Hello.The problem on this car is that the customer change the coding and the front left indicator don't work I try to fix it but I don't find anything in central electronics and gateway about front left indicator,can anybody help me with this problem?
thank you in advance
Thursday,20,September,2018,14:53:24:57658
VCDS Version: 18.2.1.5 HEX-V2 CB: 0.4411.4
Dealer/Shop Name: THANOS
VIN: WVWZZZAUZEP047287 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP047287 Mileage: 51143km-31778miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 7635
Revision: 84H22---
Coding: 01110012032405092000
Shop #: WSC 42525 001 1048576
ASAM Dataset: EV_ECM16TDI01104L906021M 002012
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F381964B7935FDFD8E-807A
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
Component: ESC H31 0472
Revision: 00000000 Serial number: 6293300000039F
Coding: 01FA62A1242409730379060841CA2580462490C06082A4F300400064C002
VCID: 074891C47FA3279F30E-8052
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00020104200100011005000000101000
Shop #: WSC 00028 028 00023
VCID: 382A223842DD9867894-806C
B10CD 00 [008] - -
Reset counter: 89
Mileage: 51143 km
Date: 2018.09.20
Time: 11:29:29
Voltage terminal 30: 11.1 V
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 084 R HW: 5Q0 937 084 R
Component: BCM MQBAB B H14 0112
Serial number: 00011328700791
Coding: 000A0042C60000FB4BE44000000403801000000000000000000000000000
Shop #: WSC 12345 123 61029
ROD: EV_BCMBOSCH_011.rod
VCID: 47C851C43F23E79FF0E-8012
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 131020 042 0551
Serial number: 131021153203
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Labels: 8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 20531215
527372 - Local Data Bus 3
U10DB 00 [009] - Electrical Malfunction
[Lokaler Datenbus 3 (LIN)->elektrischer Fehler im Stromkreis]
Reset counter: 49
Mileage: 51143 km
Date: 2018.09.20
Time: 14:26:06
527628 - Local Data Bus 4
U10DC 00 [009] - Electrical Malfunction
[Lokaler Datenbus 4 (LIN)->elektrischer Fehler im Stromkreis]
Reset counter: 49
Mileage: 51143 km
Date: 2018.09.20
Time: 14:26:06
529173 - Databus
[Anhaenger_01 Datenbus fehlende Botschaft]
Reset counter: 49
Mileage: 51143 km
Date: 2018.09.20
Time: 14:26:04
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR011D46
Shop #: WSC 00028 028 00064
VCID: 7F58092427736F5F08E-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0340
Serial number: 34169667B23101371621
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0340
Serial number: 34169668B24101340262
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 910 13
Serial number: 357670000004C085ED0+
Subsystem 4 - Part No SW: ----------- HW: 480 000 910 13
Serial number: 35867000000D42801E0S
Subsystem 5 - Part No SW: ----------- HW: 480 402 210 13
Serial number: 3516502A711FBEA1B05M
Subsystem 6 - Part No SW: ----------- HW: 480 402 110 13
Serial number: 3526502C711FBEA1237L
Subsystem 7 - Part No SW: ----------- HW: 480 402 610 13
Serial number: 3556502B51230BB211B%
15360768 - Component Protection
U1101 00 [008] - Active
[ATP Inconsistency]
Mileage: 51143 km
Date: 2018.09.20
Time: 11:47:42
Part No SW: 5Q0 953 507 AM HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 24101304400258
Coding: 1604
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 015C8FDC518719AF7EA-8054
Part No SW: 5G0 920 861 A HW: 5G0 920 861 A
Component: KOMBI 252 2210
Coding: 07E51A002380000800087A00040000
VCID: 2708F1449F63079F10E-8072
Reset counter: 88
Mileage: 51143 km
Date: 2018.09.20
Time: 11:47:42
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 K
Component: GW MQB Low 210 2147
Revision: -------- Serial number: 19101310800732
Coding: 030000000F0873006F000240080F00010000000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009_VW37.rod
VCID: 392C273C79D7816F76A-806C
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 6648551503
0769 - Analog Measuring Input
C1155 31 [009] - No Signal
Reset counter: 49
Mileage: 51143 km
Date: 2018.09.20
Time: 14:36:41
Supply voltage: Terminal 30: 11.6 V
Terminal 15: On
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 18041304080452
Coding: 00150F645E00080000011B02
VCID: 3FD8492467F3AF5F48E-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003178067
458773 - Databus
[FLA_01 Datenbus fehlende Botschaft]
Reset counter: 48
Mileage: 51143 km
Date: 2018.09.20
Time: 11:16:09
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 0103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DC4FDC1107D9AF3EA-8014
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 16111200011311
Coding: 00150320DE00040000011100
VCID: 3E26342060F9A657438-806A
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003189091
Coding: 090000
458773 - Databus
Reset counter: 48
Mileage: 51143 km
Date: 2018.09.20
Time: 11:16:09
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
Component: MU-S-N-ER 041 0430
Serial number: V1F01207141895
Coding: 02730001FF0F00001D110001000800105F010084118001047F
ROD: EV_MUStd4CPASE_VW37.rod
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS402D4K
1589 - invalid data record
B2005 00 [009] - -
[Control module (data record download) - invalid data record for power management timer]
Reset counter: 48
Mileage: 51143 km
Date: 2018.09.20
Time: 11:16:09
Voltage terminal 30: 11.5 V
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 48
Mileage: 51143 km
Date: 2018.09.20
Time: 11:16:09
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: ERROR
Byte_Coding_Condition-byte_9_condition: OK
[Anti-theft protection - component protection active (0xEA6300)]
Reset counter: 88
Mileage: 51143 km
Date: 2018.09.20
Time: 11:47:42
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Reset counter: 48
Mileage: 51143 km
Date: 2018.09.20
Time: 11:16:09
End----(Elapsed Time: 01:00, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
