Results 1 to 10 of 17
Thread: Powered Tailgate minor issue
    Mar 2015
    Australia
    Hi All,
    I have a B6 Passat variant with factory fitted powered tailgate.
    I can't be certain this was the trigger however at one point someone fairly forcibly closed the boot not realising that it was powered.
    The tailgate still opens and closes however once the motors are fully up, the position of the tailgate is now sagging down by about 100mm. So it's now very easy to hit my head if not paying attention..
    I have been through the process of setting the upper limit at a very low level, then again whilst holding the boot up as far as it used to go, but it still sags back down.
    I have replaced the gas struts with new ones of the correct part number and nm rating.
    I then replaced both motors with revision G (originals were rev F) and went through the process as described in O..S which says to open the tailgate about half way, then press both internal and external buttons simultaneously and it will open fully.
    It is SLIGHTLY better than the old motors by about 20mm however it is still not the same as it used to be...still sagging down at the top of the travel.
    I inspected the toothed drive pins that connect the motors to the hinges (thinking that maybe somehow they slipped a few teeth?) but I can't see any obvious sign of damage.
    MVB at open shows motors at 98%...
    Anyone have any similar experience or perhaps another suggestion? Not the end of the world but it would be nice to have them back to full extension.
    No fault codes, but these are the motors, now replaced with G:
    Part No SW: 3C9 827 383 F HW: 3C9 827 383 F
    Component: J605 HECKDECKEL 0720
    Revision: 00H27001
    Shop #: WSC 05311 000 08193
    VCID: 3431E21B92350C8746C-8060
    Subsystem 1 - Part No: 3C9 827 384 F
    Component: J756 HECKDECKEL 0720
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
  2. Likes Dana liked this post
  3. #2
    United States
    I don't have anything to contribute but that system should only require the button holding dance to learn the top stop:
    http://wiki.ross-tech.com/wiki/index...nk_Electronics
    My 7P T'reg does NOT like to cooperate when running Output tests (my calibration is completed via Basic Settings) but you may want to see if anything is supported when clicking 03-Output tests followed by Next.
  4. Likes Uwe, kamold liked this post
  5. #3
    Mar 2015
    Australia
    Thanks Dana,
    Unfortunately there don't appear to be any output tests or basic settings for my motors.
    I tried holding the interior and exterior buttons down together for 5 and 10 seconds however that doesn't appear to have made a difference.
    It's fine for now, just a minor annoyance. At some point in the future I'll try pulling the motors out again and checking if there is some way to adjust how the drive pin is rotated with respect to the hinge.
  6. Likes Dana liked this post
  7. #4
    Mar 2015
    Australia
    Thanks to Rhinopower I have this issue fixed
    Adaptation channel 1 is the 'adjustable opening stop' (thanks Golfi_vend for the correct description). Mine was set to 348. Changed this to a higher value (400, but I need to test if smaller values still work) and the tailgate now opens back up to full height!
    Not sure why the adaptation routine isn't correcting this on it's own, but I'm just happy to not be bumping my head any more.
  8. Likes Dana, Zenerdiode, jyoung8607, rhinopower liked this post
  9. #5
    United States
    Excellent! If we already had a label file I'd toss that in there right now.
    I'll drop a link to this thread onto the Wiki page as a reminder to revisit the topic. If you happen to have time to create a 6D blockmap with the lid open and then another closed in addition to a single Adp function map please post them here or send them to Support.
    Best,
    Dana
  10. Likes Uwe liked this post
  11. #6
    Mar 2015
    Australia
    Update:
    Channel 1 reset itself back to 355 after power cycle. So tailgate wasn't going to full height again.
    I ran channel 0 (resetting of all adaptation values) and then set channel 1 to 370, this now seems to be surviving power cycles and lid is opening properly
    (although when channel 1 is set to 380 or 400 it actually does go a little higher...but this setting doesn't stick)
    Closed:
    ;SW:3C9-827-383-G   HW:3C9-827-383-G ---  Trunk Elect.
    ;Component:J605  HECKDECKEL    0730, Coding:
    ;Sunday,30,September,2018,09:15:40:58930
    ;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.1
    ;VCID: 3537DF1F994F158F921-8060
    1,0,,
    1,1,,,
    ;11.10 V,Voltage,
    1,2,,,
    ;11.10 V,Voltage,
    1,3,,,
    1,4,,,
    2,0,,
    2,1,,,
    ;Not Oper., ,
    2,2,,,
    ;Not Oper., ,
    2,3,,,
    ;Not Oper., ,
    2,4,,,
    ;Not Oper., ,
    3,0,,
    3,1,,,
    ;OFF, ,
    3,2,,,
    ;0.0 %,Duty Cycle,
    3,3,,,
    ;OFF, ,
    3,4,,,
    ;0.0 %,Duty Cycle,
    4,0,,
    4,1,,,
    ;Hold, ,
    4,2,,,
    ;Hold, ,
    4,3,,,
    4,4,,,
    5,0,,
    5,1,,,
    ;12.0 %,Duty Cycle,
    5,2,,,
    5,3,,,
    ;100.0 %,Duty Cycle,
    5,4,,,
    6,0,,
    6,1,,,
    6,2,,,
    ;0.0 %,Duty Cycle,
    6,3,,,
    ;2.5 %,Duty Cycle,
    6,4,,,
    ;0.0 %,Duty Cycle,
    7,0,,
    7,1,,,
    ;0.0,(no units),
    7,2,,,
    7,3,,,
    7,4,,,
    8,0,,
    8,1,,,
    ;Locked, ,
    8,2,,,
    ;Not Installed, ,
    8,3,,,
    ;Deactivated, ,
    8,4,,,
    ;ON, ,
    9,0,,
    9,1,,,
    ;Term 15 On, ,
    9,2,,,
    ;StatCurStg 0, ,
    9,3,,,
    ;0.0 km/h,Speed,
    9,4,,,
    ;8.0,(no units),
    10,0,,
    10,1,,,
    ;Trailer: No, ,
    10,2,,,
    10,3,,,
    10,4,,,
    11,0,,
    11,1,,,
    ;Closed, ,
    11,2,,,
    ;Retracted, ,
    11,3,,,
    11,4,,,
    Open:
    ;Sunday,30,September,2018,09:18:05:58930
    1,0,,
    1,1,,,
    ;11.10 V,Voltage,
    1,2,,,
    ;11.10 V,Voltage,
    1,3,,,
    1,4,,,
    2,0,,
    2,1,,,
    ;Not Oper., ,
    2,2,,,
    ;Not Oper., ,
    2,3,,,
    ;Not Oper., ,
    2,4,,,
    ;Not Oper., ,
    3,0,,
    3,1,,,
    ;OFF, ,
    3,2,,,
    ;0.0 %,Duty Cycle,
    3,3,,,
    ;OFF, ,
    3,4,,,
    ;0.0 %,Duty Cycle,
    4,0,,
    4,1,,,
    ;Hold, ,
    4,2,,,
    ;Hold, ,
    4,3,,,
    4,4,,,
    5,0,,
    5,1,,,
    ;100.5 %,Duty Cycle,
    5,2,,,
    5,3,,,
    5,4,,,
    6,0,,
    6,1,,,
    6,2,,,
    6,3,,,
    ;2.5 %,Duty Cycle,
    6,4,,,
    ;0.0 %,Duty Cycle,
    7,0,,
    7,1,,,
    ;0.0,(no units),
    7,2,,,
    7,3,,,
    7,4,,,
    8,0,,
    8,1,,,
    ;Stopped, ,
    8,2,,,
    ;Not Installed, ,
    8,3,,,
    ;Deactivated, ,
    8,4,,,
    ;ON, ,
    9,0,,
    9,1,,,
    ;Term 15 On, ,
    9,2,,,
    ;StatCurStg 0, ,
    9,3,,,
    ;0.0 km/h,Speed,
    9,4,,,
    ;8.0,(no units),
    10,0,,
    10,1,,,
    ;Trailer: No, ,
    10,2,,,
    10,3,,,
    10,4,,,
    11,0,,
    11,1,,,
    ;OPEN, ,
    11,2,,,
    ;Extended, ,
    11,3,,,
    11,4,,,
    Adapmap:
    ;Sunday,30,September,2018,09:18:38:58930
    A01,0,
    ;370
    A01,1,
    ;N/A
    A01,2,
    ;N/A
    A01,3,
    ;N/A
    A01,4,
    ;N/A
    A02,0,
    ;0
    A02,1,
    ;N/A
    A02,2,
    ;N/A
    A02,3,
    ;N/A
    A02,4,
    ;N/A
    A03,0,
    ;1
    A03,1,
    ;N/A
    A03,2,
    ;N/A
    A03,3,
    ;N/A
    A03,4,
  12. Likes Uwe, Dana liked this post
  13. #7
    Have you tried this:
    1. Force tailgate half open manually
    2. Press both buttons at inside and outside at the same time
    3. Tailgate should move then up
    Check after ignition cycle, if Channel 1 has changed.
  14. Likes Dana, jyoung8607 liked this post
  15. #8
    Tartu, Estonia
    I think label file should look something like this:
    ;Written by Magnus Jaaska jaaska@gmail.com
    ;First Release 09.09.17
    001,0,Control Module Voltages
    001,1,Master Voltage,,Specification: 8.5V...15.5V
    001,2,Slave Voltage,,Specification: 8.5V...15.5V
    002,0,Button Activations
    002,1,Soft-Touch Handle,,Range:Operated/Not Operated
    002,2,Inner,Tailgate Button,Range:Operated/Not Operated
    002,3,Driver Door,Button,Range:Operated/Not Operated
    002,4,Remote Control,Button,Range:Operated/Not Operated
    009,1,Terminal 15,,Range: On/Off
    009,3,Vehicle Speed,
    010,0,Trailer Detection
    010,1,Trailer Detection,,Range: No/Yes
    A000,0,Resetting all Adaption Channels
    A001,0,Adjustable Opening Stop
    Monday,03,September,2018,19:27:11:42366
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
    VCDS Version 18.7.1.1 (x64)  HEX-V2 CB: 0.4427.4
    Data version: 20180731 DS293.0
    VIN: WVWZZZ3CZEE   License Plate: STEN-ADMAP-SCAN
    Mileage: 224390km-139429mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 22 25 36 3C 42 44 46
              4F 52 53 55 5F 61 62 65 69 6C 6D 72 A5
    VIN: WVWZZZ3CZEE   Mileage: 224390km-139429miles
    Address 01: Engine (J623-CFGC)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 RE    HW: 03L 907 309 AE
       Component: R4 2,0L EDC   H28 4780
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 001D003A047601080000
       Shop #: WSC 00015 115 00000
       ASAM Dataset: EV_ECM20TDI01103L906018RE 003003
       ROD: EV_ECM20TDI01103L906018RE.rod
       VCID: 7EA6F465407D2217E08-802B
    Address 02: Auto Trans        Labels: 02E-927-770.CLB
       Part No SW: 02E 300 016 G    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4345
       Revision: 05652104    Serial number: 00001307110966
       Shop #: WSC 05311 000 00000
       VCID: 186AC2FD4E99FC274A4-804D
    Address 03: ABS Brakes        Labels: 3AA-614-109.CLB
       Part No SW: 3AA 614 109 AS    HW: 3AA 614 109 AS
       Component: J104   C2 450M VE1F 0030
       Revision: --H07---    Serial number: 00000007172921
       Coding: 0121279
       VCID: 7EA6F4654CFD2217E08-802B
       Part No SW: 3AA 907 044 CA    HW: 3AA 907 044 CA
       Component: Climatronic   H05 0505
       Revision: 00001K02
       Coding: 061900C803
       Shop #: WSC 00015 115 00001
       VCID: 71BCDF5901234D6F6DA-8025
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.CLB
       Part No SW: 3AA 937 087 Q    HW: 3AA 937 087 Q
       Component: BCM PQ47 H+   422 0475
       Revision: BC422001
       Coding: 000A000000000000009C0088710029DC27FD4B886721AF60E480EF240049
       Shop #: WSC 00046 000 00000
       VCID: 48CA52BD52B9ACA71A4-801D
       Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer 25071  10  0603
       Coding: 00BF95
       Component: RLS 050813 05  54  0403
       Coding: 06302A
    00833 - Signal for Activation of Heated Windshield
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 31
                        Mileage: 224390 km
                        Date: 2018.09.03
                        Time: 19:08:41
                        Voltage: 14.50 V
       Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0480
       Revision: --------    Serial number: 39431423801330
       Coding: 0031163251
       Shop #: WSC 99999 123 12345
       ASAM Dataset: EV_EPHVA2CVW364GP00 001010
       ROD: EV_EPHVA2CVW364GP00_VW36.rod
       VCID: 3B203D7113EFF73F876-806F
    Address 13: Auto Dist. Reg        Labels: 3AA-907-567.CLB
       Part No SW: 3AA 907 567 A    HW: 3AA 907 567
       Component: AC201  RDW A    036 0170
       Revision: 00036000    Serial number: 00000000596744
       Coding: 0010000
       VCID: 382A227D2E59DC276A4-806D
    Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.CLB
       Revision: 00000000    Serial number: 27061306810001
       Coding: 030180
       Shop #: WSC 05314 000 00000
       VCID: 2708F101FFE743DFF3E-8073
    Address 15: Airbags        Labels: 5N0-959-655.LBL
       Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
       Component: J234__10H VW10 HI   2318
       Revision: 27019000    Serial number: 003N5PFHEQ0%
       Coding: 0012360
       VCID: 005A8A9D360954E7924-8055
       Subsystem 1 - Serial number: 6332MTS604851933
       Subsystem 2 - Serial number: 6342MTS617192023
       Subsystem 3 - Serial number: 6351HTS67HDF6CKR
       Subsystem 4 - Serial number: 6361HTS6EP7F6CKJ
       Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
       Revision: FF010042    Serial number: 20130725200260
       Coding: 399AA50001
       VCID: 75B4EB49754B614FB12-8021
       Coding: E30000
       Part No SW: 3C8 920 880 T    HW: 3C8 920 880 T
       Component: KOMBI         H04 1008
       Coding: 160F000000
       Shop #: WSC 05311 115 08193
       VCID: 3D2433690DFBF90FB92-8069
    Address 18: Aux. Heat        Labels: 1K0-815-007.CLB
       Part No: 7N0 963 272 C
       Component: Standheizer     044 4840
       Revision: 00044000    Serial number: 09024302000000
       Coding: 0031032
       Shop #: WSC 23805 001 1048576
       VCID: 35342B49394B214F712-8061
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.CLB
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1682
       Revision:   H56       Serial number: 080813F1001576
       Coding: 462006
       Shop #: WSC 00046 123 12345
       VCID: 7BA0FD7153EF373FC76-802F
    Address 22: AWD        Labels: 0AY-907-554-V1.CLB
       Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
       Component: Haldex 4Motion      4016
       Coding: 0000005
       VCID: 46D65C8554ADBAD7E88-8013
    Address 25: Immobilizer        Labels: 3C0-959-433-25.CLB
       Part No SW: 3AA 959 799 C    HW: 3AA 959 799 C
       Component:    IMMO         090 0407
       Revision: 00090000    Serial number: VWZCZ000000000
       VCID: 48CA52BD5EB9ACA71A4-801D
    Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.LBL
       Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
       Component: Sitzmemory    H05 3101
       Revision: 00H05000
       Coding: 000039
       Shop #: WSC 40022 666 40022
       VCID: 372821412F47D35F63E-8063
    Address 3C: Lane Change        Labels: NONE
       Part No SW: 3AA 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0030
       Revision: 00H02000    Serial number: 6PZ 010 316-09
       Coding: 0010172
       VCID: 3A2E38751055CE379C0-806F
       Subsystem 1 - Part No: 3AA 907 568 D
       Component: J770  SWA Slave H02 0030
       Subsystem 2 - Serial number: 6PZ 010 316-29
       Subsystem 3 - Serial number: 5F14.06.1300H02000AMS15979˙
       Subsystem 4 - Serial number: S15979˙
       Component: TUER-SG FT    002 0533
       Revision: 12110009    Serial number: 0007346487
       Coding: 0211FF
       Shop #: WSC 05311 115 12345
       VCID: 35342B4935CB214F712-8061
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 703 B    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0503
       Serial number: 00000003576714
       Coding: 0100D8
    Address 44: Steering Assist        Labels: 5N1-909-144.CLB
       Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.318 1401
       Revision: 1BH04737    Serial number: 00131910092201
       Coding: 0000258
       VCID: 3FD849610B77EB1FABE-806B
    Address 46: Central Conv.        Labels:. 3C0-959-799-46.CLB
       Component: 02 KESSY PQ47   090 0367
       Coding: 01900A00D2C30E76340A94157E028FCE705B00130427BC
       Shop #: WSC 05311 123 12345
       Subsystem 4 - Part No: 3AA 962 243 B
       Component: GEB.F.Heckoef       0810
    Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.CLB
       Component: EZE_2         H56 1682
       Coding: 050B0509
       VCID: 6FB8D92117975B9F7BE-803B
       Component: J245EE20SKB13  H05 0220
       Component: J394EE20SKB13  H05 0220
       Subsystem 3 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0004
       Component: TUER-SG BT    002 0533
       Revision: 14110009    Serial number: 0007338200
       Coding: 0211FE
       VCID: 36362C4528CD2A57788-8063
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 704 B    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0503
       Serial number: 00000003578775
       Coding: 0100D8
    Address 53: Parking Brake        Labels: 3AA-907-801.CLB
       Revision:   H19       Serial number: 00000001299208
       Coding: 0022167
       Shop #: WSC 45632 456 32456
       VCID: 36362C45244D2A57788-8063
       Component: AFS-ECU       H04 0111
       Coding: 02BA00104F000200
       Shop #: WSC 05311 115 00000
       VCID: 372821412FC7D35F63E-8063
       Subsystem 1 - Part No SW: 3D0 941 329 C    HW: 3D0 941 329 C  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2C0000
       Subsystem 2 - Part No SW: 3D0 941 329 C    HW: 3D0 941 329 C  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2C0000
       Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
       Component: MU-S-ND-ER    H20 0252
       Serial number: VWZAZ2R8739840
       Coding: 02630101FF0000001111000100880A001F0100C40020010087
       Shop #: WSC 00020 999 12345
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 211CEF199143BDEFBDA-8075
       Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
    0001 - Antenna 1 for Radio
              B1119 13 [009] - Open Circuit
                        Reset counter: 31
                        Mileage: 224390 km
                        Date: 2018.09.03
                        Time: 19:07:43
                        Voltage terminal 30: 14.3 V
                        Status of antenna 1 for radio-Antenna current: 0 mA
                        Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
                        Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Electrical OK
                        Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.CLB
       Component: Batt.regelung H56 1682
       Coding: 530F1859
       VCID: 71BCDF5901A34D6F6DA-8025
       Component: J367-BDM  H07 0180
       Serial number: 40218L20001491865662
       Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0011
       Serial number: 30000000052544
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
    Address 69: Trailer (J345)       Labels:. 7N0-907-383.CLB
       Part No SW: 7N0 907 383     HW: 7N0 907 383
       Component: Anhaenger     H09 0120
       Revision: 3I001003    Serial number: 00008160115684
       Coding: 4106040001000000
       VCID: 73B0D5517BBF7F7F9F6-8027
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
       Component: VW428 RVC Mid H04 0040
       Coding: 012408012301000700
       Shop #: WSC 00020 999 39850
       ASAM Dataset: EV_CamSysRearPANAVW428 002002
       ROD: EV_CamSysRearPANAVW428.rod
       VCID: 303A1A5DCAA90467224-8065
    Address 6D: Trunk Elect.        Labels: NONE
       Part No SW: 3AF 827 383 A    HW: 3AF 827 383 A
       Component: J605  HECKDECKEL    0860
       Revision: 00H52001
       Subsystem 1 - Part No: 3AF 827 384 A
       Component: J756  HECKDECKEL    0860
       Subsystem 2 - Serial number: 1300H52001001A0340˙
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H04 0231
       Serial number: 11021511P10585
       Coding: 000407020000040500261357C186880090000E100040
       ROD: EV_MFKBoschMQBB_VW46.rod
    End------(Elapsed Time: 17:33, VBatt start/end: 14.2V/14.3V, Deb=2)--------
    ;SW:3AF-827-383-A   HW:3AF-827-383-A ---  Trunk Elect.
    ;Component:J605  HECKDECKEL    0860, Coding:
    ;Friday,05,February,2016,18:43:48:35982
    ;VCDS Version: Release 15.7.3 (x64)  Data version: 20151216
    ;VCID: 3A7B088C75D317EE7F-806E
    A01,0,
    ;370
    A01,1,
    ;N/A
    A01,2,
    ;N/A
    A01,3,
    ;N/A
    A01,4,
    ;N/A
    A02,0,
    ;1
    A02,1,
    ;N/A
    A02,2,
    ;N/A
    A02,3,
    ;N/A
    A02,4,
    ;N/A
    A03,0,
    ;1
    A03,1,
    ;N/A
    A03,2,
    ;N/A
    A03,3,
    ;N/A
    A03,4,
    ;N/A
    ;04 N/A
    ;05 N/A
    ;06 N/A
    ;07 N/A
    ;08 N/A
    ;09 N/A
    ;10 N/A
    ;11 N/A
    ;12 N/A
    ;13 N/A
    ;14 N/A
    ;15 N/A
    ;16 N/A
    ;17 N/A
    ;18 N/A
    ;19 N/A
    ;20 N/A
    ;21 N/A
    ;22 N/A
    ;23 N/A
    ;24 N/A
    ;25 N/A
    ;26 N/A
    ;27 N/A
    ;28 N/A
    ;29 N/A
    ;30 N/A
    ;31 N/A
    ;32 N/A
    ;33 N/A
    ;34 N/A
    ;35 N/A
    ;36 N/A
    ;37 N/A
    ;38 N/A
    ;39 N/A
    ;40 N/A
    ;41 N/A
    ;42 N/A
    ;43 N/A
    ;44 N/A
    ;45 N/A
    ;46 N/A
    ;47 N/A
    ;48 N/A
    ;49 N/A
    ;50 N/A
    ;51 N/A
    ;52 N/A
    ;53 N/A
    ;54 N/A
    ;55 N/A
    ;56 N/A
    ;57 N/A
    ;58 N/A
    ;59 N/A
    ;60 N/A
    ;61 N/A
    ;62 N/A
    ;63 N/A
    ;64 N/A
    ;65 N/A
    ;66 N/A
    ;67 N/A
    ;68 N/A
    ;69 N/A
    ;70 N/A
    ;71 N/A
    ;72 N/A
    ;73 N/A
    ;74 N/A
    ;75 N/A
    ;76 N/A
    ;77 N/A
    ;78 N/A
    ;79 N/A
    ;80 N/A
    ;81 N/A
    ;82 N/A
    ;83 N/A
    ;84 N/A
    ;85 N/A
    ;86 N/A
    ;87 N/A
    ;88 N/A
    ;89 N/A
    ;90 N/A
    ;91 N/A
    ;92 N/A
    ;93 N/A
    ;94 N/A
    ;95 N/A
    ;96 N/A
    ;97 N/A
    ;98 N/A
    ;99 N/A
    ;100 N/A
    ;101 N/A
    ;102 N/A
    ;103 N/A
    ;104 N/A
    ;105 N/A
    ;106 N/A
    ;107 N/A
    ;108 N/A
    ;109 N/A
    ;110 N/A
    ;111 N/A
    ;112 N/A
    ;113 N/A
    ;114 N/A
    ;115 N/A
    ;116 N/A
    ;117 N/A
    ;118 N/A
    ;119 N/A
    ;120 N/A
    ;121 N/A
    ;122 N/A
    ;123 N/A
    ;124 N/A
    ;125 N/A
    ;126 N/A
    ;127 N/A
    ;128 N/A
    ;129 N/A
    ;130 N/A
    ;131 N/A
    ;132 N/A
    ;133 N/A
    ;134 N/A
    ;135 N/A
    ;136 N/A
    ;137 N/A
    ;138 N/A
    ;139 N/A
    ;140 N/A
    ;141 N/A
    ;142 N/A
    ;143 N/A
    ;144 N/A
    ;145 N/A
    ;146 N/A
    ;147 N/A
    ;148 N/A
    ;149 N/A
    ;150 N/A
    ;151 N/A
    ;152 N/A
    ;153 N/A
    ;154 N/A
    ;155 N/A
    ;156 N/A
    ;157 N/A
    ;158 N/A
    ;159 N/A
    ;160 N/A
    ;161 N/A
    ;162 N/A
    ;163 N/A
    ;164 N/A
    ;165 N/A
    ;166 N/A
    ;167 N/A
    ;168 N/A
    ;169 N/A
    ;170 N/A
    ;171 N/A
    ;172 N/A
    ;173 N/A
    ;174 N/A
    ;175 N/A
    ;176 N/A
    ;177 N/A
    ;178 N/A
    ;179 N/A
    ;180 N/A
    ;181 N/A
    ;182 N/A
    ;183 N/A
    ;184 N/A
    ;185 N/A
    ;186 N/A
    ;187 N/A
    ;188 N/A
    ;189 N/A
    ;190 N/A
    ;191 N/A
    ;192 N/A
    ;193 N/A
    ;194 N/A
    ;195 N/A
    ;196 N/A
    ;197 N/A
    ;198 N/A
    ;199 N/A
    ;200 N/A
    ;201 N/A
    ;202 N/A
    ;203 N/A
    ;204 N/A
    ;205 N/A
    ;206 N/A
    ;207 N/A
    ;208 N/A
    ;209 N/A
    ;210 N/A
    ;211 N/A
    ;212 N/A
    ;213 N/A
    ;214 N/A
    ;215 N/A
    ;216 N/A
    ;217 N/A
    ;218 N/A
    ;219 N/A
    ;220 N/A
    ;221 N/A
    ;222 N/A
    ;223 N/A
    ;224 N/A
    ;225 N/A
    ;226 N/A
    ;227 N/A
    ;228 N/A
    ;229 N/A
    ;230 N/A
    ;231 N/A
    ;232 N/A
    ;233 N/A
    ;234 N/A
    ;235 N/A
    ;236 N/A
    ;237 N/A
    ;238 N/A
    ;239 N/A
    ;240 N/A
    ;241 N/A
    ;242 N/A
    ;243 N/A
    ;244 N/A
    ;245 N/A
    ;246 N/A
    ;247 N/A
    ;248 N/A
    ;249 N/A
    ;250 N/A
    ;251 N/A
    ;252 N/A
    ;253 N/A
    ;254 N/A
    ;255 N/A
    ;Friday,05,February,2016,18:43:07:35982
    1,0,,
    1,1,,,
    ;13.79 V,Voltage,
    1,2,,,
    ;13.79 V,Voltage,
    1,3,,,
    1,4,,,
    2,0,,
    2,1,,,
    ;Not Oper., ,
    2,2,,,
    ;Not Oper., ,
    2,3,,,
    ;Not Oper., ,
    2,4,,,
    ;Not Oper., ,
    3,0,,
    3,1,,,
    ;OFF, ,
    3,2,,,
    ;0.0 %,Duty Cycle,
    3,3,,,
    ;OFF, ,
    3,4,,,
    ;0.0 %,Duty Cycle,
    4,0,,
    4,1,,,
    ;Hold, ,
    4,2,,,
    ;Hold, ,
    4,3,,,
    4,4,,,
    5,0,,
    5,1,,,
    ;14.0 %,Duty Cycle,
    5,2,,,
    5,3,,,
    5,4,,,
    6,0,,
    6,1,,,
    6,2,,,
    ;0.0 %,Duty Cycle,
    6,3,,,
    ;2.5 %,Duty Cycle,
    6,4,,,
    ;0.0 %,Duty Cycle,
    7,0,,
    7,1,,,
    ;0.0,(no units),
    7,2,,,
    7,3,,,
    7,4,,,
    8,0,,
    8,1,,,
    ;Locked, ,
    8,2,,,
    ;Installed, ,
    8,3,,,
    ;Deactivated, ,
    8,4,,,
    ;ON, ,
    9,0,,
    9,1,,,
    ;Term 15 On, ,
    9,2,,,
    ;StatCurStg 0, ,
    9,3,,,
    ;0.0 km/h,Speed,
    9,4,,,
    ;8.0,(no units),
    10,0,,
    10,1,,,
    ;Trailer: No, ,
    10,2,,,
    10,3,,,
    10,4,,,
    11,0,,
    11,1,,,
    ;Closed, ,
    11,2,,,
    ;Retracted, ,
    11,3,,,
    11,4,,,
    The world is my oyster...
  16. Likes kamold, Dana liked this post
  17. #9
    Nov 2016
    That procedure didn’t work for me. Only adjusting the figure in adaptions gave me full opening
    I wish I knew why kamolds is resetting, but at least we know the motors are capable of fully opening, as it was looking like they needed replacing otherwise
  18. Likes Dana liked this post
  19. #10
    Mar 2015
    Australia
    It keeps setting that channel back to 355
    Anyone have any ideas to try and get this setting to stay?
    NEtech when you say manual, do you mean short press the tailgate release on the keyfob so that it unlocks, but not moves, then push it up?
