Results 1 to 9 of 9
Thread: Passat CC 2.0TDI CBAB DSG -> Manual Swap, Need ABS Coding for Manual
    Sep 2018
    Poland
    Hello, we are swapping gearbox from DSG to Manual and almost all units were recoded to manual gearbox but VCDS don't have help tags for ABS Unit Coding and I need Your help.
    So here is info about ABS Unit:
    VIN: WVWZZZ3CZ9E527109
    Przebieg: 195201km
    Adres 03: ABS/hamulce Plik etykiet: 3C0-614-109-C4.clb
    Oznaczenie elementu SW: 3C0 614 109 P HW: 3C0 614 109 P
    Komponent: J104 C4 440 V2 0011
    Weryfikacja: --025--- Numer seryjny: 00000786096148
    Kodowanie: 0002325
    Kod serwisu: WSC 00352 211 60439
    VCID: 2B03F9095F061E5FF43-807E
    Znaleziono 1 błąd:
    01315 - Sterownik skrzyni biegów
    004 - Brak sygnału / brak komunikacji
    Ramka zamrożona:
    Stan błędu: 01100100
    Priorytet błędu: 3
    Częstość błędu: 1
    Wew.licznik błędów: 7
    Przebieg: 195201 km
    Wskaźnik czasu: 0
    Data: 2013.02.11
    Czas: 23:06:14
    Ramka zamrożona:
    Prędkość: 0.0 km/h
    Wartość Hex: 0x0000
    Napięcie: 11.50 V
    Bity binarnie: 00011111
    Zliczanie: 151
    Wartość Hex: 0x0000
    If it's possible please type me the proper coding for ABS Unit for Manual 6gear gearbox.
    There is also a DTC Stored in ECU:
    049409 - Brak komunikacji ze sterownikiem skrzyni biegów
    U0101 - 000 - - MIL zapalona
    But that i will sort by disabling it in EDC17CP14 ECU, so thats not the problem (ECU it self can't be recoded to manual - tested, so that is the only way to make it working without MIL On).
    Thank You,
    Daron
    Aug 2016
    Switzerland
    Please poste a full autoscan in English.
  3. Likes Jack@European_Parts, Dana, Uwe liked this post
    Moving to Retrofits.
    Sep 2018
    Poland
    Hello, here is full scan :
    Monday,01,October,2018,16:32:14:13024
    VCDS Version: 18.9.0.1 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVWZZZ3CZ9E527109   License Plate:
    Mileage: 195360km-121391mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 56 62 69
              72 77
    VIN: WVWZZZ3CZ9E527109   Mileage: 195360km-121391miles
    02-Auto Trans -- Status: Cannot be reached 1100
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 CL    HW: 03L 907 309
       Component: R4 2,0L EDC G000AG  3501
       Revision: 13H01---    Serial number: VWZCZ000000000
       Coding: 0000078
       Shop #: WSC 00352 211 69729
       VCID: 71BF2B61BDAA348F618-8024
    049409 - No Communication with Transmission Control Module
                   U0101 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 82
                        Mileage: 195134 km
                        Date: 2013.02.10
                        Time: 01:58:11
                        RPM: 782 /min
                        Temperature: 24.3°C
                        Voltage: 13.68 V
                        Bin. Bits: 00000000
                        Torque: 0.0 Nm
                        Temperature: 43.2°C
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early - Intermittent
                        Voltage: 0.00 V
                        Hex Value: 0xFF00
                        Bin. Bits: 00000000
                        Temperature: -90.0°C
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
       Component: J104    C4 440 V2   0011
       Revision: --025---    Serial number: 00000786096148
       Coding: 0002325
       Shop #: WSC 00352 211 60439
       VCID: 2B03F9095F061E5F1B4-807E
                        Reset counter: 14
                        Mileage: 195365 km
                        Date: 2013.02.21
                        Time: 21:33:49
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 151
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 AJ    HW: 5K0 907 044 AJ
       Component: Climatronic   130 0303
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 73B32169CB36069F934-8026
    9481988 - Air Quality Sensor
              B10AF 04 [009] - Internal System Fault
                        Fault Frequency: 35
                        Reset counter: 14
                        Mileage: 195201 km
                        Date: 2018.09.21
                        Time: 22:50:29
       Revision: 00H54000    Serial number: 00000008863083
       Coding: E9800F8B00041A0047970F00170000000009FF475C40017C170000000000
       Shop #: WSC 05124 000 00000
       VCID: 3333E1698736469F534-8066
       Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 080808 022  0602
       Coding: 00046997
       Shop #: WSC 05124
       Component: RLS     180908 054  0402
       Coding: 00209133
       Shop #: WSC 05124
    Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
       Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0005
       Revision: --H06---    Serial number: 28291108756395
       Coding: 110101
       ASAM Dataset: EV_EPHVA18SKxxx0000 001001
       ROD: EV_EPHVA18SKxxx0000_001.rod
       VCID: 43D3B1A9DB16F61FC34-8016
    1080340 - Parking Aid Speaker
              B107C 14 [009] - Open or Short to Ground
                        Reset counter: 7
                        Mileage: 195201 km
                        Date: 2018.09.21
                        Time: 22:53:17
    12648736 - Databus
              [Getriebesteuergerät - mGetriebe_1 - kein Signal/keine Kommunikation]
                        Reset counter: 7
                        Mileage: 195201 km
                        Date: 2018.09.21
                        Time: 22:53:17
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__300 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DPJZRVC2
       Coding: 0012336
       Shop #: WSC 05311 000 00000
       VCID: 3B23C949AF668EDF8B4-806E
       Subsystem 1 - Serial number: 6333FTS611772568
       Subsystem 2 - Serial number: 6343FTS618622268
       Subsystem 3 - Serial number: 6353ETS6RHMTUVNR
       Subsystem 4 - Serial number: 6363ETS6SQH2VVNJ
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0025
       Revision: 00030000    Serial number: 3C5953507CN
       Coding: 0000611
       VCID: 74B12275C2B801A78AE-8020
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H08 0010
       Coding: 00000131
       Part No SW: 3C8 920 870 A    HW: 3C8 920 870 A
       Component: KOMBI         H19 0023
       Coding: 140D00
       Shop #: WSC 05311 115 12345
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
       VCID: 290F0301597A0C4FE98-807C
    12648704 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Getriebe: keine Kommunikation]
                        Fault Frequency: 57
                        Reset counter: 14
                        Mileage: 195134 km
                        Date: 2018.09.20
                        Time: 01:36:32
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 H    HW:
       Component: J533__Gateway   H-- 0142
       Revision:   H--       Serial number: 2600P089080820
       Coding: FDA07F46400602F100
       VCID: 2615083D44E42337C4A-8072
                        Reset counter: 14
                        Mileage: 195365 km
                        Date: 2013.02.21
                        Time: 21:33:48
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       VCID: 392FD341A55ABCCF998-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
       Part No SW: 1T0 035 680 F    HW: 1T0 035 680 F
       Component: RNS-MID       H06 3970
       Revision: AB001001    Serial number: VWZ6Z7L8084145
       Coding: 00010400020000A0000F
       VCID: 313FEB61712A748F218-8064
       Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1533
       Revision: 71009005    Serial number: 00000784888817
       Coding: 0001205
       VCID: 40D9BEA5C680ED07DE6-8014
       Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.075 0401
       Revision: 1AH02234    Serial number: 00081850247502
       Coding: 0000258
       VCID: 3635D87D944453B774A-8062
       Component:    KSG PQ46 ELV 042 0472
       Coding: 02910A8001860E763604941570084F0B607C01
       Shop #: WSC 05311 123 12345
       Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1533
       Revision: 71009005    Serial number: 00000017788822
       Coding: 0001204
       VCID: 41DFBBA1CD8AE40FD18-8014
       Part No SW: 3C8 907 801 C    HW: 3C8 907 801 C
       Component: J540 EPB3  VW-13618 0005
       Revision:   010       Serial number: 00000000047251
       Coding: 0000057
       VCID: 2A0DFC0D50FC0757E02-807E
                        Fault Status: 11100100
                        Reset counter: 14
                        Mileage: 195365 km
                        Date: 2013.02.21
                        Time: 21:33:48
                        Voltage: 11.70 V
                        Count: 75
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
       Component: J388   TUER-SG HL   0309
       Revision: 43004101    Serial number: 00000000587680
       Coding: 0001168
       VCID: 313FEB617D2A748F218-8064
    Address 69: Trailer        Labels: RETROFIT69.lbl
       Part No SW: 5F0 01V 000 6    HW: 8P0 907 383
       Component: TRAILER ECS V0006   0010
       Shop #: WSC 00164 211 66245
       VCID: 280906054EF03547F66-807C
       Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
       Component: J388   TUER-SG HR   0309
       Revision: 43004101    Serial number: 00000000584631
       Coding: 0001168
       VCID: 323DE46D782C4F97582-8066
    Address 77: Telephone        Labels: RETROFIT77.lbl
       Part No SW: KTC 364 96P     HW: KTC 364 96P
       Component: SWP:3.21.9      H24 0195
       Shop #: WSC 21977 142 74100
       VCID: 3E25C05DBC749BF7ACA-806A
    End----------(Elapsed Time: 01:24, VBatt start/end: 11.9V/12.0V)-----------
    Aug 2016
    Switzerland
    what if you remove 02 from gateway installation list?
  7. Likes Uwe liked this post
    Sep 2018
    Poland
    02 removed from gateway and Instrument Cluster started giving "Press Clutch to Engine Start", but in other modules there aren't any differences.
    ABS Coding should make the job (after that i think Parking Assist should also MIL Off), any advices ?
    Võru, Estonia
    I would give 0002322 a try
    The world is my oyster...
  10. Likes iichel, Uwe, m87a liked this post
  11. #8
    Sep 2018
    Poland
    After 0002322 - coding Accepted but "Incorrect Module Coding" Error
  12. #9
    Sep 2018
    Poland
    Solved by changing "Gearbox Codierung" in Flash (I've changed that the car is equipped from factory with manual gearbox). No metter that the coding in ECU is currently 078 (DSG Gearbox) - ECU is working like there is Manual Gearbox installed.
    After that, ABS Coding 0002322 correct, and DTC's from gearbox in all modules dissapeared.
    Topic could be closed,
    Thank You
  13. Likes Uwe, m87a liked this post
