Results 1 to 4 of 4
Thread: 2005 MK5 TDI Jetta SRI intervals cant be adjusted it seems
    Verified VCDS User shwagondawheels's Avatar
    Jul 2018
    I tried to adjust the oil change interval from 10,000 to 5,000 on a friends 2005 TDI Jetta and found when logging in to the instrument cluster and going to 10-adaptations under all the channels that had anything to do with service intervals they came up as error or not available. Any idea to why? Will this cluster not allow me to or does one of the faults in the cluster have something to do with this?
    Auto-scan attached below:
    Friday,28,December,2018,21:02:33:24261
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: 3VWST71K95M632523   License Plate: XXXXXXX
    Mileage: 486620km-302371mi   Repair Order: Kenneths MK5 TDI jetta
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 72 7D
    VIN: 3VWST71K95M632523   Mileage: 486620km-302371miles
    1C-Position Sensing -- Status: Malfunction 0010
       Part No SW: 03G 906 016 AB    HW: 028 101 223 8
       Component: R4 1,9L EDC G000SG  7550
       Revision: --H01---    Serial number: VWZ7Z0E1914485
       Coding: 0050071
       Shop #: WSC 00066 000 00000
       VCID: 63935353B750544FE37-8036
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0021122
       VCID: 3A2DCE37605A7587901-806E
       Part No: 1K0 907 044 AG
       Component: ClimatronicPQ35 066 0505
       VCID: 6C81386F5A8E1B3752D-8038
       Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
       Component: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 00000000046852
       Coding: F4098E02400418000014000000140000002077035C
       VCID: 2F3BEF63AB18A02F37F-807A
       Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 005  0605
       Coding: 00217125
       Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
       Component: SDAR XM         H03 0080
       Revision: 00000000    Serial number: AUZ4Z7E7040451
       VCID: 2B03FB739F00DC0F1B7-807E
                000 -  -  - Intermittent
                        Fault Frequency: 75
                        Reset counter: 173
                        Mileage: 472985 km
                        Time: 06:46:03
       Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
       Component: 1S AIRBAG VW8R  024 6300
       Revision: 03024000    Serial number: 0037KD01JSX
       Coding: 0012627
       VCID: 2E05F267AC12A9273C9-807A
       Subsystem 1 - Part No: 1K0 959 339 B
       Component: BF-Gewichtsens. 006 0003
       Subsystem 2 - Serial number: 6332MSME087A3E7DX
       Subsystem 3 - Serial number: 6342MSME095B1857I
       Subsystem 4 - Serial number: 6351HSME06511176.
       Subsystem 5 - Serial number: 6361HSME063A0322.
       Subsystem 6 - Serial number: 63727SME065B0123V
       Subsystem 7 - Serial number: 63827SME065B603C4
       Part No SW: 1K0 953 549 L    HW: 1K0 953 549 L
       Component: Lenksäulenmodul 013 0040
       Coding: 0000041
       VCID: 3B23CB336F604C8F8B7-806E
       Part No: 1K0 920 971 D
       Component: KOMBIINSTRUMENT 3HL 2120
       Coding: 0023203
       VCID: 2C01F86F9A0EDB3712D-8078
       Part No SW: 1K0 907 530 E    HW: 1K0 907 951
       Component: Gateway         H09 0110
       Revision: 09          Serial number: 270010512010F9
       Coding: 3D3F0B620F1002
       VCID: 290F017B95FCCE1FE9B-807C
       Part No SW: 1K5 919 965     HW: 1K5 919 965
       Component: Kompass         002 0001
       Revision: 00002000    Serial number: 0371356TNTYZ03
       VCID: 78A9143F1ED6A797A65-802C
                        Reset counter: 201
                        Mileage: 368891 km
                        Time: 17:58:24
       Component: IMMO            3HL 2120
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2339
       Coding: 0001271
       VCID: 3635DA07544291E7749-8062
       Part No: 1K1 909 144 H
       Component: EPS_ZFLS Kl.2       1502
       VCID: 3039EC1FB626BFD72E5-8064
       Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
       Component:    KSG PQ35 G2  010 0101
       Revision: 00010000    Serial number: 00000000000000
       Coding: 13100F880106281B0906050FA0080F0490A540
       VCID: 025D76D7480AFD47881-8056
       Component: LIN BACKUP HORN H02 1301
                003 - Mechanical Failure
                        Fault Status: 01110011
                        Reset counter: 145
                        Mileage: 472142 km
                        Time: 06:49:09
                        Reset counter: 100
    Address 47: Sound System        Labels: 3C0-035-456.clb
       Part No: 1K6 035 456
       Component: 08K Audioverst.     0003
       Revision: 00002000    Serial number: 00000000022339
       VCID: 698F417B557C0E1F29B-803C
       Part No: 1K0 959 702 K
       Coding: 0001271
       VCID: 372BD703534868EF6FF-8062
       Part No SW: 1K0 035 180     HW: 1K0 035 180
       Component: Radio ZSW       015 0016
       Revision: 00015000    Serial number: VWZ5Z7E6275336
       Coding: 0010010
       VCID: 5DE765AB913462BFD53-8008
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2416
       Coding: 0000144
       VCID: 313FE91BBD2CB6DF21B-8064
       Part No: 1K0 959 704 D
       Coding: 0000144
       VCID: 323DE617B82A8DC7581-8066
       VCID: 2D07F56BA114D23F053-8078
    End----(Elapsed Time: 01:17, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
    Address 09-02,1K0 955 559 M,recoded (Short coding),from,00217125,to,00479269,(00000/000/00000),
    Address 46,1K0 959 433 AT,recoded (Long Coding),from,13100F880106281B0906050FA0080F0490A540,to,13100F880106283F2902050FA0080F0490A540,(00066/000/00000),
    Address 46,1K0 959 433 AT,recoded (Long Coding),from,13100F880106283F2902050FA0080F0490A540,to,13100F880106083F2902050FA0080F0490A540,(00066/000/00000),
    Address 09,1K0 937 049 C,recoded (Long Coding),from,F4098E02400418000014000000140000002077035C,to,F4098E02400418000014000000140000002177035C,(00000/000/00000),
    Address 09-02,1K0 955 559 M,recoded (Short coding),from,00479269,to,00479269,(00000/000/00000),
    Address 17,1K0 920 971 D,recoded (Short coding),from,0023203,to,0023207,(00066/000/00000),
    Thanks, I was not finding much about this issue in searches
    I have a fuzzy recollection that the early NAR Mk.5 Jetta clusters don't support SRI at all.
    Jul 2018
    I had a feeling this was the case. I couldn't even find a mileage or time to next service in the MFI menu. He said he rest it when he changed to oil after he got the car but I'm thinking he reset nothing and just did it thinking it needed it.
    Quote Originally Posted by shwagondawheels View Post
    Yeah, IIRC, it's strictly a fixed interval that can only be reset with the appropriate button press. I think they got better/smarter in later model years (and were never that dumb in ROW models).
