Results 1 to 2 of 2
Thread: CVT to Tiptronic programming issues
    Oct 2018
    Good day to everyone. I am having issues with a 2010 Audi a4 2.0. The car was purchased 6 months ago with a bad CVT transmission. The bad transmission was removed and a 2013 8 speed tiptronic and rear differential was installed, converting it into a Quattro. A 2015 engine was also installed at the same time. The car was taken to a local Audi dealership to have the transmission programmed to the car. After much ado, the technician told me that I needed to buy a new ECU that matches the engine/ transmission combination that was installed. A new ECU was installed and the dealership still could not program the transmission, saying the car kept rejecting all that they tried. The car was returned to me and the 8 speed automatic transmission was removed and a 2010 6 speed tiptronic transmission (LML) was installed with its matching rear differential. The car was taken back to the Audi dealership and after many failed attempts at programming, they removed all the computers from the car and installed them in a known “good“ car of same year to have the test car program the computers. No help. As they tell me, their equipment still indicates that all the programming is incorrect for the car. The dealership also said that Audi Corporate won’t release the source coding to them to aid in programing the computers. Sounds like they have no idea how to program a car that didn’t come straight off the assembly line, but I have really have no idea. A copy of the latest scan done on the car is shown below. There are no copies of previous scans done before the modifications from original with CVT transmission. Looking for anyone’s help on how to get this car to accept all of the modifications done to it. I have searched this and different forums and the internet looking for information, but so far has been no help. I am sure this isn’t the first time that an Audi has been modified from original. Thank you for any help or direction that can be offered.
    Saturday,06,October,2018,11:42:30:51825
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WAUAFAFL1AN046853   License Plate: 10_06_2018
    Mileage: 199160km-123752mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 72 77
    VIN: WAUAFAFL1AN046853   Mileage: 199160km-123752miles
    2E-Media Player 3 -- Status: Sporadic communication error 1000
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H16 0001
       Revision: E1H16---
       Coding: 0104010A02070160
       Shop #: WSC 48649 001 1048576
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79ACE52DC955F5DFD9B-802C
              U1113 00 [032] - -
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:21:59
                        Engine speed: 727.50 /min
                        Normed load value: 13.7 %
                        Vehicle speed: 255 km/h
                        Coolant temperature: 52 °C
                        Intake air temperature: 22 °C
                        Voltage terminal 30: 13.735 V
              U1113 00 [032] - -
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:21:59
    7021 - MIL Request Signal Active (Check TCM for errors too!)
              P1624 00 [047] - -
                        Mileage: 199160 km
                        Date: 2018.10.04
                        Time: 11:28:01
                        Engine speed: 1169.50 /min
                        Normed load value: 23.9 %
                        Coolant temperature: 11 °C
                        Intake air temperature: 13 °C
                        Voltage terminal 30: 12.910 V
    4201 - Fuel Level too Low
              P1250 00 [047] - -
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:20:29
                        Engine speed: 1200.00 /min
                        Normed load value: 25.9 %
                        Coolant temperature: 30 °C
                        Intake air temperature: 21 °C
                        Unlearning counter according OBD: 0
    4278 - Implausible Data Received from ABS Control Module
              U0415 00 [032] - -
              [Invalid Data Received FromAnti-Lock Brake System Control Module]
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:22:00
                        Engine speed: 726.50 /min
    Readiness: 1010 0101
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 J    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0003
       Revision: --H04---
       Coding: 001012
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_TCMAL651 A01006
       ROD: EV_TCMAL651.rod
       VCID: 3D24313D9DFD09FFB53-8068
    2501 - Transmission Control Module
              P0614 00 [175] - Incorrect Software Version
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 08:58:48
                        Transmission input speed: 0 /min
                        Transmission output speed: 0 /min
                        Engine torque: 0 Nm
                        Transmission fluid temperature: 22 °C
                        Accelerator position: 0.0 %
                        Clutch status: 0
       Part No SW: 8K0 907 379 BT    HW: 8K0 907 379 BT
       Component: ESP8 front    H04 0010
       Coding: 080D10
       Shop #: WSC 02391 823 56573
       VCID: 0C42ACF99647F077F2D-8058
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 187
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 09:00:51
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0027
                        Hex Value: 0x248F
                        Hex Value: 0x00FF
    00597 - Wheel Speed Impulses; Deviation
                003 - Mechanical Failure - Intermittent - MIL ON
                        Fault Status: 10100011
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:21:59
                        Hex Value: 0x0400
                        Hex Value: 0x4082
                        Hex Value: 0x020A
                        Hex Value: 0x75AD
                        Hex Value: 0x00FF
                        Fault Status: 00101101
                        Reset counter: 227
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:22:00
                        Hex Value: 0x0000
                        Hex Value: 0x4782
                        Hex Value: 0x0232
                        Hex Value: 0x02AC
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 DF    HW: 8K0 907 064 DF
       Component: BCM2 1.1      H02 0327
       Coding: 090100
       Shop #: WSC 02399 823 56573
       VCID: 77A8E315FFC1E3AFAFF-8022
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Serial number: 0510000001567011
       Serial number: 0210000000272016
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:22:04
       Part No SW: 8T1 820 043 AM    HW: 8T1 820 043 AM
       Component: KLIMA 1 ZONE  H08 0171
       Revision: A0000000    Serial number: 01160120101954
       Coding: 64002000
       VCID: 7CA2FC39C6E7C0F7C2D-8028
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:21:59
       Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
       Component: BCM1 1.0      H25 0380
       Revision: 09025001    Serial number: 00000000427204
       Coding: 690000B1063C00010000080000007F5F0F14520800000021000000
       VCID: 3A2E3A218C533EC7901-806E
       Component: WWS 160110  H06 0070
       Serial number: SWF10010165551
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002112090321
       Subsystem 3 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:22:00
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EGD05E4VE
       Coding: 303836354230303030304A55304C384B3053
       Shop #: WSC 02135 785 00200
       VCID: 42DE42C1E4037607C81-8016
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R0900005A83
       Serial number: 6334MSME4E0107155
       Serial number: 6344MSME4F324E7F
       Serial number: 6352QSME6F4B1706R
       Serial number: 6362QSME114C23304
       Serial number: 63732SME4B4A0332-
       Serial number: 63832SME5B4A15340
    9483008 - Seat Occupied Recognition
              B10B3 00 [008] - Function Restriction due to Implausible Message(s)
              [Bladder Mat: functional restriction because of message unplausible]
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:22:15
       Revision: --------    Serial number: 90304JAH00021
       Coding: 000014
       VCID: 3D24313D9D7D09FFB53-8068
       Component: E221 - MFL  H02 0010
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:21:59
       Part No SW: 8K0 920 950 E    HW: 8K0 920 950 E
       Component: KOMBIINSTR.   H20 0255
       Revision: 00100000    Serial number: CIM22HA1A
       Coding: 8B1209000300D705020000
       VCID: 313C1D0D5125FD9F21B-8064
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G101118139
       Coding: 00C303
       VCID: 50FA78893AEF94974E5-8004
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 10000D2B070110
    02078 - Media Player Position 3 (R120)
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 08:58:49
                        Bin. Bits:    10111
                        Voltage: 11.50 V
                        Count: 6
                        Bin. Bits:    10000
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 09:33:22
                        Bin. Bits:    00000
                        Voltage: 11.90 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.40 s
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0280
       Revision: 00000000
       Coding: 020302
       VCID: 392C252D895535DF99B-806C
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009902738
       Coding: 011C03204000410001
       VCID: 45D459DDF5AD413FED3-8010
       Revision: 00002001    Serial number: 0125694671
       Coding: 0106023A007A400400B0013200000000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000208835
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS037  H06 0041
    01134 - Alarm Horn (H12)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 186
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 08:58:47
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:22:04
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2200000
       Coding: 0203010102
       VCID: 74B2D419EEB788B78AD-8020
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009933014
       VCID: 44D244D9FE977837FAD-8010
       Revision: 00000003    Serial number: 00000000541236
       VCID: 34321419AE37C8B74AD-8060
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:22:00
                        Voltage: 13.90 V
                        Count: 62
                        Hex Value: 0x0260
                        Hex Value: 0x0082
                        Hex Value: 0x0101
                        Reset counter: 226
                        Mileage: 199160 km
                        Date: 2018.09.28
                        Time: 10:22:16
                        Voltage: 13.90 V
                        Count: 80
                        Hex Value: 0x0270
                        Hex Value: 0x0082
                        Hex Value: 0x0101
    End----------(Elapsed Time: 01:44, VBatt start/end: 14.7V/14.7V)-----------
    Quote Originally Posted by Jim3010 View Post
    Right, the programming in these cars is pretty dang complicated, which makes it somewhere between difficult and impossible to mix and match parts like you've done.
