Results 11 to 20 of 25
Thread: update 14.10.0 ?
    Quote Originally Posted by jakematic View Post
    Have run into the same thing with shortcuts - got ultra confused on this update versus the beta that was still installed
    Confused how? Betas and releases install in different folders by default. A beta shouldn't interfere with an existing release installation, and a new release installation shouldn't interfere with an existing beta installation.
    NC USA
    The first thing I do is delete all the shortcuts.
    In Win8.1 it's easier to let it make them, which is not my SOP, because it puts tiles on the Start pane.
    However I had manually put the Beta there, and after the update clicked the shortcut and 14.9 showed up.
    Swapped the tiles and all was good.
    On the upside the auto-update popup isn't showing only on Start for the other screen when using RDP
  3. #13
    I guess I'll have to fiddle with 8.1 on the Venue at some point to see if I can reproduce that -- after I get back. ;-)
    Jul 2014
    Yorkshire
    hmmmmm............. contemplating a full uninstall & re-install as the previous version seemed a little better but not as it was, seemed laggy & unresponsive at times & after carrying out basic settings i had to cycle the ignition because it knocked boost control out (was basic settings 120), could this be the firmware update as before it was perfect ??
  5. #15
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Robski View Post
    Anything is possible, but if the FW update broke things, I would think there would be more complaints on the forum. It's been in the Betas for a couple months, and the older 12.12.3 release for several weeks. I've used my HUC interface with at least three cars, one CAN and two K-line without incident, and I'm on Windows 8.1 as well. Also, from what I understand, the FW update was issued primarily to fix a very specific K-line comms bug that shouldn't affect your CAN-based vehicle.
    I know it's not what you want to hear, but it seems likely to be something localized to your workstation. Did anything change there? Anything that hogs CPU, like a virus scanner, or anything that messes with power management/CPU state can affect the real-time responsiveness needed by the vehicle diagnostic protocols. If you were running on battery, if possible, try doing a scan with your laptop plugged into AC power from your house/garage. It can help prevent the CPU from aggressively throttling down to save power. My laptop definitely does better on AC power.
    Jason
  6. Likes Eric, Uwe liked this post
  7. #16
    Jul 2014
    Yorkshire
    Jason
    Jason thanks for the reply, I have installed the latest version on another hard drive to give it a try.Nothing has changed (not by me anyway) before the update & firmware update, so I will see how it goes now ?
  8. #17
    Stoke on Trent, England
    Well when I had Win8.0 I installed Classic Shell because I hated having no Start button.
    New User Keith
  9. #18
    NC USA
    One thing I have noticed is Windows Defender goes a little crazy for some time after installing any new program or updates.
    Robski- I presume you didn't install the update and immediately try to use it? Keep us posted.
  10. #19
    Jul 2014
    Yorkshire
    No Jake I didn't try right away, I don't have windows defender running neither, I will keep you posted when I next use it
  11. #20
    Jul 2014
    Yorkshire
    It's been a while as I've not had much in the way of the VAG range.......... BUT on a 2005 Skoda Superb 2.5 TDI (EDC15) today it was very laggy & when trying to clear DTC's in 01 i was getting an error warning saying the module won't allow me to clear (did in OBD-II), also laggy going through MVB's, the egg timer was hanging about with the cursor & when closing VCDS down it went away. I am really wishing I never updated & left it at vers 12.X.X.
    Is there another update due out anytime soon as my user experience isn't what it used to be & my trust of the tool is wearing thin ?
    EDIT: this is another HDD to when I first opened this thread.
