Results 1 to 8 of 8
Thread: Auto levelling headlights Audi A6 C5 2.5 TDI
    Jul 2018
    Hi, I have no communication with controller. Replaced controller, still no communication, changed levelling sensor on front suspension (front wheel drive) still no communication.I have no warning lights on dash. Can anyone give me some suggestions other than wiring. Thanks for any replies.
    Please post an Auto-Scan for context. There may be clues in other modules.
    Jul 2018
    Wednesday,03,October,2018,18:31:54:10284
    VCDS Version: 18.9.0.2
    VIN: WAUZZZ4B04N008991   License Plate:
              75 76 77
    Address 01: Engine        Labels: 059-907-401-AKE.clb
       Part No: 4B0 907 401 S
       Component:  2.5l/4VTEDC G000AG  D66
       Coding: 01001
       Shop #: WSC 00028
       VCID: 2E58DD36EA3F693A77-4A9C
    18062 - Please check DTC Memory of Instrument Cluster
                P1654 - 35-00 -
    Readiness: N/A
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 4B0 927 156 BL
       Component: AG5 01V 2.5lTDI RdW 9419
       Coding: 00000
       VCID: 72E009463E870DDAD3-4A9C
    Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
       Part No: 8E0 614 111 AH
       Component: ABS/ASR 5.3 FRONT   D10
       Coding: 00011
       Shop #: WSC 02325
       VCID: 64CC7F1EF473936A51-50E6
    Address 15: Airbags        Labels: 4B0-959-655-AI8.lbl
       Part No: 4B0 959 655 G
       Component: Airbag Front+Seite 1001
       Coding: 01106
       Shop #: WSC 02335
       VCID: 346CCF5E041343EA01-50E6
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487
       Component: E Lenkrad Elektronik X03
       VCID: 69D26E2A1351CE0262-4B64
                49-00 - No Communications
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 J
       Component: KOMBI+WEGFAHRS. VDO D12
       Coding: 02460
       Shop #: WSC 00050
       VCID: 2D5ADA3AE73912224E-50E6
       WAUZZZ4B04N008991     AUZ7Z0C2418282
    01304 - Radio
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 H
       Component: Central Lock/Alarm  D33
       Coding: 04811
       Shop #: WSC 00028
       VCID: 2E58DD36EA3F693A77-4E78
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00001
       Shop #: WSC 02335
       VCID: 60C4730EE06B8F4AB5-4AE6
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 186 B
       Component:  Radio              D04
       Coding: 00014
       Shop #: WSC 02325
       VCID: 1F4630F29D95F0B2CC-4AB4
    Address 76: Park Assist        Labels: 4B0-919-283.lbl
       Part No: 4B0 919 283
       Component: Parkingsystem A6 RDW D18
       Coding: 01106
       Shop #: WSC 02335
       VCID: 66C86516024FE17A4F-515A
    End-------------------------(Elapsed Time: 05:46)--------------------------
    Unfortunately, there's nothing obvious in that scan.
    I'm reasonably confident that on a 2004 4B A6, 55 should be on K2 (pin 15 of your diagnostic socket). Check that pin 15 is populated and check continuity between there and whatever pin the K-line goes to on the headlight range module. Also check power and ground connections to the headlight range module.
    Jul 2018
    Hi, thanks for your reply. The car is a 2000, I've swapped the cluster and it's showing
    cluster's previous car's vin. I'll check-out wiring. I've had the car 14 years but now electrics are doing my head in. Once again thanks for your reply and your interest.
    Quote Originally Posted by carcav View Post
    Aha. A 2004 4B would most likely have had dual K-lines, with the second one on pin 15. A 2000 would not; everything would be on one K-line on pin 7.
    So check continuity between pin 7 and the K-line pin on the headlight range module. And still check power and ground on that module.
  7. #7
    Jul 2018
    Hi, you're some boy. There's some that know and there's some that don't know and you're a knower. Thanks again for your swift reply.
  8. #8
    I've been doing this for a while now.
    But there's still more than I don't know than I do know.
  9. Likes Fredrick Awuor liked this post
