Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2015 VW Jetta battery replacement
    Jul 2014
    Tallinn, Estonia
    Was the ignition on even? Anyway the steering and traction lights after disconnecting the battery are normal for electric steering assist VWs. When standing still with the engine running, turn lock to lock and drive forward and the steering light will go out.
  2. #12
    Feb 2017
    A VM isn't frowned upon if it works. But yours doesn't seem to be working real well. Maybe try a different one?
    does vagcom still have a restriction on the amount of times you can activate your license with different computers? It used to be 2 activations per account right? I believe i have a windows computer around the house and that would be my second activation
  3. #13
    Near Philadelphia, PA, USA
    VCDS-Lite can only be installed twice before a new license has to be purchased. VCDS has no such restrictions but it must be used with a Ross-Tech dongle style interface.
    VCDS-Lite works with car models 1995 through 2006ish... when most VAG cars moved to CAN diagnostics. VCDS-Lite is K-Line only and will not work on the more recent platforms.
  4. #14
    Feb 2017
    Quote Originally Posted by Bruce View Post
    Good to know. I do have VCDS with a MicroCAN so shouldn’t have a problem. Thank you!
  5. #15
    Quote Originally Posted by modderspot View Post
    Right, you can use it on any computer you wish because the license is embedded in the interface, and the software will read the license info from the interface when you connect to a car.
  6. Likes modderspot liked this post
  7. #16
    Feb 2017
    AutoScan using Windows 7
    Thursday,27,September,2018,09:48:14:16856
    VCDS Version: 18.2.1.5
    VIN: 3VWD17AJ6FM219580   License Plate:
    Mileage: 96340km-59862mi   Repair Order:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 2E 37 44 56 75 77
    VIN: 3VWD17AJ6FM219580   Mileage: 96340km-59862miles
    37-Navigation -- Status: Malfunction 1010
    56-Radio -- Status: Sporadic communication error 1000
    75-Telematics -- Status: Malfunction 1010
    Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 071 C    HW: 06K 907 425 C
       Component: Simos18.2     H13 8100
       Revision: --H13---
       Coding: 001A0012242400175000
       Shop #: WSC 00066 790 00011
       ASAM Dataset: EV_ECM18TFS02006K906071C 001004
       ROD: EV_ECM18TFS02006K906071C.rod
       VCID: 2B7BE64A4244E81CA1-807E
    17178 - Databus
                        Mileage: 96304 km
                        Date: 2018.09.26
                        Time: 07:49:53
                        Engine speed: 711.00 /min
                        Normed load value: 7.5 %
                        Coolant temperature: 86 ∞C
                        Intake air temperature: 47 ∞C
                        Voltage terminal 30: 13.984 V
                        Unlearning counter according OBD: 38
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    Address 02: Auto Trans (J217)       Labels:| 09G-927-749-V1.clb
       Part No SW: 09G 927 749 A    HW: 09G 927 749 A
       Component: AISIN AG6 G3  109 2856
       Coding: 000348
       ASAM Dataset: EV_TCMAQ250031 001004
       ROD: EV_TCMAQ250031_001_VW26.rod
       VCID: 3753CA3A8E0C5CFCD5-8062
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: A14B400C49230003851002EC92190041A5140022
       Shop #: WSC 00066 123 12345
       VCID: 04296DF6875AC76400-8050
                        Reset counter: 103
                        Mileage: 96305 km
                        Date: 2018.09.26
                        Time: 02:25:01
                        Count: 7
                        Count: 12
                        Count: 12800
                        Count: 16390
                        Count: 50432
                        Count: 198
                        Count: 507
                        Count: 65280
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 63
                        Mileage: 96305 km
                        Date: 2018.09.26
                        Time: 02:24:52
                        Count: 3
                        Count: 12
                        Count: 12800
                        Count: 16401
                        Count: 50688
                        Count: 507
                        Count: 65280
       Revision: 00092000    Serial number: 0342801868
       Coding: 000F0F
       Shop #: WSC 00066 000 00190
       Part No SW: 5C0 820 047 CA    HW: 5C0 820 047 CA
       Component: J301  Klimaanlage   0207
       Revision: 2001001S    Serial number: 00000002328854
       VCID: 61E74462B808724C4B-8034
       Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
       Component: BCM PQ25 Max3 H74 0725
       Revision: B8074001    Serial number: 27018241140147
       Coding: 7A994FB8082B0F00003826803C0884CD0FC6700E60A04010B0A050022844
       Shop #: WSC 14112 002 104857
       VCID: 3041F12663628BC494-8064
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Serial number: 14102585140807185821
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Serial number: 14102584140814181828
       Coding: 820000
       Subsystem 3 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
       Serial number: 1931411290401206AD1B
       Coding: 280000
       Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14102587140813144204
       Coding: 800000
       Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14102586140815071333
       Coding: 800000
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 62
                        Mileage: 45729 km
                        Date: 2016.09.19
                        Time: 13:10:34
                        Fault Status: 00100111
                        Reset counter: 101
                        Mileage: 45729 km
                        Date: 2016.09.19
                        Time: 13:10:34
       Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
       Component: AirbagVW10    500 0975
       Serial number: 003LZD02C505
       Coding: 00004B32
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 72C53B2EA5EEF9D422-8026
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  H05 0016
       Serial number: IBH0000J14000160XU0B
       Coding: 30334B
       Serial number: 3572MSME1E2B6C47ZZZ7
       Serial number: 3582MSME6C186C47ZZZ7
       Serial number: 3516KSME762A1C30ZZZU
       Serial number: 3526KSME5011792FZZZU
       Serial number: 3556LSME0055702FZZZS
       Serial number: 3566LSME0D69702FZZZ4
       Part No SW: 5C6 920 954 B    HW: 5C6 920 954 B
       Component: KOMBI         H04 0806
       Coding: 270A00
       Shop #: WSC 00066 123 00121
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 2D7FE8527C50E62CBF-8078
       Part No SW: 6N0 909 901     HW: 7H0 937 090 A
       Component: GW-K-CAN TP20 H74 0725
       Revision: B8074001
       Coding: 102200
       VCID: 70C13126A3E2CBC4D4-8024
    01304 - Radio
                        Reset counter: 101
                        Mileage: 96305 km
                        Date: 2018.09.26
                        Time: 00:05:50
                        Reset counter: 101
                        Mileage: 96305 km
                        Date: 2018.09.26
                        Time: 00:05:50
    01302 - Control Module for Telematic (J499)
                        Reset counter: 65
                        Mileage: 95805 km
                        Date: 2018.09.10
                        Time: 19:43:38
       Component: IMMO          H04 0806
       Coding: 000007
       Shop #: WSC 00066 123 00119
       VCID: 6AF5234E8D3E31149A-803E
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
       Revision: 00000000    Serial number: 14000181826002
       Coding: 4900000000000000
       Shop #: WSC 00066 000 00119
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3041F1266B628BC494-8064
    Address 2E: Media Player 3
       Part No SW: 1Q0 035 274 C    HW: 1Q0 035 274 C
       Component: RNS315-NAR    H81 0501
       Serial number: VWZAZ2R0856502
       Coding: 040004610200060000008000
       Shop #: WSC 07928 002 1048576
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 2A75E34E4DBEF1145A-807E
       Component: NAR_V6N  0051
    1048580 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 100
                        Mileage: 96302 km
                        Date: 2018.09.26
                        Time: 07:11:20
    1048671 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 65
                        Mileage: 95805 km
                        Date: 2018.09.10
                        Time: 19:43:38
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 305    3501
       Revision: 00H22000
       VCID: 3957CC0270184A8C23-806C
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0102
       Serial number: 000003554140525
       Coding: 02630102C2421A107F1606000000
       Shop #: WSC 01383 790 50316
       ROD: EV_OCULow_001.rod
       VCID: 538B9EAA3AB490DCC9-8006
    13637376 - Mobile Online Services
              B149A F2 [008] - Remote Control of Vehicle Signalling
                        Reset counter: 216
                        Mileage: 63402 km
                        Date: 2017.04.16
                        Time: 12:36:17
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 0
       Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
       Component: TELEFON       H07 0593
       Revision: 1B001001    Serial number: 00007666425946
       Coding: 0A100300A0010110
       ROD: EV_UHVUMI.rod
       VCID: 3245FB2E656EB9D4E2-8066
    0023 - Databus
                        Reset counter: 65
                        Mileage: 95805 km
                        Date: 2018.09.10
                        Time: 19:43:34
    End-------------------------(Elapsed Time: 02:55)--------------------------
    Engine
    Thursday,27,September,2018,09:49:19:16856
                    Address 01: Engine       Labels: 06K-907-425-V2.clb
    Control Module Part Number: 06K 906 071 C    HW: 06K 907 425 C
      Component and/or Version: Simos18.2     H13 8100
               Software Coding: 001A0012242400175000
                Work Shop Code: WSC 00066 790 00011
                  ASAM Dataset: EV_ECM18TFS02006K906071C 001004 (VW36)
    17178 - Databus
                        Mileage: 96304 km
                        Date: 2018.09.26
                        Time: 07:49:53
    ABS Brakes
    Thursday,27,September,2018,09:50:28:16856
                    Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 BS    HW: 1K0 907 379 BS
      Component and/or Version: ESP MK60EC1   H46 0166
               Software Coding: A14B400C49230003851002EC92190041A5140022
                Work Shop Code: WSC 00066 123 12345
                        Reset counter: 103
                        Mileage: 96305 km
                        Date: 2018.09.26
                        Time: 02:25:01
                        Count: 7
                        Count: 12
                        Count: 12800
                        Count: 16390
                        Count: 50432
                        Count: 198
                        Count: 507
                        Count: 65280
                        Reset counter: 63
                        Mileage: 96305 km
                        Date: 2018.09.26
                        Time: 02:24:52
                        Count: 3
                        Count: 12
                        Count: 12800
                        Count: 16401
                        Count: 50688
                        Count: 507
                        Count: 65280
    Cent. Elect. ---- I know about these two, changed the running lights to aftermarket, Eventually i turned off DRL's
    Thursday,27,September,2018,09:51:21:16856
                    Address 09: Cent. Elect.       Labels: 7H0-937-08x-09.clb
    Control Module Part Number: 7H0 937 090 E    HW: 7H0 937 090 A
      Component and/or Version: BCM PQ25 Max3 H74 0725
               Software Coding: 7A994FB8082B0F00003826803C0884CD0FC6700E60A04010B0A050022844
                Work Shop Code: WSC 14112 002 104857
                        Reset counter: 62
                        Mileage: 45729 km
                        Date: 2016.09.19
                        Time: 13:10:34
                        Reset counter: 101
                        Mileage: 45729 km
                        Date: 2016.09.19
                        Time: 13:10:34
    CAN Gateway
    Thursday,27,September,2018,09:52:08:16856
                    Address 19: CAN Gateway       Labels: 6N0-909-901-6R.clb
    Control Module Part Number: 6N0 909 901     HW: 7H0 937 090 A
      Component and/or Version: GW-K-CAN TP20 H74 0725
               Software Coding: 102200
    01304 - Radio
                        Reset counter: 101
                        Mileage: 96305 km
                        Date: 2018.09.26
                        Time: 00:05:50
                        Reset counter: 101
                        Mileage: 96305 km
                        Date: 2018.09.26
                        Time: 00:05:50
                        Reset counter: 65
                        Mileage: 95805 km
                        Date: 2018.09.10
                        Time: 19:43:38
    Navigation
    Thursday,27,September,2018,09:52:49:16856
                    Address 37: Navigation       Labels: 1K0-035-27x-37.clb
    Control Module Part Number: 1Q0 035 274 C    HW: 1Q0 035 274 C
      Component and/or Version: RNS315-NAR    H81 0501
               Software Coding: 040004610200060000008000
                Work Shop Code: WSC 07928 002 1048576
                  ASAM Dataset: EV_RNS315NARV2UDS 001705 (VW36)
              U1400 00 [008] - -
                        Reset counter: 100
                        Mileage: 96302 km
                        Date: 2018.09.26
                        Time: 07:11:20
              U1111 00 [008] - -
                        Reset counter: 65
                        Mileage: 95805 km
                        Date: 2018.09.10
                        Time: 19:43:38
    Telematics
    Thursday,27,September,2018,09:53:38:16856
                    Address 75: Telematics       Labels: 12E-035-284.clb
    Control Module Part Number: 561 035 285     HW: 561 035 285
      Component and/or Version: OCULowUSA     014 0102
               Software Coding: 02630102C2421A107F1606000000
                Work Shop Code: WSC 01383 790 50316
                  ASAM Dataset: EV_OCULow 001010 (VW36)
                        Reset counter: 216
                        Mileage: 63402 km
                        Date: 2017.04.16
                        Time: 12:36:17
                        Fault Priority: 8
                        Reset counter: 0
    Telephone
    Thursday,27,September,2018,09:54:05:16856
                    Address 77: Telephone       Labels: 5N0-035-729.clb
    Control Module Part Number: 5N0 035 729 E    HW: 5N0 035 729 E
      Component and/or Version: TELEFON       H07 0593
               Software Coding: 0A100300A0010110
                  ASAM Dataset: EV_UHVUMI 001007 (VW36)
                           ROD: EV_UHVUMI.rod
    0023 - Databus
                        Reset counter: 65
                        Mileage: 95805 km
                        Date: 2018.09.10
                        Time: 19:43:34
  8. Likes Uwe, Dana liked this post
