Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 2017 MK7 R retrofit - 5F module (with 9.2 display)
    Jan 2018
    Kuwait
    Dear Guys,
    my car originally had the 8' discover pro.
    new 5F and display retrofit done by VW dealer
    every thing working like a charm.
    but when I get the car back I connected VCDS and found those errors in 5F module.
    went back to dealer to check those errors , they told me that the system show this message when he tried to do online software configuration using ODIS.
    "ERP0617E
    software configuration (coding, adaptation/calibration , parametrization ) could not be computed please check whether a compatible module or replacement part is installed in the vehicle . if the malfunction continues, consult customer support"
    I checked the original coding and adaptation and compare it with the new one, its the same coding , but adaptation is around 1500 channels, spent hours checking almost the same.
    I don't face any functional issue everything works like a dream (but errors is there), attached is the auto scan.
    Sunday,30,September,2018,13:25:15:35129
    VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
    VIN: WVWGR2AU2HW033267   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 47 52 55 5F
              A9
    VIN: WVWGR2AU2HW033267   Mileage: 14793km-9191miles
    Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D00122426050B3004
       ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
       ROD: EV_ECM20TFS0205G0906259F.rod
       VCID: 312AFB8A60A063CC98-8064
    Readiness: 1010 0001
       Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H54 4934
       Revision: 06354004    Serial number: TFK01605092874
       ROD: EV_TCMDQ250021.rod
       VCID: 53E691023A7C71DCCA-8006
       Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
       Component: ESC           H62 0636
       Revision: 00000000    Serial number: 61696000000969
       Coding: 01FA6BA15423196F4779070641CA6980D62A98E2E0829677004200F8C20803
       Shop #: WSC 04033 002 1048576
       ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
       VCID: 7AB81CA6FD56609469-802E
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0408352248
       Coding: 032C0C
       VCID: 3B36D9A2B2EC999C32-806E
       Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
       Revision: 00001K08
       Coding: 00020014200100001005000012101422
       VCID: 72A83486A52618D421-8026
       Serial number: 01061617100204
       Coding: 00111A46C24122F30BA44080B10C07281800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 0444625E8F92266403-8050
       Component: WWS    160604  043 0551
       Serial number:         160613064939
       Component: RLHS  037 0059
       Serial number: S4Y16M06D25H01M38S35
       Coding: 90A8DD
       Serial number: 000000000ZY1615123DN
       Serial number: 00000000000066231573
       Sun Roof:
       Component: J245 PS73.403  H03 0004
       Serial number: 0000FST0010PXH400000
       Coding: 181801
       Revision: --------    Serial number: 39331617706049
       Coding: 0031151011
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 43C6A142CA1CE15C7A-8016
       Serial number: 30051641350349
       ROD: EV_DRCONTITEMIC_VW27.rod
       VCID: 383CC6AE83DAB284DF-806C
       Serial number: 003F6R1W6ZPL
       VCID: 41CAAB4AD000F34C68-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 002 306 16
       Serial number: 35767000000FC2846C12
       Subsystem 2 - Part No SW: -----------    HW: 480 002 306 16
       Serial number: 35867000000B87F46C17
       Subsystem 3 - Part No SW: -----------    HW: 480 401 806 16
       Serial number: 35165029F21160C4C2BB
       Subsystem 4 - Part No SW: -----------    HW: 480 401 806 16
       Serial number: 3526502C521160C0C2B1
       Subsystem 5 - Part No SW: -----------    HW: 480 401 806 16
       Serial number: 35565029920EDB6092BQ
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 18061604221605
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 075E7552BEA40D7C66-8052
       Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
       Component: KOMBI         408 3196
       Coding: 47AD40183B80000801086B001400000000000000
       VCID: 2A18ECE64D76101459-807E
       Revision: --------    Serial number: 0005050239
       Coding: 030100043F085900FB00026A9C0F00010001050000000000000000000000
       Shop #: WSC 30586 002 1048576
       VCID: 7CB41ABEF7625EA47B-8028
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29160001143840096243
       Coding: 29FFFF
       Serial number: 6226310304
       Serial number: HA1-00012.05.16
       Coding: 0001
       VCID: 4AD88C66ED363014B9-801E
       Revision: 00000000    Serial number: 16000108135004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424F29E9FB256E4F3-8060
       Serial number: 080616EF802086
       Coding: 003E1220D000040000001000
       Serial number: 00000000000010546876
       Coding: 110000
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A38DCA6BDD6A09429-806E
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0150
       Revision: 00000001    Serial number: VWZ8Z1GBA01ZJ0J
       Coding: 12000000008AAA8A000000000000
       ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
       ROD: EV_AMPMst11CGen2ALPI.rod
       VCID: 6D9227FABC18C72CFC-8038
       Serial number: 120616EFC04057
       Coding: 003E1020D000040000801000
       VCID: 42C8A446D506E85471-8016
       Serial number: 00000000000010454152
       Coding: 090000
       Coding: 02A202000B010200
       VCID: 40CCAE4EDB0AFA4467-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 5NA 035 045     HW: 5NA 035 045
       Component: MU-H-N-RW     H51 0981
       Serial number: A849L0HB001908
       Coding: 0273000C0000000051110002001828001F0207F401200000DF
       Shop #: WSC 35332 001 104857
       VCID: 75A20F9AD4480FEC04-8020
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H35 9074
       Serial number: VWZ6ZFS2960131
       Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
       Component: ROW 2017  --- 0062
       Component: Gracenote2  --- 4011
    9 Faults Found:
    1586 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for speed shutoff thresholds]
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:01
                        Voltage terminal 30: 13.8 V
    1587 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for language]
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:01
    1588 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for visible MMI system languages]
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:01
    1589 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for power management timer]
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:01
    1595 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for audio management HMI constants]
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:01
    1652 - invalid data record
              B2005 00 [009] -  -
              [Control module (data record download) - invalid data record for eco HMI]
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:01
    1597 - Data Set Implausible
              B2012 00 [009] -  -
              [Control module (data record download) - implausible data record for language]
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:01
    1598 - Data Set Implausible
              B2012 00 [009] -  -
              [Control module (data record download) - implausible data record for visible MMI system languages]
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:01
              B201A 00 [009] -  -
                        Reset counter: 44
                        Mileage: 14793 km
                        Date: 2018.09.30
                        Time: 12:51:06
                        Status_Software_Version_Management-module_name: MMIBLite/MIBLite
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Serial number: 160506200106
       VCID: 2F2EFDF27694753C8E-807A
    End----------(Elapsed Time: 01:44, VBatt start/end: 13.7V/13.7V)-----------
    Oct 2017
    Northwest UK
    If it's not broken don't try and fix it!
    May 2017
    You need to install correct dataset for the MIB unit. You audio outputs for example are not correct. It might sound like it but you’ll notice the difference when you upload a correct one
    That you cannot do with VCDS unfortunately. You’ll need the other tool for it. ODIS is not very usable either as you need to get the dataset as original xml file.
    Software version management error is easy. Google for the solution
    Jan 2018
    Kuwait
    Thanks downtime for the replay,
    Which tool are used for this ?
    From where I can get the original dataset ?!
    Oct 2017
    Northwest UK
    Vcp vagcanpro
  6. Likes downtime liked this post
    Jan 2018
    Kuwait
    Quote Originally Posted by myounus View Post
    Vcp vagcanpro
    Thank you myounus , I will update this thread once I get my hand on this tool.
    Regarding “check software version management” error , any tips how it can be done ?! Google is miss leading sometimes.
    May 2017
    This one works. Used that myself after upgrading 5F firmware from 846 to 846A. Had that error and with these instructions it went away.
    http://forums.ross-tech.com/showthre...ics-tool/page2
  9. Likes Uwe liked this post
  10. #8
    Oct 2017
    Northwest UK
    Of the Audi way is http://audienthusiasts.com/Application_SVMError.html
    If neither work then it's a trip to the dealers or someone who has online ODIS. Personally I would leave it alone as it doesn't mean anything
  11. Likes Qassem, downtime liked this post
  12. #9
    Jan 2018
    Kuwait
    Great , SVM fault removed and never come back, thank you a lot.
    Still the invalid data record faults , I will try VCP once I receive tool, I hope it will work as I live in Kuwait , so it will take time until I get it in hand.
  13. #10
    May 2017
    It will work. You just need to pickup the correct dataset for the radio. First register to their forums, you'll get the support you need from there.
  14. Likes Qassem liked this post
