Results 11 to 20 of 27
Thread: MK7 Golf, no back up camera and reverse lights.
    May 2017
    Ok, check these channels in the module 09 adaptation, remember the security login before trying to change the values.
    If I'm not badly off, Leuchte28RFL is left backup light.
    So change :
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 value from 100 to 127
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 from whatever it is at the moment to 40 Allgemeine LED, this means general LED
    These are the values now stored in your BCM. If the LastTyp value is really not active, then that's most likely the reason why the backup light is not working and why the reversing camera is not working either. Factory reversing camera takes trigger signal from backup light.
    So these two problems you have are correlating each other.
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100	16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	not active 	16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
    Edit :
    Check on which side of the car the backup light is. I think on LHD it should be on the left so in that case the channels are Leucthe28RFL, if it's RHD car, it should be on the right and in that case it's Leuchte29RFL. So change the channels accordingly on which side the backup light is.
  2. Likes PetrolDave, Uwe liked this post
  3. #12
    Oct 2018
    Canada
    Ok do now I have changed those codes and I have a back up light on the left side with a rear fog light now on all the time. But nothing on the right side. I should say as well that my reverse lights are filament bulbs not led.
  4. #13
    May 2017
    Backup light is only on one side. The rear fog light should be on opposite side.
    Can you post a new adamap from 09 module after changes?
    Edit : Also it would be nice to see the instructions you received. What exactly you changed when you installed the lights?
  5. Likes Uwe liked this post
  6. #14
    Oct 2018
    Canada
    ;SW:5Q0-937-087-AA   HW:5Q0-937-087-AA ---  Cent. Elect.
    ;Component:BCM PQ37BOSCH 028 0162	 Coding:000018664041805949E44000091407001000000000000000000000000000
    ;EV_BodyContrModul1UDSBosc	15002	EV_BCMBOSCH_015.rod
    ;Tuesday	9	October	2018	11:51:36:16743
    ;VCDS Version: Release 18.9.0  Data version: 20180927 DS296.0
    ;VCID: 7AADF1763C5B4FA7D01-802E
    IDE00001-ENG99061-Production mode-Access control	not active 	3
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active 	3
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active 	3
    IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
    IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
    IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
    IDE00002-Transport mode	active 	1
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active 	12
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0	12
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active 	12
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active 	12
    IDE01268-ENG133394-Windshield wiper-Frontwischer_Abtauposition	not active 	12
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	12
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active 	12
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Deactivating 	12
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active 	12
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	0 ms	12
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	0 ms	12
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms	12
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms	12
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	0 ms	12
    IDE01268-ENG133393-Windshield wiper-Tippendes_Frontwaschen	not active 	12
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active 	12
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active 	12
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active 	12
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant	0	12
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	12
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active 	12
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active 	12
    IDE01550-Service position	170.49 °	2
    IDE02152-Characteristics in production mode	2000 ms	4
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	4
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	4
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	4
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	4
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	4
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	4
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	4
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	4
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	4
    IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	4
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active 	4
    IDE02332-Deactivate production mode	0	3
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
    IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
    IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	0 s	8
    IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	0.0 s	8
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active 	8
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80%	8
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80%	8
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80%	8
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled 	8
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed 	8
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.75 °	14
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.00 %/s	14
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	14
    IDE03638-ENG116675-static AFS light-Lower speed threshold	0.00 km/h	14
    IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.00 °C	14
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.00 °C	14
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	14
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.00 °C	14
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	180 °	14
    IDE03638-ENG116676-static AFS light-Upper speed threshold	40.00 km/h	14
    IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	14
    IDE04923-ENG133379-Turn signal control-Abbruch Komfortblinken	active 	8
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte 	8
    IDE04923-ENG115774-Turn signal control-Komfortblinken	active 	8
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	5	8
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	MFG 	8
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled 	8
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active 	8
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	8
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.1	8
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00%	8
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h	14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h	14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active 	14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig 	14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h	14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	not active 	14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active 	14
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus	active 	14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	not active 	14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active 	14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min	14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam 	8
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	Not Present 	8
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	ignition 	8
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	0 lx	8
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	0 lx	8
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	not enabled 	8
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	not active 	8
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	not active 	8
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	not active 	8
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	not active 	8
    IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	8
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C	8
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C	8
    IDE04927-ENG126845-Window heater-FSH Automatik	active 	8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	4
    IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	4
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	driver door contact thatcham 	4
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	4
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	4
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	4
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	4
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active 	8
    IDE05142-ENG116621-Access control-automatisches Entriegeln	active 	8
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	active 	8
    IDE05142-ENG116706-Access control-Autounlock NAR	active 	8
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	8
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	not active 	8
    IDE05142-ENG133387-Access control-Deaktivierung_Laderaumschliessung_extern	not active 	8
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	8
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	not active 	8
    IDE05142-ENG115722-Access control-Electrical rear lid	not active 	8
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	8
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active 	8
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	8
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active 	8
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	8
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	8
    IDE05142-ENG133386-Access control-Heckfreigabe_Ohne_Verzoegerung	not active 	8
    IDE05142-ENG133388-Access control-LS_Taster_Togglefunktion	not active 	8
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active 	8
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable 	8
    IDE05142-ENG137162-Access control-Mindestbetaetigung_HDF_Innentaster	0.00 s	8
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	8
    IDE05142-ENG115755-Access control-Notschließfunktion	active 	8
    IDE05142-ENG133389-Access control-Nutzfahrzeug_Schliessung	not active 	8
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	8
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	8
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Always 	8
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden	Always 	8
    IDE05142-ENG115758-Access control-Valet Parking	not active 	8
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe	not active 	8
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active 	8
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active 	8
    IDE05142-ENG133390-Access control-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	8
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active 	8
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active 	8
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Einzeltuerentriegelung 	8
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active 	8
    IDE05143-MAS02985-Writing parameter-Value	130	5
    IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00 	5
    IDE05144-Read parameter address	FE 00 00 	3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34	560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E 	560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10	0	560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11	0	560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12	0	560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13	0	560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0	560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0	560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16	0	560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17	0	560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18	0	560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19	0	560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2	0	560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20	13	560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21	23	560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29	560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0A 	560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24	1A 	560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28	560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26	0	560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27	0	560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B 	560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B 	560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3	0	560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0	560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0	560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0	560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0	560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0	560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4	48	560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5	4C 	560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36	560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40	560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8	37	560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9	41	560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize 	560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize 	560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize 	560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize 	560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize 	560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize 	560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize 	560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize 	560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize 	560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize 	560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	maximize 	560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize 	560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	maximize 	560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	minimize 	560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	minimize 	560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize 	560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize 	560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize 	560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize 	560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize 	560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize 	560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize 	560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize 	560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	maximize 	560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize 	560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize 	560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize 	560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize 	560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize 	560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	minimize 	560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	minimize 	560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize 	560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize 	560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize 	560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize 	560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize 	560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize 	560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize 	560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize 	560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize 	560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize 	560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize 	560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize 	560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize 	560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize 	560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize 	560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize 	560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize 	560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize 	560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize 	560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize 	560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	maximize 	560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	maximize 	560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize 	560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize 	560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize 	560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize 	560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize 	560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize 	560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize 	560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize 	560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize 	560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize 	560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize 	560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize 	560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize 	560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize 	560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize 	560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize 	560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize 	560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize 	560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize 	560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize 	560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize 	560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize 	560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize 	560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize 	560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize 	560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize 	560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize 	560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize 	560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize 	560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	minimize 	560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize 	560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize 	560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize 	560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize 	560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize 	560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize 	560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize 	560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize 	560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize 	560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize 	560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	minimize 	560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize 	560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize 	560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize 	560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize 	560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize 	560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize 	560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize 	560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize 	560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize 	560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize 	560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize 	560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0	100	560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1	100	560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10	0	560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11	0	560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12	0	560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13	0	560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0	560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0	560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16	0	560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17	0	560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18	0	560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19	0	560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100	560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100	560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100	560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100	560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23	28	560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24	28	560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25	100	560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26	0	560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27	127	560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28	127	560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29	100	560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100	560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30	0	560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31	0	560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32	0	560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33	0	560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34	0	560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4	100	560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5	100	560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6	100	560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7	100	560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8	100	560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9	100	560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0	560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0	560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0	560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0	560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0	560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0	560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0	560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0	560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0	560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0	560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0	560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0	560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2	0	560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20	0	560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21	0	560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0	560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23	127	560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24	127	560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0	560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0	560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0	560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0	560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0	560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3	0	560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0	560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0	560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0	560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0	560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0	560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4	0	560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5	0	560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0	560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0	560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0	560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0	560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0	560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0	560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0	560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0	560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0	560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0	560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0	560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0	560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0	560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0	560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0	560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0	560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2	0	560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20	28	560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21	28	560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0	560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0	560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0	560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0	560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26	0	560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27	0	560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0	560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0	560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3	0	560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0	560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0	560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0	560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0	560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0	560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4	31	560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5	31	560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0	560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0	560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0	560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0	560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0	560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0	560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0	560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0	560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0	560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0	560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0	560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0	560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0	560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0	560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0	560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0	560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0	560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0	560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0	560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0	560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0	560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0	560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0	560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0	560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0	560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0	560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0	560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0	560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0	560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0	560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0	560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0	560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0	560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0	560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0	560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0	560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0	560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0	560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0	560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14	560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15	560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	0	560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	0	560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	0	560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	0	560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0	560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	0	560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0	560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	0	560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	0	560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	0	560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	45	560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	3D 	560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3E 	560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C 	560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	29	560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	2A 	560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30	560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	0	560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	47	560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31	560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32	560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	46	560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	0	560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	0	560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	0	560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	0	560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	0	560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	43	560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	44	560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A 	560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B 	560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	1C 	560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	1D 	560
    IDE05145-ENG115873-Light configuration-Lasttyp 0	14 - kombinierte Blink- Bremsleuchten 	560
    IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten 	560
    IDE05145-ENG116062-Light configuration-Lasttyp 10	not active 	560
    IDE05145-ENG116081-Light configuration-Lasttyp 11	not active 	560
    IDE05145-ENG116100-Light configuration-Lasttyp 12	not active 	560
    IDE05145-ENG116119-Light configuration-Lasttyp 13	not active 	560
    IDE05145-ENG116138-Light configuration-Lasttyp 14	not active 	560
    IDE05145-ENG116157-Light configuration-Lasttyp 15	not active 	560
    IDE05145-ENG116176-Light configuration-Lasttyp 16	not active 	560
    IDE05145-ENG116195-Light configuration-Lasttyp 17	not active 	560
    IDE05145-ENG116214-Light configuration-Lasttyp 18	not active 	560
    IDE05145-ENG116233-Light configuration-Lasttyp 19	not active 	560
    IDE05145-ENG115910-Light configuration-Lasttyp 2	not active 	560
    IDE05145-ENG116252-Light configuration-Lasttyp 20	34 - LED Bremsleuchten 	560
    IDE05145-ENG116271-Light configuration-Lasttyp 21	34 - LED Bremsleuchten 	560
    IDE05145-ENG116290-Light configuration-Lasttyp 22	42 - LED dritte Bremsleuchte 	560
    IDE05145-ENG116309-Light configuration-Lasttyp 23	33 - LED-Modul Blinkleuchten 	560
    IDE05145-ENG116328-Light configuration-Lasttyp 24	33 - LED-Modul Blinkleuchten 	560
    IDE05145-ENG116347-Light configuration-Lasttyp 25	18 - 2* 5W 	560
    IDE05145-ENG116366-Light configuration-Lasttyp 26	not active 	560
    IDE05145-ENG116385-Light configuration-Lasttyp 27	40 - allgemeine LED 	560
    IDE05145-ENG116404-Light configuration-Lasttyp 28	40 - allgemeine LED 	560
    IDE05145-ENG116423-Light configuration-Lasttyp 29	not active 	560
    IDE05145-ENG115929-Light configuration-Lasttyp 3	not active 	560
    IDE05145-ENG116442-Light configuration-Lasttyp 30	not active 	560
    IDE05145-ENG116461-Light configuration-Lasttyp 31	not active 	560
    IDE05145-ENG116480-Light configuration-Lasttyp 32	not active 	560
    IDE05145-ENG116499-Light configuration-Lasttyp 33	not active 	560
    IDE05145-ENG116518-Light configuration-Lasttyp 34	not active 	560
    IDE05145-ENG115948-Light configuration-Lasttyp 4	not active 	560
    IDE05145-ENG115967-Light configuration-Lasttyp 5	not active 	560
    IDE05145-ENG115986-Light configuration-Lasttyp 6	11 - Abblendlicht 	560
    IDE05145-ENG116005-Light configuration-Lasttyp 7	11 - Abblendlicht 	560
    IDE05145-ENG116024-Light configuration-Lasttyp 8	10 - allgemeine Scheinwerfer 	560
    IDE05145-ENG116043-Light configuration-Lasttyp 9	10 - allgemeine Scheinwerfer 	560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always 	560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always 	560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always 	560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always 	560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always 	560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always 	560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always 	560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always 	560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always 	560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always 	560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always 	560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always 	560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always 	560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always 	560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always 	560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always 	560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	Always 	560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	Always 	560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always 	560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	Always 	560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	Always 	560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	Always 	560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	Always 	560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always 	560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always 	560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always 	560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always 	560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always 	560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always 	560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always 	560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always 	560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always 	560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always 	560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always 	560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always 	560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0	560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	0	560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2	560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4	560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	0	560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	0	560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	0	560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	0	560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0	560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0	560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	0	560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	0	560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	0	560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	0	560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	8	560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24	560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24	560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24	560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	0	560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	0	560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8	560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	0	560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	8	560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	25	560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25	560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	8	560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	0	560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	0	560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	0	560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	0	560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	0	560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20	560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20	560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11	560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12	560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	13	560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	14	560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0	560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0	560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	0	560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	0	560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	0	560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	0	560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0	560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0	560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0	560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0	560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0	560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	0	560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0	560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0	560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0	560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	0	560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	0	560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	0	560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0	560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0	560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0	560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0	560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	0	560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0	560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0	560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0	560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0	560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0	560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0	560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0	560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	0	560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	0	560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	15	560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	15	560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	0	560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	0	560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0	560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0	560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	0	560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0	560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0	560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0	560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0	560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	0	560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	0	560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	0	560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	0	560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	0	560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0	560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	2	560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	4	560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0	560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0	560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0	560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0	560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0	560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	0	560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0	560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0	560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0	560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0	560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0	560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	6	560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	7	560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0	560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0	560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0	560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0	560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0	560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0	560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0	560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0	560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0	560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0	560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0	560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0	560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0	560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0	560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0	560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0	560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	0	560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	0	560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	0	560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0	560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	0	560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	0	560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0	560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0	560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0	560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0	560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0	560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	0	560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0	560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0	560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0	560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0	560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0	560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	0	560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	0	560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0	560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0	560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0	560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0	560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0	560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0	560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0	560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0	560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0	560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0	560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0	560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0	560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0	560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0	560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0	560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0	560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	0	560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	8	560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	8	560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0	560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	0	560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	0	560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0	560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	0	560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	0	560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0	560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0	560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	0	560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0	560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0	560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0	560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0	560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0	560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	8	560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	8	560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0	560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0	560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0	560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0	560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0	560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0	560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0	560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0	560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0	560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0	560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0	560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0	560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0	560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0	560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0	560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0	560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	0	560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0	560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0	560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0	560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0	560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0	560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0	560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0	560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0	560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0	560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0	560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0	560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0	560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0	560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0	560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0	560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	0	560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0	560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0	560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0	560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0	560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3	0	560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5	0	560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0	560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0	560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0	560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0	560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0	560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0	560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0	560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0	560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0	560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0	560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0	560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0	560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	3	560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0	560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0	560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0	560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0	560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0	560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0	560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0	560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0	560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0	560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0	560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	3	560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0	560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0	560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0	560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0	560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0	560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0	560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0	560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0	560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0	560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0	560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0	560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0	560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0	560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0	560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0	560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0	560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0	560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0	560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0	560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0	560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0	560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0	560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0	560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0	560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0	560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0	560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0	560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0	560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0	560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0	560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0	560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0	560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0	560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0	560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0	560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0	560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0	560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0	560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0	560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0	560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0	560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0	560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0	560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0	560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0	560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0	560
    IDE05145-ENG154438-Light configuration-Reserved 0	0	560
    IDE05145-ENG99841-Light configuration-Reserved 1	0	560
    IDE05145-ENG154357-Light configuration-Reserved 10	0	560
    IDE05145-ENG154352-Light configuration-Reserved 11	0	560
    IDE05145-ENG154182-Light configuration-Reserved 12	0	560
    IDE05145-ENG154265-Light configuration-Reserved 13	0	560
    IDE05145-ENG154334-Light configuration-Reserved 14	0	560
    IDE05145-ENG154340-Light configuration-Reserved 15	0	560
    IDE05145-ENG154204-Light configuration-Reserved 16	0	560
    IDE05145-ENG154344-Light configuration-Reserved 17	0	560
    IDE05145-ENG154195-Light configuration-Reserved 18	0	560
    IDE05145-ENG154190-Light configuration-Reserved 19	0	560
    IDE05145-ENG99862-Light configuration-Reserved 2	0	560
    IDE05145-ENG154300-Light configuration-Reserved 20	0	560
    IDE05145-ENG154439-Light configuration-Reserved 21	0	560
    IDE05145-ENG154440-Light configuration-Reserved 22	0	560
    IDE05145-ENG154441-Light configuration-Reserved 23	0	560
    IDE05145-ENG154442-Light configuration-Reserved 24	0	560
    IDE05145-ENG154443-Light configuration-Reserved 25	0	560
    IDE05145-ENG154444-Light configuration-Reserved 26	0	560
    IDE05145-ENG154445-Light configuration-Reserved 27	0	560
    IDE05145-ENG154446-Light configuration-Reserved 28	0	560
    IDE05145-ENG154447-Light configuration-Reserved 29	0	560
    IDE05145-ENG101107-Light configuration-Reserved 3	0	560
    IDE05145-ENG154448-Light configuration-Reserved 30	0	560
    IDE05145-ENG154449-Light configuration-Reserved 31	0	560
    IDE05145-ENG154450-Light configuration-Reserved 32	0	560
    IDE05145-ENG154451-Light configuration-Reserved 33	0	560
    IDE05145-ENG154452-Light configuration-Reserved 34	0	560
    IDE05145-ENG154267-Light configuration-Reserved 4	0	560
    IDE05145-ENG154291-Light configuration-Reserved 5	0	560
    IDE05145-ENG154239-Light configuration-Reserved 6	0	560
    IDE05145-ENG154308-Light configuration-Reserved 7	0	560
    IDE05145-ENG154184-Light configuration-Reserved 8	0	560
    IDE05145-ENG154255-Light configuration-Reserved 9	0	560
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	24
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	24
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C	24
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C	24
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C	24
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C	24
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	24
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	35.00 °C	24
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	24
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	35.00 °C	24
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	53.50 °C	24
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	52.50 °C	24
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	53.50 °C	24
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	52.50 °C	24
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active 	8
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active 	8
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active 	8
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active 	8
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active 	8
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100%	8
    IDE06425-Roller test bench mode: functional	not active 	1
    IDE06507-MAS13125-Button in center console-Function of button 1	Start-stop 	8
    IDE06507-MAS13129-Button in center console-Function of button 2	Luggage hold closure 	8
    IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
    IDE06507-MAS13135-Button in center console-Function of button 4	Steering wheel heater 	8
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights 	4
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	4
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	4
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active 	4
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active 	4
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active 	4
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	4
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active 	4
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	4
    IDE07356-Position during interval mode	31.49 °	2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit 	12
    IDE07470-ENG133381-After-run for park light-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	12
    IDE07470-ENG133380-After-run for park light-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	12
    IDE07470-ENG133382-After-run for park light-Faktor fuer Verfügbarkeitstimer	Faktor fuer x5 Minuten 	12
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	12
    IDE07470-ENG133383-After-run for park light-Standlicht-Verfügbarkeit	6 s	12
    IDE08542-IDE02021-Access control 2-Comfort closing	active 	8
    IDE08542-IDE02022-Access control 2-Comfort opening	not active 	8
    IDE08542-ENG128459-Access control 2-easycloselight_aktiv	not active 	8
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active 	8
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	not active 	8
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s	8
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active 	8
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active 	8
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active 	8
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	not active 	8
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by convenience operation via remote control key 	8
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	not active 	8
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	active 	8
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	not active 	8
    IDE08542-ENG115670-Access control 2-Komfortbedienung global	active 	8
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active 	8
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active 	8
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active 	8
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	active 	8
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	not active 	8
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active 	8
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	active 	8
    IDE08542-ENG125656-Access control 2-Regenschliessen_art	once 	8
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	not active 	8
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	not_active 	8
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active 	8
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active 	8
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	not active 	8
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting 	8
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	not active 	8
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	not active 	8
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	active 	8
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active 	8
    IDE08542-ENG133411-Access control 2-Spiegelanklappen_bei_Wiederverriegelung	not active 	8
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	not active 	8
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active 	8
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active 	8
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	0 ms	8
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	8
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active 	8
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis 	8
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	not active 	8
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms	8
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	sensitive 	8
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active 	8
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present 	8
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	8
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	not active 	8
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	not active 	8
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active 	2
    IDE08787-ENG101416-Auxiliary functions-Reserved_1	not active 	2
    IDE08787-ENG99458-Auxiliary functions-Reserved_2	not active 	2
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active 	2
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	2
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	2
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active 	4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active 	4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active 	4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active 	4
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken	not active 	4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active 	4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active 	4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active 	4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active 	4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active 	4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active 	4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active 	4
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active 	4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active 	4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active 	4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active 	4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active 	4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active 	4
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	20
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	20
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	20
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	20
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1	225	20
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2	225	20
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3	225	20
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%	20
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2	20
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%	20
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1	225	20
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2	225	20
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3	225	20
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	20
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1	225	20
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2	225	20
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3	225	20
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	active 	20
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	20
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	2
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed 	2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	2
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	2
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	not installed 	2
    IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	2
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	2
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	12
    IDE10298-Alternating park position 1	7.49 °	2
    IDE10299-Alternating park position 2	29.49 °	2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	64	256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	64	256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0	256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	64	256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	64	256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	64	256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	64	256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0	256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	0%	256
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	0%	256
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	0%	256
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	0%	256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	0%	256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	0%	256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	0%	256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	0%	256
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	0%	256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	0%	256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	0%	256
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	0%	256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	0%	256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	0%	256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	0%	256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	0 ms	256
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0 s	256
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0 s	256
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0 s	256
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0 s	256
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0 s	256
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0 s	256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0 s	256
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0 s	256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	0 s	256
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0 s	256
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0 s	256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0 s	256
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0 s	256
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0 s	256
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0 s	256
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0 s	256
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0 s	256
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0 s	256
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0 s	256
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0 s	256
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0 s	256
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0 s	256
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0 s	256
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0 s	256
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0 s	256
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0 s	256
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0 s	256
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0 s	256
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0 s	256
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0 s	256
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0 s	256
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0 s	256
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0 s	256
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0 s	256
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0 s	256
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0 s	256
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0 s	256
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0 s	256
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0 s	256
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0 s	256
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0 s	256
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0 s	256
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	E1 	30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	E1 	30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	E1 	30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	E1 	30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	E1 	30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	E1 	30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	E1 	30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	E1 	30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	E1 	30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	E1 	30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	E1 	30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	E1 	30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	E1 	30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	E1 	30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	E1 	30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	E1 	30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	E1 	30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	E1 	30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	E1 	30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	E1 	30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	E1 	30
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	1
    MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	1
    MAS05055-lower turn position	31.49 °	2
    MAS05056-upper turn position	170.49 °	2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active 	8
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active 	8
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active 	8
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active 	8
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active 	8
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active 	8
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	8
    MAS05934-ENG133391-Convert. top oper.-Remote Lock Unlock Timer s1	0 s	8
    MAS05934-ENG133392-Convert. top oper.-Remote Lock Unlock Timer s3	0.000 ms	8
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active 	8
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active 	8
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active 	8
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active 	8
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active 	8
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active 	8
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active 	8
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active 	8
    MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	60 lx	24
    MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	110 lx	24
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	1000 lx	24
    MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	30 lx	24
    MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	60 lx	24
    MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	110 lx	24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	80	24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	100 lx	24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	4500 mV	24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	300 lx	24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	2000 mV	24
    MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door 	30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
    ENG126647-ENG98399-debug_light_function-Activation	0	11
    ENG126647-ENG101417-debug_light_function-Adresse	0	11
    ENG126647-ENG126820-debug_light_function-Bitmask	0	11
    ENG126647-ENG126821-debug_light_function-Divisor	0	11
    ENG126647-ENG98827-debug_light_function-Offset	0	11
    ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe	0	11
    ENG99457-ENG117394-Head area heater-blower_speed	1	2
    ENG99457-ENG98971-Head area heater-Temperature	-2	2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms	22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms	22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms	22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms	22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms	22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms	22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms	22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms	22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms	22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms	22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms	22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%	22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00%	22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%	22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00%	22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.00%	22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.00%	22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.00%	22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.00%	22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.00%	22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.00%	22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.00%	22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0	22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50	22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0	22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100	22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200	22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253	22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0	22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0	22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0	22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0	22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0	22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx	22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx	22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx	22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx	22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200	22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500	22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0	22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx	22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx	22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx	22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx	22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms	22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms	22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms	22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms	22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms	22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms	22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms	22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms	22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms	22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms	22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms	22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%	22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%	22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%	22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%	22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%	22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%	22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%	22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%	22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%	22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%	22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%	22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%	12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%	12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%	12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%	12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%	12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%	12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10	12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10	12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100	12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150	12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220	12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253	12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx	10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx	10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx	10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx	10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx	10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16	10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16	10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100	10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100	10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100	10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx	10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx	10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx	10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx	10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx	10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6	10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6	10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100	10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100	10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100	10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0	12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10	12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50	12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100	12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220	12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253	12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	2.00%	12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	2.00%	12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	6.00%	12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	10.00%	12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	80.00%	12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%	12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx	8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx	8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx	8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx	8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100	8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100	8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100	8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100	8
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx	8
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx	8
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx	8
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx	8
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6	8
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6	8
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100	8
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100	8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%	6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%	6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%	6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%	6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%	6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%	6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx	8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx	8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx	8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx	8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100	8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100	8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100	8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100	8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx	8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx	8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx	8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx	8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6	8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6	8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100	8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100	8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%	6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%	6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%	6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%	6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%	6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%	6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms	10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	100 ms	10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	160 ms	10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	200 ms	10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	260 ms	10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%	10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5	10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15	10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	10	10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100	10
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	14 - kombinierte Blink- Bremsleuchten 	16
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	0	16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	0	16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	0	16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	not active 	16
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	not active 	16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active 	16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	0	16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	0	16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	0	16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	not active 	16
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	not active 	16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active 	16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize 	16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize 	16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize 	16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0	16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0	16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0	16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0	16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0	16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0	16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active 	16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always 	16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	not active 	16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	not active 	16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	not active 	16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	not active 	16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	not active 	16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	not active 	16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	not active 	16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	not active 	16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0	16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0	16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active 	16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active 	16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0	16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0	16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active 	16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active 	16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	0	16
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0	16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	0	16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	not active 	16
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	not active 	16
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	0	16
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0	16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	0	16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	not active 	16
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	not active 	16
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten 	16
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize 	16
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	28	16
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	34 - LED Bremsleuchten 	16
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active 	16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	not active 	16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize 	16
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	28	16
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	34 - LED Bremsleuchten 	16
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active 	16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	not active 	16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100	16
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active 	16
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	28	16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	127	16
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	33 - LED-Modul Blinkleuchten 	16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	not active 	16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active 	16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Blinken links Hellphase 	16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	28	16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	127	16
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	33 - LED-Modul Blinkleuchten 	16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	not active 	16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active 	16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Blinken rechts Hellphase 	16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	100	16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	18 - 2* 5W 	16
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	0	16
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	0	16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0	16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	not active 	16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	not active 	16
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	127	16
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	47	16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0	16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	40 - allgemeine LED 	16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	40 - allgemeine LED 	16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100	16
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	not active 	16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize 	16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	minimize 	16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0	16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0	16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	45	16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	0	16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	not active 	16
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	not active 	16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active 	16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active 	16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active 	16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	Blinken links Dunkelphase 	16
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	0	16
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	0	16
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	not active 	16
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	not active 	16
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize 	16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	minimize 	16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0	16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0	16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	46	16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	0	16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	not active 	16
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	not active 	16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active 	16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active 	16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active 	16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	Blinken links Dunkelphase 	16
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize 	16
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	100	16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	31	16
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	43	16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	48	16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	not active 	16
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen) 	16
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active 	16
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize 	16
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	100	16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	31	16
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	44	16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	4C 	16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	not active 	16
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen) 	16
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active 	16
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht 	16
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht 	16
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C 	16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	10 - allgemeine Scheinwerfer 	16
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam 	16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell 	16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active 	16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D 	16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	10 - allgemeine Scheinwerfer 	16
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam 	16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell 	16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active 	16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize 	16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize 	16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize 	16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0	16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0	16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0	16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0	16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0	16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0	16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active 	16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always 	16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	not active 	16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	not active 	16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	not active 	16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	not active 	16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	not active 	16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	not active 	16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	not active 	16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	not active 	16
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	active 	1
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	active 	1
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	active 	1
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	active 	1
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	active 	1
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	active 	1
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
    ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	active 	16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active 	16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG133403-Personalization-PSO_FSG_Setup2_Bit_0	active 	16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	active 	16
    ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	active 	16
    ENG98831-ENG133408-Personalization-PSO_FSG_Setup2_Bit_5	active 	16
    ENG98831-ENG133409-Personalization-PSO_FSG_Setup2_Bit_6	active 	16
    ENG98831-ENG133410-Personalization-PSO_FSG_Setup2_Bit_7	active 	16
    ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
    ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung	active 	8
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
    Elapsed Time: 01:57
  7. Likes downtime liked this post
  8. #15
    Oct 2018
    Canada
    https://www.ecstuning.com/b-ecs-part...738ecs01-01kt/
    Please go to this link and look at the pdf at the bottom of the page. Those are the instructions for coding the lights I bought.
  9. Likes downtime liked this post
  10. #16
    May 2017
    Let's have another go
    Looks like some errors in leuchte27NSL too.
    So to this :
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	1-LED Tagfahrlichtmodul Versorgung
    Then I have AJ index BCM euro spec adaptation map, so try these changes :
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Nebelschlusslicht wenn kein Anhaenger gesteckt
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	40 - allgemeine LED
  11. Likes Uwe liked this post
  12. #17
    Oct 2018
    Canada
    Ok, I made those changes, now the right rear back up light comes instead of the left rear, the left side rear fog is still on all the time and the back up camera now makes a noise, but no single is seen on the screen in the dash. I have run another scan, will post shortly.
  13. #18
    Oct 2018
    Canada
    ;SW:5Q0-937-087-AA   HW:5Q0-937-087-AA ---  Cent. Elect.
    ;Component:BCM PQ37BOSCH 028 0162	 Coding:000018664041805949E44000091407001000000000000000000000000000
    ;EV_BodyContrModul1UDSBosc	15002	EV_BCMBOSCH_015.rod
    ;Tuesday	9	October	2018	13:12:22:16743
    ;VCDS Version: Release 18.9.0  Data version: 20180927 DS296.0
    ;VCID: 7AADF1763C5B4FA7D01-802E
    IDE00001-ENG99061-Production mode-Access control	not active 	3
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active 	3
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active 	3
    IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
    IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
    IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
    IDE00002-Transport mode	active 	1
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active 	12
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0	12
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active 	12
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active 	12
    IDE01268-ENG133394-Windshield wiper-Frontwischer_Abtauposition	not active 	12
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	12
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active 	12
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Deactivating 	12
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active 	12
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	0 ms	12
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	0 ms	12
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms	12
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms	12
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	0 ms	12
    IDE01268-ENG133393-Windshield wiper-Tippendes_Frontwaschen	not active 	12
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active 	12
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active 	12
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active 	12
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant	0	12
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	12
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active 	12
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active 	12
    IDE01550-Service position	170.49 °	2
    IDE02152-Characteristics in production mode	2000 ms	4
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	4
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	4
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	4
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	4
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	4
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	4
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	4
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	4
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	4
    IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	4
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active 	4
    IDE02332-Deactivate production mode	0	3
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
    IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
    IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	0 s	8
    IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	0.0 s	8
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active 	8
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80%	8
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80%	8
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80%	8
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled 	8
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed 	8
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.75 °	14
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.00 %/s	14
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	14
    IDE03638-ENG116675-static AFS light-Lower speed threshold	0.00 km/h	14
    IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.00 °C	14
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.00 °C	14
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	14
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.00 °C	14
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	180 °	14
    IDE03638-ENG116676-static AFS light-Upper speed threshold	40.00 km/h	14
    IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	14
    IDE04923-ENG133379-Turn signal control-Abbruch Komfortblinken	active 	8
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte 	8
    IDE04923-ENG115774-Turn signal control-Komfortblinken	active 	8
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	5	8
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	MFG 	8
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled 	8
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active 	8
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	8
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.1	8
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00%	8
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h	14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h	14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active 	14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig 	14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h	14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	not active 	14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active 	14
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus	active 	14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	not active 	14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active 	14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min	14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam 	8
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	Not Present 	8
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	ignition 	8
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	0 lx	8
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	0 lx	8
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	not enabled 	8
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	not active 	8
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	not active 	8
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	not active 	8
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	not active 	8
    IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	8
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C	8
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C	8
    IDE04927-ENG126845-Window heater-FSH Automatik	active 	8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	4
    IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	4
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	driver door contact thatcham 	4
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	4
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	4
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	4
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	4
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active 	8
    IDE05142-ENG116621-Access control-automatisches Entriegeln	active 	8
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	active 	8
    IDE05142-ENG116706-Access control-Autounlock NAR	active 	8
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	8
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	not active 	8
    IDE05142-ENG133387-Access control-Deaktivierung_Laderaumschliessung_extern	not active 	8
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	8
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	not active 	8
    IDE05142-ENG115722-Access control-Electrical rear lid	not active 	8
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	8
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active 	8
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	8
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active 	8
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	8
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	8
    IDE05142-ENG133386-Access control-Heckfreigabe_Ohne_Verzoegerung	not active 	8
    IDE05142-ENG133388-Access control-LS_Taster_Togglefunktion	not active 	8
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active 	8
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable 	8
    IDE05142-ENG137162-Access control-Mindestbetaetigung_HDF_Innentaster	0.00 s	8
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	8
    IDE05142-ENG115755-Access control-Notschließfunktion	active 	8
    IDE05142-ENG133389-Access control-Nutzfahrzeug_Schliessung	not active 	8
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	8
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	8
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Always 	8
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden	Always 	8
    IDE05142-ENG115758-Access control-Valet Parking	not active 	8
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe	not active 	8
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active 	8
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active 	8
    IDE05142-ENG133390-Access control-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	8
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active 	8
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active 	8
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Einzeltuerentriegelung 	8
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active 	8
    IDE05143-MAS02985-Writing parameter-Value	130	5
    IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00 	5
    IDE05144-Read parameter address	FE 00 00 	3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34	560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E 	560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10	0	560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11	0	560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12	0	560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13	0	560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0	560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0	560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16	0	560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17	0	560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18	0	560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19	0	560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2	0	560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20	13	560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21	23	560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29	560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0A 	560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24	1A 	560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28	560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26	0	560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27	0	560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B 	560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B 	560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3	0	560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0	560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0	560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0	560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0	560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0	560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4	48	560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5	4C 	560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36	560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40	560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8	37	560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9	41	560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize 	560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize 	560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize 	560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize 	560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize 	560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize 	560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize 	560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize 	560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize 	560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize 	560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	maximize 	560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize 	560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	maximize 	560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	minimize 	560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	minimize 	560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize 	560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize 	560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize 	560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize 	560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize 	560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize 	560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize 	560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize 	560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	maximize 	560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize 	560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize 	560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize 	560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize 	560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize 	560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	minimize 	560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	minimize 	560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize 	560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize 	560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize 	560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize 	560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize 	560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize 	560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize 	560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize 	560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize 	560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize 	560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize 	560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize 	560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize 	560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize 	560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize 	560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize 	560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize 	560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize 	560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize 	560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize 	560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	maximize 	560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	maximize 	560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize 	560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize 	560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize 	560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize 	560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize 	560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize 	560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize 	560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize 	560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize 	560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize 	560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize 	560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize 	560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize 	560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize 	560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize 	560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize 	560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize 	560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize 	560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize 	560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize 	560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize 	560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize 	560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize 	560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize 	560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize 	560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize 	560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize 	560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize 	560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize 	560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	minimize 	560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize 	560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize 	560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize 	560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize 	560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize 	560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize 	560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize 	560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize 	560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize 	560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize 	560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	minimize 	560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize 	560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize 	560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize 	560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize 	560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize 	560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize 	560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize 	560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize 	560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize 	560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize 	560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize 	560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0	100	560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1	100	560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10	0	560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11	0	560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12	0	560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13	0	560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0	560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0	560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16	0	560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17	0	560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18	0	560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19	0	560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100	560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100	560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100	560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100	560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23	28	560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24	28	560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25	100	560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26	0	560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27	127	560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28	127	560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29	127	560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100	560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30	0	560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31	0	560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32	0	560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33	0	560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34	0	560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4	100	560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5	100	560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6	100	560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7	100	560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8	100	560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9	100	560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0	560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0	560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0	560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0	560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0	560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0	560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0	560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0	560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0	560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0	560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0	560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0	560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2	0	560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20	0	560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21	0	560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0	560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23	127	560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24	127	560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0	560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0	560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0	560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0	560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0	560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3	0	560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0	560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0	560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0	560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0	560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0	560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4	0	560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5	0	560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0	560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0	560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0	560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0	560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0	560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0	560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0	560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0	560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0	560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0	560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0	560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0	560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0	560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0	560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0	560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0	560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2	0	560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20	28	560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21	28	560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0	560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0	560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0	560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0	560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26	0	560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27	0	560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0	560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0	560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3	0	560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0	560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0	560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0	560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0	560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0	560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4	31	560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5	31	560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0	560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0	560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0	560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0	560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0	560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0	560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0	560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0	560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0	560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0	560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0	560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0	560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0	560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0	560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0	560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0	560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0	560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0	560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0	560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0	560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0	560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0	560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0	560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0	560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0	560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0	560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0	560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0	560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0	560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0	560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0	560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0	560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0	560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0	560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0	560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0	560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0	560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0	560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0	560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14	560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15	560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	0	560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	0	560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	0	560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	0	560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0	560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	0	560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0	560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	0	560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	0	560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	0	560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	45	560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	3D 	560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3E 	560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C 	560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	29	560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	2A 	560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30	560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	0	560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	47	560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31	560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32	560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	46	560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	0	560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	0	560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	0	560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	0	560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	0	560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	43	560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	44	560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A 	560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B 	560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	1C 	560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	1D 	560
    IDE05145-ENG115873-Light configuration-Lasttyp 0	14 - kombinierte Blink- Bremsleuchten 	560
    IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten 	560
    IDE05145-ENG116062-Light configuration-Lasttyp 10	not active 	560
    IDE05145-ENG116081-Light configuration-Lasttyp 11	not active 	560
    IDE05145-ENG116100-Light configuration-Lasttyp 12	not active 	560
    IDE05145-ENG116119-Light configuration-Lasttyp 13	not active 	560
    IDE05145-ENG116138-Light configuration-Lasttyp 14	not active 	560
    IDE05145-ENG116157-Light configuration-Lasttyp 15	not active 	560
    IDE05145-ENG116176-Light configuration-Lasttyp 16	not active 	560
    IDE05145-ENG116195-Light configuration-Lasttyp 17	not active 	560
    IDE05145-ENG116214-Light configuration-Lasttyp 18	not active 	560
    IDE05145-ENG116233-Light configuration-Lasttyp 19	not active 	560
    IDE05145-ENG115910-Light configuration-Lasttyp 2	not active 	560
    IDE05145-ENG116252-Light configuration-Lasttyp 20	34 - LED Bremsleuchten 	560
    IDE05145-ENG116271-Light configuration-Lasttyp 21	34 - LED Bremsleuchten 	560
    IDE05145-ENG116290-Light configuration-Lasttyp 22	42 - LED dritte Bremsleuchte 	560
    IDE05145-ENG116309-Light configuration-Lasttyp 23	33 - LED-Modul Blinkleuchten 	560
    IDE05145-ENG116328-Light configuration-Lasttyp 24	33 - LED-Modul Blinkleuchten 	560
    IDE05145-ENG116347-Light configuration-Lasttyp 25	18 - 2* 5W 	560
    IDE05145-ENG116366-Light configuration-Lasttyp 26	not active 	560
    IDE05145-ENG116385-Light configuration-Lasttyp 27	1 - LED Tagfahrlichtmodul Versorgung 	560
    IDE05145-ENG116404-Light configuration-Lasttyp 28	40 - allgemeine LED 	560
    IDE05145-ENG116423-Light configuration-Lasttyp 29	40 - allgemeine LED 	560
    IDE05145-ENG115929-Light configuration-Lasttyp 3	not active 	560
    IDE05145-ENG116442-Light configuration-Lasttyp 30	not active 	560
    IDE05145-ENG116461-Light configuration-Lasttyp 31	not active 	560
    IDE05145-ENG116480-Light configuration-Lasttyp 32	not active 	560
    IDE05145-ENG116499-Light configuration-Lasttyp 33	not active 	560
    IDE05145-ENG116518-Light configuration-Lasttyp 34	not active 	560
    IDE05145-ENG115948-Light configuration-Lasttyp 4	not active 	560
    IDE05145-ENG115967-Light configuration-Lasttyp 5	not active 	560
    IDE05145-ENG115986-Light configuration-Lasttyp 6	11 - Abblendlicht 	560
    IDE05145-ENG116005-Light configuration-Lasttyp 7	11 - Abblendlicht 	560
    IDE05145-ENG116024-Light configuration-Lasttyp 8	10 - allgemeine Scheinwerfer 	560
    IDE05145-ENG116043-Light configuration-Lasttyp 9	10 - allgemeine Scheinwerfer 	560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always 	560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always 	560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always 	560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always 	560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always 	560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always 	560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always 	560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always 	560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always 	560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always 	560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always 	560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always 	560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always 	560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always 	560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always 	560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always 	560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	Always 	560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	Always 	560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always 	560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	Always 	560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	Always 	560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	Always 	560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	Always 	560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always 	560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always 	560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always 	560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always 	560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always 	560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always 	560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always 	560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always 	560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always 	560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always 	560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always 	560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always 	560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0	560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	0	560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2	560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4	560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	0	560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	0	560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	0	560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	0	560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0	560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0	560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	0	560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	0	560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	0	560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	0	560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	8	560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24	560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24	560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24	560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	0	560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	0	560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8	560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	0	560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	8	560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	26	560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25	560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	8	560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	0	560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	0	560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	0	560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	0	560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	0	560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20	560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20	560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11	560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12	560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	13	560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	14	560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0	560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0	560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	0	560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	0	560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	0	560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	0	560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0	560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0	560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0	560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0	560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0	560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	0	560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0	560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0	560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0	560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	0	560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	0	560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	0	560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0	560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0	560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0	560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0	560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	0	560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0	560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0	560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0	560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0	560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0	560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0	560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0	560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	0	560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	0	560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	15	560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	15	560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	0	560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	0	560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0	560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0	560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	0	560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0	560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0	560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0	560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0	560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	0	560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	0	560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	0	560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	0	560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	0	560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0	560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	2	560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	4	560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0	560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0	560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0	560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0	560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0	560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	0	560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0	560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0	560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0	560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0	560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0	560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	6	560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	7	560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0	560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0	560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0	560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0	560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0	560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0	560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0	560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0	560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0	560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0	560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0	560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0	560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0	560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0	560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0	560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0	560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	0	560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	0	560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	0	560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0	560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	0	560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	0	560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0	560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0	560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0	560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0	560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0	560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	0	560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0	560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0	560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0	560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0	560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0	560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	0	560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	0	560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0	560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0	560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0	560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0	560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0	560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0	560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0	560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0	560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0	560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0	560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0	560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0	560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0	560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0	560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0	560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0	560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	0	560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	8	560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	8	560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0	560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	0	560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	0	560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0	560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	0	560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	0	560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0	560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0	560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	0	560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0	560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0	560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0	560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0	560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0	560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	8	560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	8	560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0	560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0	560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0	560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0	560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0	560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0	560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0	560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0	560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0	560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0	560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0	560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0	560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0	560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0	560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0	560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0	560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	0	560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0	560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0	560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0	560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0	560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0	560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0	560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0	560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0	560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0	560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0	560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0	560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0	560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0	560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0	560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0	560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	0	560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0	560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0	560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0	560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0	560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3	0	560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5	0	560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0	560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0	560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0	560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0	560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0	560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0	560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0	560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0	560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0	560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0	560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0	560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0	560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	3	560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0	560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0	560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0	560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0	560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0	560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0	560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0	560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0	560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0	560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0	560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	3	560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0	560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0	560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0	560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0	560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0	560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0	560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0	560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0	560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0	560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0	560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0	560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0	560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0	560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0	560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0	560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0	560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0	560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0	560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0	560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0	560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0	560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0	560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0	560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0	560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0	560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0	560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0	560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0	560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0	560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0	560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0	560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0	560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0	560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0	560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0	560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0	560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0	560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0	560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0	560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0	560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0	560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0	560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0	560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0	560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0	560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0	560
    IDE05145-ENG154438-Light configuration-Reserved 0	0	560
    IDE05145-ENG99841-Light configuration-Reserved 1	0	560
    IDE05145-ENG154357-Light configuration-Reserved 10	0	560
    IDE05145-ENG154352-Light configuration-Reserved 11	0	560
    IDE05145-ENG154182-Light configuration-Reserved 12	0	560
    IDE05145-ENG154265-Light configuration-Reserved 13	0	560
    IDE05145-ENG154334-Light configuration-Reserved 14	0	560
    IDE05145-ENG154340-Light configuration-Reserved 15	0	560
    IDE05145-ENG154204-Light configuration-Reserved 16	0	560
    IDE05145-ENG154344-Light configuration-Reserved 17	0	560
    IDE05145-ENG154195-Light configuration-Reserved 18	0	560
    IDE05145-ENG154190-Light configuration-Reserved 19	0	560
    IDE05145-ENG99862-Light configuration-Reserved 2	0	560
    IDE05145-ENG154300-Light configuration-Reserved 20	0	560
    IDE05145-ENG154439-Light configuration-Reserved 21	0	560
    IDE05145-ENG154440-Light configuration-Reserved 22	0	560
    IDE05145-ENG154441-Light configuration-Reserved 23	0	560
    IDE05145-ENG154442-Light configuration-Reserved 24	0	560
    IDE05145-ENG154443-Light configuration-Reserved 25	0	560
    IDE05145-ENG154444-Light configuration-Reserved 26	0	560
    IDE05145-ENG154445-Light configuration-Reserved 27	0	560
    IDE05145-ENG154446-Light configuration-Reserved 28	0	560
    IDE05145-ENG154447-Light configuration-Reserved 29	0	560
    IDE05145-ENG101107-Light configuration-Reserved 3	0	560
    IDE05145-ENG154448-Light configuration-Reserved 30	0	560
    IDE05145-ENG154449-Light configuration-Reserved 31	0	560
    IDE05145-ENG154450-Light configuration-Reserved 32	0	560
    IDE05145-ENG154451-Light configuration-Reserved 33	0	560
    IDE05145-ENG154452-Light configuration-Reserved 34	0	560
    IDE05145-ENG154267-Light configuration-Reserved 4	0	560
    IDE05145-ENG154291-Light configuration-Reserved 5	0	560
    IDE05145-ENG154239-Light configuration-Reserved 6	0	560
    IDE05145-ENG154308-Light configuration-Reserved 7	0	560
    IDE05145-ENG154184-Light configuration-Reserved 8	0	560
    IDE05145-ENG154255-Light configuration-Reserved 9	0	560
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	24
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	24
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C	24
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C	24
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C	24
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C	24
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	24
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	35.00 °C	24
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	24
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	35.00 °C	24
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	53.50 °C	24
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	52.50 °C	24
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	53.50 °C	24
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	52.50 °C	24
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active 	8
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active 	8
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active 	8
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active 	8
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active 	8
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100%	8
    IDE06425-Roller test bench mode: functional	not active 	1
    IDE06507-MAS13125-Button in center console-Function of button 1	Start-stop 	8
    IDE06507-MAS13129-Button in center console-Function of button 2	Luggage hold closure 	8
    IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
    IDE06507-MAS13135-Button in center console-Function of button 4	Steering wheel heater 	8
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights 	4
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	4
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	4
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active 	4
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active 	4
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active 	4
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	4
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active 	4
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	4
    IDE07356-Position during interval mode	31.49 °	2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit 	12
    IDE07470-ENG133381-After-run for park light-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	12
    IDE07470-ENG133380-After-run for park light-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	12
    IDE07470-ENG133382-After-run for park light-Faktor fuer Verfügbarkeitstimer	Faktor fuer x5 Minuten 	12
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	12
    IDE07470-ENG133383-After-run for park light-Standlicht-Verfügbarkeit	6 s	12
    IDE08542-IDE02021-Access control 2-Comfort closing	active 	8
    IDE08542-IDE02022-Access control 2-Comfort opening	not active 	8
    IDE08542-ENG128459-Access control 2-easycloselight_aktiv	not active 	8
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active 	8
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	not active 	8
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s	8
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active 	8
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active 	8
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active 	8
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	not active 	8
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by convenience operation via remote control key 	8
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	not active 	8
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	active 	8
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	not active 	8
    IDE08542-ENG115670-Access control 2-Komfortbedienung global	active 	8
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active 	8
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active 	8
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active 	8
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	active 	8
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	not active 	8
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active 	8
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	active 	8
    IDE08542-ENG125656-Access control 2-Regenschliessen_art	once 	8
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	not active 	8
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	not_active 	8
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active 	8
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active 	8
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	not active 	8
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting 	8
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	not active 	8
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	not active 	8
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	active 	8
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active 	8
    IDE08542-ENG133411-Access control 2-Spiegelanklappen_bei_Wiederverriegelung	not active 	8
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	not active 	8
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active 	8
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active 	8
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	0 ms	8
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	8
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active 	8
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis 	8
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	not active 	8
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms	8
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	sensitive 	8
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active 	8
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present 	8
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	8
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	not active 	8
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	not active 	8
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active 	2
    IDE08787-ENG101416-Auxiliary functions-Reserved_1	not active 	2
    IDE08787-ENG99458-Auxiliary functions-Reserved_2	not active 	2
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active 	2
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	2
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	2
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active 	4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active 	4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active 	4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active 	4
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken	not active 	4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active 	4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active 	4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active 	4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active 	4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active 	4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active 	4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active 	4
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active 	4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active 	4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active 	4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active 	4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active 	4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active 	4
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	20
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	20
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	20
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	20
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1	225	20
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2	225	20
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3	225	20
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%	20
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2	20
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%	20
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1	225	20
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2	225	20
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3	225	20
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	20
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active 	20
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	20
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	20
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1	225	20
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2	225	20
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3	225	20
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	active 	20
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	20
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	2
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed 	2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	2
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	2
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	not installed 	2
    IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	2
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	2
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	12
    IDE10298-Alternating park position 1	7.49 °	2
    IDE10299-Alternating park position 2	29.49 °	2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	64	256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	64	256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0	256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	64	256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	64	256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	64	256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	64	256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0	256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	0%	256
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	0%	256
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	0%	256
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	0%	256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	0%	256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	0%	256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	0%	256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	0%	256
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	0%	256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	0%	256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	0%	256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	0%	256
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	0%	256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	0%	256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	0%	256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	0%	256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	0%	256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	0%	256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	0 ms	256
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0 s	256
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0 s	256
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0 s	256
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0 s	256
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0 s	256
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0 s	256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0 s	256
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0 s	256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	0 s	256
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0 s	256
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0 s	256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0 s	256
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0 s	256
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0 s	256
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0 s	256
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0 s	256
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0 s	256
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0 s	256
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0 s	256
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0 s	256
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0 s	256
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0 s	256
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0 s	256
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0 s	256
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0 s	256
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0 s	256
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0 s	256
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0 s	256
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0 s	256
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0 s	256
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0 s	256
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0 s	256
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0 s	256
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0 s	256
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0 s	256
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0 s	256
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0 s	256
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0 s	256
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0 s	256
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0 s	256
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0 s	256
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0 s	256
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	E1 	30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	E1 	30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	E1 	30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	E1 	30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	E1 	30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	E1 	30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	E1 	30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	E1 	30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	E1 	30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	E1 	30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	E1 	30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	E1 	30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	E1 	30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	E1 	30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	E1 	30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	E1 	30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	E1 	30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	E1 	30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	E1 	30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	E1 	30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	E1 	30
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	1
    MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	1
    MAS05055-lower turn position	31.49 °	2
    MAS05056-upper turn position	170.49 °	2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active 	8
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active 	8
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active 	8
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active 	8
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active 	8
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active 	8
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	8
    MAS05934-ENG133391-Convert. top oper.-Remote Lock Unlock Timer s1	0 s	8
    MAS05934-ENG133392-Convert. top oper.-Remote Lock Unlock Timer s3	0.000 ms	8
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active 	8
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active 	8
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active 	8
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active 	8
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active 	8
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active 	8
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active 	8
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active 	8
    MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	60 lx	24
    MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	110 lx	24
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	1000 lx	24
    MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	30 lx	24
    MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	60 lx	24
    MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	110 lx	24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	80	24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	100 lx	24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	4500 mV	24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	300 lx	24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	2000 mV	24
    MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door 	30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
    ENG126647-ENG98399-debug_light_function-Activation	0	11
    ENG126647-ENG101417-debug_light_function-Adresse	0	11
    ENG126647-ENG126820-debug_light_function-Bitmask	0	11
    ENG126647-ENG126821-debug_light_function-Divisor	0	11
    ENG126647-ENG98827-debug_light_function-Offset	0	11
    ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe	0	11
    ENG99457-ENG117394-Head area heater-blower_speed	1	2
    ENG99457-ENG98971-Head area heater-Temperature	-2	2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms	22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms	22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms	22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms	22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms	22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms	22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms	22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms	22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms	22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms	22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms	22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%	22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00%	22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%	22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00%	22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.00%	22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.00%	22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.00%	22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.00%	22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.00%	22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.00%	22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.00%	22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0	22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50	22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0	22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100	22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200	22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253	22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0	22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0	22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0	22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0	22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0	22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx	22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx	22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx	22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx	22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200	22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500	22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0	22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx	22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx	22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx	22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx	22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms	22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms	22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms	22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms	22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms	22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms	22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms	22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms	22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms	22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms	22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms	22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%	22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%	22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%	22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%	22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%	22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%	22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%	22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%	22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%	22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%	22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%	22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%	12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%	12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%	12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%	12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%	12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%	12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10	12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10	12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100	12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150	12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220	12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253	12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx	10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx	10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx	10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx	10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx	10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16	10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16	10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100	10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100	10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100	10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx	10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx	10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx	10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx	10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx	10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6	10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6	10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100	10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100	10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100	10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0	12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10	12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50	12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100	12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220	12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253	12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	2.00%	12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	2.00%	12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	6.00%	12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	10.00%	12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	80.00%	12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%	12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx	8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx	8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx	8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx	8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100	8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100	8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100	8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100	8
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx	8
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx	8
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx	8
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx	8
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6	8
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6	8
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100	8
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100	8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%	6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%	6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%	6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%	6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%	6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%	6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx	8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx	8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx	8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx	8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100	8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100	8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100	8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100	8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx	8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx	8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx	8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx	8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6	8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6	8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100	8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100	8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%	6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%	6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%	6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%	6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%	6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%	6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms	10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	100 ms	10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	160 ms	10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	200 ms	10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	260 ms	10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%	10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5	10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15	10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	10	10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100	10
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	14 - kombinierte Blink- Bremsleuchten 	16
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	0	16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	0	16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	0	16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	not active 	16
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	not active 	16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active 	16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	0	16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	0	16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	0	16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	not active 	16
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	not active 	16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active 	16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize 	16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize 	16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize 	16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0	16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0	16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0	16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0	16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0	16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0	16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active 	16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always 	16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	not active 	16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	not active 	16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	not active 	16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	not active 	16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	not active 	16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	not active 	16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	not active 	16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	not active 	16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0	16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0	16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active 	16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active 	16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0	16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0	16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active 	16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active 	16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	0	16
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0	16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	0	16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	not active 	16
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	not active 	16
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	0	16
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0	16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	0	16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	not active 	16
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	not active 	16
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten 	16
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize 	16
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	28	16
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	34 - LED Bremsleuchten 	16
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active 	16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	not active 	16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize 	16
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	28	16
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	34 - LED Bremsleuchten 	16
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active 	16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	not active 	16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100	16
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active 	16
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	28	16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	127	16
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	33 - LED-Modul Blinkleuchten 	16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	not active 	16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active 	16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Blinken links Hellphase 	16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	28	16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	127	16
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	33 - LED-Modul Blinkleuchten 	16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	not active 	16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active 	16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Blinken rechts Hellphase 	16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	100	16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	18 - 2* 5W 	16
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	0	16
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	0	16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0	16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	not active 	16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	not active 	16
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	127	16
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	47	16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0	16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	1 - LED Tagfahrlichtmodul Versorgung 	16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	40 - allgemeine LED 	16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	40 - allgemeine LED 	16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize 	16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	minimize 	16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0	16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0	16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	45	16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	0	16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	not active 	16
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	not active 	16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active 	16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active 	16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active 	16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	Blinken links Dunkelphase 	16
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	0	16
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	0	16
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	not active 	16
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	not active 	16
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize 	16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	minimize 	16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0	16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0	16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	46	16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	0	16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	not active 	16
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	not active 	16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active 	16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active 	16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active 	16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	Blinken links Dunkelphase 	16
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize 	16
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	100	16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	31	16
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	43	16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	48	16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	not active 	16
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen) 	16
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active 	16
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize 	16
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	100	16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	31	16
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	44	16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	4C 	16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	not active 	16
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen) 	16
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active 	16
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht 	16
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht 	16
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C 	16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	10 - allgemeine Scheinwerfer 	16
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam 	16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell 	16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active 	16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D 	16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	10 - allgemeine Scheinwerfer 	16
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam 	16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell 	16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active 	16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize 	16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize 	16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize 	16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0	16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0	16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0	16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0	16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0	16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0	16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active 	16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always 	16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	not active 	16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	not active 	16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	not active 	16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	not active 	16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	not active 	16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	not active 	16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	not active 	16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	not active 	16
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	active 	1
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	active 	1
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	active 	1
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	active 	1
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	active 	1
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	active 	1
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
    ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	active 	16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active 	16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG133403-Personalization-PSO_FSG_Setup2_Bit_0	active 	16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	active 	16
    ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	active 	16
    ENG98831-ENG133408-Personalization-PSO_FSG_Setup2_Bit_5	active 	16
    ENG98831-ENG133409-Personalization-PSO_FSG_Setup2_Bit_6	active 	16
    ENG98831-ENG133410-Personalization-PSO_FSG_Setup2_Bit_7	active 	16
    ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
    ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung	active 	8
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
    Elapsed Time: 01:57
  14. #19
    Oct 2018
    Canada
    Update! Back up camera works! Thank you Thank you Thank you. Is it possible to have the rear fog light work with the light switch? I bought the switch with the front fog lights and rear fog light, but it works all the time. Thoughts?
  15. Likes Uwe, Jack@European_Parts, downtime liked this post
  16. #20
    May 2017
    Don, that's how it was set on one of the many many many adamaps I have from different cars Usually backup light is only on one side. At least on EURO spec lights. Same goes for the fog light.
    And according to the link the OP posted taking you to ECS tuning where he bought the lights from, all the lights look to be LEDs.
    And what's more interesting is that according to ECS tunings coding instructions, they state that from mid 2015 onwards the fog light has moved from Leuchte 26 to Leuchte27.
    His Leuchte27 function is now :
    If that is fog light then it means that it is constantly on. So instead of changing the leuchte28 just yet, why not first change the lichtfunction to this one for leuchte27:
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	 Nebelschlusslicht wenn kein Anhaenger gesteckt
    I'm 100% sure that it will put the fog light out of it's misery
    If it really is the case that there's a parking light also on the left side. Then change the leuchte28 lichtfunction to this one as Don stated already :
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
    And sorry Don for jumping on the subject.
  17. Likes Uwe liked this post
