Results 1 to 10 of 14
Thread: 2018 Golf Rear Wiper Washer
    Oct 2016
    Hi all,
    2018 Golf 5dr.
    When we operate the rear wiper, to just clear the condensation in the morning, pushing the stalk to the first stop operates the washer at the same time.
    Is there anywhere in adaptations that will allow me to remove this feature, and just allow the washer part to work if the stalk is pushed fully back, like they used to do?
    Ive had a look through but i cant find anything that relates!
    Scan for reference..
    Monday,24,September,2018,14:23:44:35443
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WVWZZZAUZJW235518   License Plate: GOLF
    Mileage: 456km-283mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 4B 52 5F A9 D6 D7
    VIN: WVWZZZAUZJW235518   Mileage: 456km-283miles
    29-Left Light -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
       Revision: --H13---
       Coding: 091900122444050B2000
       ROD: EV_ECM20TFS0205G0906259C_VW37.rod
       VCID: 2E0607E4309FE247D3B-807A
       Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
       Component: ESC           H25 0423
       Revision: 00000000    Serial number: 50718000003774
       Coding: 01FA93A134232171477C0601E0CBA980C92C84E26007957734405078C009430B00000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_037_VW27.rod
       VCID: 025E8354D487B627673-8056
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 0012000420011001100500000010102A
       VCID: 6D84C0E8FD19595FAA1-8038
       Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H36 0253
       Serial number: 01001809302583
       ROD: EV_BCMCONTI.rod
       VCID: 084A917CF2BB9C77397-805C
       Component: WWS    180306  042 0551
       Serial number:         180312101612
       Component: RLHS  047 0105
       Serial number: S9Y18M04D03H21M58S31
       Coding: 00A8DD
       Serial number: 000000000ZY180572KNP
       Serial number: 00000000000099742075
       Serial number: 000308418018086
       Coding: 0471051801
       VCID: 4BC06E70A34DB76FD45-801E
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 2B00608159FFC728949C810560400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E2637A4E0FF12C743B-806A
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Serial number: 003VWR40P9HJ
       Coding: 98CCC000000000005C0000CF008800000065
       VCID: 094C9478E9B1E57F269-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E26031830782
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E27031830797
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 404 18
       Serial number: 3570000000002C9D0C2M
       Subsystem 4 - Part No SW: -----------    HW: 480 003 103 18
       Serial number: 35800000000B993D1C2X
       Subsystem 5 - Part No SW: -----------    HW: 480 402 603 18
       Serial number: 3510001A529633C2B24-
       Subsystem 6 - Part No SW: -----------    HW: 480 402 603 18
       Serial number: 3520001A329633C5541V
       Subsystem 7 - Part No SW: -----------    HW: 480 400 304 18
       Serial number: 3550001A329B7D43C26A
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 01041804400928
       Coding: 0400
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 0D44A0689DD9F95F0A1-8058
       Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
       Component: KOMBI         408 3195
       Coding: 27AD11002F80060001886B011401000000000000
       VCID: 2A0E0BF40C778E670F3-807E
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007655850
       Coding: 030100047F085900FB00027E080F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW27.rod
       VCID: 382A21BCC2DB2CF7897-806C
       Serial number: 29180000468740068097
       Coding: 2CFFFF
       Serial number: 5305497304
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       VCID: 47C85240BF25530FF0D-8012
    0033 - Supply voltage
              [Supply voltage - lower limit exceeded]
                        Reset counter: 45
                        Mileage: 11 km
                        Date: 2018.09.13
                        Time: 11:19:59
                        Reset counter: 45
                        Mileage: 12 km
                        Date: 2018.09.13
                        Time: 12:08:56
       Serial number: 200318ECK04572
       Coding: 003F0220D001048000001000
       VCID: 43D046508B1D7F2F2C5-8016
       Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000020321747
       Coding: 0D0000
       Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 81170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 3B203EB0F3ED07EF645-806E
       Serial number: 21031810522064
       Coding: 000000050100164E01100F01020000000000000000000000000000000000
       VCID: 72BED394E42786A7773-8026
       Serial number: 210318ECL05837
       Coding: 003F0020DE01048000801000
       VCID: 42DE435494077627273-8016
       Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000020335145
       Coding: 150000
       Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
       Component: MU-S-ND-ER    851 0867
       Coding: 02731001FF00000051110101008808001F0503E601200000CF
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 323E139424A7C6A7B73-8066
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZHV0861245
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
       Serial number: 180216201596
       VCID: 6B80CEF0C30D576FB45-803E
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392C24B8F9D135FF769-806C
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End----(Elapsed Time: 01:34, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Thanks!
    Jun 2017
    So you push the stalk to the front (towards dashboard) in order to get the rear wiper activated. The rear washer already gets activated on this very first position?
    This is new to me...
    Does the manual say anything about it?
    (Manual is the book-alike thing in your glove box where so many interesting things are written down about your car but nobody does ever take a look at it...)
  3. Likes jasons6930 liked this post
    Oct 2016
    Yes, one push to the intermittent setting also gives a squirt of the washer!
    To be honest, i did read the manual when we first got it, but didn't really take any notice how to use the rear wiper as i wasn't expecting it to operate any differently than before!
    ETA:
    My wife has just returned home and said the same, in that it works when it shouldn't!
    Jul 2014
    Tallinn, Estonia
    Are you sure you arent inadvertently pushing beyond the intermittent setting? If not, I'd imagine VW has come up with a unnecessary way to not dry wipe the rear screen
  6. Likes jasons6930 liked this post
    Is there any settings in the infotainment Car menu that affect the operation of the rear wiper?
    In my MQB car there is an option for the rear wiper to always be on (intermittent) when the front wiper is on, and I'm wondering if there are more options including one affecting the rear washer behavior?
  8. Likes jasons6930 liked this post
  9. #6
    Oct 2016
    Hi guys,
    Just checked the manual and no mention of this 'function'.
    As discussed, it just says one push forward is a wipe, and a full push operates the washer.
    No settings in the car menu either other than Automatic wiping in rain and rear window wiping in reverse gear.
  10. #7
    Jun 2017
    Could you create an CSV adaptation map of Unit 09 and attach it here? (like the AutoScan)
  11. Likes jasons6930 liked this post
  12. #8
    Oct 2016
    Ok i'll get it today.
  13. #9
    Oct 2016
    Do i upload the file or copy and paste with tags?
  14. #10
    Oct 2016
    Sorry, messed up forum formatting!
    IDE00001-ENG99061-Production mode-Access control	not active 	3
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active 	3
    IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
    IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
    IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
    IDE00002-Transport mode	active 	1
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE01550-Service position	170.494336 °	2
    IDE02152-Characteristics in production mode	2000 ms	4
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active 	10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active 	10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active 	10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	10
    IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active 	10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	300 ms	10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	300 ms	10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	300 ms	10
    IDE02332-Deactivate production mode	0	3
    IDE02488-DWA Interior monitoring	100%	1
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
    IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
    IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
    IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert 	8
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.3 °	16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	16
    IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
    IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	16
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	80 °	16
    IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h	16
    IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	16
    IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
    IDE03787-Activate left/right hand drive switch-over	not active 	1
    IDE04927-IDE01446-Window heater-Running time of heated front window	600 s	11
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
    IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
    IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
    IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
    IDE04927-ENG126845-Window heater-FSH Automatik	active 	11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	11
    IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
    IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
    IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
    IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
    IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	8
    IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	active 	8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	not_active 	8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	activ 	8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active 	8
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	Sounder_verbaut 	8
    IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed 	8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm	activ 	8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	not_active 	8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No 	8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	Yes 	8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme 	8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor	Yes 	8
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	2 sekunden verzoegerung 	8
    IDE05144-Read parameter address	00 00 00 	3
    IDE05145-Light configuration	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 38 00 22 12 00 7F 00 00 00 00 00 00 00 00 00 06 42 00 23 13 00 7F 00 00 00 00 00 00 00 00 00 	224
    IDE05822-DWA Vehicle inclination sensor	100%	1
    IDE05823-DWA Interior monitoring parameter set	01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 	172
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C	30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C	30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C	30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C	30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	35.00 °C	30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	35.00 °C	30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	53.50 °C	30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	52.50 °C	30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	53.50 °C	30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	52.50 °C	30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung 	30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
    IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.0 V	30
    IDE06425-Roller test bench mode: functional	not active 	1
    IDE06507-MAS13125-Button in center console-Function of button 1	Start-stop 	8
    IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
    IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
    IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed 	8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
    IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed 	8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
    IDE07356-Position during interval mode	31.494474 °	2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	not active 	6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	255 min	6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	active 	6
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
    IDE08786-ENG141956-Assistance light functions-Humidity sensor	installed 	9
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	active 	9
    IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	7	19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	active 	19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	19
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%	19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0	19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	50%	19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%	19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	50%	19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	50%	19
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	not active 	19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active 	19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active 	19
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
    IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	installed 	19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	0	5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed 	5
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	5
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
    IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	not installed 	17
    IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
    IDE10298-Alternating park position 1	7.494498 °	2
    IDE10299-Alternating park position 2	29.494476 °	2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.2	256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0.6	256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%	256
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	96%	256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%	256
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	96%	256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%	256
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	96%	256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%	256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	96%	256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%	256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127%	256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%	256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%	256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127%	256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%	256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126%	256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%	256
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	96%	256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	96%	256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%	256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	96%	256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%	256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	96%	256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s	256
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.5 s	256
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	not installed 	3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy	not installed 	3
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	not active 	3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	3
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
    IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
    MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
    MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
    MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
    MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
    MAS01490-ENG141978-Energy management-Recuperation	active 	5
    MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
    MAS05055-lower turn position	31.494474 °	2
    MAS05056-upper turn position	170.494336 °	2
    MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
    MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	0 lx	24
    MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
    MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
    MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 00 	24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx	24
    MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
    MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
    MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
    MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
    MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	0 mV	24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	0 mV	24
    MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
    MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	4
    ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door 	30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Keine_Spannungsanforderung 	23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active 	10
    ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
    ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
    ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	active 	10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	active 	10
    ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	active 	10
    ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
    ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
    ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
    ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
    ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
    ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	active 	10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	active 	10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	active 	10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	active 	10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	active 	10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	active 	10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	active 	10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	active 	10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	active 	10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	active 	10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	active 	10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
    ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h	9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	active 	9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active 	9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active 	9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active 	9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
    ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
    ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active 	9
    ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen 	9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	No 	5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h	5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	active 	5
    ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active 	5
    ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed 	18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	abschaltbar über Energiemanagement 	18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	abschaltbar über Energiemanagement 	18
    ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung 	18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Fog light 	18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
    ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	active 	18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	Hinweis_in_LDS-Stellung_Null_und_SL 	18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten 	18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx	18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
    ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	false 	18
    ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	Yes 	18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
    ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
    ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete 	18
    ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	installed 	18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	10 seconds 	18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	10 seconds 	18
    ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
    ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	One-sided 	18
    ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	active 	18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	24 s	18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5 	18
    ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
    ENG126647-ENG98399-debug_light_function-Activation	0	11
    ENG126647-ENG101417-debug_light_function-Adresse	0	11
    ENG126647-ENG126820-debug_light_function-Bitmask	0	11
    ENG126647-ENG126821-debug_light_function-Divisor	0	11
    ENG126647-ENG98827-debug_light_function-Offset	0	11
    ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
    ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
    ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
    ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
    ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
    ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
    ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
    ENG122925-DWA_Interior_Monitoring_Data_Set_Development	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	150
    ENG122934-erase_error_table	55 00 00 	3
    ENG122933-error_mask	0 bit	2
    ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	AFS: Fernlicht ueber AFS 	6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	not active 	6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	6
    ENG141685-Front_wash_function	10	2
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	active 	6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms	6
    ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active 	6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung 	6
    ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
    ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
    ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
    ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms	6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
    ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active 	6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
    ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
    ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
    ENG99457-ENG117394-Head area heater-blower_speed	1	2
    ENG99457-ENG98971-Head area heater-Temperature	-2	2
    ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
    ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear	installed 	8
    ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
    ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
    ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
    ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
    ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
    ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active 	8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	100.00%	30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	100.00%	30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	100.00%	30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	100.00%	30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	83.00%	30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	67.00%	30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	50.00%	30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	33	30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	17.00%	30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	0.00%	30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	58.50%	30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	58.50%	30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	58.50%	30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	58.50%	30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	54.50%	30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	49.50%	30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	46.50%	30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	35.50%	30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	31.50%	30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	20.00%	30
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	0	16
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	0	16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	0	16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	not active 	16
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	not active 	16
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
    ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
    ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
    ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
    ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
    ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
    ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
    ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
    ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
    ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
    ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
    ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
    ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
    ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
    ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
    ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
    ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	127	16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	6 - LED Lichtmodul 	16
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links 	16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active 	16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	127	16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	6 - LED Lichtmodul 	16
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts 	16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active 	16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	127	16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	41	16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	38 - LED Blinkleuchten 	16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Blinken links Hellphase 	16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	127	16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	42	16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	38 - LED Blinkleuchten 	16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Blinken rechts Hellphase 	16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	127	16
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16	16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8	16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	38 - LED Blinkleuchten 	16
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase 	16
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	127	16
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18	16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18	16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	38 - LED Blinkleuchten 	16
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase 	16
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	0	16
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	0	16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	0	16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	not active 	16
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	not active 	16
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize 	16
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	127	16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0	16
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	2B 	16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	9	16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	34 - LED Bremsleuchten 	16
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active 	16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	not active 	16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active 	16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize 	16
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	127	16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0	16
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	2D 	16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	19	16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	34 - LED Bremsleuchten 	16
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active 	16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	not active 	16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active 	16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127	16
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	Quittierungsfunktion 1 	16
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	127	16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0	16
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	43 - allgemeine LED 	16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active 	16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	127	16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0	16
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	43 - allgemeine LED 	16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Parking light right 	16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active 	16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	127	16
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2F 	16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	1C 	16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED 	16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	only_if_closed 	16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 	16
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	127	16
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	0	16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0	16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	36 - LED Kleinleistung 	16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken 	16
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	43 - allgemeine LED 	16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	only_if_closed 	16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	minimize 	16
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	43 - allgemeine LED 	16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	only_if_closed 	16
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 	16
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize 	16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	0	16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0	16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0	16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	0	16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	0	16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	not active 	16
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	not active 	16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	not active 	16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active 	16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active 	16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active 	16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89	16
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung 	16
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize 	16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	0	16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0	16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0	16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	0	16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	0	16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	not active 	16
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	not active 	16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	not active 	16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active 	16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active 	16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active 	16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize 	16
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	0	16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0	16
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	0	16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	0	16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	not active 	16
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	not active 	16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	not active 	16
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	not active 	16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active 	16
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize 	16
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	0	16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0	16
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	0	16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	0	16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	not active 	16
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	not active 	16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	not active 	16
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	not active 	16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active 	16
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127	16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	5 - LED Abblendlicht 	16
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell 	16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127	16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	5 - LED Abblendlicht 	16
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell 	16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127	16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	127	16
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	4B 	16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	44	16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	5 - LED Abblendlicht 	16
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Versorgungsbedarf der LCM Module 	16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	not active 	16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	Parking light right 	16
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127	16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	127	16
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	49	16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	3A 	16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	5 - LED Abblendlicht 	16
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Versorgungsbedarf der LCM Module 	16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	not active 	16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1C 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 1C 00 80 00 00 00 00 00 00 	192
    ENG141662-Leuchtenkonfiguration_Sonstiges	26 00 00 41 02 00 7F 00 00 00 00 00 00 00 00 00 26 00 00 42 04 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
    ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	0 mm	62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active 	62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	90.00%	62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	10.00%	62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-114.3 ms	62
    ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
    ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	-8.00 mm/%	62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	-8.00 mm/%	62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	-8.00 mm/%	62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	-8.00 mm/%	62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	-8.00 mm/%	62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	-8.00 mm/%	62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1 	62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	0.00%	62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.00 Hz	62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal 	62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	0 mm	62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	0 mm	62
    ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	2.50%	62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h	62
    ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.00 Hz	62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	Rear 	62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active 	62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	20.00%	62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active 	62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	0.0 %/s	62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%	62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	0.00 s	62
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-5.00%	20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-5.00%	20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-5.00%	20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-5.00%	20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-5.00%	20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-5	20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-5	20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-5	20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-5	20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-5	20
    ENG122979-ENG141954-Networking-A/C electronics	installed 	8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet	not installed 	8
    ENG122979-ENG99457-Networking-Head area heater	not installed 	8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
    ENG122979-ENG141969-Networking-UGDO	not installed 	8
    ENG124714-ENG142044-OCU-DWA_push	active 	8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	active 	8
    ENG124714-OCU-	not installed 	8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock	Via ZV-Absicherung Light 	8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
    ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active 	16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_active 	16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
    ENG98831-ENG142030-Personalization-Profil_Variante	Konto (v. 1.x) 	16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
    ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW 	5
    ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	not active 	5
    ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
    ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed 	5
    ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Right 	5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Left 	5
    ENG122927-RLS_close_glazing	2.0 s	1
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s	3
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	10 s	3
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h	3
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h	3
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx	2
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12	2
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6	2
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s	2
    ENG122929-RLS_LIN_Communication	4 s	1
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	200 lx	1
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	500 lx	1
    ENG122930-RLS_tunel_gateway_recognize	5 s	1
    ENG122935-RLS_Washer_Front	15 s	1
    ENG122926-RLS_wiper_position_parking	15 s	1
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10	10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	installed 	10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	active 	10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	2000 ms	10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	400 ms	10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms	10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms	10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	400 ms	10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung 	10
    ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor	Not available 	6
    ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor	Not available 	6
    ENG141684-SFT271875-Slave_systems_identification-Light switch	Not available 	6
    ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module	Not available 	6
    ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit	Not available 	6
    ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System	Not available 	6
    ENG141684-SFT271896-Slave_systems_identification-Alarm horn	Not available 	6
    ENG141684-SFT271904-Slave_systems_identification-Sun Roof	Not available 	6
    ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module	Not available 	6
    ENG141684-SFT271928-Slave_systems_identification-Roof Blind	Not available 	6
    ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender	Not available 	6
    ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left	Not available 	6
    ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right	Not available 	6
    ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left	Not available 	6
    ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left	Not available 	6
    ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right	Not available 	6
    ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right	Not available 	6
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	MFG 	4
    ENG116588-Sonderfunktionen-	not enabled 	4
    ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	active 	5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by look command via remote control key 	5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	active 	5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	active 	5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	active 	5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	active 	5
    ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	active 	5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	active 	5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	active 	5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	250	10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	CAN 	10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	10.0 min	10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
    ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
    ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
    ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
    ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
    ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
    ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
    ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
    ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
    ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
    ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
    ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
    ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
    ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
    ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
    ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
    ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
    ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
    ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
    ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
    ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
    ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
    ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
    ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
    ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	HMI 	21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s	21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s	21
    ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active 	21
    ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	2	21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	100%	21
    ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
    ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1	21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	6.00%	21
    ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
    ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
    ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
    ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
    ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
    ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
    ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
    ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
    ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
    ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
    ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
    ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
    ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
    ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
    ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
    ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
    ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
    ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
    ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
    ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
    ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
    ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
    ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
    ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
    ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
    ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
    ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
    ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
    ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
    ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
    ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
    ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
    ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	510 lx	8
    ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
    ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
    ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
    ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
    ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
    ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
    ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
    ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
    ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
    ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
    ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
    ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
    ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
    ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
    ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
    ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
    ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
    ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
    ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
    ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
    ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
    ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
    ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
    ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
    ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
    ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
    ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
    ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	50 lx	10
    ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
    ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
    ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
    ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
    ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	16	10
    ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	25	10
    ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	30	10
    ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	50	10
    ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
    ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50	12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100	12
    ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
    ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.00%	12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.00%	12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.00%	12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.00%	12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.00%	12
    ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
    ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
    ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
    ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
    ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
    ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
    ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
    ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
    ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
    ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
    ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
    ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
    ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
    ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
    ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
    ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
    ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
    ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
    ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
    ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
    ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
    ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
    ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
    ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx	12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx	12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx	12
    ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
    ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
    ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20	12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	80	12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180	12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300	12
    ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
    ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
    ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
    ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
    ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
    ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
    ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
    ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
    ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
    ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
    ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	not active 	4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	not active 	4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	not installed 	4
    ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed 	4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN 	4
    ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	active 	9
    ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active 	9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	active 	9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	active 	9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	active 	9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active 	9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always 	9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always 	9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed 	9
    ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	active 	9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	active 	9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	active 	9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	active 	9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	active 	9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	active 	9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active 	9
    ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba	not active 	9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed 	9
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute	40	3
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute	60	3
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30	3
    ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
    ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
    ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	active 	7
    ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
    ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
    ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active 	7
    ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
    ENG141651-ENG141957-ZV allgemein-Radio freq.	434.42MHz 	7
    ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
    ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Globale Entriegelung 	7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	not installed 	7
    ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
    ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	not active 	3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR	not active 	3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable 	3
    ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	active 	4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	not active 	4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	active 	7
    ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
    ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	not installed 	7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	not active 	7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	not active 	7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Contact control 	7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	7
    ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
    ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
    ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
    ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
    ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
    ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
    ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active 	8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	active 	8
    ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
    ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
    ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	active 	8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	active 	8
    ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
    ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
    ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
    ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
    ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
    ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	not active 	8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	not active 	8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser 	5
    ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
    ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
    ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
    ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
    ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
    ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
    ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
    ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	No 	5
    ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
