Results 11 to 20 of 26
Thread: Early 05 Passat ABS 1 Fault Found: 00301 - ABS Return Flow Pump (V39) 35
    Sep 2018
    Thank you JYOUNG!
    From reading other posts, could it be that some recoding needs to be done?
    And if so, can the VagCom do it?
    If not, I was thinking about going to junk yard and trying to find the complete unit and swapping it out. (I know it is a major job with all the bleeding )
    I think someone told me once that if I find the same part?? number, I could?
    And if I do all that, will some recoding be necessary?
    Thanks!
  2. #12
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by glkirk View Post
    Thank you JYOUNG!
    VCDS could change it if needed, but your current coding of 4277 is appropriate to your car:
    0?xxx: Chassis
    4 = Audi A4 (8D) / VW Passat (3B)
    6 = Audi A6 (4B)
    8 = Audi A8 (4D)
    0x?xx: Brakes
    1 = C54 (Lucas) [PR-1LZ]
    2 = FN3 (Teves/ATE) [PR-1LB/1LE/1LF/1LT/1ZC] (verified you have PR-1LE using PartsLink24 lookup of your VIN)
    3 = FN2/HP2 (Dual-Piston) [PR-1LX] & Brembo [PR-1ZL]
    4 = FNRG-60 (Teves/ATE) [PR-1LA/1LG]
    0xx?x: Engine
    5 = 4/6/8 Cyl. Diesel
    7 = 4/5 Cyl. Gasoline
    9 = 6/8/12 Cyl. Gasoline
    0xxx?: Transmission
    3 = Manual with Low Range (only Audi A6 Allroad)
    5 = Manual
    7 = Automatic (01L/01N/01V)
    9 = Multitronic (01J)
    Sure. And I think that would be my next step, if this were my car. Some repair info sources for other VW/Audi makes indicates there's some electrical troubleshooting that you would want to do, and I had wondered about that 3-pin connector you mentioned. However, the Bentley repair manual specific to this model-year-range Passat says you skip straight to condemning the hydraulic assembly. Mmmkay!
    Printed output from Scan Tool VAG1551 (ST) Possible cause Corrective action
    00301 - ABS return flow pump V39
    Malfunction in hydraulic control module
    Erase DTC Memory 05 Erase DTC Memory (function 05), End Output (Function 06).
    Switch off ignition.
    Switch on ignition
    If malfunction occurs again, replace hydraulic control unit.
    There are some reasonably priced units on eBay if you are okay with used. I would get the entire assembly, not just the electronics, because the pump in question is part of the hydraulic side. PL24 indicates you may use 4B0 614 517 G (your original), 4B0 614 517 P, or 4B0 614 517 J. Avoid all other variants, they're for different powertrain configurations.
    Potentially. When you install the new module, scan the car and see if it's already coded to 4277. If so, you're good. If not, there's some instructions you need to follow, it takes a little more than "just" setting the coding to 4277.
    Check out this link: http://wiki.ross-tech.com/wiki/index...S/EDS/ASR/ESP)
    And here's a video where Jef @ Ross-Tech steps through the process:
    Silence gives consent.
  3. Likes glkirk, Uwe liked this post
  4. #13
    Sep 2018
    Thank you very much for your help!
    I will take your numbers and look on Ebay and at my local junk yard.
    Awfully nice of you to help me!
  5. Likes jyoung8607 liked this post
  6. #14
    Sep 2018
    I hope these pictures show.
    So, I looked on Ebay to find ambiguous listings or very expensive 1000.00 units. Became confused and discouraged. Will continue to at least understand what may or may not work from ebay and online.
    Went to my local junk yard. They had 3 passats but none of them had the config with the 3pin connector to it. See pic of mine and junk yards.
    I tested the 3 pin connector and think (quite sure!) I found the red to be the ground and the other two to have 4.5 volts.
    I found this posting on another site and found it very interesting. https://forums.vwvortex.com/showthre...low-Pump-(V39) by Reiddy
    From this idea, I loosened the housing< like it said, and it did feel stuck. Put it all back together, cleared codes and road tested-no joy.
    Even tried removing fuse from computer and tried to activate the pump but could not, and could not understand how Reiddy was telling me to.
    I wonder if there is a wiring schematic showing the wiring going into the ABS Module, so I could test just the motor?
    Thanks for any help.
  7. #15
    Sep 2018
    Looks like they did not show.
    The instructions says to paste the url between tags, but when I click on "Post image" I get a bar telling me to paste into!
  8. #16
    Sep 2018
    0?xxx: Chassis
    6 = Audi A6 (4B)
    8 = Audi A8 (4D)
    0x?xx: Brakes
    0xx?x: Engine
    0xxx?: Transmission
    5 = Manual
    The link to Wiki refers to a Bosch 5.3 whereas my unit is a Bosch 5.7.
    I have worked with the Wiki for 05 Passat with no luck yet. The code showed a letter then several spaces then 4 odd numbers. Not the code! Couldn't make the steering procedure work as the video shows.
    I think I tried the 4277 for the code but am still unsure about the log in. The Wiki asks about a Passat W8. Not sure? Also- the engine- not sure? Probably 7??
    http://wiki.ross-tech.com/wiki/index...ics_(Bosch_5.7)
    So these are the things I am researching now.
    Any help would be appreciated!
  9. #17
    Sep 2018
    My brake code is ILE, so would it be 5, (the only line with ILE in it.
    I did find that mine is a 4 cylinder so not the W8
  10. #18
    Sep 2018
    I do now see on my scan that the code should be the 04277. But what would the login be? I wonder if I should try the redirect of the 5.3?
    Am a little concerned about an error message I saw once "Incorrect coding could render unit inopperable" ?
  11. #19
    If you know the coding, you can work backwards to derive the login.
    Coding Meaning Login
    4 Passat (not W8) 9
    2 PR-1LB/1LE/1ZC Brakes 5
    7 PR-T0B/T10/T6V/T0D/T0F Engine 7
    7 Automatic Trans 7
  12. #20
    Sep 2018
    Thank you for your responce!
    I have tried that set and just tried that set again. I got them off the Audi, redirect Bosch 5.3 Wiki page. I always get "t 3428", which I suspect is the original code to the item/unit/component.
    When I try VW 3B Passat Wiki, using 9-reg passat, 5-ILE brakes (as I have), 5-engine-only one that has ILE in it, and 7- for auto trans. for log in
    4257 for code......still get t 3428 in the pane.
