Results 11 to 20 of 28
Thread: Retrofit B9 S4 Seats to B9 Audi S4
    Dec 2016
    Amsterdam
    Have you set this channel:
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus not activated
    To the correct bus network? You need to select the can-network the seat modules are on. When in doubt, check WD or auto-scans from similar cars who have the option from the factory.
    Current:
  2. #12
    Aug 2014
    HI Thanks also for the reply.
    Not yet no, forgive my ignorance WD?
    I know the seats are connected into the LIN BUS of the central control module (09).
    Not found any auto scans from a B9 Audi S4 yet, found some for the S5 but no adaption lists. The hunt continues!
  3. #13
    See how WD is bold, green, and has a double broken underline? Hover your cursor over it.
  4. Likes paul liked this post
  5. #14
    Aug 2014
    Already checked wiring against factory manuals online via erwin thanks. Control module sees them (listed in autoscan) and can see all switch actions in measure blocks so must be a coding / adaption issue
  6. #15
    Dec 2016
    Amsterdam
    Do you have any other modules connected as a slave through LIN to another module? If so, what bus are they set to in 5F? That might give you a clue what the logic behind it is. It could be that the correct network is the network the LIN master is on, or another option in the list thats not a can-network.
    Current:
  7. #16
    Dec 2016
    Amsterdam
    Edit: on my MQB car I know the front wipers are on LIN with the BCM as LIN master. In my 5F comfort wiper functions are set to the comfort-can, so i’d try setting the msg_bus to where your BCM is also on.
    Current:
  8. Likes Uwe liked this post
  9. #17
    Aug 2014
    Will give it a go! Report back as and when I get a spare moment to play. Huge thanks again
  10. #18
    Aug 2014
    So finally the seats options appear in the MMI menu! Need to fine tune the adaptions as the seats list in the MMI is still greyed out. As soon as complete I will post adaption map for reference
  11. Likes Uwe liked this post
  12. #19
    Nov 2017
    Really interested.
  13. #20
    Mar 2015
    Quote Originally Posted by paul View Post
    Hi Paul,
    Can you let me know what you have changed so far? Is it what was listed above? I have a good friend with an A5 who has added some S5 seats and has exactly the same issue
