   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 28 34 36 3B 3C 42 44
              46 47 52 53 55 56 5F 62 69 6C 6D 72 82 84 85 8B 8E 8F 90 A9
              C0
    VIN: WAUZZZ4G8CN119797   Mileage: 90538km-56257miles
    84-Night Vision -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
       Part No SW: 4G0 907 589 A    HW: 4G0 907 589
       Component: 3.0BTD EDC17  H21 0002
       Revision: 57H21---
       Coding: 122A401A057601020000
       ASAM Dataset: EV_ECM30BTD0114G0907589A 001003
       ROD: EV_ECM30BTD0114G0907589A.rod
       VCID: 326096D86572FDDA13-8067
       Part No SW: 4G0 927 158 AB    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H16 1006
       Revision: --H16---
       Coding: 000001
       VCID: 6ED842A8B1CA993A37-803B
       Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
       Coding: 49A7C70192E5E380FB00
       VCID: 3874A4F0830E178A2D-806D
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
       Coding: 05A92F06000000000000
       VCID: 78F464F0CB8ED78AED-802D
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H12 0064
       Serial number: 20011200040139
       Coding: 369200B83C
       VCID: 2756778C5EB08872B4-8073
       Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0111
       Revision: 20012002    Serial number: 00000001205578
       Coding: 0200E01050B49FE2C98100C3A0001908CF9CE708AE080121000008402101
       VCID: 75EA6DC4DC9CAAE2F6-8021
       Component: WWS57X 111215  H35 0051
       Serial number:         120104165931
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 20035549
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
       Component: E1 - LDS  H07 0044
       Serial number: 12 01 2012  00000098
       Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
       Component: EHL2 V07.03  H30 0030
       Serial number: 0000002274537R0K0201
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: F5384906000000000001
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901201701451
       Coding: 292B08
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3D7AB5E4AC2C32A2FE-8069
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H17 0400
       Coding: 7F04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002010
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 285474B053AE870ABD-807D
    145408 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Fault Frequency: 172
                        Reset counter: 206
                        Mileage: 90453 km
                        Date: 2018.09.24
                        Time: 13:30:10
                        Control Module temperature: 13 ∞C
                        Voltage terminal 15: 14.658 V
                        Velocity_vehicle_reference: 19.30 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.31 m/s≤
       Revision: --------    Serial number: 003JG006B00C
       Coding: 30323436313330303437554A304C34473053
       VCID: 3668AAC8891AE1FA3F-8063
       Serial number: 3575HRB405F12NLA3GCF
       Serial number: 3585HRB405F12NLA9G1B
       Serial number: 3515JRB405D12QE6L8VU
       Serial number: 3525JRB404R1082KB1I$
       Serial number: 3554VRB405F0V8BON9AB
       Serial number: 3564VRB405F0V8BO7HGA
       Revision: --------    Serial number: 90372LAJ000F7
       Coding: 0004FD
       VCID: 3874A4F08B0E178A2D-806D
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Component: E221 - MFL  H08 0009
       Serial number: 19 10 2011  B0076390
       Part No SW: 4G8 920 931 S    HW: 4G8 920 931 S
       Component: TDieRdwAccNv  H79 0416
       Revision: 28460177    Serial number: 658130112593038
       Coding: 138611001F150008010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K.rod
       VCID: 3E78B2E8A12A29BAE7-806B
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105 E    HW: 4H0 265 105 E
       Component: Standheizung  H24 0260
       Revision: 66006006    Serial number: 20111205073029
       Coding: 5D3F01
       VCID: 244C60802786636A91-8071
       Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0214
       Revision: --------    Serial number: 00000000363521
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 346C90C09F66F3EA01-8061
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790496778
       Voltage stabilizer:
       Serial number: 12011000989011200410
       Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
       Component: KLIMA FOND    H07 0064
       Serial number: 19011200040089
       Coding: 01
       VCID: 30649CD06B7ECFCA65-8065
       Part No SW: 4G0 907 553 E    HW: 4G0 907 553
       Component: LUFE-DAEMPFER H17 0781
       Coding: 008003
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2D5A85A47C4CA2224E-8079
       Revision: AA000000    Serial number: 00000021978989
       Shop #: WSC 02311 785 00200
       VCID: 77F667CCC690D8F2E4-8023
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0009
       Revision: --------    Serial number: EJ1BPA4203EZY00
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0020
       Revision: 00H02000    Serial number: 6PZ 010 287-03
       Coding: 0010102
       VCID: 30649CD0A37ECFCA65-8065
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H02 0020
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F19.01.1200H020003CF25147ˇ
       Subsystem 4 - Serial number: F25147ˇ
       Part No SW: 4G8 959 793 D    HW: 4G8 959 793
       Component: TSG FA        H05 0212
       Coding: 011F16205E00628002080013
       VCID: 4182C914D8D456429A-8015
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0007298829
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0168448018
       Coding: 013A0E2020B97495832009842E0304000000000000000000000000000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000066418
       Subsystem 2 - Part No: 4G0 951 177
       Subsystem 4 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J245 PS20.006  H02 0007
       Serial number:     WOO1445205
       Coding: 901F00
       Subsystem 5 - Part No SW: 4G0 947 135 L    HW: 4G0 947 135
       Serial number: 0000000AP00000624985
       Subsystem 6 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J394 PS20.006  H02 0007
       Serial number:     WOO14441930
       Coding: 801F00
       Subsystem 7 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93054210
       Revision: CJ007001    Serial number: 00000000019652
       Coding: 030000
       Shop #: WSC 19540 002 1048576
       VCID: 1D3A556404EC52A2DE-8049
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011F16205E00628002080002
       Revision: --------    Serial number: 00000000228491
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A508EB84DA2B51AAB-807F
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0012
       Serial number: 120123-0004-066
       Coding: 11226F33F91AEB00
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
    H02 0008
       Coding: 1D0000
    H02 0008
       Coding: 1D0000
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109A$0C7545397
       Coding: 010103010000000001
       VCID: 2B5E8BBC4A58AC1250-807F
       Part No SW: 4G0 035 670 P    HW: 4G0 035 670 A
       Component: H-BNT-EU      H48 0939
       Revision: --------    Serial number: 428AY0C7538270
       Coding: 050100010003FFEF7D36EB1E00000003080001000000000000
       VCID: 30649CD0637ECFCA65-8065
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB1302444V
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349LAH0001B
       Component: CD-Database  3638
    00862 - Antenna for GPS Navigation (R50/R52)
                        Fault Frequency: 32
                        Reset counter: 206
                        Mileage: 90450 km
                        Date: 2018.09.24
                        Time: 08:32:41
                        Voltage: 12.00 V
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14204000628002080002
       VCID: 448CC000C7C6436AB1-8011
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Revision: 5G001001    Serial number: 00000168003890
       Coding: 0109080000000000
       VCID: 71E259D4A8F486C22A-8025
       Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
       Component: TopView       H05 0111
       Revision: 11001001    Serial number: 82330JF0023414
       Coding: 0202000001010000010102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
       ROD: EV_CamerSysteTopViewAUDI_005_AU57.rod
       VCID: 2B5E8BBC4258AC1250-807F
       Part No SW: 4G9 959 107 A    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0139
       Revision: 14003001    Serial number: 013200277
       Coding: 097205C011
       ASAM Dataset: EV_HDSGAu572 001001
       ROD: EV_HDSGAu571.rod
       Component: TSG HR        H04 0212
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 G    HW: 4G0 919 604 G
       Component: HeadUpDisplay 005 0106
       Coding: D70000
       ASAM Dataset: EV_HUDContiC7 001020
       ROD: EV_HUDContiC7.rod
       VCID: 2F669FAC7640D0327C-807B
    Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
       Part No SW: 4H0 907 547 E    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H09 0028
       Serial number: 0K84AE40059237
       Coding: 1311
       ASAM Dataset: EV_NightVisioGen1 001002
       ROD: EV_NightVisioGen1.rod
       VCID: 316299D46074C6C26A-8065
       Night vision system camera:
       Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
       Component: NV-CAM-Gen1  H08 0007
       Serial number: 00000000001135400185
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H25 0036
       Coding: EE060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 65CA3D84643C5A6246-8031
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Coding: 7F04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 26487A8859BA917A8F-8073
              U1113 00 [009] - -
                        Fault Frequency: 12
                        Reset counter: 206
                        Mileage: 90536 km
                        Date: 2018.10.12
                        Time: 14:21:06
                        Control Module temperature: 20 ∞C
                        Voltage terminal 15: 11.987 V
                        Velocity_vehicle_reference: -0.00 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
       Part No SW: 4G0 907 107 D    HW: 4H0 907 107
       Component: BV-SG         H30 0038
       Serial number: 005000051501127
       Coding: 04C0BB1C1111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    0118 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Fault Frequency: 10
                        Reset counter: 206
                        Mileage: 90536 km
                        Date: 2018.10.12
                        Time: 14:21:08
                        Outside air temperature: 18.5 ∞C
                        Voltage terminal 15: 12.3 V
                        Control Module temperature: 23.0 ∞C
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       Coding: 0066E608031F037E070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 111123201347
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0004
       Serial number: 111210200121
       VCID: 244C60802F86636A91-8071
    End-------------------------(Elapsed Time: 08:15)--------------------------
    When I started troubleshooting this was the scan result:
    Friday,12,October,2018,10:53:56:23964
              C0
    VIN: WAUZZZ4G8CN119797   Mileage: 90534km-56255miles
       Revision: 57H21---
       Revision: --H16---
       Coding: 000001
       Coding: 369200B83C
       Coding: 0045F7
       Coding: 02512B
       Coding: 292B08
       Coding: 7F04010202
              U1113 00 [009] - -
                        Fault Frequency: 154
                        Reset counter: 206
                        Mileage: 90453 km
                        Date: 2018.09.24
                        Time: 13:30:10
       Coding: 0004FD
       ROD: EV_RBD4K.rod
       Coding: 5D3F01
       Coding: 00CD077D00
       Voltage stabilizer:
       Coding: 01
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
                        Reset counter: 240
                        Mileage: 88214 km
                        Date: 2018.06.29
                        Time: 15:45:07
                        Outside air temperature: 29.5 ∞C
                        Left rear vent temperature: 21.5 ∞C
       Coding: 008003
              C10C8 00 [008] -  -
                        Reset counter: 229
                        Time: 00:00:00
       Coding: 0010102
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Component: BCM2 2.0      H31 BCM2 2.0      H31 03330333
       Coding: 901F00
       Coding: 801F00
       Subsystem 7 - Part No: 3AA 962 243 D
       Component: GEB.F.Heckoef  0811
    No Faults Found
       Coding: 030000
    H02 0008
       Coding: 1D0000
    H02 0008
       Coding: 1D0000
                        Fault Status: 00101011
                        Fault Frequency: 31
                        Reset counter: 246
                        Mileage: 90450 km
                        Date: 2018.09.24
                        Time: 08:32:41
                        Voltage: 12.00 V
       Coding: 097205C011
       Coding: D70000
       Coding: 1311
       Coding: EE060000
    0001 - Front Heater for Lane-Holding Assist
              C1101 15 [008] - Open or Short to Plus
                        Fault Frequency: 42
                        Reset counter: 235
                        Mileage: 85715 km
                        Date: 2018.04.05
                        Time: 15:19:33
                        Outside air temperature: -45.0 ∞C
                        Voltage terminal 15: 13.0 V
                        Control Module temperature: 33.0 ∞C
       Coding: 7F04010202
              U1113 00 [008] - -
                        Fault Frequency: 171
                        Reset counter: 246
                        Mileage: 90453 km
                        Date: 2018.09.24
                        Time: 13:30:10
                        Control Module temperature: 12 ∞C
                        Voltage terminal 15: 14.752 V
                        Velocity_vehicle_reference: 18.89 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.26 m/s≤
       ROD: EV_BC7.rod
              U1113 00 [008] - -
                        Fault Frequency: 94
                        Reset counter: 246
                        Mileage: 90453 km
                        Date: 2018.09.24
                        Time: 13:30:14
                        Outside air temperature: 6.5 ∞C
                        Voltage terminal 15: 14.7 V
                        Control Module temperature: 13.0 ∞C
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    End-------------------------(Elapsed Time: 08:37)--------------------------
    And immediately after clearing the fault codes:
    Friday,12,October,2018,13:55:04:23964
              C0
    17-Instruments -- Status: Cannot be reached 0100
    47-Sound System -- Status: Cannot be reached 0100
    56-Radio -- Status: Cannot be reached 0100
    5F-Information Electr. -- Status: Malfunction 0110
       Revision: 57H21---
       Revision: --H16---
       Coding: 000001
       Coding: 369200B83C
       Coding: 0045F7
       Coding: 02512B
       Coding: 292B08
       Coding: 7F04010202
              U1113 00 [008] - -
                        Fault Frequency: 163
                        Reset counter: 246
                        Mileage: 90453 km
                        Date: 2018.09.24
                        Time: 13:30:10
       Coding: 0004FD
       ROD: EV_RBD4K.rod
       Coding: 5D3F01
       Coding: 00CD077D00
       Voltage stabilizer:
       Coding: 01
                        Reset counter: 240
                        Mileage: 88214 km
                        Date: 2018.06.29
                        Time: 15:45:07
       Coding: 008003
              C10C8 00 [008] -  -
                        Reset counter: 229
                        Time: 00:00:00
       Coding: 0010102
       Coding: 901F00
       Coding: 801F00
    02616 - Fuel Tank Cap; Unlock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 12
                        Reset counter: 195
                        Mileage: 78887 km
                        Date: 2017.06.13
                        Time: 18:10:27
    02615 - Fuel Tank Cap; Lock
                        Fault Frequency: 9
                        Reset counter: 195
                        Mileage: 78925 km
                        Date: 2017.06.13
                        Time: 19:21:26
    03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                000 -  -  - Intermittent
                        Reset counter: 218
                        Mileage: 88616 km
                        Date: 2018.07.16
                        Time: 16:37:31
    H02 0008
       Coding: 1D0000
    H02 0008
       Coding: 1D0000
    Address 56: Radio
       Coding: 097205C011
       Coding: D70000
       Coding: 1311
       Coding: EE060000
                        Fault Frequency: 42
                        Reset counter: 235
                        Mileage: 85715 km
                        Date: 2018.04.05
                        Time: 15:19:33
       Coding: 7F04010202
              U1113 00 [008] - -
                        Reset counter: 246
                        Mileage: 90453 km
                        Date: 2018.09.24
                        Time: 13:30:10
       ROD: EV_BC7.rod
              U1113 00 [024] - -
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Fault Frequency: 94
                        Reset counter: 246
                        Mileage: 90453 km
                        Date: 2018.09.24
                        Time: 13:30:14
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    End-------------------------(Elapsed Time: 08:16)--------------------------
    And for comparison an older scan from before the summer:
    Monday,07,May,2018,21:29:56:23964
    VCDS Version 17.1.3.0
    Data version: 20170220 DS267.3
    Chassis Type: 4G (4G0)
              C0
    VIN: WAUZZZ4G8CN119797   Mileage: 86547km-53777miles
       Revision: 57H21---
       VCID: 326096D86572FDD12F-8067
    Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
       Revision: --H16---
       Coding: 000001
       VCID: 6ED842A8B1CA99310B-803B
    Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
       VCID: 3874A4F0830E178111-806D
       VCID: 78F464F0CB8ED781D1-802D
    Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
       Coding: 369200B83C
       VCID: 2756778C5EB0887988-8073
    0075 - Motor for Right Footwell Flap
              B10BA 07 [008] - Mechanical Failure
                        Reset counter: 82
                        Mileage: 85669 km
                        Date: 2018.04.01
                        Time: 12:26:42
                        Voltage terminal 30: 13.29 V
                        Outside air temperature: 3.0 ∞C
                        Interior temperature: 3.72 ∞C
                        Right footwell flap motor-Act.value: 10619
                        Right footwell flap motor-Specified value: 10442
                        Right footwell flap motor-Stop open: 10587
                        Right footwell flap motor-Stop closed: 10000
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       VCID: 75EA6DC4DC9CAAE9CA-8021
       Coding: 0045F7
       Coding: 02512B
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Coding: 292B08
       VCID: 3D7AB5E4AC2C32A9C2-8069
    Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
       Coding: 7F04010202
       VCID: 285474B053AE870181-807D
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       VCID: 3668AAC8891AE1F103-8063
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Coding: 0004FD
       VCID: 3874A4F08B0E178111-806D
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       ROD: EV_RBD4K.rod
       VCID: 3E78B2E8A12A29B1DB-806B
    Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
       Coding: 5D3F01
       VCID: 244C608027866361AD-8071
       Coding: 00CD077D00
       VCID: 346C90C09F66F3E13D-8061
       Voltage stabilizer:
              U140B 00 [008] - -
                        Fault Frequency: 7
                        Reset counter: 85
                        Mileage: 85557 km
                        Date: 2018.03.05
                        Time: 18:12:26
                        Voltage terminal 30: 11.6 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 16 ∞C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 16
    Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
       Coding: 01
       VCID: 30649CD06B7ECFC159-8065
                        Reset counter: 96
                        Mileage: 86108 km
                        Date: 2018.04.22
                        Time: 12:34:37
                        Outside air temperature: 10.0 ∞C
                        Left rear vent temperature: 12.1 ∞C
    Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
       Coding: 008003
       VCID: 2D5A85A47C4CA22972-8079
       VCID: 77F667CCC690D8F9D8-8023
       Coding: 0010102
       VCID: 30649CD0A37ECFC159-8065
       VCID: 4182C914D8D45649A6-8015
    Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
       Coding: 901F00
       Coding: 801F00
                        Fault Frequency: 12
                        Reset counter: 195
                        Mileage: 78887 km
                        Date: 2017.06.13
                        Time: 18:10:27
                        Fault Frequency: 12
                        Reset counter: 195
                        Mileage: 78887 km
                        Date: 2017.06.13
                        Time: 18:10:27
       Coding: 030000
       VCID: 1D3A556404EC52A9E2-8049
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 2A508EB84DA2B51197-807F
    Address 55: Headlight Range (J431)       Labels: 4H4-907-357-V1.clb
    H02 0008
       Coding: 1D0000
    H02 0008
       Coding: 1D0000
       VCID: 2B5E8BBC4A58AC196C-807F
       VCID: 30649CD0637ECFC159-8065
                        Reset counter: 78
                        Mileage: 85543 km
                        Date: 2018.03.05
                        Time: 13:12:47
                        Voltage: 12.40 V
       VCID: 448CC000C7C643618D-8011
    Address 69: Trailer (J345)       Labels: Redir Fail!
       VCID: 71E259D4A8F486C916-8025
    Address 6C: Back-up Cam. (J928)       Labels: None
       ROD: EV_CamerSysteTopViewAUDI_005.rod
       VCID: 2B5E8BBC4258AC196C-807F
    Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
       Coding: 097205C011
    0114 - Load Space Cover
              B12EF 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 99
                        Mileage: 86336 km
                        Date: 2018.04.28
                        Time: 08:20:13
                        11.00 V
    Address 82: Heads Up Display (J898)       Labels: 4G0-919-604.clb
       Coding: D70000
       VCID: 2F669FAC7640D03940-807B
    Address 84: Night Vision (J853)       Labels: 4H0-907-547.clb
       Coding: 1311
       VCID: 316299D46074C6C956-8065
    Address 85: On Board Cam. (J852)       Labels: None
       Coding: EE060000
       VCID: 65CA3D84643C5A697A-8031
                        Reset counter: 84
                        Mileage: 85715 km
                        Date: 2018.04.05
                        Time: 15:19:33
    Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
       Coding: 7F04010202
       VCID: 26487A8859BA9171B3-8073
    Address 8E: Image Processing (J851)       Labels: 4H0-907-107-V2.clb
       ROD: EV_BC7.rod
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
       ROD: EV_ActuaForExterNoiseUDS_VW12.rod
       VCID: 244C60802F866361AD-8071
    End-------------------------(Elapsed Time: 08:07)--------------------------
    It looks like both radars sensors and the image processing unit are ticked off about something going on in another module, but it's not obvious to me which one.
    The radar sensors are not connected to the MOST bus, and that bus has so much bandwidth that I'm skeptical about your ""traffic rush" in the MOST" theory.
    If nobody else chimes in before then, please bump this thread on Monday when we are back in the office.
    Coding: EE060000
    Fault Frequency: 42
    Reset counter: 235
    Mileage: 85715 km
    Date: 2018.04.05
    Time: 15:19:33
    Voltage stabilizer:
    U140B 00 [008] - -
    Fault Frequency: 7
    Reset counter: 85
    Mileage: 85557 km
    Date: 2018.03.05
    Time: 18:12:26
    Engine running: OFF
    IN ZAS_Te_X: OFF
    Datenfeld: 16
    I'm thinking you must correct these two things first for voltage and a clear open or short to B+ can be traced with WD.
    Oct 2018
    Norway
    Yes, I took notice of those two faults from March and April when I did the scan in May. But the ACC did work perfectly until a couple of weeks ago, and these faults are not present any longer. I know they popped up there for a reason.
    The voltage issue I think is because the car was almost left alone unused for several months during winter and drained the battery a bit down. 5th March was the day I started it for first time in a while.
    The camera heater issue is more tricky, and I should do some repair. But not easy to repair it if it is working now as the latest scan shows. However, outside air temperature of -45!!! Where does that unit take the measurement from? The lowest temperature measured in the history of the car is -12 (I found that scrolling through the various logs on the ECU).
    Quote Originally Posted by ovelaur View Post
    Does that suggest there is either a connection problem or a faulty sensor in the camera? If the car thinks the temperature is that low then maybe it's turning on the heater permanently and maybe it's burnt out?
    Worth doing a wiring check IMHO.
    May 2017
    Check OPs post again. After summer there’s a failure in level control electronics
    That is connected to drive bus like acc and I’m pretty sure that is now causing the ACC to be disabled.
    ACC is very picky and if there’s even a slightest problem in the chain, it disables itself as precaution.
    So check is the level control working or not. So means also physical check of the level control arms in front and rear axle.
  7. Likes Uwe, Fredrick Awuor liked this post
    Even you say it is old, I vote for GPS.
    In [13]:
              U1113 00 [009] - -
                        Mileage: 90453 km
                        Date: 2018.09.24
                        Time: 13:30:10
    In [5F]:
                        Mileage: 90450 km
                        Date: 2018.09.24
                        Time: 08:32:41
  9. Likes PetrolDave liked this post
  10. #8
    Oct 2016
    Ukraine
    Hi. but it seems to me that navigation cannot affect the operation of the ACC. I vote for 85 and 8E. and it is desirable to make a diagnosis ODIS.
  11. #9
    Oct 2018
    Norway
    Thanks for all the comments! I have suspected all of those you mention myself, but I have voted out the GPS antenna early as that failed a year ago (probably damaged by moist as I live in a very wet place...). The level measurement I can start a log on to see if there are any intermittent levels.
    The camera is a prime suspect yes, is there any log I can start to read values/bits from the controller to see if it shows sign of any fluctuations? It is clearly not dead because I can sometimes start the ACC and keep it running for a few miles of steady drive.
    Still the main thing that confuses me is what I observed by coincidence when going through all systems with VCDS. I kept my engine on idle for almost an hour while logging. Then after a few minutes the ACC alarm kept quiet until I touched the MMI controls to select another radio channel while working. Then 2-3 new alarms came a few seconds (a new scan also proved frequency count). Then quiet again until I gave the "control system" new commands. So was the lost connection to the MMI controllers just a glitch on my interface, or did I actually find something relevant on that scan? As far as I can find there is a MOST connection to the ACC unit. How would the unit otherwise know how long distance and speed to keep if not? And also if comfort or active mode is selected.
    I would like to setup a log with various values. Bit I have not used that much earlier, so any suggestions? Would the sampling rate be good enough to see the intermittent failures shutting the system off?
  12. Likes Lgibson liked this post
  13. #10
    Oct 2018
    Norway
    Sorry, but I am not into all terms... What does ODIS mean?
