today I finally upgraded BCM and Gateway to High version with correct part number for my car.
CP was removed in all modules where it kicked in. Key fobs have been learned.
BCM was recoded and make admap like stock one, all is good, upgrade is 100% success
Gateway was recoded and make admap like stock one, then re-parameterized because DRIVING PROFILE SELECTION was missing.
now I have one problem and one logged error:
- problem is DPS button does not go orange light anymore when I select different profile than Normal. really not a big deal but it's curious, and I have already checked the setting in the BCM.
- logged error you can see on Gateway in autoscan. on the radio, when I press the CAR button and then START&STOP on screen, it says "This function is not available at the moment".
does anybody have any hint please?
Thursday,27,September,2018,17:20:07:06888
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWZZZAUZHW0xxxxx License Plate:
Mileage: 21334km-13256mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 18 19 42 44 52 5F 65
VIN: WVWZZZAUZHW0xxxxx Mileage: 21334km-13256miles
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HB HW: 04E 907 309 BH
Component: R4 1.4l TFS H25 2833
Revision: R7H25---
Coding: 0119003223241D082000
Shop #: WSC 21385 002 1048576
ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
ROD: EV_ECM14TFS01104E906027HB.rod
VCID: 6B833BBF03045EDFB46-803E
CAN Converter 01:
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CC HW: 5Q0 614 517 AG
Component: ESC H62 0637
Revision: 00000000 Serial number: 91596000011507
Coding: 01FA6AA1242219704779060841C62980562498E2608294730020500A400203
Shop #: WSC 131071 102 209715
ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
VCID: 74B120C35E3A812765C-8020
Part No SW: 5G0 907 044 BE HW: 5G0 907 044 BE
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004104111011005004000101022
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061633700891
Coding: 00000846C20102FB0B244080B11407281400000000000000000000000000
Shop #: WSC 00028 028 00069
ROD: EV_BCMBOSCH_015.rod
VCID: 045170030E9AB1A755C-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160522 043 0551
Serial number: 160601172917
Coding: 0E4DFD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y17M06D01H13M38S50
Coding: 06A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY15028208R
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000030139763
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 D HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0042
Revision: -------- Serial number: 61131402901978
Coding: 0031161041
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 40D9BC135A026D87314-8014
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1V1W4Y
VCID: 41DFB9175108648F3EA-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 506 16
Serial number: 35767000000432B44C1Q
Subsystem 2 - Part No SW: ----------- HW: 480 001 506 16
Serial number: 358670000008B4C4DB17
Subsystem 3 - Part No SW: ----------- HW: 480 400 306 16
Serial number: 3516502BB205729313D3
Subsystem 4 - Part No SW: ----------- HW: 480 401 105 16
Serial number: 3526502AF2076340F201
Subsystem 5 - Part No SW: ----------- HW: 480 401 106 16
Serial number: 35565029B21160C1025X
Part No SW: 5Q0 953 507 FT HW: 5Q0 953 549 F
Revision: -------- Serial number: 13061608490829
Coding: 0400
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 0D4755275DD0F0EF0A2-8058
Part No SW: 5G1 920 750 B HW: 5G1 920 750 B
Component: KOMBI 303 8311
Coding: 03A501802290000D02083B041400000000000000
VCID: 26150A8BD866A3B72B8-8072
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 B HW: 5Q0 963 272 B
Component: STH-MQB 006 0069
Coding: 1309
VCID: 3537DDC715C0D82F922-8060
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001256652
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0004271482
Coding: 030100043F085700FB000248080F00010001050000000000000000000000
Shop #: WSC 12345 123 28888
VCID: 7CA108E3766AC9672DC-8028
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29160001142480026234
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 8442320304
1029 - invalid data record
B2005 00 [009] - -
[ungültiger Datensatz: Funktion "erweiterte Anzeige StartStopp"]
Reset counter: 178
Mileage: 21331 km
Date: 2018.09.27
Time: 17:01:15
Supply voltage: Terminal 30: 11.8 V
Terminal 15: On
Component: TSG FS 020 0041
Serial number: 300516EEU02971
Coding: 003B0220D000040100001000
VCID: 43D3B31F4B14769F2C6-8016
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8307
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2DCEFB3CDE37577F0-806E
Component: TSG BFS 020 0041
Serial number: 280516EER24731
Coding: 003B0020DE00040100801000
VCID: 42DDB61B540E7F97270-8016
Part No SW: 3Q0 035 824 B HW: 3Q0 035 824 B
Component: MU-S--ER 710 0744
Coding: 02730000AA0000005111000100080A001F0206D40120010003
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2C01F8A3C68A99E7FDC-8078
Subsystem 1 - Part No SW: 3G0 919 605 B HW: 3G0 919 605 B
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9SJT00QNA
6700 - Databus
[Dimming: no communication]
Reset counter: 218
Mileage: 21331 km
Date: 2018.09.27
Time: 16:54:50
Voltage terminal 30: 11.9 V
6718 - Databus
[BCM: no communication]
Reset counter: 218
Mileage: 21331 km
Date: 2018.09.27
Time: 16:54:50
6913 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[A/C system (0x01) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 218
Mileage: 21331 km
Date: 2018.09.27
Time: 16:54:50
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000018766
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E0C31EBAC127A5C-8060
End----------(Elapsed Time: 01:51, VBatt start/end: 12.6V/12.5V)-----------
