As the title states. Some mornings (and twice in the evening after being off 2-4hours) the past two weeks my car will not start. It is push button start and I hear the starter crank once or twice maybe. I then get a ton of errors (audi pre sense fault, ABD, park assist, hill assist, TPMS, etc) that things are not functioning. The lights typically dim and/or flicker when trying to start but the MMI infotainment always works (if that means anything). Eventually the car starts when I put it on a battery charger. Sometimes it starts right away off my battery charger, sometimes it takes 20-30mins on a 10amp charge.
I want to believe it is a parasitic battery drain while its off. Battery is original (4yrs old - Aug 2014). Hope the below auto-scan shows something note worthy. There are a lot of faults this causes. There are no lights on after it starts and I drive a bit (TPMS and ESC take a minute to go away).
Maybe i never did it when the drain was actually happening, but I have been trying to set up my multimeter in series (with the negative battery lead) to test the drain while its off. Its always been around low (20 Ma's or so if I am reading it right)
Any help is appreciated. Every time I go to start the car I am worried. I now carry a battery charger, 50ft extension cord and jumper cables in my trunk...
Note: the two engine faults "blocking valve for coolant (N82)" were there prior to this as well. Thanks!
Thursday,20,September,2018,18:01:18:16812
VCDS Version: 18.2.1.5 (x64)
VIN: WAUKFGFF4F1007030 License Plate:
Mileage: 81419km-50591mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 47 52 55 5F
6C BB BC
VIN: WAUKFGFF4F1007030 Mileage: 81419km-50591miles
BB-Door Rear Drv -- Status: Malfunction 0010
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00324426000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259A 001004
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C576E66474A9B24A8-8078
15446 - Blocking Valve for Coolant (N82)
P1889 00 [047] - Open or Short to Ground
Fault Frequency: 15
Mileage: 81074 km
Date: 2018.09.17
Time: 15:57:45
Engine speed: 807.75 /min
Normed load value: 8.2 %
Coolant temperature: 100 °C
Intake air temperature: 48 °C
Voltage terminal 30: 13.515 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 0 s
MAP_MES_SAE: 30 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.855 V
FAC_TPS_1_SAE: 12.500000 %
FUP_H_SAE: 3580.0 kPa
15450 - Blocking Valve for Coolant (N82)
P1889 00 [046] - Open or Short to Ground
Fault Frequency: 13
Mileage: 81075 km
Date: 2018.09.17
Time: 16:03:32
Engine speed: 801.00 /min
Normed load value: 10.6 %
Coolant temperature: 106 °C
Intake air temperature: 51 °C
Voltage terminal 30: 13.496 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 113 s
MAP_MES_SAE: 36 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
FAC_TPS_1_SAE: 12.109375 %
FUP_H_SAE: 4940.0 kPa
17178 - Databus
U1123 00 [040] - Received Error Message
Mileage: 81074 km
Date: 2018.09.17
Time: 15:57:43
Engine speed: 802.25 /min
Normed load value: 8.6 %
Voltage terminal 30: 13.593 V
Unlearning counter according OBD: 31
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Part No SW: 0D9 300 011 S HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4312
Revision: 03252204 Serial number: TFK01401252238
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 25419B4224A0AA6C77-8070
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 602740000009A0
Coding: 13FF6A9234200A730177030381C329C8562C5080C08194B4024100588608
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 7BF59D3AF2A4CC9C71-802E
0128 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 33
Mileage: 81084 km
Date: 2018.09.18
Time: 08:03:15
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 28
Date: 2018.09.17
Time: 15:57:45
8277 - Databus
Reset counter: 32
Mileage: 81084 km
Date: 2018.09.18
Time: 08:03:04
Reset counter: 29
Mileage: 81074 km
Date: 2018.09.17
Time: 15:57:57
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 33
Mileage: 81074 km
Date: 2018.09.17
Time: 14:17:17
Revision: 00021000 Serial number: 0325951219
Coding: 030C0C
VCID: 3A7B583EBD1E35942A-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000240353
Coding: 03000014010000000000000000001400
VCID: 3365751A9A74C4DCE9-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 77784C07000000000001
131076 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 32
Mileage: 81084 km
Date: 2018.09.18
Time: 08:03:36
Voltage terminal 30: 8.4 V
Outside air temperature: 21 °C
System run time-Terminal 15 on: 34 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 S HW: 5Q0 937 085 S
Component: BCM MQBAB MNA H16 0124
Serial number: 00011401800440
Coding: 04151C46C04106FD41C04004511007A00800000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
VCID: 499937F2E8F8AE0CB3-801C
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140122 041 0585
Serial number: 140125155204
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 22165632
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Component: E1 - LDS MQB H05 0032
Serial number: 27 08 2013 00000185
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000028834227
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.009 H02 0007
Serial number: WOO2662701+
Coding: 101F00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 G HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0133
Revision: -------- Serial number: 39331402005488
Coding: 0030150011
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 3F8D292AA63C10BC1D-806A
13635840 - Supply voltage
Reset counter: 32
U1400 00 [008] - -
Reset counter: 32
13637426 - Databus
Reset counter: 29
Mileage: 81074 km
Date: 2018.09.17
Time: 15:57:44
Component: AirbagVW20 009 0825
Serial number: 003GCR004VLS
Coding: 9DCCFCC0000000005000001AC24800000065
VCID: 479D31CAFEEC587CA5-8012
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34178311A04021440737
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34178312A04021470957
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y1300010JKD0O
Coding: 303230
Subsystem 4 - Part No SW: ----------- HW: 480 002 501 14
Serial number: 357000000000EA5CBE0
Subsystem 5 - Part No SW: ----------- HW: 480 002 501 14
Serial number: 3580000000020429BE0F
Subsystem 6 - Part No SW: ----------- HW: 480 401 701 14
Serial number: 3510002C713013E3333L
Subsystem 7 - Part No SW: ----------- HW: 480 401 701 14
Serial number: 3520002A111FBE94104/
Subsystem 8 - Part No SW: ----------- HW: 480 400 901 14
Serial number: 3550002BF11FBE93507L
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 901 14
Serial number: 3560002A313013E1C26T
9634838 - Control Module for Front Left Belt Tensioner
B1304 16 [008] - Voltage Too Low
Reset counter: 32
Mileage: 81084 km
Date: 2018.09.18
Time: 08:03:18
9635094 - Control Module for Front Right Belt Tensioner
B1305 16 [008] - Voltage Too Low
Reset counter: 32
Mileage: 81084 km
Date: 2018.09.18
Time: 08:03:18
1050117 - Databus
Reset counter: 29
Mileage: 81074 km
Date: 2018.09.17
Time: 15:57:45
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 02021408490268
Coding: A018
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 0A1BC8FEAD7EE5147A-805E
Part No SW: 8V0 920 970 A HW: 8V0 920 970 A
Component: KOMBI H03 2220
Coding: 03ED18192B88B7050200EA00180000
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 25011410800190
Coding: 0101000824085A005B00020C180B00000001000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_010_VW37.rod
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 09 01 2014 D0380768
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00009.01.14
Coding: 0001
VCID: 46833CCEF9E641745E-8012
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000014196004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346776069F7AC3E4F0-8060
U1400 00 [008] - -
Reset counter: 32
ELV State: 24
Information Clamps: 77 60
CoCo State: E0 00
WFS State: 00 06
Vehicle speed: 0.00 km/h
Voltage: 3A
AD-Value H-bridge: 1C
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0320958887
Coding: 030311
ROD: EV_LaneChangAssis_VW51.rod
VCID: 387F423683122784DC-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0320989562
Coding: 030311
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 27011404081480
Coding: 005D1F205C00048000000002
VCID: 408F2AD6DBC26F4464-8014
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 8102
ROD: EV_SteerAssisMQB_010.rod
VCID: 41892FD2D0C8664C6B-8014
Address 47: Sound System (J525) Labels:* None
Part No SW: 8V0 035 465 B HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0400
Serial number: AUZ8ZADN9003P1U
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
VCID: 377D410A8E0C28FCD5-8062
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 26011406070370
Coding: 005D17205E00048000000002
Part No SW: 7P6 907 357 B HW: 7P6 907 357 B
Component: AFS-ECU H01 0040
Coding: 012A00012B200400
Shop #: WSC 33433 000 1048576
ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
ROD: EV_HeadlRegulLEDAFSMQB.rod
VCID: 3E73542EA13619B416-806A
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7530
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7530
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7000
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7000
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 038 HW: 8V0 035 038
Component: MU-H-LNS-US H42 0289
Serial number: A302A0E7501032
Coding: 017301020000000021220002041A00102F000125010001047E
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 71E9BF12A0E8B6CCDB-8024
Subsystem 1 - Part No SW: V03 959 800 SE HW: -----------
Component: NAR 2014 --- 0024
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY200KVA
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 S HW: 8V0 919 614 E
Component: ControlUnit_H H64 0766
Serial number: C1000013121300020227
Component: Gracenote --- 3005
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 HW: 5Q0 907 441
Component: MQB RVC Mid H06 0130
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: 6FEDB96AB6DCA03CCD-803A
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 22011401100553
Coding: 004D17204000048000000002
65548 - Supply voltage
Reset counter: 28
Component: TSG HBFS 020 0025
Serial number: 22011406070602
End-------------------------(Elapsed Time: 06:32)--------------------------
