Results 11 to 20 of 25
Thread: Possible to turn off bulb error light on VW Jetta 2016
    Aug 2016
    Switzerland
    Yes, thank you for your answers. My question is more like, does the bulb error come on when pressing the brake, starting the indicator, directly when key is turned, etc?
  2. #12
    Quote Originally Posted by myounus View Post
    The voltage current used by LED lights is a fraction of incandescent ones
    Fixed that for you.
  3. Likes Borja, PetrolDave liked this post
  4. #13
    Oct 2017
    Northwest UK
    Thanks UWE .
    My phone is playing up or the internet so I can't see the posts properly. What have you got for Byte 18?
  5. #14
    Sep 2018
    Mexico City
    Hello Iichel
    Borja: Yes the Bulb error come when presing the brake, activate the turn right/left indicator , When the key is turned on nothing happens until i activate any function of the lights
  6. #15
    Sep 2018
    Mexico City
    Fixed that for you.
    Hello UWE
    Is more clear with the image LOL
  7. #16
    Sep 2018
    Mexico City
    Thanks UWE .
    Hello Ounus
    I want to confirm if the information sharing with you regarding Byte 18 are the correct one:
    Steps:
    1.-I go to the "Select control module" option from the main screen
    2.- Then I select "09-cent. Elect. " Button
    3.- Then Coding "07 button" and a menu pop out with several options i select the one on blue, I dont know if the other ones are different options
    https://imgur.com/a/ntACx5K
    https://imgur.com/a/qhHdLeC
    4.- From the option on blue selected on the previews step i go to the 18 byte as you can check the value on the image
    https://imgur.com/a/aM3F97K
  8. #17
    Me personally? Nothing.
  9. #18
    Aug 2016
    Switzerland
    I'm afraid this cannot be solved, the PQ25 BCM that you have in your jetta has no option to disable the warning light for indicators (i.e. if you install LED).
    The warning light for the brakes can be disabled if you set the byte for the light diagnosis in the BCM.
    I guess the LED tail lights has only been an option for the PQ35 BCM.
    Just to verify, all of the lights in the rear LED cluster work?
  10. #19
    Sounds like your best option is to add resistors in parallel with the indicator LEDs - this is what I had to do on my other car (a Citroen C1) to make them flash at the correct rate.
  11. Likes Uwe liked this post
  12. #20
    Aug 2016
    Switzerland
    Yes, I agree, but I wouldn't call it a nice solution for an OEM installation.
  13. Likes PetrolDave liked this post
