Can anyone help with coding this ABS Module full scan of car attached.
> Log-2N_6269-WVWZZZ6RZBU091610-88320km-54879mi.txt
> Tuesday,25,September,2018,04:18:09:50011
> VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
> VCDS Version: 18.2.1.2 (x64)
> Data version: 20180518 DS287.1
> www.Ross-Tech.com
> VIN: WVWZZZ6RZBU091610 License Plate: 2N_6269
> Mileage: 88320km-54879mi Repair Order:
> Chassis Type: 6R-VW25 (6N0)
> Scan: 01 02 03 04 08 09 15 17 19 25 44 56
> VIN: WVWZZZ6RZBU091610 Mileage: 88320km-54879miles
> 01-Engine -- Status: OK 0000
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: Malfunction 1010
> 04-Steering Angle -- Status: OK 0000
> 08-Auto HVAC -- Status: Malfunction 0010
> 09-Cent. Elect. -- Status: OK 0000
> 15-Airbags -- Status: Malfunction 0010
> 17-Instruments -- Status: Malfunction 1010
> 19-CAN Gateway -- Status: Malfunction 0010
> 25-Immobilizer -- Status: OK 0000
> 44-Steering Assist -- Status: Malfunction 0010
> 56-Radio -- Status: Malfunction 0010
> Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
> Part No SW: 03F 906 070 BQ HW: 03F 906 070 D
> Component: SIMOS10.20H02 9692
> Revision: -------- Serial number:
> Coding: 002500D6200400080000
> Shop #: WSC 31414 790 50316
> ASAM Dataset: EV_ECM12TFS02103F906070BQ 003009
> ROD: EV_ECM12TFS_003_VW25.rod
> VCID: 72E014E8A56C7AD421-8026
> No fault code found.
> Readiness: 0110 0101
> Address 02: Auto Trans Labels: 0AM-927-769.clb
> Part No SW: 0AM 300 050 Q HW: 0AM 927 769 D
> Component: GSG DSG AG7 431 9060
> Revision: 00043014 Serial number: CU501307316650
> Coding: 0000020
> Shop #: WSC 58040 981 137700
> VCID: 3776E5FC458EDFFCD6-515A
> Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
> Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
> Component: ESP8.2i front H05 0001
> Revision: --------
> Coding: 000000000000000000000000000000000000
> Shop #: WSC 31414 790 31414
> VCID: 0716553CB2EE6F7C66-8052
> 4 Faults Found:
> 03306 - Coding Not Valid
> 000 - - - Intermittent
> Freeze Frame:
> Fault Status: 00100000
> Fault Priority: 0
> Fault Frequency: 1
> Reset counter: 74
> Mileage: 88328 km
> Time Indication: 0
> Date: 2013.02.15
> Time: 02:33:36
> Freeze Frame:
> Hex Value: 0x0002
> Hex Value: 0x0000
> Hex Value: 0x32E7
> Hex Value: 0x259C
> Hex Value: 0x00FF
> Hex Value: 0x7F7F
> Hex Value: 0x7CF9
> 01042 - Control Module; Not Coded
> 000 - -
> Freeze Frame:
> Fault Status: 01100000
> Fault Priority: 0
> Fault Frequency: 1
> Reset counter: 34
> Mileage: 88328 km
> Time Indication: 0
> Date: 2013.02.15
> Time: 02:42:09
> Freeze Frame:
> Hex Value: 0x0007
> Hex Value: 0x0000
> Hex Value: 0x3213
> Hex Value: 0x149D
> Hex Value: 0x00FF
> Hex Value: 0x7F7F
> Hex Value: 0x7F00
> 00778 - Steering Angle Sensor (G85)
> 005 - No or Incorrect Basic Setting / Adaptation
> Freeze Frame:
> Fault Status: 01100101
> Fault Priority: 0
> Fault Frequency: 1
> Reset counter: 34
> Mileage: 88328 km
> Time Indication: 0
> Date: 2013.02.15
> Time: 02:42:09
> Freeze Frame:
> Hex Value: 0x0007
> Hex Value: 0x0000
> Hex Value: 0x3251
> Hex Value: 0x1B9D
> Hex Value: 0x00FF
> Hex Value: 0x7F7F
> Hex Value: 0x7F00
> 00493 - ESP-Sensor Unit (G419)
> Freeze Frame:
> Fault Priority: 0
> Fault Frequency: 1
> Reset counter: 34
> Mileage: 88328 km
> Time Indication: 0
> Date: 2013.02.15
> Time: 02:42:09
> Freeze Frame:
> Hex Value: 0x0007
> Hex Value: 0x0000
> Hex Value: 0x32E1
> Hex Value: 0x209D
> Hex Value: 0x00FF
> Hex Value: 0x7F7F
> Hex Value: 0x7F00
> Address 08: Auto HVAC (J301) Labels: None
> Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
> Component: Man AC 02 0101
> Revision: 0002S 02
> VCID: 3260D4E86DEC3AD4E1-8066
> 2 Faults Found:
> 01316 - ABS Control Module
> 004 - No Signal/Communication - Intermittent
> Freeze Frame:
> Fault Status: 00100100
> Fault Priority: 6
> Fault Frequency: 1
> Reset counter: 74
> Mileage: 88328 km
> Time Indication: 0
> Date: 2011.09.20
> Time: 02:41:54
> 01317 - Control Module in Instrument Cluster (J285)
> Freeze Frame:
> Fault Priority: 6
> Fault Frequency: 1
> Reset counter: 74
> Mileage: 88328 km
> Time Indication: 0
> Date: 2011.09.20
> Time: 02:42:09
> Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
> Part No SW: 6R0 937 087 J HW: 6R0 937 087 A
> Component: BCM PQ25 H+3 H46 0230
> Revision: BE046001 Serial number: 0393 138110105
> Coding: 24B02BBF08A10000003008003C2B0CD00040410F60040000200000000000
> VCID: 448C8230C758846443-8010
> Subsystem 1 - Part No SW: 6R0 959 802 AC HW: 6R0 959 802 AC Labels: 6R0-959-802.CLB
> Component: J386__TSG_FT 007 1611
> Serial number: KU0KU024031100013265
> Coding: 18BC34
> Subsystem 2 - Part No SW: 6R0 959 801 AE HW: 6R0 959 801 AE Labels: 6R0-959-801.CLB
> Component: J387__TSG_BT 007 1611
> Serial number: KU0KU013041100010168
> Coding: 08BC34
> Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
> Component: J388__TSG_HL 007 1611
> Serial number: KU0KU014041100012441
> Coding: 08BC32
> Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
> Component: J389__TSG_HR 007 1611
> Serial number: KU0KU017041100010235
> Coding: 08BC32
> Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
> Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
> Component: VW10Airbag01K H09 0020
> Revision: -------- Serial number: 003GY0037BSG
> Coding: 00314B
> ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
> ROD: EV_AirbaVW10BPAVW250.rod
> VCID: 4B9EA90CE2064B1C82-801E
> Crash sensor for side airbag: driver side:
> Serial number: 3575HRB404T0G6909PAF
> Crash sensor for side airbag: front passenger side:
> Serial number: 3585HRB404V0G690DHKO
> Crash sensor for side airbag: rear: driver side:
> Serial number: 3515RRB405N0GQ8QA17X
> Crash sensor for side airbag: rear: passenger side:
> Serial number: 3525RRB405P0GQ8Q60F$
> 3 Faults Found:
> 9445417 - Key switch for deactivation of passenger-side airbag
> B1020 29 [136] - Signal Implausible
> MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
> Freeze Frame:
> Fault Status: 00000001
> Fault Priority: 2
> Fault Frequency: 254
> Mileage: 83754 km
> Date: 2017.11.20
> Time: 16:19:35
> 12854016 - Databus
> U1122 00 [008] - Implausible Message
> [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
> Freeze Frame:
> Fault Priority: 6
> Reset counter: 74
> Mileage: 88328 km
> Date: 2018.09.23
> Time: 02:33:13
> 12656896 - Databus
> Freeze Frame:
> Fault Priority: 6
> Fault Frequency: 55
> Reset counter: 74
> Mileage: 87684 km
> Date: 2018.08.19
> Time: 03:19:06
> Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
> Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
> Component: KOMBI H05 0304
> Serial number: 00000000000000
> Coding: 540A00
> ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
> ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
> VCID: 3776E5FC8E8EDFFCD6-8062
> 2 Faults Found:
> 10485833 - Internal Control Module Memory Check Sum Error
> B2000 49 [137] - Internal electronic failure
> MIL ON - Confirmed - Tested Since Memory Clear
> Freeze Frame:
> Fault Priority: 2
> Fault Frequency: 1
> Mileage: 86677 km
> Date: 2018.06.23
> Time: 00:01:09
> 12656896 - Function Restricted due to Missing Message(s)
> U1111 00 [008] - -
> Freeze Frame:
> Fault Priority: 6
> Fault Frequency: 1
> Reset counter: 74
> Mileage: 88328 km
> Date: 2018.09.23
> Time: 02:42:01
> Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
> Part No SW: 6N0 909 901 HW: 6R0 937 087 A
> Component: GW-K-CAN TP20 0230
> Coding: 002300
> VCID: 70E41EE0A36048C4D7-8024
> 2 Faults Found:
> Freeze Frame:
> Fault Priority: 2
> Fault Frequency: 1
> Reset counter: 74
> Time Indication: 0
> Freeze Frame:
> Fault Priority: 2
> Fault Frequency: 1
> Reset counter: 74
> Time Indication: 0
> Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
> Part No SW: 5K0 953 234 HW: 5K0 953 234
> Component: IMMO H05 0304
> Serial number:
> Coding: 000000
> Shop #: WSC 00000 000 00000
> ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
> ROD: EV_Immo_UDS_VDD_RM09.rod
> VCID: 6AD00C888DBCB21499-803E
> Address 44: Steering Assist Labels: 6Q0-423-156.clb
> Part No: 6R0 423 156 B
> Component: LenkhilfeTRW V277
> Coding: 11230
> Shop #: WSC 31414
> VCID: 2F66DD9CEADE173C8E-807A
> 1 Fault Found:
> 49-10 - No Communications - Intermittent
> Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
> Part No SW: 5M0 035 183 HW: 5M0 035 183
> Component: Radio RCD310 016 0049
> Revision: 01000000 Serial number: VWZ1Z2L0182799
> Coding: 0500040002
> VCID: 66C878B891A49674BD-8032
> 1 Fault Found:
> 00625 - Vehicle Speed Signal
> Freeze Frame:
> Fault Priority: 6
> Fault Frequency: 1
> Reset counter: 74
> Mileage: 88328 km
> Time Indication: 0
> Date: 2013.02.13
> Time: 02:42:31
> End-------------------------(Elapsed Time: 02:48)--------------------------
