I have a 2015 Passat TDI with the phase 2 exhaust modification. I was trying to see if the EGT's were viewable after the phase 2 modification because I installed a PF03+ and it is unable to find them. Autopolar seems to believe it may not be viewable so thy cant program it into their firmware.
I have included an autoscan for my full vehicle for reference. If EGT's are viewable, can anyone give me the PID's and formula that I can forward to autopolar?
Monday,24,September,2018,17:49:29:20576
VCDS Version: 18.2.1.2
VIN: 1VWBV7A39FC086733 License Plate:
Mileage: 95430km-59297mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
75 77
VIN: 1VWBV7A39FC086733 Mileage: 95430km-59297miles
Address 01: Engine (J623-CVCA) Labels: None
Part No SW: 04L 997 016 D HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9466
Revision: 8AH20---
Coding: 011D0012032410080000
Shop #: WSC 22600 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016D 004002
ROD: N/A
VCID: 346C8CCE9F6B0FE4F3-8060
No ASAM data for: "EV_ECM20TDI01104L997016D" (VW41)
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4518
Revision: 05653104 Serial number: 00001501231965
Shop #: WSC 09003 957 00200
VCID: 254A618AECB1666C74-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - Intermittent
Reset counter: 28
Mileage: 94195 km
Date: 2018.09.15
Time: 08:05:29
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492A0000A31203E7921C0042A0100012
VCID: 040C1C0E874B7F6403-8050
Part No SW: 561 907 426 J HW: 561 907 426 J
Component: AC Manuell H02 0404
Revision: 00001K01
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 22407A96359F915411-8076
Part No SW: 5K0 937 085 AB HW: 5K0 937 085 AB
Component: BCM PQ35 B+ 122 0174
Revision: BH122001
Coding: EF200E3B902B08D40988000106000C4002F5A00040801520648460000C70
VCID: 73EE4FD2D2E548DC2A-8026
Reset counter: 251
Term 15 Off
Voltage: 12.70 V
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD05VF4+
Coding: 00004D35
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72E04AD6A5FF41D421-8026
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y150001B8P00I
Coding: 303044
Serial number: 3572MSME4E47284EZZZ7
Serial number: 3582MSME7A414B4DZZZ5
Serial number: 3516KSME22597C34ZZZX
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME20191135ZZZC
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME461D1332ZZZR
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME1B031132ZZZH
Part No SW: 1K5 953 521 BM HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20150126201626
Coding: 088A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 79F27DFAF889328C60-802C
Component: E221__MFL-8LP H07 0023
Serial number: 00000000000001032640
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H05 0813
Coding: 231C01
VCID: 1E384E6601E7B5B435-804A
13654544 - Databus
Reset counter: 251
Mileage: 95429 km
Date: 2018.09.24
Time: 03:12:03
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 12031503000383
Coding: 461000
VCID: 0004101E9353634427-8054
Address 1C: Position Sensing
Component: IMMO H05 0813
VCID: 6AD052B68D2F891499-803E
Address 2E: Media Player 3
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0009362627
Coding: 0404B5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BBE07725275E09C12-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630150312085101
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
VCID: 3972BDFA7009F28C20-806C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FE643A2BECD6C3CCE-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011416800027
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 009 0005
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0009387535
Coding: 0404B4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CBC046E577BE7A41B-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14102631150323161125
Coding: 800000
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H08 0009
Revision: -----13S Serial number: VWZ4Z7R3688320
Coding: 0100044004000B
VCID: 2B5E97B24A55501CA2-807E
Reset counter: 95
Mileage: 92107 km
Date: 2018.07.25
Time: 23:57:07
02633 - Antenna for Satellite Tuner
Fault Status: 00101011
Reset counter: 248
Mileage: 93945 km
Date: 2018.09.09
Time: 18:38:43
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140534
Coding: 02140102C21632007F1606C00000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 142C2C4EFF2BEFE493-8040
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666961555
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 32608AD6657F01D4E1-8066
End-------------------------(Elapsed Time: 03:31)--------------------------
