Hi guys anyone know the coding or even if it can be done where when I’m in D on the auto gear box it also shows what number im in like when you select S it tells you
Cheers Matt
Cheers Matt
VIN: WAUZZZ8K2AA109768 License Plate: JK04MAT
Mileage: 138460km-86035mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72
77
VIN: WAUZZZ8K2AA109768 Mileage: 138460km-86035miles
Address 01: Engine (J623-CAGA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 022 MK HW: 03L 906 022 B
Component: R4 2.0l TDI H03 9981
Revision: 11H03---
Coding: 0104002C02072120
Shop #: WSC 52502 002 1048576
ASAM Dataset: EV_ECM20TDI03L906022MK A01016
ROD: EV_ECM20TDI03L906022C.rod
VCID: 7AADF1B74C53A1573F0-802E
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K0 927 155 AF HW: 0AW 927 156 H
Component: 0AW 20TDI RdW H04 0007
Revision: --H04--- Serial number: 0000000684
Coding: 000002
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMVL381 A02006
ROD: EV_TCMVL381.rod
VCID: 77ABE8837F41BC3F40E-8022
Part No SW: 8K0 907 379 AK HW: 8K0 907 379 AK
Component: ESP8 front H04 0070
Coding: 170500
VCID: 025D89572403E997670-8056
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0327
Coding: 011200
VCID: 015F865B2105F28F7EA-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000073087012
Component: J764 ELV MLB H37 0042
Serial number: 0209000100182007
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01151220090358
Coding: 34040000
VCID: 76B5E58778CBC5375B8-8022
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000538272
Coding: 260050914034AF010001000000001D0D001D470800010141000000
VCID: 3A2D31B70C5361577F0-806E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 091008 H05 0070
Serial number: SWF08100090531
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10713876
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000512091290
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39990932200105
Coding: 100103
Shop #: WSC 06335 123 12345
VCID: 3E253DA7107B4D77438-806A
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD08CDD5
Coding: 30363435363030303030554A3052384B3053
VCID: 41DF465B6105328F3EA-8014
Serial number: 6334MSME4D42540BG
Serial number: 6344MSME4D430579J
Serial number: 6352QSME39482138F
Serial number: 6362QSME34480A3AK
Serial number: 63732SME31482E3A1
Serial number: 63832SME3148442E/
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319ILE000AH
Coding: 000037
VCID: 3D273AAB1D7D566F5A2-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 N HW: 8K0 920 980 N
Component: KOMBIINSTR. H20 0255
Revision: 00100000 Serial number: CIZ58ZFD9
Coding: 2F0F100002002600010000
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G09C0982D6
Coding: 00C303
VCID: 50F9731FBAEFCB07A14-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1909FB12021209
Reset counter: 1
Mileage: 138426 km
Date: 2018.09.23
Time: 18:47:12
Bin. Bits: 10000
Voltage: 12.20 V
Count: 16
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000102522562
Coding: 011002204001410001
VCID: 47CB58434FA10CBFF0E-8012
Revision: 00002001 Serial number: 0124837903
Coding: 013B0622203904000020023280000000
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F3B10E3C711B4FFD8E-807A
Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
Component: TSG BF H11 0306
Revision: Serial number: 0000102541394
VCID: 46D5554748AB15B70B8-8012
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000397315
VCID: 34311F8F2E379727A5C-8060
Part No: 8K5 907 357
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 77ABE88373C1BC3F40E-8022
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 195 AA HW: 8T2 035 195 AA
Component: Symphony3 H04 0310
Revision: 00000007 Serial number: AUZ5Z4I1163640
Coding: 0502008201028D00035B070000
VCID: 77ABE8837FC1BC3F40E-8022
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
03138 - Input AUX IN
Reset counter: 206
Mileage: 138186 km
Date: 2018.09.18
Time: 17:52:46
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102533325
Coding: 010002204001210001
VCID: 42DD495764832997270-8016
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102533328
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005145707
Coding: 0010320
VCID: 3B2334B30F69585F646-806E
End----------(Elapsed Time: 01:35, VBatt start/end: 13.2V/14.1V)-----------
What do you mean "nothing comes up"?I have had a look at the auto trans then adaptions but when I select single gear display nothing comes up also don't know the security code
Looks to me like your TCM doesn't support that feature.
Same year doesn't mean the same version modules, they are often changed mid year.Ok cheers pretty sure I read the same year cars have been done not the end of the world but would be nice
And software versions change at random, unpredictable intervals.Same year doesn't mean the same version modules, they are often changed mid year.
If VAG have changed the software and it's not included in the software any more then there's no coding or adaptation changes that can make the software do something that isn't included any more.Anyway to code it back in maybe ??
