Wednesday,10,October,2018,16:02:46:36209
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: WVGZZZ1TZBW044968 License Plate: TODAY
Mileage: 190130km-118141mi Repair Order:
Chassis Type: 1T-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 61 62 72
VIN: WVGZZZ1TZBW044968 Mileage: 190130km-118141miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AR HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 8023
Revision: -------- Serial number: 00000000000000
Coding: 00194014032500080000
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_ECM16TDI02103L906023AR 003003
ROD: EV_ECM16TDI02103L906023AQ_003.rod
VCID: 76B51A1ED84FEAA7B49-8022
6442 - Accelerator Position Sensors (G79) / (G185)
P2138 00 [032] - Implausible Correlation
Mileage: 190122 km
Date: 2018.10.10
Time: 14:21:41
Engine speed: 2356.25 /min
Vehicle speed: 55 km/h
Coolant temperature: 76 °C
Intake air temperature: 37 °C
Voltage terminal 30: 14.118 V
Engine speed: 2356 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 14.1 V
Accelerator pedal: sensor voltage 1-V_PVS_1_BAS: 0.688 V
Accelerator pedal: sensor voltage 2-V_PVS_2_BAS: 0.542 V
Readiness: 0100 0000
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 333B4016092606FECC1402EA90216081310000
VCID: 76B51A1ED8CFEAA7B49-8022
Part No SW: 7N0 907 426 K HW: 7N0 907 426 K
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000000002
ROD: EV_ClimaBasis_VW36.rod
VCID: 3C21C836A6E370F782D-8068
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0045
Revision: BA011001
Coding: 40180A38802518E040000080100000E441018E08524DA160648042000040
VCID: 3537DD128549A1BF7D3-8060
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 16101 26 0512
Coding: 009795
12 Faults Found:
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 105
Mileage: 190070 km
Date: 2013.02.28
Time: 16:30:26
Voltage: 11.35 V
Fault Status: 00101010
Reset counter: 105
Mileage: 190071 km
Date: 2013.03.01
Time: 14:00:48
Voltage: 14.05 V
00985 - Right Tail Light (M2)
Fault Frequency: 10
Reset counter: 105
Mileage: 190079 km
Date: 2013.03.01
Time: 14:14:48
Voltage: 14.20 V
Fault Frequency: 11
Reset counter: 105
Mileage: 190082 km
Date: 2013.03.01
Time: 14:26:46
Voltage: 14.30 V
Reset counter: 105
Mileage: 190098 km
Date: 2013.03.01
Time: 16:57:52
Term 15 Off
Voltage: 12.35 V
Reset counter: 105
Mileage: 190098 km
Date: 2013.03.01
Time: 17:10:03
Voltage: 11.80 V
Reset counter: 105
Mileage: 190070 km
Date: 2013.02.28
Time: 18:00:47
Voltage: 11.40 V
01503 - Bulb for 3rd Brake Light (M25)
Fault Frequency: 36
Reset counter: 105
Mileage: 190071 km
Date: 2013.03.01
Time: 14:00:31
Voltage: 14.25 V
Fault Frequency: 24
Reset counter: 105
Mileage: 190070 km
Date: 2013.02.28
Time: 16:30:30
Voltage: 11.35 V
01506 - Bulb for Rear Fog; Right (L47)
Reset counter: 105
Mileage: 190082 km
Date: 2013.03.01
Time: 14:30:52
Voltage: 12.75 V
Reset counter: 105
Mileage: 190082 km
Date: 2013.03.01
Time: 14:26:46
Voltage: 14.10 V
Fault Frequency: 181
Reset counter: 105
Mileage: 190070 km
Date: 2013.02.28
Time: 16:30:30
Voltage: 11.35 V
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D018H1O
Coding: 0012338
VCID: 372BD71A934553AF6FF-8062
Subsystem 1 - Serial number: 6332QSME527B25007
Subsystem 2 - Serial number: 6342QSME427A052CI
Subsystem 3 - Serial number: 6352QSME3B780C1EX
Subsystem 4 - Serial number: 6362QSME297A1B32N
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JK3001E7
Coding: 5080140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 70B92C06BA2BC4976E5-8024
Part No SW: 1T0 920 961 D HW: 1T0 920 961 D
Component: KOMBI H05 0404
Coding: 480B00
VCID: 3431E0168EB3B8B74AD-8060
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 A
Component: Zuheizer 051 2630
Revision: 00051000 Serial number: 09022126000000
Coding: 0000011
VCID: 323DE60E7827B687581-8066
01415 - Recirculating Pump (V55)
Fault Status: 00100111
Reset counter: 23
Mileage: 176161 km
Date: 2011.12.23
Time: 18:58:02
Locked
Temperature: 54.0°C
Temperature: 57.0°C
Voltage: 14.45 V
01410 - Heater Over-Temp
Reset counter: 10
After-Run
Temperature: 145.0°C
Temperature: -48.0°C
Voltage: 12.50 V
02251 - Heater Unit Locked
Reset counter: 10
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 121110F1002469
Coding: 358003
VCID: 313FE90271218D9F21B-8064
01304 - Radio
Reset counter: 64
Mileage: 190070 km
Date: 2013.02.28
Time: 16:30:31
Component: IMMO H05 0404
VCID: 6A8D3E6E9CF73E47201-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2122
Coding: 0000693
VCID: 48C9A4E6EEBB2C57165-801C
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 01324 785 00200
VCID: 313FE9027D218D9F21B-8064
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000693
VCID: 47CBA7DAE3A5232F1FF-8012
Address 56: Radio
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: E100085A
VCID: 71BF2902B1A1CD9F61B-8024
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0000144
Shop #: WSC 01324 020 1012552
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3333E30A873DBF8F537-8066
End----------(Elapsed Time: 01:01, VBatt start/end: 12.1V/12.1V)-----------
