Results 1 to 10 of 14
Thread: Audi A3 8P1 Cruise Control Retrofit Problems
    New User
    Sep 2018
    Unhappy Audi A3 8P1 Cruise Control Retrofit Problems
    I can't see any previous relating post and I'm not able to post in the retrofit section and so will have to post here...
    I have retrofitted my 2003 Audi A3 8P1 with cruise control, when coming to activate it I am bumping into a problem... I am unable to activate it in the engine control module as I don't know the access key... I’ve tried putting the codes 11463 and 12233 in the “Security Access -16” section as per guidance I have found on this topic but keep getting error messages, see photos of errors and VCDS scans here: https://1drv.ms/f/s!AnHbbepIQF2ZgRi2hHP1caol0_oZ
    Any ideas of a code that would work or do I need a new steering wheel module?
    Please post an Auto-Scan here in the forum. The screen pics do not provide full context.
  3. Likes PetrolDave, Jack@European_Parts liked this post
    New User
    Sep 2018
    I've uploaded it to the same link. This was the scan immediately after putting everything back together hence the numerous errors, these have now cleared.
    Quote Originally Posted by Karl49 View Post
    I can only see 2 screen shots there not a FULL Auto-Scan, which is what we need.
    See below in my signature how to post an Auto-Scan here.
  6. Likes Jack@European_Parts liked this post
    It's definitely there as an .OXPS file but here you are...
    We much prefer plain old text here.
    ECU data is conspicuously absent from the above post.
    Please don't use the PRINT function in VCDS to post data here. Just copy & paste the plain text, either by using the COPY button in VCDS itself, or by opening the .txt files that VCDS saves in your Logs or Scans sub-folder with Notepad and copying the contents.
  8. Likes PetrolDave, Jack@European_Parts liked this post
  9. #6
    New User
    Sep 2018
    Right, third time's the charm...
    I notice that address 16 for the steering wheel details that the control module is incorrectly coded
    All references to the aux heater have been knocking around for a while, I tried to fix it but failed and it's not really an essential so I'm not too fussed with that.
    I also have a problem with the sound emitter in the instrument cluster for the indicator and warning beeps as it works as and when it feels like it, possibly a loose connection or dry solder joint somewhere, but that's not high priority either.
    Tuesday,09,October,2018,17:26:57:61053
    VCDS Version: 18.9.0.2 (x64)
    VIN: WAUZZZ8P74A109085   License Plate: DC53 JSY
    Mileage: 339170km-210750mi   Repair Order: 09.10.18
    Chassis Type: 8P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P74A109085   Mileage: 339170km-210750miles
    7D-Aux. Heat -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 AT    HW: 028 101 145 3
       Component: R4 2,0L EDC 0000AG  5689
       Revision: 12345678    Serial number: AUX7Z0CNFNE052
       Coding: 0000078
       Shop #: WSC 06435 000 00000
       VCID: 75E1917E1C2F4BE2F6-8020
    Readiness: 0 0 1 1 1
       Part No SW: 02E 300 041 C    HW: 02E 927 770 G
       Component: GSG DSG             0623
       Revision: 02100224    Serial number: 00000311050101
       VCID: 122BCAE20D81FCDA73-8046
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0023174
       VCID: 3A7B424275B1E49ADB-806E
       Part No SW: 8P0 820 043 D    HW: 8P0 820 043 D
       Component: KlimavollautomatH12 0150
       Revision: 014759      Serial number: 8P0820043D
       VCID: 2D51791EB4FF43224E-8078
    00797 - Sunlight Photo Sensor (G107)
                        Fault Status: 00101001
                        Reset counter: 200
                        Mileage: 234502 km
                        Date: 2016.03.19
                        Time: 13:40:20
    00483 - Control Module for Auxiliary Air Heater
                        Reset counter: 105
                        Mileage: 294760 km
                        Date: 2018.01.01
                        Time: 00:00:51
    Address 09: Cent. Elect.        Labels: None
       Part No HW: 8P0 907 279 A*
       Revision: 00029000    Serial number: 00000000192123
       VCID: 55A1F1FEBCEF2BE2D6-8000
    02071 - Local Databus
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
       Component: Airbag 8.4ED    H00 0130
       Coding: 0011602
       VCID: 43853FA6027BA55288-8016
       Part No SW: 8P0 953 549     HW: 8P0 953 549
       Component: Lenks‰ulenmodul H11 0020
       Coding: 0011112
       VCID: 7BF587463A0B1D9280-802E
       Component: Lenkradmodul    H02 0030
       Part No SW: 8P0 920 980 H    HW: 8P0 920 980 H
       Component: KOMBIINSTR. VDO H25 0110
       Revision: D07         Serial number: 224NCD07003169
       Coding: 0000403
       Shop #: WSC 01076 210 00001
       VCID: 3C77445A7F85DAAAC9-8068
    00003 - Control Module
                014 - Defective
                        Fault Status: 00000011
                        Mileage: 220628 km
                        Date: 2015.08.17
                        Time: 07:22:36
       Part No SW: 1K0 907 530 B    HW: 1K0 907 951
       Component: Gateway         H08 0090
       Revision: 08          Serial number: 24001039064300
       Coding: 3F0F0B42070101
       VCID: 264386329109707A8F-8072
                        Reset counter: 161
                        Mileage: 339175 km
                        Date: 2018.10.09
                        Time: 17:20:18
       Revision: D07         Serial number: AUX7Z0CNFNE052
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
       Part No: 8P0 959 801 A
       Component: Tuersteuerger.  H10 0010
       Coding: 0000120
       VCID: 39795D4E70B7EF82D2-806C
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.10      1202
       VCID: 2E537E12B9F9383A77-807A
       Part No: 8P0 959 433
       Component:    KSG          H02 0040
       Coding: 188800186D288505485AC63000
       Shop #: WSC 00171 210 51532
       VCID: 79F99D4E30372F8292-802C
       Subsystem 1 - Part No: 1K0 951 605 A
       Component: LIN BACKUP HORN H01 1201
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  002 0002
       Component: Innenraumueberw.H03 0010
       Part No SW: 8P3 035 382     HW: 8P3 035 382
       Component: AB2 SUBWOOFERBOXH23 0100
       Revision: 00001       Serial number: 10000001080832
       VCID: 70EFA06A634D6ECA25-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
       Part No: 8P0 959 802 A
       Coding: 0000120
    Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
       Part No SW: 8P0 035 186     HW: 8P0 035 186
       Component: concert II EU   H53 0060
       Revision:      07S    Serial number: AUZ2Z3C1673814
       Coding: 0001001
       VCID: 6FEDA3167E7371323C-803A
    Address 7D: Aux. Heat
    End-------------------------(Elapsed Time: 01:47)--------------------------
  10. #7
    Vőru, Estonia
    Was control wire already in place(pin5 of swcm)?
    ECU is not Security Access, but Coding2(Login: 11463)
    SWCM coding should be:0011142
    The world is my oyster...
  11. Likes Uwe liked this post
  12. #8
    New User
    Sep 2018
    No I had to install the wire myself, but I installed it into pin 13 of the steering wheel control module side and then pin 4 of the blue connector at the bulkhead as per the guidance I had found on videos and forums.
    I can code the SWCM easy enough, I’ve just tried again with the ECU Coding II and used the login 11463 which it didn’t accept.
    This is as far as I had gotten before
  13. #9
    Off Topic - but shouldn't this thread be in Retrofits not Uwe's Bar?
  14. #10
    New User
    Sep 2018
    I'm not a verified member and so could only post here but otherwise yes I think it should be.
    Maybe Uwe can move it?
