Results 1 to 10 of 16
Thread: 2015 VW Jetta battery replacement
    Feb 2017
    I have a 2015 VW Jetta Sport 1.8T. Battery took a . Got a new battery and they said I'd have to reprogram it. I said I had a programmer (VagCom), no big deal. Brought it home, had Traction control and Steering Column lock light on. Then I started researching and ross tech had a video about the BEM code. Looked up a video from ross tech and they said that I can only use an OE battery. Tried tried tried to find out why these lights were on then concluded to return new battery and get old battery back. I took a picture of the top of the old battery below.
    Today, I spoke to VW and they said that I can use an aftermarket battery, as long as I trust the brand, which was duralast. I inquired about the BEM code and the guy asked the technician and he had no idea what he was talking about.
    Who is the the "they" that told you you'd have to reprogram it?
    Please post an Auto-Scan. It's quite possible that your Jetta doesn't have a Battery Management system and doesn't need any programming.
  3. Likes Jetta ,97, Jack@European_Parts liked this post
    Dallas (McKinney) ,TX ,USA
    There should not be any programing on that car . For Traction light ,just drive car over 20 miles and it will go out by it self.
    One thing I will tell you, Original battery is cheaper then any Aftermarket. So I always buy original .
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
    Feb 2017
    Would the steering column light go off as well when traction control goes off?
    HQ
    Quote Originally Posted by modderspot View Post
    Maybe... depends on what kind of codes are stored. Please follow up with the request Auto-Scan.
    Jef
  7. Likes Uwe, Jack@European_Parts liked this post
    Feb 2017
    Tuesday,25,September,2018,06:48:26:16856
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(Parallels)
    VCDS Version 18.2.0.3
    VIN: 3VWD17AJ6FM219580   License Plate:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 2E 37 44 56 75 77
    75-Telematics -- Status: Malfunction 1010
    Address 01: Engine
    Address 02: Auto Trans
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: A14B400C49230003851002EC92190041A5140022
       Shop #: WSC 00066 123 12345
       VCID: 04296DF6875AC7643C-8051
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 60
                        Mileage: 96301 km
                        Date: 2045.14.24
                        Time: 06:30:00
                        Count: 16387
                        Count: 12
                        Count: 12800
                        Count: 8269
                        Count: 37376
                        Count: 256
                        Count: 510
                        Count: 6144
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 239
                        Mileage: 45729 km
                        Date: 2022.14.23
                        Time: 13:10:35
                        Count: 7
                        Count: 12
                        Count: 4096
                        Count: 16401
                        Count: 45312
                        Count: 512
    Address 05: Acc/Start Auth.
       Part No SW: 5C0 820 047 CA    HW: 5C0 820 047 CA
       Component: J301  Klimaanlage   0207
       Revision: 2001001S    Serial number: 00000002328854
       Shop #: WSC 00066 790 00011
       VCID: 61E74462B808724C77-8035
       Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
       Component: BCM PQ25 Max3 H74 0725
       Revision: B8074001    Serial number: 27018241140147
       Coding: 7A994FB8082B0F00003826803C0A84CD4FC6700E60804050B0A050022844
       Shop #: WSC 14112 002 104857
       VCID: 3041F12663628BC4A8-8065
       Subsystem 1 - Part No: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT
    Address 15: Airbags
    Address 17: Instruments
       Part No SW: 6N0 909 901     HW: 7H0 937 090 A
       Component: GW-K-CAN TP20 H74 0725
       Revision: B8074001
       Coding: 102200
       VCID: 70C13126A3E2CBC4E8-8025
    01302 - Control Module for Telematic (J499)
                        Reset counter: 65
                        Mileage: 95805 km
                        Date: 2045.14.08
                        Time: 19:43:38
    Address 25: Immobilizer
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
       Revision: 00000000    Serial number: 14000181826002
       Coding: 4900000000000000
       Shop #: WSC 00066 000 00119
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3041F1266B628BC4A8-8065
    Address 2E: Media Player 3
    Address 37: Navigation
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 305    3501
       Revision: 00H22000
       VCID: 3957CC0270184A8C1F-806D
    Address 56: Radio
    Address 75: Telematics
    Address 77: Telephone
    End-------------------------(Elapsed Time: 02:02)--------------------------
    Wednesday,26,September,2018,08:36:08:16856
    37-Navigation -- Status: Malfunction 1010
    56-Radio -- Status: Sporadic communication error 1000
    Address 01: Engine
       Revision: 00H46001
                        Reset counter: 63
                        Mileage: 96305 km
                        Date: 2045.14.24
                        Time: 02:24:52
                        Count: 3
                        Count: 12
                        Count: 12800
                        Count: 16401
                        Count: 50688
                        Count: 507
                        Count: 65280
                        Reset counter: 63
                        Mileage: 96305 km
                        Date: 2045.14.24
                        Time: 02:25:01
                        Count: 7
                        Count: 12
                        Count: 12800
                        Count: 16390
                        Count: 50432
                        Count: 198
                        Count: 507
                        Count: 65280
       Coding: 7A994FB8082B0F00003826803C0884CD0FC6700E60804010B0A050022844
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Serial number: 14102585140807185821
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Coding: 820000
       Component: 14
    Address 15: Airbags
       Revision: B8074001
       Coding: 102200
    01304 - Radio
                        Reset counter: 101
                        Mileage: 96305 km
                        Date: 2045.14.24
                        Time: 00:05:50
                        Reset counter: 101
                        Mileage: 96305 km
                        Date: 2045.14.24
                        Time: 00:05:50
                        Reset counter: 65
                        Mileage: 95805 km
                        Date: 2045.14.08
                        Time: 19:43:38
       Revision: 00H22000
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 9.0 V
                            PD
                        Temperature: 32.0∞C
                        Count: 2
                        Steering Angle: 0.00∞
                            SteerAng n.Init
    Address 56: Radio
    End-------------------------(Elapsed Time: 01:49)--------------------------
    Feb 2017
    Just drove .001 miles and the lights went off
  10. #8
    HQ
    Well, glad the lights went out... but several control modules are like a tyrannosaurus rex going for the cookie jar on the top shelf..... Cannot be reached.
    Are you able to scan those modules directly?
    Jef
  11. Likes NZDubNurd liked this post
  12. #9
    Feb 2017
    I'm going to check after work. Down side is I'm on a VM which doesn't exactly work all the time which I know it's "frowned" upon to use a VM because it isn't promised that it will work. It's a lot of repetition when it comes to long procedures like auto-scan's.
  13. #10
    A VM isn't frowned upon if it works. But yours doesn't seem to be working real well. Maybe try a different one?
