Results 1 to 8 of 8
Thread: Golf LED headlight adjustment
    Oct 2016
    Hi Guys,
    2018 Golf with LED headlights.
    For some reason, the dipped beam is set quite low from the factory, so i would like to raise them slightly to light up a little more of the road ahead.
    Seeing as they have auto levelling, is there anywhere in VCDS i can raise them?
    It seems there is no longer a range control module, but a couple of left and right lights modules.
    I had a quick look in those but i cant see anything related to aim adjustment (unless i am missing it!)
    Any help appreciated.
    Scan for reference..
    Monday,24,September,2018,14:23:44:35443
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WVWZZZAUZJW235518   License Plate: GOLF
    Mileage: 456km-283mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 4B 52 5F A9 D6 D7
    VIN: WVWZZZAUZJW235518   Mileage: 456km-283miles
    29-Left Light -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
       Revision: --H13---
       Coding: 091900122444050B2000
       ROD: EV_ECM20TFS0205G0906259C_VW37.rod
       VCID: 2E0607E4309FE247D3B-807A
       Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
       Component: ESC           H25 0423
       Revision: 00000000    Serial number: 50718000003774
       Coding: 01FA93A134232171477C0601E0CBA980C92C84E26007957734405078C009430B00000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_037_VW27.rod
       VCID: 025E8354D487B627673-8056
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 0012000420011001100500000010102A
       VCID: 6D84C0E8FD19595FAA1-8038
       Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H36 0253
       Serial number: 01001809302583
       ROD: EV_BCMCONTI.rod
       VCID: 084A917CF2BB9C77397-805C
       Component: WWS    180306  042 0551
       Serial number:         180312101612
       Component: RLHS  047 0105
       Serial number: S9Y18M04D03H21M58S31
       Coding: 00A8DD
       Serial number: 000000000ZY180572KNP
       Serial number: 00000000000099742075
       Serial number: 000308418018086
       Coding: 0471051801
       VCID: 4BC06E70A34DB76FD45-801E
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 2B00608159FFC728949C810560400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E2637A4E0FF12C743B-806A
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Serial number: 003VWR40P9HJ
       Coding: 98CCC000000000005C0000CF008800000065
       VCID: 094C9478E9B1E57F269-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E26031830782
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E27031830797
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 404 18
       Serial number: 3570000000002C9D0C2M
       Subsystem 4 - Part No SW: -----------    HW: 480 003 103 18
       Serial number: 35800000000B993D1C2X
       Subsystem 5 - Part No SW: -----------    HW: 480 402 603 18
       Serial number: 3510001A529633C2B24-
       Subsystem 6 - Part No SW: -----------    HW: 480 402 603 18
       Serial number: 3520001A329633C5541V
       Subsystem 7 - Part No SW: -----------    HW: 480 400 304 18
       Serial number: 3550001A329B7D43C26A
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 01041804400928
       Coding: 0400
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 0D44A0689DD9F95F0A1-8058
       Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
       Component: KOMBI         408 3195
       Coding: 27AD11002F80060001886B011401000000000000
       VCID: 2A0E0BF40C778E670F3-807E
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007655850
       Coding: 030100047F085900FB00027E080F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW27.rod
       VCID: 382A21BCC2DB2CF7897-806C
       Serial number: 29180000468740068097
       Coding: 2CFFFF
       Serial number: 5305497304
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       VCID: 47C85240BF25530FF0D-8012
    0033 - Supply voltage
              [Supply voltage - lower limit exceeded]
                        Reset counter: 45
                        Mileage: 11 km
                        Date: 2018.09.13
                        Time: 11:19:59
                        Reset counter: 45
                        Mileage: 12 km
                        Date: 2018.09.13
                        Time: 12:08:56
       Serial number: 200318ECK04572
       Coding: 003F0220D001048000001000
       VCID: 43D046508B1D7F2F2C5-8016
       Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000020321747
       Coding: 0D0000
       Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 81170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 3B203EB0F3ED07EF645-806E
       Serial number: 21031810522064
       Coding: 000000050100164E01100F01020000000000000000000000000000000000
       VCID: 72BED394E42786A7773-8026
       Serial number: 210318ECL05837
       Coding: 003F0020DE01048000801000
       VCID: 42DE435494077627273-8016
       Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000020335145
       Coding: 150000
       Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
       Component: MU-S-ND-ER    851 0867
       Coding: 02731001FF00000051110101008808001F0503E601200000CF
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 323E139424A7C6A7B73-8066
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZHV0861245
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
       Serial number: 180216201596
       VCID: 6B80CEF0C30D576FB45-803E
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392C24B8F9D135FF769-806C
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End----(Elapsed Time: 01:34, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    May 2017
    4B is the light control module in these newer cars.
    Nothing special, run the lights to adjustment position which puts them to center. Raise them and re-learn the new center position.
  3. Likes jasons6930, Uwe liked this post
    Oct 2016
    DO i raise them manually behind the headlight?
    May 2017
    Yes, manually using the adjustment screw. There's at least two screws. Other adjusts the height and the other adjusts the lights sideways. There also might be a third adjustment screw which adjusts the high beam led unit independently. So make sure you have the right screw before doing any adjustments.
    Look here for tips : https://www.vwroc.com/forums/topic/2...am-adjustment/
    Even the posting in the link states that no software stuff required, I would still drive the lights to adjustment position before doing ANY mechanical adjustment. At least in Leon it adjusts the headlights slightly even the car is parked on flat surface. So without doing this first, there might be some ill effects to the adjustment motors.
  6. Likes jasons6930, Uwe liked this post
    Oct 2016
    Brilliant, thank you.
    May 2017
    Just for personal education; may I ask what difference will there be if you just raise them manually with the headlight adjusting screws? - because that's what I did.
    TIA
    2017 Golf R Wagon (Mine …Dog now taken ownership )
    2016 VW Polo 1.4 [ACT] BlueGT DSG (Mine ...but SWMBO took ownership )
    May 2017
    The self adjustment is the only issue. If it has a ”wrong” center spot, it will probably adjust them a bit off all the time.
    Like I wrote, in my case the lights were not levelled even the car was on level, until I ran the adjustment position basic setting. That setting raised the lights a bit. It was clearly visible against the wall.
  10. Likes ArubaAudi liked this post
  11. #8
    May 2017
    Think I'm gonna have to go through the settings properly! My driveway is sloped, so it'll have to wait until I get time at work.
    Thanks for the heads up.
