Got a strange one, that I thought we'd sorted, but turns out it's intermittent and back!
Car arrived with hundreds of errors, and the two boot mounted starter mini relays jumpered (with a push switch) to allow the starter solenoid to engage and crank the car, which started it.
Check the 2 relays, both triggered by negative switching of the relay coils, and neither were being commanded. Easy, symptom found now to find to root cause.
One key fact, was that the starter button would always engage the ignition "on" and "off" when no brake pedal, and Engine off if it was running, and when brake pedal pressed it did not "cycle" to ignition off, remaining ignition on but no crank.
So brake pedal was considered not a high suspect, and again switch was at least partially functional (not sure how many wires it uses, no clearly can't say it's 100%!)
By-passing the relays as was done, always cranks the car, so starter motor was again not high on the suspect list.
Systematically cleared the various errors, none seemingly relevant but necessary anyway as ABS and various low battery and CAN short/open errors logged, and needed to see which might return or not clear etc.
Checked the parameter in the "05-Acc/Start Auth" which flicked from 0 to 1 (called status I think) when pressing the starter button (I'm pretty sure but had a hectic day, so maybe I could have been dreaming, but almost 1000% sure I'm correct)
Checked in Engine ECU and logged some parameters including G059/F0 which changed from "4" to "23" when pressing the starter button, while G148/F0 changes from "1" to "2" when pressing the brake pedal.
At this point I rechecked the earth command wires on the 2 relays and both were working correctly, so installed 2 new relays and voila a working car again!
Spent best part of 3 hours road testing and going over speed bumps/vibration road surfaces trying to provoke the fault and unable to, and engine parameters both as logged earlier "4" to "23" when starting and getting a crank via the button.
None of the errors returned except the Rear parking camera and intermittently on stopping or starting 2 errors in the "05-Acc/Start Auth" ECU, see below, but above the full scan. Most often
So then along comes a late client, and car having sat for 2 hours ish and gone pretty "cold" and guess what .... the car is back to no crank!
Check relays, neither being commanded, both not getting the earth control signal. Car will crank and start if they are bypassed.
Removing the relays throws up 2 separate errors, one for each, so consider the wiring to the earth command wires to be good, and the lack of crank condition still gives these errors when they are removed and clears when replaced, while still not cranking
These errors clear and no other errors (except reverse camera) are present. None!
Even the "03285 - Sensor for Contact with Door Handle; Front Left 007 - Short to Ground - Intermittent" was not occuring!
One thing not noticed during our out of character bright sunny day, that was clear at dusk, the backlight on the start button was not functioning? (does it have one!?)
With the 05: Acc/Start Auth. (J393) status parameter no longer changing when pressing the start button (stuck on 0)
And Engine parameter G059/F0 idle at 4 when not pressed and moving to 7 when pressing the start button, also showing 5,1 and even a 6 in the data log
So, to me this is clearly a ECU control issue, with either some input (button itself, some parameter {sensor} for plausibility or inter ECU comms) being the cause ???!! Famous last words!
Oh, intermittent, not quite, now it's back it's here. Might be heat related but tried everything to avoid bypassing the relays and nothing worked to allow the car to start from the button.
HELP!!
Sadly I'm without a wiring diagram for this model, so don't know what ECU commands these 2 relays, or how many wires the start button has (or if it's CAN/Data based) - Anyone able to supply?
Is there another Starter solenoid relay at the front like previous generation Bentleys? Is there an inhibitor relay beyond these 2 enabling ones?
What is the enabling criteria for the starter process? Which PIDs/parameters should be checked?
What is the description for and code description of the G059/F0 Paramater/PID ?
Is there a actuation for cranking? The engine ECU ROD seems to not be a perfect match? How do I scan for support?
Sorry for the long message, but trying to give as much detail as I can, and would rather avoid wading through hundreds of PID's to second guess which might be relevant to the starter!
Thanks in advance for any pointers or data etc
Richard
Already sent over to support the scans of the modules which are missing label files :-)
Engine Errors for relays in full:
05-Acc/Start Auth Logged errors - intermittent and not returning in current "no crank" condition
Full Scan:
Car never missed a beat the whole time!
5270 - Output for Starter Relay P0615 00 [040] - Open Circuit
5457 - Control Circuit for Starter Relay 2 P3049 00 [040] - Open Circuit
HELP!!
Richard
Address 01: Engine (J623-CKBB) Labels: None Part No SW: 07V 906 018 F HW: 07V 907 018
Component: ME17.1.1 H05 1307
Revision: Q4H05---
Coding: 0D2A0032436C00001800
Shop #: WSC 29297 001 1048576
ASAM Dataset: EV_ECM68TMP01107V906018F 001036
ROD: EV_ECM68TMP01107V906018F_BY83.rod
VCID: 3B36E164B2DE759237-806E
Mileage: 71433 km
Date: 2018.09.24
Time: 13:48:02
Engine speed: 1232.00 /min
Normed load value: 18.4 %
Coolant temperature: 87 °C
Intake air temperature: 70 °C
Voltage terminal 30: 11.520 V
Mileage: 71433 km
Date: 2018.09.24
Time: 13:46:10
Engine speed: 537.00 /min
Normed load value: 24.3 %
Coolant temperature: 86 °C
Intake air temperature: 69 °C
Voltage terminal 30: 11.897 V
Readiness: 1110 1001
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 P HW: 4H0 907 064 P
Component: BCM2 2.0 H13 0096
Coding: 059B0001000000000000
Shop #: WSC 00083 790 00174
VCID: 3620F05081FCA8FAC8-8062
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 0210000104429012
Fault Status: 00101011
Reset counter: 157
Mileage: 71433 km
Date: 2018.09.24
Time: 13:47:00
(no units): -40.0
Temperature: -1004.5°C
Raw, Index/Key Err.: 217 157 118
Angle: 8816.640°
Raw, Index/Key Err.: 236 146 110
Full Scan:
Revision: Q4H05---
Mileage: 71433 km
Date: 2018.09.24
Time: 13:48:02
Mileage: 71433 km
Date: 2018.09.24
Time: 13:46:10
Monday,24,September,2018,15:48:04:48085VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.7.2.1 (x64) HEX-NET CB: 0.4430.4
Data version: 20180808 DS295.0
VIN: SCBBA63Y4BC015423 License Plate:
Chassis Type: 3Y-BY83 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 30 34 36 3B 42
46 47 48 52 53 56 5B 5F 62 65 6C 6D 72 81 88 89 8A 8B 8D
VIN: SCBBA63Y4BC015423 Mileage: 71449km-44396miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Revision: Q4H05---
Readiness: 0100 1001
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 3Y0 927 158 A HW: 0BL 927 156 B
Component: 0BL 67 BiTRdW H08 0003
Revision: --H08---
Coding: 001001
ASAM Dataset: EV_TCMALX51011 001012
ROD: EV_TCMALX51011_001.rod
VCID: 3D32EF7CACCA7BA209-8068
Address 03: ABS Brakes (J104) Labels:. 3Y0-614-517.clb
Part No SW: 3Y0 614 517 A HW: 3Y0 614 517 A
Component: ESP PREMIUM H09 0150
Coding: 22E1820044874100D300
Shop #: WSC 00083 790 00165
ASAM Dataset: EV_ESPPremi 004018
ROD: EV_ESPPremi_004_BY73.rod
VCID: 3522F75C94FAA3E2C1-8060
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00001002112600
Coding: C028360085060301290001010101002100212323000000
VCID: 3522F75C9CFAA3E2C1-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 3Y0 907 040 B HW: 3Y0 907 040 B
Component: Klima 4 Zonen H07 0030
Coding: 282100F680
ROD: EV_AirCondiFront_BY73.rod
VCID: 3228CC406594B4DAE4-8066
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 C HW: 4H0 907 063 C
Component: BCM1 2.0 H11 0083
Revision: 14011002 Serial number: 00000000606877
Coding: 46CA201000369F210A81000480001B00CF9DD348B3010161800008000000
VCID: 281C2E285B48CE0A4A-807C
Subsystem 1 - Part No SW: 3Y2 955 119 HW: 3Y2 955 119
Component: WWS83x 090312 H32 0040
Serial number: 090508102604
Coding: 0045F7
Component: RLS H04 0003
Serial number: 10643139
Coding: 025729
Subsystem 3 - Part No SW: 3Y0 941 531 HW: 3Y0 941 531
Component: E1 - LDS H03 0044
Serial number: 26 08 2010 00000048
Subsystem 4 - Part No SW: 4H0 907 410 HW: 4H0 907 410
Component: EHL2 V07.03 H30 0020
Serial number: 0000001805568R05VW05
Subsystem 5 - Part No SW: 4H0 907 705 H HW: 4H0 907 705 C
Component: EVLS-SG H08 0275
Serial number: WA100296000000049228
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: AE188625000000000001
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 156217DCFC3A43E2E1-8040
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 3Y0 919 465 HW: 3Y0 919 465
Component: PARKHILFE ACC H02 0101
Revision: 11001001 Serial number: 01431014801549
Coding: 300901
ASAM Dataset: EV_BY83XParkiAssis2 001001
ROD: EV_BY83XParkiAssis2_BY83.rod
VCID: 7EB02870E14CA0BA50-802A
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 3Y0 907 561 A HW: 3Y0 907 561 A
Component: ACC3 H13 0120
Coding: 2404010201
Shop #: WSC 29655 000 1048576
ASAM Dataset: EV_AdaptCruisContrBY83X 001004
ROD: EV_AdaptCruisContrBY83X_BY83.rod
VCID: 393AFB6CB8E2478225-806C
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 B HW: 4H0 959 655 B
Component: Airbag10.43 H24 0028
Revision: -------- Serial number: 003G100173K8
Coding: 30323331303230303033554A304C34483053
ROD: EV_AirbaAU10BPAAU64X_BY83.rod
Serial number: 3575HRB405F6O2OUEHCD
Serial number: 3585HRB405F6O2OUC9C4
Serial number: 3515JRB40556094I68IP
Serial number: 3525JRB40576094IBPB0
Serial number: 3554VRB405070PNCMOTM
Serial number: 3564VRB405070PNCAHP0
Part No SW: 4H0 953 568 A HW: 4H0 953 568 A
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815JID0000U
Coding: 00003C
Shop #: WSC 00083 790 00170
VCID: 312AC34C68928FC29D-8064
Subsystem 1 - Part No SW: 3Y0 959 442 B HW: 3Y0 959 442 B
Component: E221 - MFL H05 0003
Serial number: 07 10 2010 46000548
Address 17: Instruments (J285) Labels:* None-SRI1
Part No SW: 3Y0 920 840 P HW: 3Y0 920 840 P
Component: Kombi H50 0284
Revision: 13140038 Serial number: 658050810593019
Coding: 3F16080117002600010000
ASAM Dataset: EV_DashBoardBY83XMMO 004033
ROD: EV_DashBoardBY83XMMO.rod
VCID: 43C69984CA2E0D527F-8016
Analog_clock:
Subsystem 1 - Part No SW: 3Y0 919 527 K HW: 3Y0 919 527 K
Component: Bentley C F T H05 0010
Serial number: 20100929000000000521
Part No SW: 4H0 907 468 C HW: 4H0 907 468 C
Component: J533--Gateway H07 0175
Revision: -------- Serial number: 00000000027306
Coding: 000103FF00
ASAM Dataset: EV_GatewUDS 001021
ROD: EV_GatewUDS_BY83.rod
VCID: 312AC34C60928FC29D-8064
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0125
Serial number: 00000000002799169085
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 3Y0 907 049 B HW: 3Y0 907 049 B
Component: Klima Fond H07 0030
Coding: 0E00000000
ASAM Dataset: EV_AirCondiHeck 001038
ROD: EV_AirCondiHeck_BY73.rod
Address 30: Special Function II (J843) Labels: None
Part No SW: 3Y0 907 440 HW: 3Y0 907 440
Component: DBMC H06 0001
Revision: S0H06000 Serial number: 00000000004927
Coding: 01000000000000000000000000
VCID: 74A40A58D700FAEA36-8020
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 3Y0 907 553 HW: 3Y0 907 553
Component: LUFE-DAEMPFER H16 1095
Coding: 008002
ASAM Dataset: EV_AirSuspe 003017
ROD: EV_AirSuspe_003_BY83.rod
VCID: 79BA3B6CF862878265-802C
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002112554
Coding: C028BF8085870301090001010101002100212323000000
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0015
Revision: -------- Serial number: EJ1BPA31003HX80
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6C9412388730222AEE-8038
Part No SW: 4H0 959 793 M HW: 4H0 959 793 E
Component: TSG FA H02 0166
Revision: -------- Serial number: 0000108726755
Coding: 011F1E207E01060006040103
Shop #: WSC 00092 106 131806
VCID: 43C69984C22E0D527F-8016
Revision: 00002001 Serial number: 0130785122
Coding: 011B1E2010797581A03007B0400000000000000000000000000000000000
Shop #: WSC 00092 106 182497
Subsystem 1 - Part No SW: 3Y0 959 511 HW: 3Y0 959 511
Component: GTO BF H03 0070
Serial number: 00000000000000012630
Subsystem 2 - Part No: 8K0 951 177
Subsystem 4 - Part No SW: 3Y0 947 811 HW: 3Y0 947 811
Component: Dachelektroni H63 0025
Serial number: BY83X_OS_FRONT_00000
Coding: 0F0000
Part No SW: 3Y0 035 456 HW: 3Y0 035 456
Component: Naim 3G BY H03 0070
Revision: 00003001 Serial number: 78802000147706
VCID: 73A60944D20EFDD22F-8026
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 2608 km
Date: 2011.06.23
Time: 08:09:31
Voltage: 11.70 V
Voltage: 11.60 V
Temperature: 26.0°C
Temperature: 20.0°C
Bin. Bits: 00000100
Bin. Bits: 10000000
Bin. Bits: 00000000
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 A HW: 4H0 959 860 A
Component: MEM-FS-Fond H06 0153
Revision: AA000000 Serial number: 00001002136777
Coding: C02896808500010D090039000039000039003B3B000000
VCID: 3228CC406D94B4DAE4-8066
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0166
Revision: -------- Serial number: 0000108723088
Coding: 011F1E207E01060006040100
VCID: 3A38E460B5E44C9A2C-806E
Part No SW: 3Y0 907 801 HW: 4H0 907 801 A
Component: EPB-4 H03 0001
Revision: -------- Serial number: 00000000002572
ASAM Dataset: EV_ParkiBrake 001015
ROD: EV_ParkiBrake_BY83.rod
VCID: 75A2375CD47AE3E201-8020
Part No SW: 4E0 035 061 H HW: 4E0 035 061
Component: Radio U DAB H46 0048
Revision: AB001007 Serial number: 014G.0A7509387
Coding: 010103010000000001
VCID: 200C36083378364A02-8074
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0153
Revision: AA000000 Serial number: 00001002136798
Part No SW: 3Y0 035 670 HW: 3Y0 035 670
Component: H-BNT-EU H43 0139
Revision: -------- Serial number: 461IX0A7502518
Coding: 010101000020F9EFE502030200000003F0000100
Shop #: WSC 00083 790 00163
VCID: 71AA034CA812CFC2DD-8024
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1106
Subsystem 2 - Part No SW: 3Y0 035 624 HW: 3Y0 035 624
Component: BTHS H50 0130
Serial number: P10001596481
Subsystem 3 - Part No SW: 3Y0 919 604 HW: 3Y0 919 604
Component: DU8 BY83 SV H41 0021
Serial number: BYZ8ZDA160002L4
Subsystem 4 - Part No SW: 3Y0 907 595 F HW: 3Y0 907 595
Component: E0380 Bedient H07 0032
Serial number: 00000000000561
Subsystem 5 - Part No: 8R0 060 961
Component: CD-Database 1886
Part No SW: 4H0 959 795 A HW: 4H0 959 795 A
Component: TSG HL H04 0162
Revision: -------- Serial number: 0000108732740
Coding: 010F1E200201064006000104
Shop #: WSC 00083 790 00172
VCID: 393AFB6CB0E2478225-806C
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 3Y0 907 273 HW: 3Y0 907 273
Component: RDKBERU25 108 0710
Serial number: 10000000002316
ASAM Dataset: EV_RDKBERU25 003004
ROD: EV_RDKBERU25_BY83.rod
VCID: 78BC3E68C3689E8A1A-802C
Address 6C: Back-up Cam. Labels: None
Part No SW: 3Y0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0040
Revision: --H03--- Serial number: 525 PA8J08D097
Coding: 2022004
Shop #: WSC 00083 790 00202
VCID: 75A2375C1C7AE3E201-8020
02203 - Audio / Video Input 1
Reset counter: 117
Mileage: 71448 km
Date: 2018.09.24
Time: 15:40:48
Reverse OFF
Count: 3
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 D HW: 4G8 959 107
Component: HDSG-Modul H12 0036
Revision: 11012001 Serial number: 272000203
Coding: 0B0204C000
Shop #: WSC 00083 790 00177
ASAM Dataset: EV_HDSGBy831 001012
ROD: EV_HDSGAu573Nar_BY73.rod
VCID: 3620F05089FCA8FAC8-8062
Component: TSG HR H04 0162
Revision: -------- Serial number: 0000108732662
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 3Y0 927 731 HW: 3Y0 927 731
Component: GSM-LL H04 0778
Revision: 0L0D4010 Serial number: SN100622 0059
ASAM Dataset: EV_GSM2x3Mono 001012
ROD: EV_GSM2x3Mono.rod
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 D HW: 4H0 907 182 D
Component: IVB H03 0027
Serial number: 00454376147401
Coding: 314000
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2B16D12442BEE512A7-807E
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00454376150601
Coding: 314000
Address 8A: Multicont. Seat Rear,DS (J875) Labels:* None
Serial number: 00454376231001
Coding: 314000
ASAM Dataset: EV_IVBDriveSideRear 001003
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 3Y0 907 541 A HW: 3Y0 907 541 A
Coding: 2404010201
ASAM Dataset: EV_AdaptCruisContr2BY83X 001004
ROD: EV_AdaptCruisContr2BY83X.rod
VCID: 373EFD548EF651F2D3-8062
Address 8D: Multicont. Seat Rear,PS (J874) Labels:* None
Serial number: 00454376169501
Coding: 314000
ASAM Dataset: EV_IVBPasseSideRear 001003
End----------(Elapsed Time: 02:52, VBatt start/end: 14.3V/14.3V)-----------
