Hey Guys,
Short story is, my KESSY module was under water for almost 2 weeks (with battery attached) before it was discovered. I currently have No keyless entry, No Ignition accessory, steering is locked (key stuck in ignition) and gear shift locked. I have been checking the posts on KESSY module issues but I still have a few questions
1. What are my options for doing a scan with a dead KESSY? (I have seen an option to power/jump terminal 15 or 30 relays but need some instructions).
2. Does the letter at the end of the KESSY part # really matter? (In my case the "F" in 3D0 909 137 F)
3. Does the "Continental" brand on the module make it any different from the others?. (Mine is branded VW Continental)
4. Is there any way to get the IMMO-ID from dead KESSY? (saw some instructions from KESSY swapping that will need this)
5. I have seen some used modules online that include "login code". Would I be able to replace KESSY without dealer intervention?
6. What are my best options in dealing with this KESSY situation?
Any assistance would be greatly appreciated. Thanks in advance.
I will include an earlier version of VCDS scan.
Friday,08,June,2018,06:48:33:37723
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWZZZ3DZD8001098 License Plate: 2270HV
Mileage: 113160km-70314mi Repair Order:
Chassis Type: 3D-VW61 (6N0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 28 2E 34 36 37 38 42 46
47 52 55 56 62 68 6C 71 72 76
VIN: WVWZZZ3DZD8001098 Mileage: 113160km-70314miles
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (CMV) Labels: None
Part No SW: 03H 906 032 GL HW: 03H 907 309 B
Component: D1-3.6-FSI-AGEU5G 3903
Revision: 5KH07--- Serial number: VWX3Z0L3966034
Coding: 0000175
Shop #: WSC 01065 000 00000
VCID: 72BD2652B8B61427773-5160
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - MIL ON
Fault Status: 11100010
Mileage: 113142 km
Date: 2018.07.06
Time: 02:56:15
RPM: 673 /min
Load: 36.1 %
Temperature: 89.0°C
Temperature: 48.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.700 V
Readiness: 0010 0001
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 09L 927 760 S HW: GS1 911 4
Component: AG6 09L 3,6 FSI RdW 3603
Revision: --H05--- Serial number: 4636407
VCID: 47CBA786E3B4C18FF0D-5160
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H35 0047
Coding: 0008566
Shop #: WSC 30001 000 00000
VCID: 6B833B369F9CC5EFB45-51F2
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 F HW: 3D0 909 137 F
Component: Kessy 6850
Revision: 00H24072 Serial number: VWX3Z0L3966034
Coding: 0151788
VCID: 2A0DFE3250B61CE70F3-807E
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1722
Coding: 0000003
VCID: 77AB1746D384710F40D-8022
Address 07: Control Head Labels: 3D0-907-048.clb
Part No SW: 3D0 907 048 HW: 3D0 907 048
Component: J127 KBT vorn 0035
Revision: ABH03001 Serial number: VWZ6Z7M0155020
VCID: 63935316771C8DAF0C5-8036
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 M
Component: Climatronic D1 2039
Coding: 0000003
VCID: 2809043A4EBA2EF7197-807C
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 Q HW: 3D0 937 049 Q
Component: J519 7700
Revision: -4006--- Serial number: --------------
Coding: 618C0000EB2915825502770000000000
VCID: 3829D47A9E1ABE77897-806C
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 M
Component: 08 Airbag 8.4E+ H14 1155
Coding: 0012344
VCID: 2D07F52E61580BDFEA1-8078
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000012
VCID: 47CBA786E3E4C18FF0D-8012
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No SW: 3D0 920 886 B HW: 3D0 920 886 B
Component: J285 KOMBI-INST. 1521
Revision: KPH06V08
Coding: 0039501
Shop #: WSC 27202 001 104857
VCID: 2A0DFE3250F61CE70F3-807E
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3D0 920 886 B
Component: J533 GW-K-CAN TP20 1521
Coding: 7FF2F7BEE3011003
VCID: 70B92C5AB6AA2637817-8024
Address 28: HVAC, Rear Labels: 3D0-919-158.lbl
Part No: 3D0 919 158 M
Component: Klima-Bedienteil D1 0124
VCID: 3537DD4E8908431F921-8060
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662638292
Coding: 020100
VCID: 2A0DFE325CF61CE70F3-807E
00532 - Supply Voltage B+
Reset counter: 211
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005521
Shop #: WSC 28868 001 1048576
VCID: 270B070643A4218F10D-8072
01400 - Suspension Level Control
01577 - Turn-Off due to Over-Temp
01583 - Leak in System Detected
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1722
Coding: 0000004
VCID: 6FBB2F26ABD439CF98D-803A
Address 37: Navigation (J0506) Labels: None
Part No SW: 3D0 035 686 HW: 3D0 035 686
Component: RNS-MID H03 2198
Revision: AB001001 Serial number: VWZ6Z7M0155020
Coding: 06070002000000200000
VCID: 639353167B5C8DAF0C5-8036
Subsystem 1 - Part No: 7L6 919 859 J
Component: SIMA V4 7769
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 F
Component: Dachmodul 0903
Coding: 0012335
VCID: 26150A0244AE38872BB-8072
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 P
Component: HSG 8135
Coding: 0000040
VCID: 3D27C56EB1689B5F5A1-4B1E
Subsystem 1 - Part No: 3D2 959 701 L
Component: Tuersteuergeraet FS 6004
Subsystem 2 - Part No: 3D2 959 702 L
Component: Tuersteuergeraet BF 6004
Subsystem 3 - Part No: 3D0 959 703 K
Component: Tuersteuergeraet HL 6004
Subsystem 4 - Part No: 3D0 959 704 K
Component: Tuersteuergeraet HR 6004
Subsystem 5 - Part No: 3D0 909 610 F
Component: 3P HDSG 2630
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
00316 - Bulbs for Rear Illumination
009 - Open or Short to Ground
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 3D0 035 466 D HW: 3D0 035 466 D
Component: R12___DSP 12 Kanal 0570
Revision: DBH06001 Serial number: BP225721243173
VCID: 2313131637DCCDAF4C5-8076
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 012E00000B000200
Shop #: WSC 01065 000 00023
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 372BD7469FC4B10F80D-8062
Subsystem 1 - Part No: 3D0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 3D0 941 329 Labels: 3D0-941-329.CLB
Address 56: Radio (J0506) Labels: None
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V2.clb
Part No: 3D2 955 120 B
Component: Front Wiper 3501
Coding: 0015733
Shop #: WSC 01065 000 376832
VCID: 211F191E2D80DFBF5E9-8074
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3D0 907 441 HW: 3D0 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J231098
Coding: 0000003
VCID: 60995C1A664A96B7117-8034
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 F
Component: Batteriemanagement 2800
Address 76: Park Assist Labels: Redir Fail!
Part No: 3D0 919 283 F
Component: 18 Einparkhilfe 1207
End----------(Elapsed Time: 02:17, VBatt start/end: 12.2V/12.2V)-----------
