Help with 2012 plate Polo - lost ABS coding
uberbit
Romania
C?ID=251010
Hi there friends!
I am posting this here as I am in process of being verified so until mr. ROSS validates me, please help a brother out :D
I have a 2012 plate Polo that had stolen ecu. The car was brought to me by other shop and already had abs coding 000000000000000....
I managed to adapt neu ECU but the ABS is driving me nuts.
I found a guide on a dutch forum ( https://www.mypolo.nl/xenforo/thread...english.11914/ ) but I do not manage to pull it through. Always code rejected.
Car is basic option Polo 1.2 .
Below is autoscan result maybe one of you mates could help me:
Tuesday,09,October,2018,09:19:47:43779
VCDS Version: 18.9.0.2
VIN: WVWZZZ6RZCY252889 License Plate:
Mileage: 55190km-34293mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
VIN: WVWZZZ6RZCY252889 Mileage: 55190km-34293miles
Address 01: Engine (J623-CGPB) Labels:. 03E-906-019-CGP.clb
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 8949
Revision: -------- Serial number:
Coding: 00110016000400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12MPI02103E906019M 001007
ROD: EV_ECM12MPI02103E906019A.rod
VCID: 2E54977D71BC463A77-807A
Readiness: 0010 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Shop #: WSC 00788 648 00255
VCID: 000819C597A8004AD5-8054
Fault Frequency: 27
Reset counter: 20
Mileage: 55193 km
Date: 2013.02.26
Time: 01:04:45
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x149D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Status: 01100101
Fault Frequency: 26
Reset counter: 20
Mileage: 55193 km
Date: 2013.02.26
Time: 01:04:45
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B9D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Fault Frequency: 26
Reset counter: 20
Mileage: 55193 km
Date: 2013.02.26
Time: 01:04:45
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x209D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
03306 - Coding Not Valid
Reset counter: 60
Mileage: 55193 km
Date: 2013.02.26
Time: 14:48:10
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x25A3
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 M HW: 6R0 820 045 M
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 3878B1258BF8888A2D-806C
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 085 E HW: 6R0 937 085
Component: BCM PQ25 M+ H46 0254
Revision: BB046001 Serial number: 0430 088120141
Coding: 64B02BBF08A10048002008002D2B0C900040410F6006000020 0000000000
VCID: 3D76A031A4DAADA2FE-8068
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU019031200016765
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU023031200011339
Coding: 18BC30
00968 - Right Turn Signals
Fault Status: 00101010
Reset counter: 60
Mileage: 55193 km
Date: 2013.02.26
Time: 19:53:46
00967 - Left Turn Signals
Reset counter: 60
Mileage: 55193 km
Date: 2013.02.26
Time: 19:53:46
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag022 H10 0020
Revision: -------- Serial number: 003GX015WR4Z
Coding: 003232
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9CFBEDED140A1A4B-801E
Serial number: 3575HRB406516AM4C0N$
Serial number: 3585HRB405B16AM089F
Serial number: 3515RRB406315TC6H8IG
Serial number: 3525RRB404V17HSI7GA8
Part No SW: 6R0 920 860 G HW: 6R0 920 860 G
Component: KOMBI H04 0206
Serial number: 00000010852333
Coding: 140200
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3878B12583F8888A2D-806C
Part No SW: 6N0 909 901 HW: 6R0 937 085
Component: GW-K-CAN TP20 H46 0254
Revision: BB046001
Coding: 002200
VCID: 70E84905A30810CA25-8024
Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H04 0014
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25.rod
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6A8A79EAB64F327C-807A
End-------------------------(Elapsed Time: 02:08)--------------------------
All coding found with google from similar plates were rejected.
Many thanks in advance!
iichel
Netherlands, eastern part
C?ID=284912
Ignore the guy that wrote on that dutch forum. He's an idiot :D
Try these codings please for your car:
210224E3217200B4842D24EA84DA00401700
210224E3217200B4842D24EA84DA00400700
if failed, please post the advnaced ID of both your engine and your immobiliser (adresses 01 and 25)
uberbit
Romania
C?ID=251010
Hi!
1st of all thanks for the replies.
Since I was under pressure I sent the car at the local VW shop. They managesd to code it OK. I spoke with one of their techs and confirmed it.
The owner will bring the car back for some other issue I have to fix. Will scan it then and reply to you.
Sorry for not posting earlier, but after a few days without replies, I kind of lost hope. I see now that I just needed to wait a little longer. Not a problem for me but for owner :D
One more thing, maybe it's worth mentioning, AVDI does not support these units yet. I saw in some thread I red here that somebody asked. Maybe they'll update later.
Thanks again! Will get back with news!
iichel
C?ID=284912
Thanks for the update. Curious to see the factory coding :-)
