Before getting into the issue I am dealing with, just wanted to call out that I am new to VCDS please be patient
I got a new to me 2008 Continental GT Speed, and there where two issues that need to be resolved:
-Backup camera doesn't have the steering wheel lines at all.
-The central display has a PDC screen but it always shows the PDC as in active even when the tones can be heard (which work perfectly)
Once I did an auto scan (see below), I saw that the 07 Control Head needs to be coded correctly (seems that it has been replaced at some point in the past since the CD button also has "MM" on it which came on 2009 and later CGTs)
I tried to code it based on the suggestions in the tool, but that seems to be accurate for older CGT and not those with the mid-cycle refresh that happened for MY2008.
Looking around on here, I was able to find the coding from a 2009 CGT (but it was a UK model): 0451237
Using that I got an error that the TV turner isn't present nor is the media interface. I came up with 0451227 which got rid of the TV turner error but still shows that the coding is incorrect. If I do 0400227, I lose the button for the rear camera on the PDC screen. And in all cases the PDC screen just shows it as inactive always.
For the rear camera, trying to code module 6C to anything other than 2000002 causes it to fail (out of range) but I can code 2000002 without issue. No idea why it is not showing any lines. Any way to try to reset the module or should I try to disconnect it from the car to try to get it to reset?
Sorry for the wall of text, but wanted to try to call out everything I have tried out so far.
Auto-scan:
Auto-scan:
Thursday,11,October,2018,17:13:35:59171
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: SCBCP73W68C057432 License Plate:
Chassis Type: 3W (6N0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1F 34 36 37 38 46
47 53 54 65 68 6C 71 76 77
VIN: SCBCP73W68C057432 Mileage: 53090km-32988miles
1F-Sat. Tuner -- Status: OK 0000
54-Rear Spoiler -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine ( ) Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 FS HW: 07C 906 018 FK
Component: BY - 6.0 L - TT G ª1934
Revision: --H03--- Serial number: VWX3Z0H7731095
Coding: 0001175
Shop #: WSC 00083 790 00000
VCID: 7BA3F4457FFB12EFCB7-5160
Part No SW: 09E 927 760 K HW: GS1 911 4
Component: ZWGU3406 6L W12TT 3406
Revision: --H04--- Serial number: 0121868
Coding: 0000111
VCID: 38292B490E4DF9F7665-5160
Address 03: ABS Brakes Labels: 3W0-614-511.clb
Part No SW: 3W0 614 511 HW: 3W0 614 511
Component: ESP 8.1 4WD H01 0250
VCID: 6C81C7190A95855752D-5160
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 E HW: 5WK 485 07
Component: 75 Kessy 6840
Revision: 0020524ÿ Serial number: 7731095 RBG-SME2
Coding: 0405741
VCID: 290FFE0DC5B7507FE9B-807C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 3W0 959 759 B
Component: CM Seat Pass. 0017
Shop #: WSC 38998 001 1048576
VCID: 48C95B897EFD8977165-801C
01903 - Seat Tilt Adjustment Motor (V231)
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 J
Component: ZAB COCKPIT 2270
Coding: 0000000
VCID: 34311F7912251D974AD-5160
02076 - Media Player Position 1 (R118)
Part No: 3W0 907 040 F
Component: Climatronic BY614 2014
Coding: 0000112
VCID: 34311F7912751D974AD-8060
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 M HW: 3D0 937 049 M
Component: J519 6500
Revision: -4004--- Serial number: --------------
Coding: 40020000AB2A11000000000000000000
Address 11: Engine II Labels: 07C-906-018-BWR2.clb
Coding: 0001175
Address 15: Airbags Labels: None
Part No SW: 3W8 909 601 HW: 3W8 909 601
Component: 16 Airbag 9.41 H14 0040
Revision: 91H14004 Serial number: 0039L000AG3J
Coding: 0012598
VCID: 7BA3F4457FAB12EFCB7-802E
Subsystem 1 - Part No: 3W7 959 339
Component: BF-Gewichtsens. H02 0004
Subsystem 2 - Serial number: 01NV7
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB403A3E662Mÿ†63
Subsystem 5 - Serial number: 3E662Mÿ†63428RB403A40E3CPÿ†63
Subsystem 6 - Serial number: 40E3CPÿ†63528RB403A6933FTÿ†63
Subsystem 7 - Serial number: 6933FTÿ†63628RB403A40EC9Xÿ†63
Subsystem 8 - Serial number: 40EC9Xÿ†63700RB4 Iÿ†63
Subsystem 9 - Serial number: Iÿ†63800RB4 Jÿ
Subsystem 10 - Serial number: Jÿ
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000032
VCID: 47CB58B573E3860F1FF-8012
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No SW: 3W0 920 841 H HW: 3W0 920 841 H
Component: J285 KOMBI-INST. 1623
Revision: K0H10V35
Coding: 0007202
Shop #: WSC 00999 444 64523
VCID: 3A2D31413051EBE7901-806E
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3W0 920 841 H
Component: J533 GW-K-CAN TP20 1623
Coding: DFF8FF2E970F4700
VCID: 70B9D36926AD61B76E5-8024
Address 1F: Sat. Tuner
Address 34: Level Control Labels: 3Wx-907-553-34.clb
Part No: 3W0 907 553 E
Component: LUFTFDR.-CDC- 3C3V0 7213
Coding: 0005571
VCID: 3C2137593A25D5D782D-8068
Part No: 3W0 959 760 E
Component: CM Seat Driver 0023
VCID: 43D34CA547DBAA2FC37-8016
Address 37: Navigation Labels: None
VCID: 55F782FDBD4F249F9D3-8000
No Faults Found
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 F
Component: Dachmodul 0802
Coding: 0006589
VCID: 392F2E4D3517E0FF99B-806C
00211 - Control Circuit for Rear Illumination Lights
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 H
Component: 0M HSG 0200
Coding: 0000040
VCID: 3537227D195F049F7D3-4B1E
Subsystem 1 - Part No: 3W8 959 701 H
Component: Tuersteuergeraet FS 1106
Subsystem 2 - Part No: 3W8 959 702 H
Component: Tuersteuergeraet BF 1106
Subsystem 3 - Part No: 3W8 959 703 D
Component: Tuersteuergeraet HL 0703
Subsystem 4 - Part No: 3W8 959 704 D
Component: Tuersteuergeraet HR 0703
Subsystem 5 - Part No: 3W0 909 610 F
Component: 14 HDSG 1809
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W8 035 456
Component: 12K-AUDIOVERST 3000
VCID: 79AFEE4D759720FFD9B-802C
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 D HW: 3W0 907 801 D
Component: EPB BC6HX24 HC6 X240
Coding: 0022401
VCID: 372B28750353F68F6FF-5184
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 30391369E33D21B72E5-51CE
Address 65: Tire Pressure Labels: None
Part No SW: 3W7 907 273 A HW: 3W7 907 273 A
Component: J0502 RDK 0004
Revision: 0004 004 Serial number: 00000900003339
Coding: 0000E052A5F9A5A5F9A7DA00A7DA00
VCID: 3E253D512C39C7C7AC9-806A
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 L
Component: Wischermodul ª0401
Shop #: WSC 00000 725 65552
VCID: 3FDB40552B33CECFA7F-806A
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3W3 907 441 HW: 3W3 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: PA8 J820521
Coding: 2000002
VCID: 76B5E57144894F87B49-8022
03006 - Back-up Camera System not calibrated
Reset counter: 146
Invalid
Invalid
Invalid
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 2411EF39A2958D17DAD-8070
Address 76: Park Assist Labels: Redir Fail!
Part No: 3W0 919 283 B
Component: 0C Einparkhilfe 0404
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 AS HW: 3W0 035 385 AS
Component: rSAP Bentley 0262
Revision: 00008000 Serial number: 30800000036980
Coding: 0031000
VCID: 065595B134695F07A49-8052
00003 - Control Module
014 - Defective
End----(Elapsed Time: 03:13, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
