Results 1 to 3 of 3
Thread: Parking Sensors Front and Rear from Car-Systems Poland
    Oct 2018
    Hi
    I have installed F+R parking sensors which beep as you approach an obstacle and this all works fine. The problem is that there is no graphic display showing on the Bolero and four faults found on the scan, anybody got any ideas as to what the problem might be and how to fix it?
    Sunday,07,October,2018,16:59:43:22263
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: TMBKG7NE3E0070343   Mileage: 78536km-48800miles
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 5517
       Revision: 84H22---
       Coding: 01110012032501090000
       Shop #: WSC 46617 001 1048576
       ASAM Dataset: EV_ECM16TDI01104L906021M 002009
       ROD: EV_ECM16TDI01104L906021P.rod
       VCID: 2F3AE5B4E798230F37F-807A
       Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
       Component: EMB8 EHCB     H31 0356
       Revision: 00000000    Serial number: 6253300000038D
       Coding: 1C078A912427096C007A060441C6243851249000608224F0004300004002
       Shop #: WSC 73430 031 00063
       VCID: 4BC2912473407F2F3B7-801E
    Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
       Part No SW: 5E0 820 047 D    HW: 5E0 820 047 D
       Component: AC Manuell    H02 0604
       Revision: 00001K06
       Coding: 02110104000100001000000000400000
       ASAM Dataset: EV_ACManueBHBVW37X 002017
       ROD: EV_ACManueBHBVW37X_002_SK37.rod
       VCID: 23121984BB50976FA37-8076
       Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
       Component: BCM MQBAB M   H14 0112
       Serial number: 00011325002391
       Coding: 0F0008424207005307A04082B10407080000000000000000000000000000
       Shop #: WSC 73430 790 00104
       ROD: EV_BCMBOSCH_011.rod
       VCID: 48C8AE2862369437165-801C
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 130819  041 0570
       Serial number:         130903061717
       Coding: 065DDD
       Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY131751YEB
       Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Serial number: 00000000000027757986
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391603402459
       Coding: 0030051041
       Shop #: WSC 33361 790 09999
       VCID: 44D0BA185E1EB057FAD-8010
    12658704 - Databus
              [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                        Reset counter: 217
                        Mileage: 78536 km
                        Date: 2018.10.06
                        Time: 16:58:35
    12656921 - Databus
              [Bremsensteuergerät - ESP_24 - kein Signal/keine Kommunikation]
                        Reset counter: 217
                        Mileage: 78536 km
                        Date: 2018.10.06
                        Time: 16:58:35
    12666390 - Databus
              [Diagnose-Interface für Datenbus-J533 - Gateway_79 - kein Signal/keine Kommunikation]
                        Reset counter: 217
                        Mileage: 78536 km
                        Date: 2018.10.06
                        Time: 16:58:36
    13638913 - Databus
              [Steuergerät für Lenkhilfe-J500 - LH_EPS_03 - kein Signal/keine Kommunikation]
                        Reset counter: 217
                        Mileage: 78536 km
                        Date: 2018.10.06
                        Time: 16:58:35
       Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
       Component: Airbag VW20   011 0188
       Revision: --------    Serial number: 003P4PJYH9EL
       Coding: 98CCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F5AF5F47778138FE7F-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 409 13
       Serial number: 3576U00000097D88DD0-
       Subsystem 2 - Part No SW: -----------    HW: 454 000 409 13
       Serial number: 3586U00000073B888D0O
       Subsystem 3 - Part No SW: -----------    HW: 454 800 509 13
       Serial number: 3516R97A3E2010000002
       Subsystem 4 - Part No SW: -----------    HW: 454 800 409 13
       Serial number: 3526R1EADE201000000C
       Subsystem 5 - Part No SW: -----------    HW: 454 800 508 13
       Serial number: 3556V95E0A2010000005
       Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
       Revision: --------    Serial number: 12091304400665
       Coding: 9600
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 76B410D0584252C7B49-8022
       Part No SW: 5E0 920 951 E    HW: 5E0 920 951 E
       Component: KOMBI         103 3390
       Coding: 27240A002000A60001080800040000
       Shop #: WSC 73430 031 00104
       ASAM Dataset: EV_DashBoardJCIMQBAB 008011
       ROD: EV_DashBoardJCIMQBAB_008.rod
       VCID: 290E0BACD97C4D3FE9B-807C
       Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
       Component: GW MQB Low    123 1144
       Revision: --------    Serial number: 0001024369
       Coding: 030000040B087300EF000048080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_009.rod
       VCID: 392EDBEC29DCFDBF99B-806C
       Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Serial number: 3778871303
       Part No SW: 5Q4 959 393     HW: 5Q4 959 393
       Component: TSG FS        007 0006
       Serial number: 0000075240555
       Coding: 001000208001020100001100
       VCID: 55F6775CA58439DF9D3-8000
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
       Component: EPS_MQB_ZFLS  127 1021
       Coding: 01
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D26CFFC3DF4C19FB53-8068
       Part No SW: 5Q4 959 392     HW: 5Q4 959 392
       Component: TSG BFS       007 0006
       Serial number: 0000075257401
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
       Part No SW: 5E0 035 820 A    HW: 5E0 035 820 A
       Component: MU-S-D-ER     040 0421
       Serial number: S5C01109132301
       Coding: 03730200FF0000001111120100A800002F0000860100010000
       Shop #: WSC 73430 790 00063
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 1D662F7C9D34A19F953-8048
       Subsystem 1 - Part No SW: 5E0 919 605     HW: 5E0 919 605
       Component: ABT_Std_Radio  H50 0022
       Serial number: SKZ8Z9NL2007JR
    7178 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 217
                        Mileage: 78536 km
                        Date: 2018.10.06
                        Time: 16:50:18
                        Voltage terminal 30: 11.9 V
                        BAP-BAP_Function_ID: 02
    End----------(Elapsed Time: 01:03, VBatt start/end: 12.0V/12.0V)-----------
    May 2017
    Car is Octavia right? First thing you need to re-parameterize the unit with skoda dataset. That will get rid of those epb errors in park assist module.
    Then you probably have the 5F adaptations missing for park pilot. Can you post an adamap of 5f module? Go to vcds -> applications-> controller channel maps and put 5f as the module, output csv and then go. Paste the csv content here using CODE taga.
    Oct 2018
    Thanks for your prompt response to my problem but it is now solved, the instructions I received with the kit were incorrect. The can bus connections were not pins 6 and 16 as per instructions but pins 8 and 18.Thanks again.
  4. Likes downtime liked this post
