Results 1 to 2 of 2
Thread: Audi A6 C7 Facelift Saloon rear camera retro fit coding
    Sep 2018
    Ireland
    Hi
    I got the kufatec kit for the RVC for >2015 C7, mine is a 2017. I did the wiring and camera install and then used their dongle, but no dice there is no picture only the sensor information.
    Scan below, I'm getting a 5F coding error which is only since using the dongle, any advice on what I am missing.
    I thought the dongle would do the required coding but it doesnt look like it to me.
    I've contacted kufatec but its driving me mad as I've traced all the wiring which looks good so it must be coding.
    Dave N
    Sunday,07,October,2018,12:24:05:21606
    VCDS Version: 18.9.0.2 (x64)
    VIN: WAUZZZ4GXHN088186   License Plate: 171
    Mileage: 27700km-17211mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
              5F 62 72 AC
    VIN: WAUZZZ4GXHN088186   Mileage: 27700km-17211miles
    Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
       Component: R4 2.0l TDI   H20 3830
       Revision: 8DH20---
       Coding: 0A254012242401080000
       ASAM Dataset: EV_ECM20TDI01104L906021HA 004003
       ROD: EV_ECM20TDI01104L906021HA_004.rod
       VCID: 6BDFE8AB82D1961210-803E
       Part No SW: 4G1 927 153 B    HW: 0CJ 927 156
       Component: 0CK 20TDI RdW H03 0004
       Revision: --H03---    Serial number: 0000001066
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002024
       ROD: EV_TCMDL382021_AU57.rod
       VCID: 2953D2A348AD4402A2-807C
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  002 0572
       Serial number: 75117071160363001574
       Coding: 06A29E41604579829B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41836A03D0DDAC429A-8014
       Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
       Component: BCM2 2.0      H61 0825
       Coding: 01B8704E000000000000
       VCID: 7CFDDBF7FFBF01AA89-8028
       Serial number: 3216000310830004
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Serial number: 10011700041460
       Coding: 34210978210000
       VCID: 63CF808B6A01DE52A8-8036
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0368
       Revision: 15020001    Serial number: 00001560597301
       Coding: 0105001440349FE041014083800018004F9DC3082F08020100000894E100140200400024030000
       VCID: 74EDF3D7D7EF49EAC1-8020
       Component: WWS57X 161106  H38 0080
       Serial number:         161118210045
       Coding: 004DF7
       Serial number: 20055425X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 11 01 2017  00000991
       Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: 7668426800PAG0MUFU03
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0092
       Revision: --------    Serial number: 003P100CC86O
       Coding: 30333130313630323639554A305234473053
       VCID: 3B7F18EBB231C692C0-806E
       Serial number: 3575HRB405N492DA7OOS
       Serial number: 3585HRB405P480GQEGP4
       Serial number: 3515JRB400257HS4LGSV
       Serial number: 3525JRB400257HS4F28Z
       Serial number: 3554VRB400A57J2CJ8BB
       Serial number: 3564VRB400A57J2CL9MQ
       Revision: C0068538    Serial number: 91560QA3001OD
       Coding: 000034
       VCID: 3B7F18EBBA31C692C0-806E
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Serial number: 09 01 2017  D0004873
       Part No SW: 4G8 920 987 R    HW: 4G8 920 987 R
       Component: TDieGb        H15 0225
       Revision: 15001308    Serial number: 658131216596000
       Coding: 33AF0D000B410008010000
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K.rod
       VCID: 48957727F3E79D0A5D-801C
       Part No SW: 4G8 907 468 H    HW: 4G8 907 468
       Component: J533--Gateway H15 0096
       Revision: --------    Serial number: 00000002488565
       Coding: C0CD074418
       VCID: 3D7B16F3AC25C8A2FE-8068
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 4087662504
       Voltage stabilizer:
       Serial number: 16070500000000000796
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04028264747464545425363E00
       VCID: 67D7949B9639B27274-8032
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0113
       Serial number: 17011700040604
       Coding: 22
       Revision: AA000000    Serial number: 00000226698609
       VCID: 77F7C4DBC69922F2E4-8022
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA720UVBF4
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 336F30CB9A610ED218-8066
       Coding: 011C16015E01620002080002
       VCID: 4797741BF6F9927254-8012
       Component: RCevo         H54 0202
       Revision: 00000002    Serial number: 0000537238
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A711DEFBD0BFF9ADB-806E
       Revision: 00002001    Serial number: 0428730909
       Coding: 011B062280B90080C320088400010E470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 B
       Component: Sensor, DWA  005 0002
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00027728635
       VCID: 4689791FF1F38B7AAF-8012
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002062700
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 326135CF657B07DA13-8066
       Coding: 04FE02102A630200
       VCID: 346D33D79F6F09EA01-8060
       Coding: E01E00
       Coding: E01E00
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 021 G    HW: 4G1 035 021 D
       Component: MU-H-LND-EU   053 0910
       Serial number: A733A0H7531579
       Coding: 017501010000000013111102000A00332F0006E7F1700100DF
       VCID: 1E39F17F01E3B3BAC7-804A
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9GY806V42
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
       Serial number: 90349QAG000C5
       Component: Gracenote2  --- 1015
    7179 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 199
                        Mileage: 27700 km
                        Date: 2018.10.07
                        Time: 12:17:43
                        Voltage terminal 30: 11.7 V
                        BAP-BAP_Function_ID: 02
       VCID: 49937223E0ED640242-801C
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 163200969
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F673CBB76492A327C-807A
    End-------------------------(Elapsed Time: 04:55)--------------------------
    Sep 2018
    Ireland
    Issue resolved, the Kufatec module does not so all the coding. All working with some additional VCDS coding
