Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Possible to turn off bulb error light on VW Jetta 2016
    Sep 2018
    Mexico City
    Dears
    I install European led Tail Lights on VW jetta 2016 but as you know the bulb error message appear on the dashboard of the car i saw on Internet and it seems it is not possible to delete the bulb error if someone can confirm if we can erase that Bulb error ?
    Thanks in advance
    Tuesday,25,September,2018,21:17:16:37874
    VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
    VIN: 3VW1W2AJ8GM374995   License Plate: MYK4448
    Mileage: 35600km-22120mi   Repair Order:
    Chassis Type: AJ-VW36 (7E0)
    Scan: 01 03 05 08 09 15 17 19 25 2B 56
    VIN: 3VW1W2AJ8GM374995   Mileage: 35600km-22120miles
    Address 01: Engine (CCC)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 EC    HW: 07K 907 309 B
       Component: 2,5L 125KW      G01 1401
       Revision: T4H07---    Serial number:
       Coding: 0000071
       VCID: 73B3229677BC17BF7C6-8026
                   U1017 - 000 -  - Intermittent
                        Mileage: 35243 km
                        Date: 2018.09.18
                        Time: 11:16:54
                        RPM: 2321 /min
                        Load: 32.1 %
                        Speed: 38.0 km/h
                        Temperature: 92.0C
                        Temperature: 72.0C
                        Absolute Pres.: 780.0 mbar
    Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
       Component: MK70 M MASR         0106
       Revision: 00H35001
       Coding: 0020833
       Shop #: WSC 00066 790 00014
       VCID: 7BA30AB65FEC5FFF246-802E
       Revision: 00092000    Serial number: 0396094799
       Coding: 000F0F
       Shop #: WSC 00066 000 00295
       VCID: 372BD6862FC4BB9F80E-8062
       Part No SW: 5C0 820 047 CR    HW: 5C0 820 047 CR
       Component: J301  Klimaanlage   0211
       Revision: 2001401S    Serial number: 00000003222248
       VCID: 72BD279208A61EB7770-8026
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 189     HW: 7E0 937 189
       Component: BCM PQ25 MMI3 H80 0736
       Revision: BA080001    Serial number: 18007105160151
       Coding: 73994BBA083B0700083920802C0A84D50DC6720E60C40020B1A010030844
       Shop #: WSC 00066 123 12345
       VCID: 71BF289E01A025AF8EA-8024
       Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  022 1466
       Serial number: 14102743160311065331
       Coding: 020000
       Subsystem 2 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  022 1466
       Serial number: 14102742160308062643
       Coding: 020000
       Subsystem 3 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
       Component: J245 PS41.402  H03 0004
       Serial number: 0000FST000S10B400000
       Coding: 180000
       Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
       Serial number: 0481616030901588AD1B
       Coding: 280000
       Subsystem 5 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
       Component: J388__TSG_HL  022 1466
       Serial number: 14102745160328233238
       Subsystem 6 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
       Component: J389__TSG_HR  022 1466
       Serial number: 14102744160330220310
       Part No SW: 5C0 959 655 AF    HW: 5C0 959 655 AF
       Component: AirbagVW10    015 0614
       Serial number: 003S2M088FNN
       Coding: 00004341
       ASAM Dataset: EV_AirbaVW10SMEVW360 001032
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 76B51B82684E02975B8-8022
       Serial number: 3572MSME5D4C0A57ZZZ6
       Serial number: 3582MSME224C0A57ZZZ-
       Serial number: 3516KSME2A1F2F3CZZZ6
       Serial number: 3526KSME302F2F3CZZZ%
       Part No SW: 5C6 920 855 A    HW: 5C6 920 855 A
       Component: KOMBI         H04 1007
       Coding: 170B000000
       Shop #: WSC 00066 790 00320
       VCID: 2C01F9EAE6820847FDC-8078
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 189
       Component: GW-K-CAN TP20 H80 0736
       Revision: BA080001
       Coding: 102200
       VCID: 688945FA327AE467D94-803C
                000 -  -  - Intermittent
                        Date: 2018.01.20
                        Time: 00:00:00
       Component: IMMO          H04 1007
       Coding: 000007
       VCID: 6A8D3FF22CF6D677CF0-803E
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
       Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
       Component: ELV-PQ35      H22 0240
       Revision: 00000000    Serial number: 16000060349004
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 313FE89EC1A065AFCEA-8064
       Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
       Component: Radio         534 5314
       Revision: --------    Serial number: VWZZZ4R6203904
       Coding: 16000440040005
       Shop #: WSC 00078 790 00217
       VCID: 46D5AB4258AED2170B8-8012
                        Fault Status: 00111011
                        Reset counter: 204
                        Mileage: 32260 km
                        Date: 2018.01.19
                        Time: 18:08:17
                        Reset counter: 204
                        Mileage: 32260 km
                        Date: 2018.01.19
                        Time: 18:08:17
                        Reset counter: 204
                        Mileage: 32260 km
                        Date: 2018.01.19
                        Time: 18:08:17
                        Reset counter: 204
                        Mileage: 32260 km
                        Date: 2018.01.19
                        Time: 18:08:17
                        Reset counter: 40
                        Mileage: 34927 km
                        Date: 2018.08.16
                        Time: 10:17:58
    End----------(Elapsed Time: 01:17, VBatt start/end: 14.3V/14.3V)-----------
    Aug 2016
    Switzerland
    Hard to say. The bcm doesn't tell which lights it's unhappy with so hard to advise on a coding.
    When does the light appear? Which light do you suspect? Brake, recess, fog, indicator?
  3. Likes Uwe liked this post
    Oct 2017
    Northwest UK
    We also have no idea what wiring has been changed
  5. Likes Uwe liked this post
  6. #4
    Sep 2018
    Mexico City
    Hello Guys
    Thanks for you feedback let me explain what i have done in order to install this Lights
    Description:
    I use to have the normal lights as you can check on the images with 4 pins for the ones that are on the Right & left and 3 pins for the ones that goes on the center of the car as you can check on the images
    https://imgur.com/a/rRUpmWP
    https://imgur.com/a/JjLy8Xt
    https://imgur.com/a/IRESQx2
    The problem with the European lights is that they dont use the Amber Light like in USA and Mexico so as i know there two types of LED Jetta GLI tail lights with 4 pins that have the amber color and 3 pins with out the Amber Color.
    So for the installation as i know for my electronic courses LOL I need to use the led resistor to connect them
    https://imgur.com/a/xg8qOK9
    European 3 pins LED tail lights:
    https://imgur.com/a/FriQ8YG
    https://imgur.com/a/Qg0PYYH
    After Finish wiring the Led Tail lights (i can add the diagram if it is needed) all is working fine stop light , reverse light , Etc.
    https://imgur.com/a/crcqYOR
    After all this wiring procedures i think the car will not recognize the led Tail lights because this is an adaptation and when I activate the lights the Bulb error appear on the dashboard an thats why I want to delete form the dashboard i mean not to clear the Bulb error like in the correct meaner because i think that can not be achive because this is an adaptation of the lights
    Answering Mr Iichel Questions:
    Borja: After finish the wiring process
    Borja:I supect that are all the Tail lights show the indicator, when i start the car there is not Bulb error but when i activate Brake, Recess , Fog the indicator appear , when i stop the car the Bulb error clear until i activate again the breake ETC
    All of them
    Sep 2018
    Mexico City
    Hello Iichel
    I answer to your questions and make a description of the problem on the history of the post regarding your comments the BCM module dont show witch lights what can I do to know ? And image of the serial part of the light ?
    Sep 2018
    Mexico City
    Hello Myounus
    I make a description of the problem if the diagram of needs I can attach to the history of the post thanks in advance
    Oct 2017
    Northwest UK
    Hi Borja
    So you have gone from incandescent to LED - is that correct?
  10. #8
    Sep 2018
    Mexico City
    Hello Myounus
    Thats correct from incandescent to LED , I attach images to the description i dont know why are not showing , maybe it takes some minutes to be showed
    https://imgur.com/a/gOKnFZG
    https://imgur.com/a/pgjZuYy
  11. #9
    Oct 2017
    Northwest UK
    Hi Borja
    The voltage used by LED lights is a fraction of incandescent ones which would explain why you are getting bulb errors. Have you made any coding changes in your BCM?
  12. #10
    Sep 2018
    Mexico City
    Quote Originally Posted by myounus View Post
    Hi Borja
    Hello Ounus
    I see, i haven't change anything on the BCM of the car because i am not sure if there is way to disable the Bulb Sensor of the car or a way to trick the car in order they believe they have the incandescent ones.
    I want to ask first before doing something wrong LOL
