2011 golf mk6 wagon
Part# 1k0907379at
I do not have the original part as it burnt out and lost coding to the new part.
Is there any help available?
Part# 1k0907379at
Monday,17,September,2018,19:20:42:04458
VCDS Version: 18.2.1.5 (x64)
VIN: 3VWPL7AJ1BM636929 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWPL7AJ1BM636929 Mileage: 126010km-78298miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 B HW: 03L 906 019 DA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H10--- Serial number:
Coding: 0050078
Shop #: WSC 60048 002 1048576
VCID: 2D517573B400542CBF-8078
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9136
Revision: 05351113 Serial number: 00001103210450
Shop #: WSC 44551 111 44551
VCID: 183FB4A72B82C184FC-804C
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
VCID: 74E7A017D7AA45E430-8020
Reset counter: 44
Date: 2013.02.07
Time: 12:36:18
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 48896
Fault Status: 01100101
Reset counter: 44
Mileage: 125911 km
Date: 2013.02.07
Time: 12:36:16
Count: 3
Count: 12
Count: 29184
Count: 279
Count: 48384
Count: 768
Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Shop #: WSC 00066 000 00149
ROD: EV_ClimaBasis_VW36.rod
VCID: 6ED3B27FB1866F34C6-803A
Part No SW: 5K0 937 086 H HW: 5K0 937 086 H
Component: BCM PQ35 M 011 1035
Revision: BJ011001
Coding: 25380E3B902B3EC400800081600083040300001653118560648020000040
VCID: 39795123B048F88C23-806C
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 14101 21 0512
Coding: 009795
Fault Status: 00101010
Reset counter: 84
Mileage: 125921 km
Date: 2013.02.07
Time: 13:10:34
Voltage: 13.85 V
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00ZRAW
Coding: 00003046
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 39795123B848F88C23-806C
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME05587256ZZZV
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME402E7256ZZZY
Serial number: 3511HSME1A6E2023ZZZJ
Serial number: 3521HSME584C1223ZZZJ
Component: F.Sens.Fahr --- ----
Serial number: 35527SME52165123ZZZ1
Component: F.Sens.Beif --- ----
Serial number: 35627SME7F265123ZZZI
Part No SW: 5K0 953 507 AD HW: 5K0 953 549
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JHP0018W
Coding: 1880140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72EBA60FA5BE4BD422-8026
Part No SW: 5K0 920 861 A HW: 5K0 920 861 A
Component: KOMBI H21 0204
Revision: X0021007 Serial number:
Coding: 370D00
Shop #: WSC 00066 123 00149
ASAM Dataset: EV_KombiUDSMM9RM10 A04203
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 2B557B6B42145A1CA1-807E
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 03101001210677
Coding: ED807F0600020200002002
VCID: 6DD1B5737480942CFF-8038
Part No SW: 5K0 953 234 HW: 5K0 920 861 A
Component: IMMO H21 0204
ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6ADBBE6F8D6E83149A-803E
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001460856
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 275D875B5EFC7E7C45-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005194073
Coding: 000490
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 31696903A83830CC9B-8064
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001421344
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 285F846753E271044C-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005246654
Coding: 000490
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H13 0043
Revision: -----26S Serial number: VWZ4Z7K1152521
Coding: 2500040004
VCID: 61C9D9437858C04C4B-8034
02633 - Antenna for Satellite Tuner
Reset counter: 44
Mileage: 125911 km
Date: 2013.02.07
Time: 12:36:15
Reset counter: 44
Mileage: 125911 km
Date: 2013.02.07
Time: 12:36:15
End-------------------------(Elapsed Time: 02:53)--------------------------
