Monday,08,October,2018,11:35:28:43498
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 1B 22 34 36 3B 42 46 47
52 53 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
VIN: WAUAVAFD4BN023855 Mileage: 155646km-96713miles
Address 01: Engine (------CDRA) Labels:| 079-907-560-CFS.clb
Part No SW: 4H0 907 560 C HW: 4H0 907 560
Component: 4.2l V8/4V H08 0005
Revision: N5H08---
Coding: 0106000A290F0168
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
ROD: EV_ECM42FSI0114H0907560C.rod
VCID: 2A0D01236C75B7F7E01-807E
7 Faults Found:
4695 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
U1113 00 [032] - -
U1113 00 [032] - -
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
[ABS brake control moduleRead out DTC]
4715 - No Communication with Instrument Cluster
U0155 00 [032] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 00 [096] - Too Lean
Fault Frequency: 8
Mileage: 155541 km
Date: 2018.09.28
Time: 16:54:00
Engine speed: 2290.50 /min
Normed load value: 41.2 %
Vehicle speed: 138 km/h
Coolant temperature: 98 °C
Intake air temperature: 37 °C
Voltage terminal 30: 13.476 V
Unlearning counter according OBD: 37
AFS dm: 134.3 kg/h
Median injection timing: 1.655 ms
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
Part No SW: 4H1 927 158 AD HW: 0BK 927 156 K
Component: 0BK 42 FSIUSA H08 1006
Revision: --H08---
Coding: 000002
Shop #: WSC 25101 444 97440
ROD: EV_TCMALX51011.rod
VCID: 72BDD9438425BF37981-8026
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 B HW: 4H0 907 379 B
Component: ESP PREMIUM H10 0273
Coding: 44FEB200227F4D00E200
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_005_AU64.rod
VCID: 313F164F41A3C42F21B-8064
0370 - FlexRay Databus
U1031 00 [136] - No Synchronization
[FlxrSysLostSync]
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 15:34:50
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 00
Bit Info 4: 00
F-Path: 36
F-Type: B0
Uz: 97
0396 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ComScl_PDU_Fahrwerk_02_Timeout]
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 12:20:44
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 02
Bit Info 4: 00
F-Path: 35
F-Type: 92
Uz: AF
0695 - Tire Pressure Warning
C102D 00 [009] - -
Fault Frequency: 12
Reset counter: 116
Mileage: 155646 km
Date: 2018.10.01
Time: 07:54:31
VzRef: 3B
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 16
Bit Info 4: 1F
F-Path: 47
F-Type: 0C
Uz: B0
0719 - Tire Pressure Warning
C102D 00 [009] - -
Fault Frequency: 121
Reset counter: 116
Mileage: 153305 km
Date: 2018.09.07
Time: 16:06:44
VzRef: 58
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 06
Bit Info 4: 1F
F-Path: 47
F-Type: 02
Uz: AD
0778 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_VL_Invalid]
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 12:39:05
VzRef: 00
Bit Info 1: 40
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 39
F-Type: 19
Uz: A8
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 AD
Component: BCM2 2.0 H24 0510
Coding: 0D872000000000000000
Shop #: WSC 07350 001 1048576
VCID: 6E85CD33909D9BD77C9-803A
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000047839013
Fault Status: 00101101
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 15:34:49
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000006059083
Coding: C018320085043201010001010101112131313333283333
Shop #: WSC 02313 785 00200
VCID: 3537225FB54BE80F7D3-8060
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 15:34:49
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 L HW: 4H0 820 043 L
Component: Klima 2 Zonen H20 0130
Coding: 4881202888
Shop #: WSC 46147 001 1048576
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 290FFE2F6973BCEFE9B-807C
0378 - Coolant Circulation Pump
B10D0 04 [009] - Internal System Fault
Reset counter: 57
Mileage: 152551 km
Date: 2018.08.31
Time: 20:52:53
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000001012407
Coding: 09072091073C9FF1BB000804A0003800009CD308820001218001085C3B00
VCID: 2C01073B6601A9C712D-8078
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 110308 H32 0040
Serial number: 110329095435
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10071797
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 24 03 2011 00000172
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0E6Q06
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000018031100010467
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000018031100010022
Coding: 100000
Subsystem 7 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA101139000000205889
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: B048CB95000000000001
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 15:34:00
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55901107000384
Coding: 300102
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 372B2857AFC71A1F6FF-8062
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H41 0041
Revision: -------- Serial number: 003JS0013AT7
Coding: 303143303230303030344A55304C34483053
Subsystem 1 - Part No SW: 4H0 959 339 HW: 4H0 959 339
Component: BF-Gewichtss. H02 0040
Serial number: 5850000R1130301F2H
Serial number: 3575HRB405H0BI7U6124
Serial number: 3585HRB405L0F3PEE97L
Serial number: 3515JRB404T0H1GGD0PO
Serial number: 3525JRB404T0H1GG9P0L
Serial number: 3554VRB405R0FUO8MGG
Serial number: 3564VRB405R0FUO8B1FC
Part No SW: 4H0 953 568 B HW: 4H0 953 568 B
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KCM00012
Coding: 000434
VCID: 323D19434425FF37581-8066
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Component: E221 - MFL H06 0009
Serial number: 30 12 2010 11086966
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 15:34:49
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 15:34:49
Part No SW: 4H0 920 920 C HW: 4H0 920 920
Component: TBenUSA------ H30 0312
Revision: 31110017 Serial number: 658290311593045
Coding: 0B660801B300D705020000
Shop #: WSC 27653 002 1048576
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: 2517F21F056B988FCD3-8070
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H05 0224
Serial number: 1110329000729
Part No SW: 4H0 907 468 E HW: 4H0 907 468 C
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000121133
Coding: 00C1034A00
ROD: EV_GatewUDS_AU57.rod
VCID: 33331C47BBBFF63F537-8066
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650017335
Part No SW: 4H0 907 144 A HW: 4H0 907 144 A
Component: DYNAMIKLENK. H06 0080
Revision: 51001005 Serial number: --------------
Coding: 8B0000
VCID: 2615F51378ED9397C49-8072
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H11 0013
Serial number: 002003110001005
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 270BF8177F678A9FFFF-8072
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008004
Shop #: WSC 00001 000 00000
ROD: EV_AirSuspe_VW51.rod
VCID: 2C01073B6681A9C712D-8078
267267 - Control Module Incorrectly Coded
U1014 00 [008] - -
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 13:38:54
0002 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 13:38:54
367877 - Ride Height Not Learned
C1044 00 [009] - -
Reset counter: 116
Mileage: 155647 km
Date: 2018.10.01
Time: 13:38:54
266752 - Control module not coded
U1013 00 [009] - -
Reset counter: 116
Mileage: 155647 km
Date: 2018.10.01
Time: 13:38:54
38144 - No End-of-Line Programming
B2013 00 [009] - -
[keine Bandendeprogrammierung erfolgt (Auslieferungszustand)]
Reset counter: 116
Mileage: 155647 km
Date: 2018.10.01
Time: 13:38:54
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000006059172
Coding: C0183B0085053201010001010101112131313333203333
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 15:34:49
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 A HW: 4H0 907 637 A
Component: SARA 6D red H02 0015
Revision: -------- Serial number: EJ1BPA3700D7J00
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D070A3F5D9BA0CF053-8078
3801346 - Function Restricted due to Missing Message(s)
U1111 00 [032] - -
[Internal Monitoring (MSG)]
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000114284999
Coding: 011F13205E00628202000002
Shop #: WSC 02312 785 00200
VCID: 3C21377B9661394782D-8068
Revision: 00002001 Serial number: 0146932981
Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000025154
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.028 H07 0006
Serial number: WOO1170317.
Coding: 001F00
Subsystem 4 - Part No SW: 4H0 947 135 BK HW: 4H0 947 135 BK
Component: Dachelektroni H11 0080
Serial number: A2011000000000362935
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS009 H05 0004
Serial number: WOO1000DA53
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 57
Mileage: 152276 km
Date: 2018.08.31
Time: 12:41:41
02616 - Fuel Tank Cap; Unlock
Reset counter: 57
Mileage: 152276 km
Date: 2018.08.31
Time: 12:42:03
Reset counter: 156
Mileage: 155647 km
Date: 2018.10.01
Time: 15:34:49
Part No SW: 4G0 035 223 A HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0070
Revision: CJ007000 Serial number: 00000000028457
VCID: 1B63D4E733AF5E7F6B7-804E
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000114564718
VCID: 3B233467936F3E7F8B7-806E
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000057411
ROD: EV_ParkiBrake_VW51.rod
459264 - Function Restriction due to Faults in Other Modules
U1113 00 [000] - -
[FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [000] - -
[FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
Part No SW: 4H0 035 082 A HW: 4H0 035 082
Component: Radio U SIRIU H51 0068
Revision: AB001007 Serial number: 155CR0B7501913
Coding: 020007010000000001
VCID: 1F1BE0F727B7425F87F-804A
Part No SW: 4H0 035 664 B HW: 4H0 035 664
Component: H-BN-NA H48 0294
Revision: -------- Serial number: 098CV0B7503171
Coding: 020200000001F1EF45128B0E00000003F400010000000000
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 4H0 919 604 C HW: 4H0 919 604 C
Component: DU8 D4 SV NB H46 0021
Serial number: AUZ8ZDB1100HF04
Subsystem 3 - Part No SW: 4H1 919 600 D HW: 4H1 919 600
Component: E380 BDT D4 H09 0063
Serial number: 00000000034221
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000114448501
Coding: 010F13204000628202000002
VCID: 3A2D31639C550777901-806E
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H04--- Serial number: 525 PA8J13D0P7
Coding: 1021002
Shop #: WSC 02391 785 00200
VCID: 6597B21F496B588F0D3-8030
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 P HW: 4H0 959 107 M
Component: HDSG-Modul H11 0036
Revision: 10011001 Serial number: 088100212
Coding: 0210044100
ROD: EV_DeckLidContrUnit.rod
VCID: 3B23346793EF3E7F8B7-806E
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000028918
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393AC074BDF26BFE37-8036
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000114817749
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H05 0081
Revision: 0L0D5012 Serial number: SN110302 0200
ASAM Dataset: EV_GSM2x3Mono 001014
ROD: EV_GSM2x3Mono.rod
VCID: 2B030427638FAEFF1B7-807E
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00000171081102
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F3B10375797D2DF37F-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00000171076702
Coding: 364FF2
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F030000030801424CD8010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBBD037971792DF77F-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B9D34B8A298D276E5-8024
End----------(Elapsed Time: 02:55, VBatt start/end: 14.1V/14.0V)-----------
