The recent dataset update
henbo
C?ID=318655
Just a placeholder for more information about my experience with VCDS Mobile and the latest dataset update.
1. 30 MB, using VCDS Mobile, it takes a while over a slow network (e.g. tethering). When interrupted, verification runs nevertheless and hangs. After successful download, extraction takes a while, too.
2. An ASAM update is required, 990 KB. After successful download and verification, extractions gets stuck at file 32/64 or 36/64. Interface hangs (LEDs stuck at random color) and needs to be power-cycled.
3. ROD update via VCDS Desktop succeeds and getting MVB via VCDS Mobile works fine in general.
4. Values selected in VCDS Mobile HUDs have changed. HUDs have to be rebuilt, but are functional (as before).
5. Some values (e.g. IDE08985,AC line current: actual val and IDE08986,AC line voltage: actual val) are not decoded correctly.
6. Selecting OBDII too quickly after reading from other units causes a car connection timeout. This does not happen when switching more slowly, e.g. until the "Installed" list is fully available in the main Select screen.
With all the retries and hangs and waits I didn't have time to do an AutoScan and get version info and updated channel maps. It's on my list ...
Dataset update verifying before download complete hangASAM update extraction hangASAM update extraction hangASAM update extraction hangWrong decoding of certain values for C6
henbo
C?ID=318655
VCDS Mobile, Codebase: Sep 14 2018 - 16:49:06 CodeBlock V0.4436 FW version: 0.254 Dataset: 60000057
2017 Audi A3 1.4 TFSI E-TRON CUKB (Germany)
1 unknown fault code (03 - ABS, error 008400)
Thu,Sep,27,2018,17:25:55
VCDS Mobile 0.4436.0.4
VIN: WAUZZZ8V6HA000000
Scan: 01 02 03 05 08 09 13 15 16 17 19 23 2B 42 44 51 52 55 5F 75
	 8C A5 C6
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine  (CUKB J623)	Labels: 04-01.clb
	Part No SW: 04E 906 023 AR	HW: 04E 907 309 F
	Component: R4 1.4l TFS   H22 3440
	Revision: X3H22---
	Coding: 021D0012636401083000
	ASAM Dataset: EV_ECM14TFS01104E906023AR 008003
	ROD: EV_ECM14TFS01104E906023AR_008.rod
	VCID: 70A343C329B09B4B817287-8025
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Part No SW: 0DD 300 046	HW: 0DD 927 770 C
	Component: GSG DQ400E    H32 1604
	Revision: 00032034
	ASAM Dataset: EV_TCMDQ400021 001001
	ROD: EV_TCMDQ400021_AU37.rod
	VCID: E58DA2976672CEE362E48E-80B0
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Part No SW: 5Q0 614 517 BL	HW: 5Q0 614 517 AH
	Component: ESC           H62 0855
	Revision: 00000000
	Coding: 12F140A23829227189800E0941C52948021C44917082947218B15074822802
	ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
	ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
	VCID: 7CBB67F375F8EF2B2DCA03-8029
008400 - ROD - Unknown faultcode
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 5Q0 959 435 B	HW: 5Q0 959 435
	Revision: 00021000
	Coding: 030C0C
	VCID: 3B39A4EF307628136440D8-806E
Address 08: Auto HVAC  (E87)	Labels: 8V0-820-043.clb
	Part No SW: 8V0 820 043 R	HW: 8V0 820 043 R
	Component: AC Automat    H03 0110
	Revision: 20002000
	Coding: 0300000000001000080000000000100001000000
	ASAM Dataset: EV_AirCondiFrontRDWAU37X 001019
	ROD: EV_AirCondiFrontRDWAU37X.rod
	VCID: 41C5D607529A42C33E9C9A-8014
	Subsystem 1 -
	Subsystem 2 - 	Part No SW: 5QE-816-803
	Component: J842 eKK     H02 0007
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
	Part No SW: 5Q0 937 084 CF	HW: 5Q0 937 084 CF
	ROD: EV_BCMMQB_017.rod
	VCID: 7EBF6DFB63E4FD3B03FE39-802B
	Subsystem 1 - 	Part No SW: 8V1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component: WWS370 161015043 0580
	Serial Number:         161029100000
	Coding: 0A47F7
	Subsystem 2 - 	Part No SW: 8U0-955-559-C	Labels: 8U0-955-559.clb
	Component: G397_RLFS    H06 0004
	Serial Number: 62500000
	Coding: 00006C
	Subsystem 3 - 	Part No SW: 8V0-941-531-AR
	Component: E1 - LDS MQB H06 0032
	Serial Number: 00000000
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 G	HW: 5Q0 907 572 G
	Component: ACC BOSCH MQB H10 0571
	Coding: 5500E7C111FFC728949C8045000026
	ASAM Dataset: EV_ACCBOSCHVW416 001005
	ROD: EV_ACCBOSCHVW416_001_AU37.rod
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 5Q0 959 655 AM	HW: 5Q0 959 655 AM
	Component: AirbagVW21    003 0317
	Coding: 98CCC0000C2000009C540000004800000065
	ROD: EV_AirbaVW20SMEVW37X.rod
	VCID: 8B59B42FA05658939460A8-80DE
	Subsystem 1 - 	Part No SW: --------------
	Component: SideSensor_Df001 0887
	Serial Number: 3570000000040AD00000
	Subsystem 2 - 	Part No SW: --------------
	Component: SideSensor_Pf001 0887
	Serial Number: 358000000006A2D00000
	Subsystem 3 - 	Part No SW: --------------
	Component: SideSensor_Dr000 6149
	Serial Number: 3510001C523B3B300000
	Subsystem 4 - 	Part No SW: --------------
	Component: SideSensor_Pr000 6149
	Serial Number: 3520001A523B3B300000
	Subsystem 5 - 	Part No SW: --------------
	Component: FrontSensor_D001 6149
	Serial Number: 3550002B523C4E500000
	Subsystem 6 - 	Part No SW: --------------
	Component: PedP_Sensor_D000 6149
	Serial Number: 2280001BB23B3B500000
	Subsystem 7 - 	Part No SW: --------------
	Component: PedP_Sensor_P000 6149
	Serial Number: 2290001BB23B3B500000
	Subsystem 8 - 	Part No SW: --------------
	Component: PedPSensor_D2001 0887
	Serial Number: I0M00000000765700000
Address 16: Steering wheel  (J527)	Labels: 8V-16.lbl
	Part No SW: 8V0 953 521 MS	HW: 5Q0 953 549 D
	Component: Lenks. Modul  004 0140
	Revision: --------
	Coding: EC18
	VCID: 9771D85FEC9EAC7320F8D4-80C2
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 8V0 920 873 H	HW: 8V0 920 873 H
	Component: KOMBI         H05 8316
	Coding: 07040C186F800008008328101200000000000000
	ASAM Dataset: EV_DashBoardVDDMQBAB 009054
	VCID: 43C9DC0F488650D32CB0B0-8016
Address 19: CAN Gateway  (J533)	Labels: 3Q-19.clb
	Part No SW: 3Q0 907 530 D	HW: 3Q0 907 530 D
	Component: GW MQB EV     615 6286
	Coding: 0201001726F200005B001218581000000001010100010000000300000000
	ROD: EV_GatewNF_AU37.rod
	VCID: 302383C3E930DB4BC1F247-8065
	Subsystem 1 - 	Part No SW: 81A-951-523-B
	Component: J453 MFL     H04 0003
	Serial Number: 20160830020125 00000
	Subsystem 2 - 	Part No SW: 5QE-915-181-A
	Component: J367-BDMHellaH10 9070
	Serial Number: 7895800000
Address 23: Brake Booster  (J539)	Labels: None
	Part No SW: 5QE 909 059 E	HW: 5QE 909 059 B
	Component: EBKV          H14 0200
	Coding: 03720100331900010002050500
	Shop #: WSC 00000 000 0000000
	ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
	ROD: EV_BrakeBoostBoschMQBOMG_004_AU37.rod
	VCID: 50E3E34389F0BB4BA13227-8005
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
	Revision: 00000000
	Coding: 5D00000000000000
	ROD: EV_ELVMarquMQB_004.rod
	VCID: 342B8FD31D28E76BA51A6B-8061
Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
	Part No SW: 5Q0 959 593 E	HW: 5Q0 959 593 B
	Coding: 00101F205C00040000001003
	ROD: EV_DCUDriveSideEWMAXKLO.rod
	B1487 54 [008] - Missing Calibration / Basic Setting
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 5Q0 909 144 T	HW: 5Q0 909 144 R
	Component: EPS_MQB_ZFLS  128 1072
	Coding: D106
	ROD: EV_SteerAssisMQB_013.rod
	VCID: 45CDC21746B26EE302A4AE-8010
Address 51: Electric Drive  (J841)	Labels: None
	Part No SW: 5G0 907 080 E	HW: 5G0 907 080 E
	Component: LE Gen 3.3
	Revision: 00H11000
	Coding: C0020000000000000000
	ASAM Dataset: EV_DMCM08530115G0907080E 001008
	ROD: EV_DMCM08530115G0907080E.rod
	VCID: 29156EA7CAEAAA83068C92-807C
Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
	Part No SW: 5Q0 959 592 E	HW: 5Q0 959 592 B
	Coding: 001017205E00040000001003
	ROD: EV_DCUPasseSideEWMAXKLO.rod
	VCID: 42C7D90B579C59DB27868D-8017
Address 55: Xenon Range  (J745)	Labels: None
	Part No SW: 8V0 907 357 A	HW: 7P6 907 357 B
	Component: MxB-ECU       001 0230
	Revision: --------
	Coding: 0E5A00102B200200
	ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
	VCID: 3E3FADFB23643D3B437EF9-806B
Address 5F: Information Electr.  (J794)	Labels: None
	Part No SW: 81A 035 842 A	HW: 81A 035 842 A
	Component: MU-S-D-ER     710 0771
	Coding: 01739300FF00000011111101000A02002F0027440170010002
	ASAM Dataset: EV_MUStd6C3DELP 001013
	ROD: EV_MUStd6C3DELP_AU37.rod
	VCID: 21057687B2DA62C35E5C3A-8074
	Subsystem 1 - 	Part No SW: 8V0-919-604-C
	Component: DU High      H49 0014
	Serial Number: AUZ8Z9GY200000
	Subsystem 2 - 	Part No SW: 8V0-919-614-BB
	Component: ControlUnit_BH50 0103
	Serial Number: ALJAL114101600000000
Address 75: Telematics  (J949)	Labels: 5Q-75.clb
	Part No SW: 5QE 035 284 C	HW: 5QE 035 284 C
	Component: OCULowMQBEU   012 0717
	Coding: 0173930110969A0100F800000000
	ROD: EV_OCULowMQB.rod
	VCID: 44CBDF134D8857EB15BABB-8011
Address 8C: Hybrid Battery  (J840)	Labels: None
	Part No SW: 5Q0 915 182 D	HW: 5Q0 915 182 C
	Component: BECM          H05 0911
	Coding: 00000000
	ASAM Dataset: EV_BECM09620115Q0915182 006040
	ROD: EV_BECM09620115Q0915182.rod
	Subsystem 1 - 	Part No SW: 5Q0-915-250-E
	Component: BJBH28 0240
	Subsystem 2 - 	Part No SW: 5QE-915-591-E
	Component: 6D1          H14 0481
	Serial Number: V013C1661700000
	Subsystem 3 - 	Part No SW: 5QE-915-591-E
	Component: 6D2          H14 0481
	Subsystem 4 - 	Part No SW: 5QE-915-591-E
	Component: 6D3          H14 0481
	Subsystem 5 - 	Part No SW: 5QE-915-591-E
	Component: 6D4          H14 0481
	Subsystem 6 - 	Part No SW: 5QE-915-591-E
	Component: 6D5          H14 0481
	Subsystem 7 - 	Part No SW: 5QE-915-591-E
	Component: 6D6          H14 0481
	Subsystem 8 - 	Part No SW: 5QE-915-591-E
	Component: 6D7          H14 0481
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q-a5.clb
	Part No SW: 3Q0 980 654 G	HW: 3Q0 980 654
	Component: MQB_B_MFK     H06 0231
	Coding: 0403070300000401012200448048A90084000E200020
	ROD: EV_MFKBoschMQBB_001_AU37.rod
Address C6: Batt. Chrg.  (J1050)	Labels: None
	Part No SW: 5QE 915 682 AF	HW: 5QE 915 682 AF
	Component: OBC KOSTAL    H31 4013
	Revision: --------
	Coding: 115068223000
	ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
	ROD: EV_OBCSinglPhaseKLOMQB12P.rod
	VCID: 9165A647C27A72436EBC6A-80C4
When I find time to carry the laptop around, I'll do an auto-scan and channel maps with VCDS Desktop.
henbo
C?ID=318655
There is little to report as my HN is currently an OBD-II interface only.
I decided to try and resolve my IDE08985 and IDE08986 value decoding issue by clearing Dataset Cache and ROD Files, then downloading any current ASAM files.
1) VCDS Mobile AutoScan reports missing ASAM as expected, but once all (949KB) is downloaded and verified, it stops after extracting some files and complains about the Internet connection.
2) VCDS Mobile Check for Updates reports "Internal server error. Please try again."
3) Selecting individual controller units, ASAM files are looked up, but not found (e.g. 01 - Engine), or, for other units (e.g. C6 - Battery Charger), a download is found but either stalls at 0% or the page does not redirect after the update is shown as finished. ASAM data is not available in any case.
4) Using VCIConfig V2.242 (18.9), ROD updates are downloaded, extracted and written to SD (successfully), but after the update, VCDS "Test" reports "The HEX-NET interface is busy talking to VCDS-Cloud. Please try again in a few seconds". This behavior does not change over time (hours). It is also the same via USB or NET. VCIConfig is able to connect and control the interface anyway and Update reports "You are up to date." Nevertheless, for VCDS Mobile, ASAM data is still not available.
To get the latest ASAM files onto the interface again, is there anything more I could try other than performing a full factory reset?
Shaun
Your alpha channel access expired, which was probably causing issues. I've added your interface back to the alpha channel for another month. Please try again with VCIConfig.
henbo
C?ID=318655
Finally, I am back in business (actually, pastime, considering the hours I already spent on it) but it was not exactly straightforward.
I didn't know how the various release channels work so I previously didn't see them as a possible problem or try and change them.
Nevertheless, just trying to update again with VCIConfig before and after an VCDS Mobile AutoScan did not resolve the issues. The behavior was almost exactly the same. Only VCDS Self Update report once "You are up to date.". Later, it was back to "Internal Server Error".
There was also no update from VCIConfig after I explicitly switched to the Beta channel. After another VCDS Mobile AutoScan, VCIConfig downloaded 474k of RODs and extracted them, but, again, ASAM data was not available using VCDS Mobile.
I then switched to the "Release" channel, which caused the DS to be updated (down-dated?) with an apparently small download. Nevertheless, VCDS "Test" still reported the "interface busy talking to VCDS Cloud" thing.
I switched back to "Beta" channel, afterwards a whole lot of DS updates was downloaded again and extracted, painfully slow this time.
But I was rewarded with a perfect VCDS Mobile AutoScan and correct reading of all the MVB I am interested in. HUDs had to be recreated, but I've become quite quick at that.
It would be good to know what I have to do once the Alpha access expires. The whole update thing is really time consuming and I would like to plan ahead for that.
I have to say, the big HV-battery in the 8VA e-tron (and being able to easily connect a 3.5 kW charger) is quite a plus for not having to worry about the 12 V system going South and not blowing a gallon of gas or two into the blue sky while running all the autoscans and updates.
Shaun
Well, you're on the beta channel now, and the beta channel never expires, so there is nothing that you NEED to do. You can stay on the beta channel and receive beta testing updates whenever they are available.
Warmshoe
C?ID=44235
Greetings all, I am having a similar issue, Test/USB, "Hex-Net interface is busy talking to VCDS-cloud...". Just updated to 18.9.0 and firmware "you are up to date". Hex-net via USB (both ports and rebooted) green/orange/flashing green LED. On both '08 R32 and '18 A5.
Then OK:
Port status OK
Interface: Not found!
OK to open firmware
Then it says firmware is latest
Shower-rinse-repeat, over and over.
Please advise. Damn near in limp mode, gotta get cracking on this. Many thanks.
Jon
PS - oops, not see this is in wrong forum, searched for "Hex-Net interface is busy talking to VCDS-cloud..."
Then OK:
Port status OK
OK to open firmware
Have you re-booted it after update?
If that doesn't fix it, please go to the Advanced tab, switch it to Beta channel and update again.
Warmshoe
C?ID=44235
I had rebooted and beta channel worked, thank you.
Jon
