- Joined
- Mar 14, 2014
- Messages
- 5
- Reaction score
- 0
- Location
- Edmonton, Canada
- VCDS Serial number
- C?ID=183663
Looking to find a way for the Advance Key to lock/unlock the doors when the ignition is on and motor running. I've attached an Auto-Scan and tried setting several bits in certain bytes high with no success. I also have a Controller Channel Map as well if that may help, I lack the experience so far to know how I can use it (if at all) to identify if I can even accomplish this.
Thank you!
Thank you!
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Friday,14,March,2014,13:36:01:28384
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72 A9
VIN: WA1LGCFP6EA052470 Mileage: 5110km/3175miles
Address 01: Engine (J623-CTUD) Labels: None
Part No SW: 8R0 907 551 D HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0003
Revision: --H07---
Coding: 2A2A0034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218R0907551D 001004
ROD: EV_ECM30TFS0218R0907551D.rod
VCID: 3979F4B5B83772D69C9-806C
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R0 927 158 AB HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1002
Revision: --H16---
Coding: 000001
ROD: EV_TCMAL551211_AU48.rod
VCID: 7DF120A5EC9F8EF6F01-8028
Part No SW: 8R0 907 379 AM HW: 8R0 907 379 AM
Component: ESP8 quattro H09 0030
Coding: 30150801
Shop #: WSC 06335 000 00000
VCID: 8B15FE7D2A2B30467E5-80DE
Part No SW: 8K0 907 064 HP HW: 8K0 907 064 GP
Component: BCM2 2.0 H13 0641
Coding: 0D854040000000000000
VCID: 8501C8450C4F4636281-80D0
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01121020130179
Coding: 6601228000
VCID: 3979F4B5B03772D69C9-806C
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000686766402
Coding: 26000096863CAFE0010048C300003D0D0F9CC708A2090221000008004400010200040034000000
VCID: 7AFB2BB9F5B1B9CED53-802F
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 131002 H11 0050
Coding: 01DD13
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Component: AirbagVW-AU10 H47 0610
Serial number: 003GPDB0GV6Z
Coding: 30373431343230303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 479D824DFEC314261AD-8012
Serial number: 6334MSME7F55453AR
Serial number: 6344MSME7F154F6A.
Serial number: 6352QSME2437465CK
Serial number: 6362QSME24373876I
Serial number: 63732SME7639056C4
Crash sensor for front airbag; passenger side:
Serial number: 63832SME6F3926569
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862MJG001CT
Coding: 000037
VCID: 489F8171FBDD1B5E137-801D
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 931 D HW: 8R0 920 931 D
Component: KOMBIINSTR. H35 0564
Revision: 00000000 Serial number: ZDS24DAAE
Coding: 8BA722000A010008020000
VCID: 3663FF8981299DAE71B-8063
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z1393000FE
Coding: 80C103FF00
VCID: 4C97BD61EFA5F77E37F-8019
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
02256 - Quiescent Current
001 - Upper Limit Exceeded
Fault Status: 01100001
Fault Frequency: 9
Reset counter: 152
Mileage: 60 km
Date: 2013.11.30
Time: 23:55:01
Fault Frequency: 172
Reset counter: 209
Mileage: 60 km
Date: 2013.12.01
Time: 02:54:33
Bin. Bits: 00000
Voltage: 12.80 V
Count: 7
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000077802537
Coding: 00581B00000000000000
VCID: 428B9359DDE1310ECD3-8017
Address 3C: Lane Change (J769) Labels: None
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0317325553
Coding: 010211
Shop #: WSC 06334 000 00000
ROD: EV_LaneChangAssis_AU48.rod
VCID: 3F8D9AADA6135CE6A2D-806A
Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000078504362
Coding: 011D13205E00440004
VCID: 4FADAA6D1EB3CC6652D-801A
Address 44: Steering Assist (J500) Labels: None
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H39 0507
Revision: 00001000 Serial number: 0008931988
Coding: 100000010000
ROD: EV_RCEPSAU48X.rod
VCID: 3B75EEBDB20B40C68E5-806E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0317421361
Coding: 0126063A20EA709584B0053200040000
Shop #: WSC 06334 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
00194 - Ignition Key Removal Lock
Fault Status: 00101011
Reset counter: 210
Mileage: 5111 km
Date: 2014.03.14
Time: 10:42:45
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813021138103
VCID: 2D51D0E5747FDE76001-8078
03029 - Subwoofer (R157)
Reset counter: 168
Voltage: 12.30 V
Temperature: 17.0°C
Temperature: 17.0°C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000078661302
VCID: 4E93B76919B9C56E59B-801B
Address 53: Parking Brake (----) Labels: None
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 20000000345817
ROD: EV_ParkiBrake_AU48.rod
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156JJ0D7918989
Coding: 020007010000000001
VCID: 244735C127B51F3EDFF-8071
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 664 D HW: 8R1 035 664 D
Component: H-BN-NA H40 0738
Revision: -------- Serial number: 203JY0D7531581
Coding: 1A020006020581EF55028B4E00000403F40000020000000000
VCID: 377DF28D862364A66AD-8062
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Component: CD-Database 5298
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000078669663
Coding: 010C13204000240004
VCID: 46838F49F1C90D2EE1B-8013
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08--- Serial number: 525PA8-J37A9RE
Coding: 1020010
VCID: 3467C58157558FBE4FF-8061
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B75EEBDBA0B40C68E5-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000078669805
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8R0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 130909201267
VCID: 3A7BEBB9BD3179CE953-806F
End ---------------------------------------------------------------------
