Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Retrofit B9 S4 Seats to B9 Audi S4
    Aug 2014
    Retrofit B9 S4 Seats to B9 Audi A4 coding / adaptation help please
    Hello to the next retrofit headache!
    So, I have the S4 seats installed in the car, run the required Airbag connection and the connection to the Central Electric Module as required as well as the extra power feed. All Good.
    The seat movement functions work fine. The seats have no module underneath as did not have memory function from donor car. The side bolsters pump up and down fine and massage button works however cannot for the life of me get the settings to show in the MMI. I have checked in module 9 measurement blocks to ensure all seat buttons are recognised, the good news is that they are! Does anyone have the adaption list of an Audi S4 B9 for module 9 and 5F? I don't believe its a coding issue.
    I can of course post a full scan here if it will help. Thanks for any direction, hugely appreciated.
    Oct 2017
    Northwest UK
    Please post an autoscan
    Aug 2014
    Sunday,30,September,2018,18:24:21:38198
    VCDS Version: 18.7.2.1 (x64)  HEX-V2 CB: 0.4430.4
    Data version: 20180808 DS295.0
    VIN: WAUZZZF40JA124225   License Plate: PAWA4
    Mileage: 5251km-3262mi   Repair Order:
    Chassis Type: F4-AU49 (8W7)
    Scan: 01 02 03 08 09 13 15 16 17 19 29 2B 39 42 44 46 47 52 5F 69
              6C 6D 81 82 8B A5 AC BB BC D6 D7
    VIN: WAUZZZF40JA124225   Mileage: 5251km-3262miles
    Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
       Part No SW: 8W0 907 401 E    HW: 059 907 309 F
       Component: 3.0TDI MD1    H24 0004
       Revision: C7H24---
       Coding: 122A40320576050324080000000000000000000000000000
       ASAM Dataset: EV_ECM30TDI0118W0907401E 001004
       ROD: EV_ECM30TDI0118W0907401E.rod
       VCID: 392F2EF8E9D0C1AF96C-806C
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 8W0 927 158     HW: 0D5 927 156 H
       Component: 0D5  30TDIRdW H05 1010
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 7F5B00E0B7742F9FE88-802A
    Address 03: ABS Brakes (J104)       Labels:. 8W0-907-379-PRE-V1.clb
       Part No SW: 8W0 907 379 M    HW: 8W0 907 379 D
       Component: ESP9 Premium  H13 0767
       Coding: 14AA309930A40A9A11A04893008252A2E4A5D2280C0C508812004A4527A54B
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 4FFB702047547F1F588-801A
    467968 - Databus
              U1122 00 [040] - Implausible Message
              [Signal_AB_Gurtschloss_FA_invalid_(0_or_1)]
                        Mileage: 4691 km
                        Date: 2018.09.27
                        Time: 22:31:59
                        91 C0 80 00 CA 00 00 00 00 00
                        Unlearning counter according OBD-OBD unlearning counter: 23
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
       Component: Klima Zone 3  H60 0210
       Coding: 2618002D5544450D02000100880000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 44D14F0C9E128C47F5A-8010
       Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
       Component: J126 FLuftV  H09 0003
       Serial number: 00000000000002043849
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 1AB1190900PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Coding: 07501343E17900CD054D57195FBE80F9110B3104000000000000000020001A810A45012B025605
       VCID: 025D8914C4864277876-8056
       Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 171122  043 0813
       Serial number: 89425300401732600688
       Coding: 5BC7F7
       Serial number: 21025295X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
       Component: E1 - LDS  H06 0008
       Serial number: 22 08 2017  01102510
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE115111723611409
       Coding: 230000
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B00641630
       Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2617000195697005
       Subsystem 7 - Part No SW: 8W0 907 182     HW: 8W0 907 182
       Component: J873 MKS_FSv  H03 0033
       Serial number: 7008174235B171329719
       Coding: BF0500
       Subsystem 8 - Part No SW: 8W0 907 182     HW: 8W0 907 182
       Component: J872 MKS_BFSv  H03 0033
       Serial number: 7008174235B171329743
       Coding: B30500
       Part No SW: 8W0 907 561 C    HW: 8W0 907 561
       Component: LRR4          H10 0340
       Coding: 3473FFEA58FFEC0A959A81A0
       ASAM Dataset: EV_ACCBOSCHAU49X 003022
       ROD: EV_ACCBOSCHAU49X.rod
       VCID: 3E253DE4F0FEE697A3E-806A
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
       Component: Airbag10.44   H03 0107
       Serial number: 003UP00BT9G.
       Coding: AACCF0C00C800000985400F3D0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006016
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: 4CC1672CB64244073DA-8018
       Subsystem 1 - Part No SW: -----------    HW: 442 062 811 17
       Serial number: 3577Y00C126D2BC2D304
       Subsystem 2 - Part No SW: -----------    HW: 442 062 911 17
       Serial number: 3587Y00C926068A152A%
       Subsystem 3 - Part No SW: -----------    HW: 442 0B1 511 17
       Serial number: 3517700B127DA976339I
       Subsystem 4 - Part No SW: -----------    HW: 442 0B0 712 17
       Serial number: 3527700B728B79E4613L
       Subsystem 5 - Part No SW: -----------    HW: 442 0C2 507 17
       Serial number: 3557500AF275CB2631BO
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C2 507 17
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500AF275CB2520CN
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 507 17
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 23075009F2772296E27D
       Subsystem 8 - Part No SW: -----------    HW: 442 430 212 17
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00B92532143E0B7
       Subsystem 9 - Part No SW: -----------    HW: 442 430 212 17
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00B9253214341D1
       Part No SW: 4M0 907 129 ME    HW: 4M0 907 129 ME
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
       Component: FBenRDW       H18 0373
       Coding: 258469D06C80060001A3E9601000600000000000
       ASAM Dataset: EV_DashBoardAU736 001027
       VCID: 43D34C109B1C8B7FCC0-8016
       Part No SW: 8W7 907 468 F    HW: 8W7 907 468 E
       Component: Gateway       H42 0123
       Revision: 7C000001    Serial number: 0187C027718109
       Coding: 03010001000086407F07000000590012D8180007100000000175078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 003111
       ROD: EV_CGateCONTIAU491_VW53.rod
       VCID: 4EC56D24405E761753E-801A
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20180108184828 21851
       Serial number: 5191156004
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
       Component: LCM_MLBevoH05 0024
       VCID: 78A9EBFC925A18A7A92-802C
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 17000379963004
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 323D19D434A632F7576-8066
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
       Component: TSG FS        005 0129
       Serial number: 0000295268633
       Coding: 005D9A215001000000001082
       Shop #: WSC 06325 790 00001
       ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
       Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0410
       Coding: 0D008380008080
       ASAM Dataset: EV_EPSZFAU49X 003023
       ROD: EV_EPSZFAU49X_003.rod
       VCID: 42DD491484068277C76-8016
       Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
       Component: BCM2 MLBevo   025 0387
       Coding: 013500006FB100406309A0000E00480233024010804706502F0400000504803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 014014
       ROD: EV_BCM2HellaAU736_014_AU49.rod
       VCID: 015F8618C180596F9EC-8054
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY173384HQP
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000099906688
       Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
       Component: GEB.F.Heckoef  H16 0905
       Serial number: >1194400
       Part No SW: 8W0 035 465     HW: 8W0 035 465
       Component: MIB2_amp_P_B9 H11 0420
       Revision: 00000001    Serial number: AUZ8ZAHJA03BZEM
       Coding: 0194020800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: EV_AMPMst16C2Gen2ALPI.rod
       VCID: 76B5E5C4984E6ED7BBE-8022
       Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
       Component: TSG BFS       005 0129
       Serial number: 0000278938534
       Coding: 005D9A215C01000000001080
       ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W5 035 035 B    HW: 8W5 035 035
       Component: MU-P-LND-EU   034 1177
       Serial number: A829A0JB050759
       Coding: 019402010000000053111102000A00332F0002E701700100BE
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 363525C4D8CE2ED77BE-8062
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
       Component: DU High AU49x  H32 0170
       Serial number: TPO00106091700820864
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
       Serial number: APVAK129111700020827
       Component: Gracenote2  --- 1016
    3086 - Antenna for Telephone Mount
              B1564 01 [009] - Electrical Failure
                        Reset counter: 79
                        Mileage: 5251 km
                        Date: 2018.09.30
                        Time: 18:07:19
                        Voltage terminal 30: 14.7 V
                        Status of telephone-Antenna diagnostic: OK
                        Status of telephone-Telephone baseplate diagnostic: not connected
                        Status of telephone-Handset in handset holder (cradle): not selected
                        Status of telephone-Handset holder (cradle): not connected
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H20 0211
       Revision: 9A001003    Serial number: 0371588379
       Coding: 0110000202000000
       VCID: 33331CD0CBBC3BFF5C0-8066
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
       Component: RVC Compact   H12 0250
       Coding: 0294020102002001400040
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
       ROD: EV_CamSysRVRVCPANAMLBEv.rod
       Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0163
       Revision: --------    Serial number: 31709534400000
       Coding: 0570
       ASAM Dataset: EV_DeckLidCONTIAU736 001015
       ROD: EV_DeckLidCONTIAU736.rod
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W2 713 041 F    HW: 4M2 713 041 F
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 17121145195270
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 372B28C0DFC4D7DF608-8062
       Part No SW: 8W5 919 617 C    HW: 8W5 919 617 C
       Component: HeadUpDisplay H18 1640
       Coding: 4F01C0
       ASAM Dataset: EV_HudNSEIKAU736 001017
       ROD: EV_HudNSEIKAU736.rod
       VCID: 48C95B3CA23AA827192-801C
    Address 8B: Adaptive Cruise 2 (J850)       Labels: None
       Part No SW: 8W0 907 541 C    HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 003022
       ROD: EV_ACC2BOSCHAU49X.rod
       VCID: 3C2137ECE6E2F4878DA-8068
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
       Component: BVS           H17 0050
       Coding: 0404090200000403024023A5A50000FCB0F0C020C020
       ROD: EV_BVSMLBevKOSTAAU736.rod
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H04 0006
       ASAM Dataset: EV_RDCMINERGAU736 005012
       ROD: EV_RDCMINERGAU736.rod
       Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
       Component: TSG HFS       005 0129
       Serial number: 0000297723583
       Coding: 000D98200001000000001080
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       VCID: 51FF7658516069EF4EC-8004
       Component: TSG HBFS      005 0129
       Serial number: 0000297723312
       ROD: EV_DCU2RearPasseMAXHCONT.rod
       VCID: 1675C544B80ECED75BE-8042
    End----------(Elapsed Time: 02:23, VBatt start/end: 14.3V/14.4V)-----------
    Oct 2017
    Northwest UK
    It's likely that the options on 5F are not activated. Can you please post an admap of both 5F and 09.
    Aug 2014
    Agreed, just knowing which ones to enable / activate.
    Module 09:
    ;SW:8W0-907-063-CG   HW:8W0-907-063-BG ---  Cent. Elect.
    ;Component:BCM1 MLBevo   H13 0267	 Coding:07501343E17900CD054D57195FBE80F9110B3104000000000000000020001A810A45012B025605
    ;EV_BCM1BOSCHAU736	18006	EV_BCM1BOSCHAU736_018_AU49.rod
    ;Sunday	30	September	2018	18:25:34:38198
    ;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
    ;VCID: 025D8914C4864277876-8056
    IDE00001-MAS10842-Production mode-Deactivate exterior lighting	not active 	3
    IDE00001-MAS10843-Production mode-Deactivate interior lighting	not active 	3
    IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper	not active 	3
    IDE00001-MAS10847-Production mode-Deactivate windshield wipers	not active 	3
    IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over	not active 	3
    IDE00001-MAS10849-Production mode-Switch parking assist to mute	not active 	3
    IDE00001-MAS10850-Production mode-Deactivate massage function	not active 	3
    IDE00001-MAS10871-Production mode-Deactivate AC compressor	not active 	3
    IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly	not active 	3
    IDE01165-Park assist activation tone	On 	1
    IDE01169-Audio reduction request	On 	1
    IDE01170-Visual display for park assist	OPS display 	1
    IDE01550-Service position	147.2	2
    IDE01996-SFT00009-Installation list: specified installations-Central Electrics	installed 	1
    IDE01996-SFT00041-Installation list: specified installations-Light Control Left	installed 	1
    IDE01996-SFT00057-Installation list: specified installations-Light Control Right	installed 	1
    IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2	installed 	1
    IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2	installed 	1
    IDE02332-Deactivate production mode	0	3
    IDE03641-Presentation run dynamic AFS light	not active 	1
    IDE03642-Presentation mode	not active 	1
    IDE03679-Adaptive light functions	active 	1
    IDE03782-Switch-off speed for parking assist	5	1
    IDE03787-Activate left/right hand drive switch-over	not active 	1
    IDE04159-Deactivation of start-stop function	not active 	1
    IDE05274-Acoustic warning for rear lid assistant	not active 	1
    IDE07356-Position during interval mode	21	2
    IDE09377-IDE00761-Multicontour seat: driver's side-After-run time	600 s	5
    IDE09377-IDE03006-Multicontour seat: driver's side-Running time of massage function	600 s	5
    IDE09377-IDE03007-Multicontour seat: driver's side-Installation location	Driver side 	5
    IDE09377-IDE03099-Multicontour seat: driver's side-Characteristics for manual seat adjustment	Open circuit 	5
    IDE09377-IDE03100-Multicontour seat: driver's side-Characteristics for seat adjustment using memory	Open circuit 	5
    IDE09378-IDE00761-Multicontour seat frt.pass. side-After-run time	600 s	5
    IDE09378-IDE03006-Multicontour seat frt.pass. side-Running time of massage function	600 s	5
    IDE09378-IDE03007-Multicontour seat frt.pass. side-Installation location	Frt. pass. side 	5
    IDE09378-IDE03099-Multicontour seat frt.pass. side-Characteristics for manual seat adjustment	Open circuit 	5
    IDE09378-IDE03100-Multicontour seat frt.pass. side-Characteristics for seat adjustment using memory	Open circuit 	5
    IDE09546-Multicontour seat on driver's side: reset compressor counter	not active 	1
    IDE09547-Multicontour seat on frt. pass. side: reset compressor counter	not active 	1
    IDE09548-Multicontour seat on driver's side: reset adaptation	not active 	1
    IDE09549-Multicontour seat on frt. pass. side: reset adaptation	not active 	1
    IDE10296-upper turn position	163.3	2
    IDE10297-lower turn position	24.51	2
    IDE10298-Alternating park position 1	15.8	2
    IDE10299-Alternating park position 2	19.1	2
    IDE10307-Presentation mode of multicolor ambient and contour lighting	not active 	1
    IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1	0 C	3
    IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2	0 C	3
    IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3	0 C	3
    IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1	0%	3
    IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2	0%	3
    IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3	0%	3
    IDE10330-Roof electronics ctrl module: delay time: change of dim value	0 ms	2
    IDE10331-MAS02201-Roof electronics control module: temperature-related dim.-Temperature	70 C	2
    IDE10331-MAS10404-Roof electronics control module: temperature-related dim.-max. brightness	0%	2
    IDE10729-Runtime measurement	on task level 	1
    IDE11055-Headlight cleaning system: activation time in production mode	2.56e+006 ms	2
    IDE11954-Automatic activation of parking distance control	active 	1
    IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1	4	2
    IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels	4	2
    IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1	4	2
    IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels	4	2
    MAS01426-Speaker volume for rear park assist	Stage 4 	1
    MAS01427-Speaker frequency for rear park assist	Stage 6 	1
    MAS01428-Speaker volume for front park assist	Stage 4 	1
    MAS01429-Speaker frequency for front park assist	Stage 4 	1
    MAS12129-Customer-oriented off-road trip	not activated 	1
    MAS12843-Maneuvering brake function	activated 	1
    ENG116833-Fehlermaske	00 00 	2
    ENG133836-Fehlermaske 2	00 00 00 00 	4
    ENG117283-Frontwaschfunktion	10	2
    ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband	60 hPa	12
    ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck	110 hPa	12
    ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte	7 s	12
    ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben	7 s	12
    ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten	7 s	12
    ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen	7 s	12
    ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1	60%	12
    ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2	60%	12
    ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3	0%	12
    ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation	10 C	12
    ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband	60 hPa	12
    ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck	110 hPa	12
    ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte	7 s	12
    ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben	7 s	12
    ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten	7 s	12
    ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen	7 s	12
    ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1	60%	12
    ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2	60%	12
    ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3	0%	12
    ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation	10 C	12
    ENG133832-sLWR_counter_left	0	4
    ENG133833-sLWR_counter_right	0	4
    Elapsed Time: 00:53
    Aug 2014
    Module 5F:
    ;SW:8W5-035-035-B   HW:8W5-035-035 ---  Information Electr.
    ;Component:MU-P-LND-EU   034 1177	 Coding:019402010000000053111102000A00332F0002E701700100BE
    ;EV_MUHig6C3Gen2HBAS	1115	EV_MUHig6C3Gen2HBAS_AU49.rod
    ;Sunday	30	September	2018	18:26:45:38198
    ;VCID: 363525C4D8CE2ED77BE-8062
    IDE00001-Production mode	00 00 00 	3
    IDE00346-Summertime-automatic	automatic 	1
    IDE00759-Base volume of speech output	50%	1
    IDE00768-Country identification: country of sale	GB 	2
    IDE00769-Number 1 for Info call	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
    IDE00770-Number 1 for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
    IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF 	1
    IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF 	1
    IDE00845-Wheel circ.	0 mm	2
    IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module	Yes 	3
    IDE01996-MAS00839-Installation list: specified installations-TV Tuner	No 	3
    IDE01996-MAS00844-Installation list: specified installations-Radio	No 	3
    IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module	Yes 	3
    IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1	Yes 	3
    IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2	No 	3
    IDE01996-MAS04300-Installation list: specified installations-DVD changer	No 	3
    IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module	No 	3
    IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit	No 	3
    IDE01996-ENG154341-Installation list: specified installations-Reserved_8	No 	3
    IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1	No 	3
    IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2	No 	3
    IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1	No 	3
    IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2	No 	3
    IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1	No 	3
    IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2	No 	3
    IDE02121-CD eject button	Enabled 	1
    IDE02122-Developer mode	activated 	1
    IDE02330-Number 2 for Info call	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
    IDE02331-Number 2 for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
    IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic 	49
    IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	32	49
    IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz	49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	85	49
    IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz	49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	85	49
    IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz	49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	85	49
    IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz	49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	85	49
    IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz	49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	85	49
    IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz	49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	85	49
    IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz	49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	85	49
    IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	17	49
    IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	17	49
    IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	32	49
    IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	85	49
    IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	85	49
    IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	85	49
    IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	85	49
    IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	85	49
    IDE02502-Confirmation of installation change	52 C2 	2
    IDE02506-MAS03229-Copy multimedia data-Data medium	On 	1
    IDE02506-MAS03230-Copy multimedia data-Optical drive	On 	1
    IDE02607-Wheel pulse	0	2
    IDE02699-Number 1 for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
    IDE02701-Number 1 (roaming) for roadside assistance	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	23
    IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo	0	8
    IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP	15	8
    IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo	0	8
    IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP	15	8
    IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo	0	8
    IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP	11	8
    IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo	0	8
    IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP	8	8
    IDE03471-ENG117847-Vehicle configuration-advanced_range_display	OFF 	30
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing	On 	30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO	On 	30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life	OFF 	30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios	OFF 	30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb	blocked 	30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant	0	30
    IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call	On 	30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support	OFF 	30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL	On 	30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts	On 	30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other	On 	30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts	On 	30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other	On 	30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data	not activated 	30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender	Deactivated 	30
    IDE03471-ENG125049-Vehicle configuration-Joker_button_1	Not Present 	30
    IDE03471-ENG125050-Vehicle configuration-Joker_button_2	Not Present 	30
    IDE03471-ENG127492-Vehicle configuration-LGI	On 	30
    IDE03471-ENG130246-Vehicle configuration-LTE_modul	activated 	30
    IDE03471-ENG142142-Vehicle configuration-map_email_support	On 	30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support	OFF 	30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support	On 	30
    IDE03471-ENG142152-Vehicle configuration-Map_Style	0	30
    IDE03471-ENG152537-Vehicle configuration-media_control	not activated 	30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link	OFF 	30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code	MIB_EU 	30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference	RGB565 	30
    IDE03471-ENG117843-Vehicle configuration-my_audi	On 	30
    IDE03471-ENG117845-Vehicle configuration-online_dictation	On 	30
    IDE03471-ENG127495-Vehicle configuration-online_media	On 	30
    IDE03471-ENG117840-Vehicle configuration-online_navigation	On 	30
    IDE03471-ENG117837-Vehicle configuration-online_POI	On 	30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice	On 	30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services	On 	30
    IDE03471-ENG152553-Vehicle configuration-online_radio	Deactivated 	30
    IDE03471-ENG117841-Vehicle configuration-online_street_view	On 	30
    IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit	OFF 	30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold	0	30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis	0	30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy	0	30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode	Data & language service active 	30
    IDE03471-ENG117844-Vehicle configuration-picture_navi	OFF 	30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking	not activated 	30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use	not activated 	30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest	0	30
    IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi	On 	30
    IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo	On 	30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version	PSD_1.5 	30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI	On 	30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component	Deactivated 	30
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input	FBAS 	30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony	not activated 	30
    IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation	no restriction 	30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag	REGION_EU 	30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch	not activated 	30
    IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch	present 	30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support	On 	30
    IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi	activated 	30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode	1	30
    IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold	OFF 	30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling	OFF 	30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone	On 	30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location	OFF 	30
    IDE03471-ENG126994-Vehicle configuration-TPEG_availability	OFF 	30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving	blocked 	30
    IDE03471-ENG137647-Vehicle configuration-UOTA	On 	30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2	OFF 	30
    IDE03471-ENG117852-Vehicle configuration-UPnP	On 	30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound	not activated 	30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound	not activated 	30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte	not activated 	30
    IDE03471-ENG117836-Vehicle configuration-VZAPro	OFF 	30
    IDE03471-ENG127494-Vehicle configuration-VZO	On 	30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI	OFF 	30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot	On 	30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch	not activated 	30
    IDE03580-Country code for mobile network	0	2
    IDE03902-Automatic ring break diagnostic	No automatic start 	1
    IDE04292-Roadside assistance mode	Corresponding setting in MMI 	1
    IDE04294-Number attempted dialing attempts for roadside assistance	3	1
    IDE04295-Bluetooth: Preferred connection profile for phone book data	PBAP 	1
    IDE04298-MAS01779-Vehicle dimensions-Length	0 mm	6
    IDE04298-MAS01780-Vehicle dimensions-Width	0 mm	6
    IDE04298-MAS02230-Vehicle dimensions-Height	0 mm	6
    IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
    IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code	2	2
    IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code	2	2
    IDE04521-Sporadic ring break detection	Visual 	1
    IDE04522-Awakening ability on optical databus	OFF 	1
    IDE04549-Telephone data services	On 	1
    IDE04550-Bluetooth: Sniff mode	OFF 	1
    IDE05111-Fee-based traffic information (TMC)	32793	2
    IDE05113-Infotainment Recorder	activated 	1
    IDE06425-Roller test bench mode: functional	not activated 	1
    IDE06697-Audio management mute function	Muting of audio sources 	1
    IDE07399-ENG142045-Engine type-Engine_type_adaption_1	Value_from_BAP_protocol 	1
    IDE07399-ENG142046-Engine type-Engine_type_adaption_2	Value_from_BAP_protocol 	1
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass	On 	1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default	On 	1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS	On 	1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo	On 	1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass	On 	1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1	OFF 	1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2	OFF 	1
    IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G	0	16
    IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G	0	16
    IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name	On 	1
    IDE10082-MAS09814-Telephone functions configuration-Call Center Function	On 	1
    IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi	Available 	1
    IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call	On 	1
    IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call	On 	1
    IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions	OFF 	1
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128	40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	17	40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	-128	40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	-128	40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128	40
    IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128	40
    IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128	40
    IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128	40
    IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128	40
    IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128	40
    IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128	40
    IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128	40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	-128	40
    IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128	40
    IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128	40
    IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128	40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	-128	40
    IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128	40
    IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128	40
    IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128	40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-128	40
    IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128	40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128	40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	7	40
    IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128	40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	-128	40
    IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128	40
    IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128	40
    IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128	40
    IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128	40
    IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128	40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128	40
    IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128	40
    IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated 	4
    IDE10480-MAS10742-Interface for external media: activation-Connection 2	activated 	4
    IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated 	4
    IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated 	4
    IDE10668-Internal SIM card: use	automatic 	1
    IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold	20 dBV	3
    IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation	50 dB	3
    IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo	0.1 s	3
    IDE11105-Brand-specific display of connect application	de.audi.mmiconnect 	19
    IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength	4294967295	330
    IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle	65535	330
    IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle	65535	330
    IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos	32767	330
    IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle	65535	330
    IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos	32767	330
    IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos	32767	330
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0	non_blocked 	21
    IDE11502-ENG127602-Locked menu contents-FB_CAR_1	non_blocked 	21
    IDE11502-ENG127611-Locked menu contents-FB_CAR_10	non_blocked 	21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11	non_blocked 	21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12	non_blocked 	21
    IDE11502-ENG127614-Locked menu contents-FB_CAR_13	non_blocked 	21
    IDE11502-ENG127615-Locked menu contents-FB_CAR_14	non_blocked 	21
    IDE11502-ENG127616-Locked menu contents-FB_CAR_15	non_blocked 	21
    IDE11502-ENG127617-Locked menu contents-FB_CAR_16	non_blocked 	21
    IDE11502-ENG127618-Locked menu contents-FB_CAR_17	non_blocked 	21
    IDE11502-ENG127619-Locked menu contents-FB_CAR_18	non_blocked 	21
    IDE11502-ENG127620-Locked menu contents-FB_CAR_19	non_blocked 	21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2	non_blocked 	21
    IDE11502-ENG127621-Locked menu contents-FB_CAR_20	non_blocked 	21
    IDE11502-ENG127622-Locked menu contents-FB_CAR_21	non_blocked 	21
    IDE11502-ENG127623-Locked menu contents-FB_CAR_22	non_blocked 	21
    IDE11502-ENG127624-Locked menu contents-FB_CAR_23	non_blocked 	21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3	non_blocked 	21
    IDE11502-ENG127605-Locked menu contents-FB_CAR_4	non_blocked 	21
    IDE11502-ENG127606-Locked menu contents-FB_CAR_5	non_blocked 	21
    IDE11502-ENG127607-Locked menu contents-FB_CAR_6	non_blocked 	21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7	non_blocked 	21
    IDE11502-ENG127609-Locked menu contents-FB_CAR_8	non_blocked 	21
    IDE11502-ENG127610-Locked menu contents-FB_CAR_9	non_blocked 	21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0	non_blocked 	21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1	non_blocked 	21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10	non_blocked 	21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11	non_blocked 	21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12	non_blocked 	21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13	non_blocked 	21
    IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14	non_blocked 	21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15	non_blocked 	21
    IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16	non_blocked 	21
    IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17	non_blocked 	21
    IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18	non_blocked 	21
    IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19	non_blocked 	21
    IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2	non_blocked 	21
    IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20	non_blocked 	21
    IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21	non_blocked 	21
    IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22	non_blocked 	21
    IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23	non_blocked 	21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3	non_blocked 	21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4	non_blocked 	21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5	non_blocked 	21
    IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6	non_blocked 	21
    IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7	non_blocked 	21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8	non_blocked 	21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9	non_blocked 	21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0	non_blocked 	21
    IDE11502-ENG127626-Locked menu contents-FB_MISC_1	non_blocked 	21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10	non_blocked 	21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11	non_blocked 	21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12	non_blocked 	21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13	non_blocked 	21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14	non_blocked 	21
    IDE11502-ENG127640-Locked menu contents-FB_MISC_15	non_blocked 	21
    IDE11502-ENG127641-Locked menu contents-FB_MISC_16	non_blocked 	21
    IDE11502-ENG127642-Locked menu contents-FB_MISC_17	non_blocked 	21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18	non_blocked 	21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19	non_blocked 	21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2	non_blocked 	21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20	non_blocked 	21
    IDE11502-ENG127646-Locked menu contents-FB_MISC_21	non_blocked 	21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22	non_blocked 	21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23	non_blocked 	21
    IDE11502-ENG127649-Locked menu contents-FB_MISC_24	non_blocked 	21
    IDE11502-ENG127650-Locked menu contents-FB_MISC_25	non_blocked 	21
    IDE11502-ENG127651-Locked menu contents-FB_MISC_26	non_blocked 	21
    IDE11502-ENG127652-Locked menu contents-FB_MISC_27	non_blocked 	21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28	non_blocked 	21
    IDE11502-ENG127654-Locked menu contents-FB_MISC_29	non_blocked 	21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3	non_blocked 	21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30	non_blocked 	21
    IDE11502-ENG127656-Locked menu contents-FB_MISC_31	non_blocked 	21
    IDE11502-ENG127657-Locked menu contents-FB_MISC_32	non_blocked 	21
    IDE11502-ENG127658-Locked menu contents-FB_MISC_33	non_blocked 	21
    IDE11502-ENG127659-Locked menu contents-FB_MISC_34	non_blocked 	21
    IDE11502-ENG127660-Locked menu contents-FB_MISC_35	non_blocked 	21
    IDE11502-ENG127661-Locked menu contents-FB_MISC_36	non_blocked 	21
    IDE11502-ENG127662-Locked menu contents-FB_MISC_37	non_blocked 	21
    IDE11502-ENG127663-Locked menu contents-FB_MISC_38	non_blocked 	21
    IDE11502-ENG127664-Locked menu contents-FB_MISC_39	non_blocked 	21
    IDE11502-ENG127629-Locked menu contents-FB_MISC_4	non_blocked 	21
    IDE11502-ENG127665-Locked menu contents-FB_MISC_40	non_blocked 	21
    IDE11502-ENG127666-Locked menu contents-FB_MISC_41	non_blocked 	21
    IDE11502-ENG127667-Locked menu contents-FB_MISC_42	non_blocked 	21
    IDE11502-ENG127668-Locked menu contents-FB_MISC_43	non_blocked 	21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44	non_blocked 	21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45	non_blocked 	21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46	non_blocked 	21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47	non_blocked 	21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5	non_blocked 	21
    IDE11502-ENG127631-Locked menu contents-FB_MISC_6	non_blocked 	21
    IDE11502-ENG127632-Locked menu contents-FB_MISC_7	non_blocked 	21
    IDE11502-ENG127633-Locked menu contents-FB_MISC_8	non_blocked 	21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9	non_blocked 	21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0	non_blocked 	21
    IDE11502-ENG127562-Locked menu contents-FB_NAV_1	non_blocked 	21
    IDE11502-ENG127571-Locked menu contents-FB_NAV_10	non_blocked 	21
    IDE11502-ENG127572-Locked menu contents-FB_NAV_11	non_blocked 	21
    IDE11502-ENG127573-Locked menu contents-FB_NAV_12	non_blocked 	21
    IDE11502-ENG127574-Locked menu contents-FB_NAV_13	non_blocked 	21
    IDE11502-ENG127575-Locked menu contents-FB_NAV_14	non_blocked 	21
    IDE11502-ENG127576-Locked menu contents-FB_NAV_15	non_blocked 	21
    IDE11502-ENG127577-Locked menu contents-FB_NAV_16	non_blocked 	21
    IDE11502-ENG127578-Locked menu contents-FB_NAV_17	non_blocked 	21
    IDE11502-ENG127579-Locked menu contents-FB_NAV_18	non_blocked 	21
    IDE11502-ENG127580-Locked menu contents-FB_NAV_19	non_blocked 	21
    IDE11502-ENG127563-Locked menu contents-FB_NAV_2	non_blocked 	21
    IDE11502-ENG127581-Locked menu contents-FB_NAV_20	non_blocked 	21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21	non_blocked 	21
    IDE11502-ENG127583-Locked menu contents-FB_NAV_22	non_blocked 	21
    IDE11502-ENG127584-Locked menu contents-FB_NAV_23	non_blocked 	21
    IDE11502-ENG127585-Locked menu contents-FB_NAV_24	non_blocked 	21
    IDE11502-ENG127586-Locked menu contents-FB_NAV_25	non_blocked 	21
    IDE11502-ENG127587-Locked menu contents-FB_NAV_26	non_blocked 	21
    IDE11502-ENG127588-Locked menu contents-FB_NAV_27	non_blocked 	21
    IDE11502-ENG127589-Locked menu contents-FB_NAV_28	non_blocked 	21
    IDE11502-ENG127590-Locked menu contents-FB_NAV_29	non_blocked 	21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3	non_blocked 	21
    IDE11502-ENG127591-Locked menu contents-FB_NAV_30	non_blocked 	21
    IDE11502-ENG127592-Locked menu contents-FB_NAV_31	non_blocked 	21
    IDE11502-ENG127593-Locked menu contents-FB_NAV_32	non_blocked 	21
    IDE11502-ENG127594-Locked menu contents-FB_NAV_33	non_blocked 	21
    IDE11502-ENG127595-Locked menu contents-FB_NAV_34	non_blocked 	21
    IDE11502-ENG127596-Locked menu contents-FB_NAV_35	non_blocked 	21
    IDE11502-ENG127597-Locked menu contents-FB_NAV_36	non_blocked 	21
    IDE11502-ENG127598-Locked menu contents-FB_NAV_37	non_blocked 	21
    IDE11502-ENG127599-Locked menu contents-FB_NAV_38	non_blocked 	21
    IDE11502-ENG127600-Locked menu contents-FB_NAV_39	non_blocked 	21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4	non_blocked 	21
    IDE11502-ENG127566-Locked menu contents-FB_NAV_5	non_blocked 	21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6	non_blocked 	21
    IDE11502-ENG127568-Locked menu contents-FB_NAV_7	non_blocked 	21
    IDE11502-ENG127569-Locked menu contents-FB_NAV_8	non_blocked 	21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9	non_blocked 	21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0	non_blocked 	21
    IDE11502-ENG127546-Locked menu contents-FB_PHONE_1	non_blocked 	21
    IDE11502-ENG127555-Locked menu contents-FB_PHONE_10	non_blocked 	21
    IDE11502-ENG127556-Locked menu contents-FB_PHONE_11	non_blocked 	21
    IDE11502-ENG127557-Locked menu contents-FB_PHONE_12	non_blocked 	21
    IDE11502-ENG127558-Locked menu contents-FB_PHONE_13	non_blocked 	21
    IDE11502-ENG127559-Locked menu contents-FB_PHONE_14	non_blocked 	21
    IDE11502-ENG127560-Locked menu contents-FB_PHONE_15	non_blocked 	21
    IDE11502-ENG127547-Locked menu contents-FB_PHONE_2	non_blocked 	21
    IDE11502-ENG127548-Locked menu contents-FB_PHONE_3	non_blocked 	21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4	non_blocked 	21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5	non_blocked 	21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6	non_blocked 	21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7	non_blocked 	21
    IDE11502-ENG127553-Locked menu contents-FB_PHONE_8	non_blocked 	21
    IDE11502-ENG127554-Locked menu contents-FB_PHONE_9	non_blocked 	21
    IDE11502-ENG127505-Locked menu contents-FB_TUNER_0	non_blocked 	21
    IDE11502-ENG127506-Locked menu contents-FB_TUNER_1	non_blocked 	21
    IDE11502-ENG127515-Locked menu contents-FB_TUNER_10	non_blocked 	21
    IDE11502-ENG127516-Locked menu contents-FB_TUNER_11	non_blocked 	21
    IDE11502-ENG127517-Locked menu contents-FB_TUNER_12	non_blocked 	21
    IDE11502-ENG127518-Locked menu contents-FB_TUNER_13	non_blocked 	21
    IDE11502-ENG127519-Locked menu contents-FB_TUNER_14	non_blocked 	21
    IDE11502-ENG127520-Locked menu contents-FB_TUNER_15	non_blocked 	21
    IDE11502-ENG127507-Locked menu contents-FB_TUNER_2	non_blocked 	21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3	non_blocked 	21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4	non_blocked 	21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5	non_blocked 	21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6	non_blocked 	21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7	non_blocked 	21
    IDE11502-ENG127513-Locked menu contents-FB_TUNER_8	non_blocked 	21
    IDE11502-ENG127514-Locked menu contents-FB_TUNER_9	non_blocked 	21
    IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42	not activated 	192
    IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus	not activated 	192
    IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47	not activated 	192
    IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus	not activated 	192
    IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51	not activated 	192
    IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus	not activated 	192
    IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45	not activated 	192
    IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus	not activated 	192
    IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D	not activated 	192
    IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus	not activated 	192
    IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41	not activated 	192
    IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus	not activated 	192
    IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50	not activated 	192
    IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus	not activated 	192
    IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E	not activated 	192
    IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus	not activated 	192
    IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44	not activated 	192
    IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus	not activated 	192
    IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40	not activated 	192
    IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus	not activated 	192
    IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A	not activated 	192
    IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus	not activated 	192
    IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B	not activated 	192
    IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus	not activated 	192
    IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C	not activated 	192
    IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus	not activated 	192
    IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48	not activated 	192
    IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus	not activated 	192
    IDE11638-Bluetooth Audio Codec	FF 	1
    IDE12266-Follow on time for telephone	activated 	1
    IDE12353-Configuration of traffic light online functions	On 	1
    IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager	not activated 	60
    IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer	not activated 	60
    IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off	not activated 	60
    IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high	not activated 	60
    IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill	not activated 	60
    IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile	not activated 	60
    IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer	not activated 	60
    IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off	not activated 	60
    IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high	not activated 	60
    IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand	not activated 	60
    IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile	not activated 	60
    IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer	not activated 	60
    IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off	not activated 	60
    IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high	not activated 	60
    IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill	not activated 	60
    IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile	not activated 	60
    IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer	not activated 	60
    IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off	not activated 	60
    IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high	not activated 	60
    IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand	not activated 	60
    IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic	not activated 	60
    IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer	not activated 	60
    IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off	not activated 	60
    IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high	not activated 	60
    IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill	not activated 	60
    IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof	not activated 	60
    IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer	not activated 	60
    IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off	not activated 	60
    IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high	not activated 	60
    IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill	not activated 	60
    IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging	not activated 	60
    IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer	not activated 	60
    IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off	not activated 	60
    IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high	not activated 	60
    IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill	not activated 	60
    MAS00951-Bluetooth	On 	1
    MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
    MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
    MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
    MAS03690-Telephone	Data & language service active 	1
    MAS03782-WLAN	On 	1
    ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off	On 	12
    ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time	150.00 ms	12
    ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off	OFF 	12
    ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time	0.00 ms	12
    ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off	OFF 	12
    ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time	0.00 ms	12
    ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off	On 	12
    ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time	150.00 ms	12
    ENG117920-Audio_Managment_Soundset_Menu	OFF 	1
    ENG117917-BAP_Debug_Mode_Release	not_released 	1
    ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated 	60
    ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated 	60
    ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated 	60
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated 	60
    ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated 	60
    ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation	not activated 	60
    ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer	not activated 	60
    ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off	not activated 	60
    ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high	not activated 	60
    ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill	not activated 	60
    ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent	not activated 	60
    ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer	not activated 	60
    ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off	not activated 	60
    ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high	not activated 	60
    ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill	not activated 	60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	activated 	60
    ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated 	60
    ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated 	60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	activated 	60
    ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated 	60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	activated 	60
    ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated 	60
    ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated 	60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	activated 	60
    ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated 	60
    ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated 	60
    ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated 	60
    ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated 	60
    ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated 	60
    ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated 	60
    ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated 	60
    ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated 	60
    ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated 	60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated 	60
    ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated 	60
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	activated 	60
    ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated 	60
    ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated 	60
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	activated 	60
    ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated 	60
    ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated 	60
    ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated 	60
    ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated 	60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated 	60
    ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated 	60
    ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated 	60
    ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated 	60
    ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated 	60
    ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated 	60
    ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated 	60
    ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated 	60
    ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated 	60
    ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated 	60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated 	60
    ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated 	60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	not activated 	60
    ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated 	60
    ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated 	60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	not activated 	60
    ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated 	60
    ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated 	60
    ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated 	60
    ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated 	60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated 	60
    ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated 	60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	not activated 	60
    ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated 	60
    ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated 	60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	not activated 	60
    ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated 	60
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated 	60
    ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated 	60
    ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated 	60
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	activated 	60
    ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated 	60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	not activated 	60
    ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated 	60
    ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated 	60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	not activated 	60
    ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated 	60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	not activated 	60
    ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated 	60
    ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated 	60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	not activated 	60
    ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated 	60
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated 	60
    ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated 	60
    ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated 	60
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated 	60
    ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated 	60
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated 	60
    ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated 	60
    ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated 	60
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	activated 	60
    ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated 	60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	activated 	60
    ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated 	60
    ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated 	60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	activated 	60
    ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated 	60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	activated 	60
    ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated 	60
    ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated 	60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	activated 	60
    ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated 	60
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	activated 	60
    ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated 	60
    ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated 	60
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated 	60
    ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated 	60
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	not activated 	60
    ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated 	60
    ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated 	60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated 	60
    ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated 	60
    ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated 	60
    ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated 	60
    ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated 	60
    ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated 	60
    ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated 	60
    ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	not activated 	60
    ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer	not activated 	60
    ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated 	60
    ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high	not activated 	60
    ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated 	60
    ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated 	60
    ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated 	60
    ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated 	60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated 	60
    ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated 	60
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	activated 	60
    ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated 	60
    ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated 	60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	activated 	60
    ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated 	60
    ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	activated 	60
    ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated 	60
    ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated 	60
    ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	activated 	60
    ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated 	60
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	activated 	60
    ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated 	60
    ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated 	60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	activated 	60
    ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated 	60
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated 	60
    ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated 	60
    ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated 	60
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	activated 	60
    ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated 	60
    ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	activated 	60
    ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated 	60
    ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated 	60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	activated 	60
    ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated 	60
    ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated 	60
    ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated 	60
    ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated 	60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated 	60
    ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated 	60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	not activated 	60
    ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated 	60
    ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated 	60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated 	60
    ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	not activated 	60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	activated 	60
    ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated 	60
    ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 	60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	activated 	60
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated 	60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	activated 	60
    ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated 	60
    ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated 	60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	activated 	60
    ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated 	60
    ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated 	60
    ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated 	60
    ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated 	60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated 	60
    ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated 	60
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	activated 	60
    ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated 	60
    ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated 	60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	activated 	60
    ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated 	60
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	activated 	60
    ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated 	60
    ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated 	60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	not activated 	60
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated 	60
    ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated 	60
    ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated 	60
    ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated 	60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated 	60
    ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated 	60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	activated 	60
    ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated 	60
    ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated 	60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	not activated 	60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	activated 	60
    ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated 	60
    ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated 	60
    ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated 	60
    ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated 	60
    ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated 	60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	activated 	60
    ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated 	60
    ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 	60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	activated 	60
    ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated 	60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	activated 	60
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated 	60
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated 	60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	activated 	60
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated 	60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated 	60
    ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated 	60
    ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated 	60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated 	60
    ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated 	60
    ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated 	60
    ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated 	60
    ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated 	60
    ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated 	60
    ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated 	60
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	activated 	60
    ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated 	60
    ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated 	60
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated 	60
    ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated 	60
    ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated 	60
    ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated 	60
    ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated 	60
    ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated 	60
    ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated 	60
    ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated 	60
    ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated 	60
    ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated 	60
    ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated 	60
    ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated 	60
    ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated 	60
    ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated 	60
    ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated 	60
    ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated 	60
    ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated 	60
    ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated 	60
    ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated 	60
    ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated 	60
    ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated 	60
    ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated 	60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	not activated 	60
    ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated 	60
    ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated 	60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	not activated 	60
    ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated 	60
    ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated 	60
    ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated 	60
    ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated 	60
    ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated 	60
    ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated 	60
    ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated 	60
    ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated 	60
    ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated 	60
    ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated 	60
    ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated 	60
    ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated 	60
    ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated 	60
    ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated 	60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated 	60
    ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated 	60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	not activated 	60
    ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated 	60
    ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated 	60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	not activated 	60
    ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated 	60
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	activated 	60
    ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated 	60
    ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated 	60
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated 	60
    ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated 	60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	activated 	60
    ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated 	60
    ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated 	60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	activated 	60
    ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated 	60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	not activated 	60
    ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated 	60
    ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated 	60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	not activated 	60
    ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated 	60
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	activated 	60
    ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated 	60
    ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated 	60
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated 	60
    ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated 	60
    ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated 	60
    ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated 	60
    ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated 	60
    ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated 	60
    ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated 	60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	activated 	64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	Terminal 15 	64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated 	64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	not activated 	64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated 	64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	not activated 	64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated 	64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated 	64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated 	64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	not activated 	64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	not activated 	64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	not activated 	64
    ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated 	64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	not activated 	64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	not activated 	64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	not activated 	64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	not activated 	64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	not activated 	64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated 	64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Terminal 15 	64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	activated 	64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Terminal 15 	64
    ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated 	64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	not activated 	64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	activated 	64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Terminal 15 	64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated 	64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	not activated 	64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	activated 	64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	Databus Infotainment 	64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated 	64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated 	64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated 	64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	not activated 	64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	activated 	64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	Databus Infotainment 	64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	Terminal 15 	64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	activated 	64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	activated 	64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	Databus Infotainment 	64
    ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38	not activated 	64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus	not activated 	64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated 	64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Terminal 15 	64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	activated 	64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	Terminal 15 	64
    ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated 	64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	not activated 	64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	activated 	64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	Terminal 15 	64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	activated 	64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Terminal 15 	64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	activated 	64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Terminal 15 	64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	activated 	64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	Databus Infotainment 	64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	not activated 	64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	not activated 	64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated 	64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated 	64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	activated 	64
    ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15 	64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated 	64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	not activated 	64
    ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated 	64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	not activated 	64
    ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated 	64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	not activated 	64
    ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated 	64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	not activated 	64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	activated 	64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Terminal 15 	64
    ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated 	64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	not activated 	64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated 	64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	not activated 	64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated 	64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	not activated 	64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated 	64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Terminal 15 	64
    ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated 	64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated 	64
    ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated 	64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	not activated 	64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	not activated 	64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	not activated 	64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	not activated 	64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	not activated 	64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated 	64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Terminal 15 	64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	activated 	64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Terminal 15 	64
    ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated 	64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	not activated 	64
    ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated 	64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	not activated 	64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated 	64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	not activated 	64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	activated 	64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Terminal 15 	64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	activated 	64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	Terminal 15 	64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	activated 	64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Terminal 15 	64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated 	64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Terminal 15 	64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Available 	8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Terminal 15 	8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available 	8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Not available 	8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL	Available 	8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment 	8
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Available 	8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Terminal 15 	8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Available 	8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Terminal 15 	8
    ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved	Not available 	8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1	Not available 	8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2	Not available 	8
    ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3	Not available 	8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN	Available 	8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Terminal 15 	8
    ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps	OFF 	10
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture	On 	10
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart	On 	10
    ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode	RLE 	10
    ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution	resolution_1 	10
    ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode	LVDS_map_FPK 	10
    ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon	0	10
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most	On 	10
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode	RLE 	10
    ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution	resolution_1 	10
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode	LVDS_map_FPK 	10
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart	On 	10
    ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0	6
    ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50	6
    ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100	6
    ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0	6
    ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50	6
    ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100	6
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0	12
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	13	12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	50	12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	100	12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	150	12
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253	12
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	0%	12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	2%	12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	8%	12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	16%	12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	43%	12
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%	12
    ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay	0 ms	3
    ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic	On 	3
    ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07	FF 	32
    ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F	FF 	32
    ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17	FF 	32
    ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F	FF 	32
    ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27	FF 	32
    ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F	FF 	32
    ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37	FF 	32
    ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F	FF 	32
    ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47	FF 	32
    ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F	FF 	32
    ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57	FF 	32
    ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F	FF 	32
    ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67	FF 	32
    ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F	FF 	32
    ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77	FF 	32
    ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F	FF 	32
    ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87	FF 	32
    ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F	FF 	32
    ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97	FF 	32
    ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F	FF 	32
    ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7	FF 	32
    ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF	FF 	32
    ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7	FF 	32
    ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF	FF 	32
    ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7	FF 	32
    ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF	FF 	32
    ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7	FF 	32
    ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF	FF 	32
    ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7	FF 	32
    ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF	FF 	32
    ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7	FF 	32
    ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF	FF 	32
    ENG107658-ENG126192-mobile phone voice control availability-apple_device	not installed 	1
    ENG107658-ENG126193-mobile phone voice control availability-other_devices	not installed 	1
    ENG167428-ENG167502-nhtsa_properties-limitation_dependency	Speed_threshold 	5
    ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length	activated 	5
    ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration	activated 	5
    ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input	activated 	5
    ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback	activated 	5
    ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input	not activated 	5
    ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists	not activated 	5
    ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists	not activated 	5
    ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps	not activated 	5
    ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard	activated 	5
    ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad	not activated 	5
    ENG117809-p_damping_Display	5 ms	1
    ENG117808-p_HMI_Display	10%	1
    ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0	2
    ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0	2
    ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN	0	3
    ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit	0 km/h	3
    Elapsed Time: 01:04
  7. #7
    Oct 2017
    Northwest UK
    In 5F, try activating the following:
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_hig h not activated 60
    You may need to reboot your MMI afterwards. Let us know how you get on.
  8. Likes Uwe liked this post
  9. #8
    Aug 2014
    Done as suggested and it produces a line in the car menu for seats but it is greyed out and unable to perform any functions. Ideally need a reference scan from an S4 with list of adaptations!
  10. #9
    Oct 2017
    Northwest UK
    Try also activating the following, BAP in German refers to display and operating protocol.
  11. #10
    Aug 2014
    Have done them already too! Hugely appreciate your replies,encouraging that I seem to be following sensible options!
