- Joined
- Apr 10, 2016
- Messages
- 232
- Reaction score
- 203
- Location
- United Kingdom
- VCDS Serial number
- C?ID=219022
Over the weekend I replaced the wiper mechanism as it had seized and couldn't move the wipers any more. The motor / ECU (J400) was fine so no fault codes were logged when it couldn't move. Replacement mechanism installed and aligned as per Elsa and wipers move once again. I was reading there's a procedure to set the distance to the A-pillar when using VAS. I had an attempt using VCDS but couldn't do it. The wiper motor ECU (J400) is a slave off 0x09 Central Electric I (J519) in the A8 4E. The coding of J400 is 00000030 and I didn't know if this was the measurement. It refused any coding changes.
Is it possible to use VCDS for this procedure? The wiper alignment is good and I'm more curious than anything. Thanks.
Here is the VAS procedure:
J519 / J400
Full scan (old because I'm at work)
Setting distance to A-pillar
The distance to the A-pillar can only be successfully set if:
the wiper motor has been brought to a reference position after fitting by pressing the windscreen wiper switch -E22 (e.g. single wipe) and the wiper arms are fitted correctly as per the Workshop Manual A Workshop Manual, Audi A8 2003> Electrical System; Rep.Gr. 92 if the windscreen wiper switch is in its basic setting (-0-).
Procedure for coding distance to A-pillar:
1. If no test program was entered in the test plan, on the VAS 5051 select the following path:
Go to/Function and component selection/Body (Rep.Gr. 01; 27; 50 - 97)/Electrical system (Rep.Gr. 01; 27; 90 - 97)/01 - Self-diagnosis compatible systems/09 - Electronic central electrics (Rep.Gr. 97)/J400 - Wiper motor control unit, Functions/J400 - Replacing (Rep.Gr.-92)
2. In the test program the control unit version and the coding of the wiper motor control unit -J400 are first displayed. If the control unit is not coded, the coding value "255" is shown here.
3. Next choose the selective control element "wiper upper reverse point". Press -Next- to move the wiper to its upper reverse position. Now the distance from the A-pillar to the hinge of the windscreen wiper on the driver side must be measured.
Be sure to fit the wiper as per the Workshop Manual, so as to avoid faults arising from incorrect fitting.
After about 15 seconds the wiper moves back to the lower reverse position. Only when the windscreen wiper switch -E22 is operated (e.g. single wipe) does the wiper return to its parked position.
4. In the test program the wiper motor control unit -J400 is then recoded. For this, the measured value between the A-pillar and the hinge of the windscreen wiper must be transmitted to the control unit. When the coding is read out again, the new value is displayed and the previous one in brackets after it.
(The coding of the distance is only accepted if a - Move to upper reverse position - control element test has been performed beforehand.)
5. If the displayed coding value does not match the specification of 36 ± 2mm, the value must be re-measured with another control element test and the coding then repeated or corrected as appropriate.
System limitations:
After 5 coding attempts no more coding values are accepted. Coding can only be resumed following a terminal 15 reset (ignition off and back on).
If no control element test was performed (move to upper reverse point) the coding is also not accepted.
J519 / J400
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0110001
Shop #: WSC 02311 785 00200
VCID: 2A5B1BAF85ED2512D0-807E
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
Sunday,13,November,2016,18:50:19:04620
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN: WAUZZZ4E04N009871 License Plate:
Mileage: 142740km-88694mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 25 34 36 37 38
42 46 47 4F 52 53 55 56 57 61 62 72 76
VIN: WAUZZZ4E04N009871 Mileage: 142740km-88694miles
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 H HW: 4E0 907 560
Component: 3.7L V8/5V G 0020
Revision: 00000000 Serial number: AUX3Z0C8121858
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 2643EF9F91F50172F4-8072
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit - Intermittent
Part No SW: 4E0 910 156 D HW: 09E 927 156 A
Component: AG6 09E 3,7L5V RdW 0070
Revision: 00000001 Serial number: 0019919
VCID: 2345F68BE2C7F45A93-8076
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 2149FC83F8DBE64A81-8074
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H03 0120
Revision: 01203603 Serial number: AUX3Z0C8121858
Coding: 0264192
VCID: 58BF9167EB016782B6-800C
Subsystem 1 - Part No: 4E0 905 852 C
Component: ELV 1734
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 E HW: 4E0 035 729 A
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 300HJ037524663
VCID: 2E5317BFB90549320C-807A
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 322GF037503551
Subsystem 3 - Serial number: ÿÿ09.07.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000018 Serial number: 00000000023996
Coding: 1069057
VCID: 5ABB8B6F950D759280-800E
Coding: 0110001
Coding: 00000030
Shop #: WSC 02311
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBC1020046
VCID: 1C37CD77DFB9CBA252-8048
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7100089
Shop #: WSC 02152 785 00200
VCID: 2447F597E7C9F362EA-8070
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H09 0940
Coding: 0431707
VCID: 63C5B68BA247B45AD3-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H09 0030
Coding: 0112141
VCID: 65C1A893AC73CA6A3D-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 CX
Component: KOMBIINSTR. VDO H54 0090
Revision: D21 Serial number: AUDID3F7000147
Coding: 0000403
Shop #: WSC 00388 210 99160
VCID: 5CB78D779F398BA292-8008
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H07 0050
Revision: 07 Serial number: 130030371617BF
Coding: FCFE7BDC3B2D04
Shop #: WSC 12345 128 00289
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
VCID: 2B551EAB4A173C1A2B-807E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0264192
Component: ELV 1734
4E0905852C ELV 1734
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 F HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 6260
Coding: 0015510
Component: Sitzmemory FS H06 0060
Coding: 4063330
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H41 1060
Revision: 00000000 Serial number: 305HS037537933
VCID: 3B752EEB7A77AC9ABB-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0080
Serial number: 00000321700038
Coding: 0035968
VCID: 1D31C073C4A3C2AAA5-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM005 0100
Coding: 0028454
VCID: 5EB3877F892599B2FC-800A
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040308140067
Coding: 0004313
VCID: 275DE29B96FF187ACF-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H00 0460
Serial number: é�Õ¿qÆm
Coding: 0000017
02084 - Component Protection
Fault Status: 01100101
Reset counter: 33
Mileage: 134152 km
Date: 2014.07.09
Time: 19:02:43
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H07 0070
Revision: Serial number: 00000000021465
Coding: 0010101
VCID: 5DB18073842382AAE5-8008
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM005 0110
Coding: 0028454
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 B HW: 4E0 907 801 A
Component: EPB A22HC020 H02 0200
Revision: A22HC020
Coding: 0000331
Shop #: WSC 27634 002 1048576
VCID: 1E33C77FC9A5D9B2BC-804A
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
VCID: 62CBB38FBD5DBD52D8-8036
Part No SW: 4E0 910 541 Q HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0620
Revision: 00000000 Serial number: 304HN037540818
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 B HW: 4E0 919 148
Component: R0078 TVhybridTuner 0360
Revision: R0H05000 Serial number: 76300700272401
Coding: 0000003
Shop #: WSC 00000 785 00200
VCID: 224BF38FFDDDFD5298-8076
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0160
Revision: 00000000 Serial number: 00000000013302
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1308200306
Coding: 303030393135313035414B56413031333038323030333036
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028454
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028454
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 08720519200155
Coding: 0201108
End-------------------------(Elapsed Time: 03:30)--------------------------
