Results 1 to 10 of 10
Thread: Arl pd150 cant rev past 4k after cambelt change
    New User
    Oct 2018
    Arl pd150
    Hey guys really hope someone can help. So after completing a water pump and cambelt change the engine is having not behaving it's starts up first time every time idle is near dead steady...the symptoms are in 1st and 2nd generally drives alright not great but alright how ever loses revs after 3k and maxes at 4k, sometimes on start up even after a lengthy drive it drives perfect but then shit......in 3rd is fine again not as it should be but fine driving round town but when i put my foot down until 3k revs you feel like it lurches, after 3k revs power drops and barely climbs to 4k....when entering motorway this lack of power then throws it into limp mode....so to be clear the symptoms I've described are all the time, and limp mode when really pushing it.
    Triple checked timing and checked again.
    No errors logged in vcds...only after limp mode
    Torsion value 0.5
    Injector deviations within tolerance all between -1.5 - +1.5
    Bench tested injector loom
    Checked vacuum to actuator (25hg)
    Vanes moves freely
    Actuator looks like it holds
    Tested maf with 2 known working sensors.(car drives slightly better unplugged altogether)
    95% sure there's no boost leak have check all pipes
    Boost gauge can read upto 20psi until said power drop and then drops to 15...sometimes it holds at 20 but still no power at all.
    Have changed fuel filter, which has smoothed out the lurching but still not full power or full revs.
    And zero black smoke
    Plan to test map sensor today and maybe cam sensor...but other than than I'm complete lost as to what has gone wrong. Any help would be greatly appreciated. Tia
    Hi and welcome to our forum.
    Please post an Auto-Scan for context, even if there are no fault codes.
    New User
    Oct 2018
    Hi and thank you, hopefully I can get this sorted before going scrappy haha. Okay no problem I'll post auto scan tomorrow. Cheers
    Sep 2017
    Croatia
    What errors do you have after limp mode?
    New User
    Oct 2018
    Can't remeber the code number but was negative deviation boost. Can't find me cable at the moment so struggling a little bit more than usual.
    Quote Originally Posted by rukil View Post
    VCDS saves the Auto-Scan results on the PC hard disk so you could find the last scan and post it without needing the cable.
  7. Likes Uwe liked this post
    New User
    Oct 2018
    Right so I have an update guys!!...it isn't the timing belt after all.. pure coincidence that the lift pump decided to fail...or at least an aspect of the lift pump...swapped out for a second hand pump...and it drove oh so much better no lurching and no rev walls....but I don't get very far as it keeps cutting out on me...I've had to jump my car like 8 times today to prime the damn thing...is this another fucked pump or is there a relay I should be looking at? At least I'm heading in the right direction. Cheers
  9. Likes Uwe, jyoung8607 liked this post
  10. #8
    May 2016
    Curios STFT and LT, when happens.
    Probably on the right track but if trim on log goes up radically when if falls on its face, the ECM is calling for fuel and is not getting it if there is no smoke. Also if injector time goes up is indicative of wanting fuel, all indicative of pump related.
    Boost wound obviously drop as it takes fuel to make boost. Check any fuel filters ECT, might be simple.
    LARIMORE
  11. #9
    New User
    Oct 2018
    Sorry don't understand STFT and LT.
    Well I've tried 3 different in tank pumps now all sound like they're priming fine...is it different wiring to prime the tank than it is for ecm to control the pump? Found a larger fuse where a smaller one where fuel pump should be...starting to think burnt out wires....when priming the the line should there be a return flow after the tandem pump?
    Yeah guessed thats why boost dropped with it. Replaced fuel filter still the same result, and the ect was new from vw couple months ago.
  12. #10
    Jul 2014
    Yorkshire
    Short Term Fuel Trim & Long Term................ BUT on a diesel
    In short pal don't waste your time !
  13. Likes Trade Member liked this post
