2017 MK7 R retrofit - 5F module (with 9.2 display)
Qassem
Kuwait
C?ID=325382
Dear Guys,
my car originally had the 8' discover pro.
new 5F and display retrofit done by VW dealer
every thing working like a charm.
but when I get the car back I connected VCDS and found those errors in 5F module.
went back to dealer to check those errors , they told me that the system show this message when he tried to do online software configuration using ODIS.
"ERP0617E
software configuration (coding, adaptation/calibration , parametrization ) could not be computed please check whether a compatible module or replacement part is installed in the vehicle . if the malfunction continues, consult customer support"
I checked the original coding and adaptation and compare it with the new one, its the same coding , but adaptation is around 1500 channels, spent hours checking almost the same.
I don't face any functional issue everything works like a dream (but errors is there), attached is the auto scan.
Sunday,30,September,2018,13:25:15:35129
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WVWGR2AU2HW033267   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 47 52 55 5F
          A9
VIN: WVWGR2AU2HW033267   Mileage: 14793km-9191miles
Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00122426050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259F.rod
   VCID: 312AFB8A60A063CC98-8064
Readiness: 1010 0001
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4934
   Revision: 06354004    Serial number: TFK01605092874
   ROD: EV_TCMDQ250021.rod
   VCID: 53E691023A7C71DCCA-8006
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 61696000000969
   Coding: 01FA6BA15423196F4779070641CA6980D62A98E2E0829677004200F8C20803
   Shop #: WSC 04033 002 1048576
   ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
   VCID: 7AB81CA6FD56609469-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0408352248
   Coding: 032C0C
   VCID: 3B36D9A2B2EC999C32-806E
   Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
   Revision: 00001K08
   Coding: 00020014200100001005000012101422
   VCID: 72A83486A52618D421-8026
   Serial number: 01061617100204
   Coding: 00111A46C24122F30BA44080B10C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0444625E8F92266403-8050
   Component: WWS    160604  043 0551
   Serial number:         160613064939
   Component: RLHS  037 0059
   Serial number: S4Y16M06D25H01M38S35
   Coding: 90A8DD
   Serial number: 000000000ZY1615123DN
   Serial number: 00000000000066231573
   Sun Roof:
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST0010PXH400000
   Coding: 181801
   Revision: --------    Serial number: 39331617706049
   Coding: 0031151011
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 43C6A142CA1CE15C7A-8016
   Serial number: 30051641350349
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 383CC6AE83DAB284DF-806C
   Serial number: 003F6R1W6ZPL
   VCID: 41CAAB4AD000F34C68-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 306 16
   Serial number: 35767000000FC2846C12
   Subsystem 2 - Part No SW: -----------    HW: 480 002 306 16
   Serial number: 35867000000B87F46C17
   Subsystem 3 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 35165029F21160C4C2BB
   Subsystem 4 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 3526502C521160C0C2B1
   Subsystem 5 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 35565029920EDB6092BQ
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18061604221605
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 075E7552BEA40D7C66-8052
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3196
   Coding: 47AD40183B80000801086B001400000000000000
   VCID: 2A18ECE64D76101459-807E
   Revision: --------    Serial number: 0005050239
   Coding: 030100043F085900FB00026A9C0F00010001050000000000000000000000
   Shop #: WSC 30586 002 1048576
   VCID: 7CB41ABEF7625EA47B-8028
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001143840096243
   Coding: 29FFFF
   Serial number: 6226310304
   Serial number: HA1-00012.05.16
   Coding: 0001
   VCID: 4AD88C66ED363014B9-801E
   Revision: 00000000    Serial number: 16000108135004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424F29E9FB256E4F3-8060
   Serial number: 080616EF802086
   Coding: 003E1220D000040000001000
   Serial number: 00000000000010546876
   Coding: 110000
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A38DCA6BDD6A09429-806E
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA01ZJ0J
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 6D9227FABC18C72CFC-8038
   Serial number: 120616EFC04057
   Coding: 003E1020D000040000801000
   VCID: 42C8A446D506E85471-8016
   Serial number: 00000000000010454152
   Coding: 090000
   Coding: 02A202000B010200
   VCID: 40CCAE4EDB0AFA4467-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 5NA 035 045     HW: 5NA 035 045
   Component: MU-H-N-RW     H51 0981
   Serial number: A849L0HB001908
   Coding: 0273000C0000000051110002001828001F0207F401200000DF
   Shop #: WSC 35332 001 104857
   VCID: 75A20F9AD4480FEC04-8020
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H35 9074
   Serial number: VWZ6ZFS2960131
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Component: Gracenote2  --- 4011
9 Faults Found:
1586 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for speed shutoff thresholds]
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:01
                    Voltage terminal 30: 13.8 V
1587 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for language]
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:01
1588 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for visible MMI system languages]
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:01
1589 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for power management timer]
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:01
1595 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for audio management HMI constants]
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:01
1652 - invalid data record
          B2005 00 [009] -  -
          [Control module (data record download) - invalid data record for eco HMI]
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:01
1597 - Data Set Implausible
          B2012 00 [009] -  -
          [Control module (data record download) - implausible data record for language]
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:01
1598 - Data Set Implausible
          B2012 00 [009] -  -
          [Control module (data record download) - implausible data record for visible MMI system languages]
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:01
          B201A 00 [009] -  -
                    Reset counter: 44
                    Mileage: 14793 km
                    Date: 2018.09.30
                    Time: 12:51:06
                    Status_Software_Version_Management-module_name: MMIBLite/MIBLite
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 160506200106
   VCID: 2F2EFDF27694753C8E-807A
End----------(Elapsed Time: 01:44, VBatt start/end: 13.7V/13.7V)-----------
myounus
Northwest UK
C?ID=321059
If it's not broken don't try and fix it!
downtime
C?ID=280813
You need to install correct dataset for the MIB unit. You audio outputs for example are not correct. It might sound like it but you’ll notice the difference when you upload a correct one :)
That you cannot do with VCDS unfortunately. You’ll need the other tool for it. ODIS is not very usable either as you need to get the dataset as original xml file.
Software version management error is easy. Google for the solution :)
Qassem
Kuwait
C?ID=325382
Thanks downtime for the replay,
Which tool are used for this ?
From where I can get the original dataset ?!
Qassem
Kuwait
C?ID=325382
Vcp vagcanpro
Thank you myounus , I will update this thread once I get my hand on this tool.
Regarding “check software version management” error , any tips how it can be done ?! Google is miss leading sometimes.
Qassem
Kuwait
C?ID=325382
Of the Audi way is http://audienthusiasts.com/Application_SVMError.html
If neither work then it's a trip to the dealers or someone who has online ODIS. Personally I would leave it alone as it doesn't mean anything
Great , SVM fault removed and never come back, thank you a lot.
Still the invalid data record faults , I will try VCP once I receive tool, I hope it will work as I live in Kuwait , so it will take time until I get it in hand.
downtime
C?ID=280813
It will work. You just need to pickup the correct dataset for the radio. First register to their forums, you'll get the support you need from there.
Qassem
Kuwait
C?ID=325382
Dear downtime,
Finally I received the tool, registered it and logged in the forum.
Explain the situation and i posted an outoscan.
The replay was that they will help me remotely using VAS5054!!!
I am really shocked.
downtime
C?ID=280813
Heh, nice :)
Send email to VCP support and ask for the file from there. Have you checked from filemanager that does the dataset for your radio exists already there?
Edit :
Aahh.. I just read the thread. If possible, let the guy help. He's a GENIUS when it comes to retrofits. He helped me activate my ACC setup and he's helped A LOT of people, he's really top dude.
Probably the radio you have is so new that there is no dataset available via the tool you bought just yet. This guy has access to VW system and he's able to run the dataset to your MIB. Dealer is not able to do it as the parameterization will fail as the radio system is not originally been in your car from factory.
Qassem
Kuwait
C?ID=325382
Heh, nice :)
Edit :
Thank you downtown, i’ll contact him.
I’ll update you.
Really appreciate your support and suggestions
darkchina811
ITALY
C?ID=333184
could you guys get me in contact with that genius? I don't have VCP so I cannot post in their forum. thank you.
myounus
Northwest UK
C?ID=321059
You'll need to get VCP as it's needed for flashing the unit.
Qassem
Kuwait
C?ID=325382
Update:
We tried to install the dataset through VCP, didn't work.
Tried also with odis engineering, didn’t work also.
Then we discovered that the dataset for European 5F , is different from ROW 5F.
Still searching for the right dataset file :-(
downtime
C?ID=280813
Have you tried the tools support mailbox and request for the dataset file if they have it available.
Qassem
Kuwait
C?ID=325382
It has been more than one month asked for the dataset file, the only reply i got it 3 weeks back that they will get it.
Then they stop replying to my follow up e-mails
Qassem
Kuwait
C?ID=325382
Its has been more than one year for this thread,
But i want to update it.
We found the correct datasets , and the faults gone 💪
darkchina811
ITALY
C?ID=333184
great. can you post an updated autoscan?
