Results 1 to 9 of 9
Thread: Passat B7 ESCL ???
    Sep 2017
    Croatia
    Passat B7 ESCL ???
    Hi,have this car,i think this car was original right hand and now left hand,car not start ,ESCL is in open state so ignition on,ESCL MVB 123 different VIN as engine ECU,i read CCM and get pin 64782 and CS " 42 B5 95 C1 16 49 CB",
    CCM refuse PIN,all lock time is zero,and no 12v from CCM to ESCL pin 10(yellow red ),
    Wednesday,26,September,2018,10:08:47:04922
    VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
    VIN: WVWZZZ3CZBP333295   License Plate:
    Mileage: 156100km-96996mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62 72
    VIN: WVWZZZ3CZBP333295   Mileage: 156100km-96996miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 FS    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 8856
       Revision: --H43---    Serial number: VWZCZ000000000
       Coding: 00194016030401080000
       Shop #: WSC 00028 028 00038
       ASAM Dataset: EV_ECM16TDI02103L906023FS 003005
       ROD: EV_ECM16TDI02103L906023FS_003.rod
       VCID: FCB4AA2177F8DDA4FB-80A8
    6 Faults Found:
    6260 - Engine Start Blocked by Immobilizer
              P1570 00 [165] - -
                        Mileage: 155932 km
                        Date: 2018.09.26
                        Time: 01:35:29
                        Coolant temperature: 17 C
                        Intake air temperature: 20 C
                        Voltage terminal 30: 11.520 V
                        Immobilizer snapshot A: 05
    10156 - Cylinder 1 Glow Plug Circuit (Q10)
              P0671 00 [037] - Electrical Fault
                        Fault Frequency: 11
                        Mileage: 155932 km
                        Date: 2018.09.26
                        Time: 01:35:32
                        Glow status-STATE_GLOW: 48
                        Fuel temperature-TFU: 16 C
                        Sensor for engine block temperature: raw value-Coolant temperature: 16 C
    10158 - Cylinder 2 Glow Plug Circuit (Q11)
              P0672 00 [037] - Electrical Fault
                        Fault Frequency: 11
                        Mileage: 155932 km
                        Date: 2018.09.26
                        Time: 01:35:32
    10160 - Cylinder 3 Glow Plug Circuit (Q12)
              P0673 00 [037] - Electrical Fault
                        Fault Frequency: 11
                        Mileage: 155932 km
                        Date: 2018.09.26
                        Time: 01:35:32
    10162 - Cylinder 4 Glow Plug Circuit (Q13)
              P0674 00 [037] - Electrical Fault
                        Fault Frequency: 11
                        Mileage: 155932 km
                        Date: 2018.09.26
                        Time: 01:35:32
    10448 - Starter Relay
              P3088 00 [101] - Electrical Malfunction
                        Mileage: 155932 km
                        Date: 2018.09.26
                        Time: 00:00:30
                        Engine speed: 0 /min
                        Battery voltage: 11.5 V
                        Status of starter activation-FRF_ST_RL: 2
                        Sensor for engine block temperature: raw value-Coolant temperature: 17 C
    Readiness: 1110 1000
       Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
       Component: J104   C2 450M V409 0005
       Revision: --H07---    Serial number: 00000003773181
       Coding: 0002471
       Shop #: WSC 22021 444 101010
       VCID: B73E750DC65E3EFC56-80E2
       Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000003
       Shop #: WSC 00015 115 00000
       VCID: 804CDED11B10B944A7-80D4
       Part No SW: 3AA 937 087     HW: 3AA 937 087
       Component: BCM PQ47 M    413 0452
       Revision: BA413001
       Coding: 000000000000000000180080100004E443016488404C81606480C7200041
       Shop #: WSC 00028 028 00001
       VCID: F7BEB50D46DEFEFC96-80A2
       Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer 15041  10  0603
       Coding: 00B795
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__102 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0P2UYC0/
       Coding: 0012338
       Shop #: WSC 00028 790 00007
       VCID: CCD43AE1AFD8AD240B-8098
       Subsystem 1 - Serial number: 6332MTS604480241
       Subsystem 2 - Serial number: 6342MTS623560281
       Subsystem 3 - Serial number: 6351HTS6KQN5O9KJ
       Subsystem 4 - Serial number: 6361HTS69IP4O9KR
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
                        Fault Status: 11101010
                        Mileage: 156101 km
                        Date: 2013.02.16
                        Time: 01:35:33
                        Fault Status: 11100001
                        Mileage: 156101 km
                        Date: 2013.02.16
                        Time: 01:35:32
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                        Mileage: 156101 km
                        Date: 2013.02.16
                        Time: 01:35:31
       Part No SW: 3C5 953 501 BF    HW: 5K0 953 569 S
       Revision: FF010040    Serial number: 20110217100888
       Coding: 1182050000
       Shop #: WSC 00028 028 00302
       VCID: EA989C790D6C531419-80BE
       Coding: E20000
       Part No SW: 3AA 920 970 A    HW: 3AA 920 970 A
       Component: KOMBI         H20 0420
       Coding: 160D00
       Shop #: WSC 48231 001 1048576
       VCID: B12A4B15E03AE0CC18-80E4
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 190211F1000176
       Coding: 461006
       VCID: B12A4B15E83AE0CC18-80E4
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0399
       Revision: 00043000    Serial number: 00000000000000
       Shop #: WSC 39674 769 84943
       VCID: F6A0B80981D487F48D-80A2
       Subsystem 1 - Part No: 3C0 905 861 D
       Component:    ELV          024 0370
       3C0905861D     ELV          024 0370
    02835 - Communications between Steering Column Lock and Convenience System
                        Reset counter: 49
                        Mileage: 156101 km
                        Date: 2013.02.13
                        Time: 02:11:12
    02822 - Electronic Steering Column Lock Incorrectly Installed
                        Fault Status: 01110101
                        Reset counter: 9
                        Mileage: 156101 km
                        Date: 2013.02.03
                        Time: 23:26:17
                        Fault Status: 00100101
                        Reset counter: 49
                        Mileage: 156101 km
                        Date: 2013.02.03
                        Time: 00:02:25
       Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
       Component: RNS-MID       H11 2660
       Revision: AB001001    Serial number: VWZ6Z7K3380251
       Coding: 06000402040000A000
       Shop #: WSC 05311 000 08193
       VCID: AE105069F904FF3405-80FA
    00857 - CD Changer Unit (R41)
                        Fault Frequency: 22
                        Reset counter: 9
                        Mileage: 156096 km
    01523 - Microphone for Telephone (R38)
                        Reset counter: 9
                        Mileage: 156101 km
                        Date: 2013.02.16
                        Time: 01:35:39
       Part No SW: 3AA 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0530
       Revision: 13110009    Serial number: 0002258361
       Coding: 0200B5
       VCID: F4A482015FA895E4B3-80A0
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0408
       Serial number: 00000001961308
       Coding: 000290
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 9
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.147 0703
       Revision: 1AH03256    Serial number: 00092460172202
       Coding: 0000258
       Shop #: WSC 05311 000 00000
       VCID: BA386C39F54C2394A9-80EE
       Component:    KSG PQ47 ELV 043 0631
       Coding: 19910A0002860E76300494157C084FCE107C01
       Shop #: WSC 03038 425 177043
       Component: EZE_2         H35 0614
       Coding: 00000008
       VCID: EFAE8D6D3E8EB63C4E-80BA
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Part No SW: 3AA 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0530
       Revision: 15110009    Serial number: 0002321681
       Coding: 0200B4
       VCID: F5A2BF0554D28CEC84-80A0
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0408
       Serial number: 00000001971916
       Coding: 000290
                        Reset counter: 9
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000180879
       Coding: 0010000
       VCID: B326411DD226D2DC6A-80E6
    03190 - Incorrect Vehicle Type
                        Fault Status: 01110000
                        Reset counter: 9
                        Mileage: 156101 km
                        Date: 2013.02.16
                        Time: 00:10:16
                        Voltage: 13.00 V
                        Count: 96
                        Hex Value: 0x1250
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Reset counter: 9
                        Mileage: 156101 km
                        Date: 2013.02.16
                        Time: 00:11:05
                        Voltage: 13.00 V
                        Count: 98
                        Hex Value: 0x1250
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Reset counter: 9
                        Mileage: 156101 km
                        Date: 2013.02.03
                        Time: 00:02:51
                        Voltage: 11.80 V
                        Count: 41
                        Hex Value: 0x1243
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 9
                        Mileage: 156101 km
                        Date: 2013.02.03
                        Time: 00:02:51
                        Voltage: 11.80 V
                        Count: 99
                        Hex Value: 0x1243
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Fault Frequency: 23
                        Reset counter: 9
                        Mileage: 156096 km
                        Reset counter: 9
                        Mileage: 156101 km
                        Date: 2013.02.16
                        Time: 01:35:39
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: F1AA8B1528BAA0CC58-80A4
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370590403
    End----(Elapsed Time: 01:36, VBatt start/end: 11.6V/11.5V. VIgn 0.0V)------
    Sep 2017
    Croatia
    why ccm refuse pin?
    Quote Originally Posted by ikara View Post
    why ccm refuse pin?
    Have you tried changing the setting without entering a security code?
    Sep 2017
    Croatia
    Not know what you mean,ar came to me after a couple workshops,maybe acidentaly or not ESCL is from other older car(some 3C from 2006 other VIN),this car is model 36 from 2011.
    I checked many things and what i can see only problem is this ESCL,have other NEW one but cant install,all time refuse pin.
    I know that is something blocked in eprom but not know what,regards
    PS.if i goes straight to adaptation without entering security,have message up " need security acces"
    Sep 2017
    Croatia
    i research this over net and many people had same problem,and after help from someone they solved,i 100% sure something locked into eprom 95320
    Jul 2014
    Poland
    It will refuse the pin because someone put used ESCL.
    Solve problem with 12v from CCM, and mount new 3C0 905 861 J lock. The one that you have in car is not for this model. After mounting brand new lock it should accept PIN.
    ESP OFFLINE coding for all VAG 2010->/ Certified GeKo user/ Retrofitting, Chip-tuning, Flash updates, ECU programming, key coding, clusters and many more...
  7. #7
    Sep 2017
    Croatia
    I try that option even that red yellow wire disconnet from ccm when power on escl
  8. #8
    Sep 2017
    Croatia
    I put second hand set ,car starts but not accept old coding ,why ,need code ABS and Engine
  9. #9
    New User
    Mar 2018
    Poland
    I've just got same problem. But can someone tell me why brand new ELV is open? 3 years ago i bought new elv and it was close. Ignition can be on only once. Now i can turn on the ignition many times and every time i got blocked for 255 minutes. After this time i can't write correct pin. In CCM i got 0 keys and communication is corrupted. I back my "old" ELV everything is ok. Maybe need other method for this type?
