VCDS-Mobile Auto-Scan video / reading scans from HEX-NET
jhuber
C?ID=346551
Hello!
In the VCDS-Mobile Auto-Scan video, at the end, the video instructs the viewer to "click here" to get information on how to read scans stored in the HEX-NET. I have clicked everywhere in that video, and I can't seem to find a link, nor can I find a video about reading saved scans. Could someone point me to the referenced video?
I have connected to the HEX-NET in AP mode from an Android smart phone, did a couple of Auto Scans and saved them to the HEX-NET, but I can't seem to figure out how to pull them out. I can see them when connected with VCDS-Mobile. I connected to the HEX-NET with VCDS from Windows 10 via USB cable, but I didn't find a function to read data stored on the HEX-NET.
Thanks!
Shaun
Open them with a browser in mobile from whatever PC you want and "save file as..."
jhuber
C?ID=346551
Thank you! That tip works great!
I have run into a couple of other issues...
1) I connect to HEX-NET with USB from a PC, and the WiFi in HEX-NET (Infrastructure Mode) is connected to my network. I did "check for updates" from the VCDS config util on the PC and it says new RODS are needed. A DS file is downloaded and applied, and the update says that it completes successfully. However, if I recheck for updates, it does the ROD update over again, and again, and again.
2) I connected the USB to power HEX-NET, and in Infrastructure mode, I can open a browser to the HEX-NET to access VCDS-Mobile. When I check for updates in VCDS-Mobile, it wants to do an ASAM update. I get "updating ASAM database", but it freezes at 0%. I can cancel the update, and try again, but it never goes past 0%. I have tried different computers and browsers, but get the same result. The network test in VCDS-Mobile shows that everything is OK.
Thanks!
Please use the VCIConfig utility to put your HEX-NET on the Beta channel for updates (on the Advanced screen). Then check for updates again. The ROD file stuff is much improved with the newer firmware and Dataset.
jhuber
C?ID=346551
Thank you for the tip! The Beta channel seems to have helped with getting things updated.
I've included a couple of scans...the first is from a 2015 Passat TDI and the second is from a 2016 Touareg TDI. Both have the stage 1 emissions fix. The Passat scan seems to take longer, and it seems there are some "Failed to respond" errors in that scan. For both vehicles, I was connected in AP mode.
VCDS Mobile 0.4430.0.4
VIN: 1VWCV7A32FC118524
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
	 52 56 62 72 75 77
Address 01: Engine  (CVCA J623)	Labels: 04-01.clb
	Part No SW: 04L 906 016 AF	HW: 04L 907 309 K
	Component: R4 2.0l TDI   H20 9289
	Revision: 8AH20---
	Coding: 011D0012032410089000
	Shop #: WSC 04905 444 00000
	ASAM Dataset: EV_ECM20TDI01104L906016AF 004017
	ROD: N/A
	VCID: 6D9D5AB71D7976AA2B54FC-8038
	No ASAM data for: "EV_ECM20TDI01104L906016AF"
020558 - ROD - Unknown faultcode
Address 02: Auto Trans	Labels: 02E-927-770.lbl
	Part No SW: 02E 300 061 T	HW: 02E927770AL
	Component: GSG DSG AG6     531  4518
	Revision: 05653104	Serial Number: 00001502070151
	Shop #: WSC 09003 957 00200
	VCID: 250D6297850916EAA364D4-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
	U0235 - 000 -  -  - Intermittent
Address 03: ABS Brakes  (J104)	Labels: 1K-03.clb
	Part No SW: 1K0 907 379 BS	HW: 1K0 907 379 BS
	Revision: 00H46001
	Coding: C54BC0F549230002A31003E6921D0042A1100012
	VCID: 844B9F13AEF30FE2543AE1-80D1
No fault codes found.
Address 05: Acc/Start Auth.  (J518)	Labels: 5K0-959-434.clb
	Part No SW: 5K0 959 434 E	HW: 5K0 959 434
	Revision: 00092000
	Coding: 130C0C
	ROD: N/A
	VCID: 3731B8DF2FA50C7A01382E-8062
	No ASAM data for: "EV_KESSYPQ35G"
Address 08: Auto HVAC  (J255)	Labels: 5K0-907-044.clb
	Part No SW: 561 907 044 AR	HW: 561 907 044 AR
	Component: Climatronic   H03 0808
	Revision: 00001K01
	Coding: 0050019012
	ROD: EV_ACClimaBHBVW411_VW41.rod
	VCID: 6791289F3F855CFA51183E-8032
Address 09: Cent. Elect.  (J519)	Labels: 1K0-937-08x-09.clb
	Part No SW: 5K0 937 087 AE	HW: 5K0 937 087 AE
	Component: BCM PQ35 H+   122 0174
	Revision: BL122001
	Coding: EF200E1B982B08D4098802013600854800F1A08645A005B064806000BC70
	VCID: 78B37BE3623BDB02C8A265-802D
	Subsystem 1 - 	Part No SW: 1K0-955-559-AH	Labels: 1K0-955-559-AG.clb
	Component: RLS 010615 0554  0403
	Coding: 02300A
Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
	Part No SW: 5C0 959 655 AB	HW: 5C0 959 655 AB
	Component: AirbagVW10    500 0975
	Coding: 00004D35
	ROD: EV_AirbaVW10SMEVW360.rod
	VCID: 72A749CB0447A952F666A7-8027
	Subsystem 1 - 	Part No SW: 5C6-959-339-B
	Component: BF-Gewichtss.H10 0046
	Serial Number: 6940000Y150001DSZE0L
	Coding: 303047
	Subsystem 2 - 	Part No SW: 5K0-959-354
	Component: S.Sens.Fahr.VH02 ----
	Serial Number: 3572MSME6D2F5E51ZZZB
	Subsystem 3 - 	Part No SW: 5K0-959-354
	Component: S.Sens.Beif.VH02 ----
	Serial Number: 3582MSME452A5E51ZZZ/
	Subsystem 4 - 	Part No SW: 5K0-959-351-A
	Component: S.Sens.Fahr.HH02 ----
	Serial Number: 3516KSME0B036E37ZZZX
	Subsystem 5 - 	Part No SW: 5K0-959-351-A
	Component: S.Sens.Beif.HH02 ----
	Serial Number: 3526KSME16504A37ZZZQ
	Subsystem 6 - 	Part No SW: 5K0-959-659-A
	Serial Number: 3556LSME73431835ZZZS
	Subsystem 7 - 	Part No SW: 5K0-959-659-A
	Serial Number: 3566LSME24523635ZZZP
Address 16: Steering wheel  (J527)	Labels: 1K-16.lbl
	Part No SW: 1K5 953 521 BR	HW: 5K0 953 569 AH
	Component: LENKS.MODUL   016 0162
	Revision: FF010042
	Coding: 000A140000
	ROD: EV_SMLSNGVOLWSXS.rod
	VCID: 7EBF6DFB401FFD3282FE23-802B
Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
	Part No SW: 561 920 970 G	HW: 561 920 970 G
	Component: KOMBI         H05 0813
	Coding: 231E01
	ROD: N/A
	VCID: 1E7F4D7BA05F5D32E23E03-804B
	No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 19: CAN Gateway  (J533)	Labels: 7N-19.clb
	Part No SW: 7N0 907 530 AR	HW: 7N0 907 530 AM
	Component: J533  Gateway H55 1653
	Revision:   H55
	Coding: 461000
	VCID: 80439303BAEB13C27012CD-80D5
Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
	Part No SW: 5K0 953 234	HW: 5K0 953 234
	Component: IMMO          H05 0813
	Coding: 000007
	VCID: EA97D1ABAC97E192CE365F-80BF
Address 2B: Steer. Col. Lock  (J764)	Labels: 5K0-905-861.clb
	Part No SW: 5K0 905 861 C	HW: 5K0 905 861 C
	Revision: 00000000
	Coding: 4900000000000000
	ROD: EV_ELVMarquMPVW36X.rod
	VCID: 302383C3CACBDB4240F25D-8065
Address 2E: Failed to respond
Address 36: Seat Mem. Drvr  (J136)	Labels: None
	Part No SW: 561 959 760 B	HW: 561 959 760 B
	Component: MEM-FS        H04 0183
	Revision: AA000000
	Coding: 00581B0000000000000021010100202020202120202020
	VCID: 2207798B942761D2C64637-8077
Address 37: Navigation  (J0506)	Labels: 1T0-035-680.clb
	Part No SW: 3C0 035 684 Q	HW: 3C0 035 684 Q
	Component: RNS-MID       H27 5382
	Revision: AB001001
	Coding: 04090042010000A6000B
	VCID: 312586C7C1C1CA4A4FFC50-8064
	Subsystem 1 - 	Part No SW: 7L6-
	Component: NAR V9       8213
Address 42: Door Elect, Driver  (J386)	Labels: 3C0-959-70X-GEN4.clb
	Part No SW: 561 959 701 A	HW: 3C0 959 793 C
	Component: TUER-SG FT    002 0525
	Revision: 12110009
	Coding: 0405FD
	ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
	ROD: EV_TSGFPQ25BRFVW46X.rod
	VCID: 1C7B4773B6434F220C0A79-8049
Address 44: Steering Assist	Labels: 1Kx-909-14x-44.clb
	Part No SW: 1K0 909 144 R
	Component: EPS_ZFLS Kl. 215     3501
	Revision: 00H22000
	VCID: 3935BEE719B1820AF72C38-806C
Address 46: Failed to respond
Address 47: Sound System  (R12)	Labels: 5K0-035-456.clb
	Part No SW: 5C6 035 456 C	HW: 5C6 035 456 C
	Component: KonzernAmp10K H08 6831
	Revision: --------
	Shop #: WSC 00000 000
	VCID: 28136BA3F21B93829882F5-807D
Address 4F: Centr. Electr. II  (J520)	Labels: 1K0-907-532.clb
	Part No SW: 7N0 907 532	HW: 7N0 907 530 AM
	Component: EZE_2         H55 1653
	Revision:   H55
	Coding: 01030108
	VCID: EFA1C0BF97751CBA994806-80BA
	Subsystem 1 - 	Part No SW: 561-959-591-A
	Component: J245 P05 9BA3H08 0005
	Coding: 181100
	Subsystem 2 - 	Part No SW: 561-919-204-B
	Component: Analoguhr    009 0005
Address 52: Door Elect, Pass.  (J387)	Labels: 3C0-959-70X-GEN4.clb
	Part No SW: 561 959 702 A	HW: 3C0 959 792 C
	Component: TUER-SG BT    002 0525
	Revision: 14110009
	Coding: 0405FC
	ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
	ROD: EV_TSGBPQ25BRFVW46X.rod
	VCID: 1D7D4A77AD59462AFB340C-8048
Address 56: Radio  (J0506)	Labels: 1T0-035-680.clb
	Revision: AB001001
Address 75: Telematics  (J949)	Labels: 56-75.clb
	Part No SW: 561 035 285 A	HW: 561 035 285 A
	Component: OCULowUSA     020 0156
	Coding: 02140102C24232007F1606000000
	ASAM Dataset: EV_OCULow 002009
	ROD: N/A
	VCID: 146B2F535E93076244DA91-8041
	No ASAM data for: "EV_OCULow"
Address 77: Telephone  (J412)	Labels: 5N0-035-729.clb
	Part No SW: 5N0 035 729 E	HW: 5N0 035 729 E
	Component: TELEFON       H07 0593
	Revision: 1B001001
	Coding: 0A10030080010110
	ROD: EV_UHVUMI.rod
	VCID: 322789CBC4C7E95236E667-8067
#hndoc:?docid=0000439D&xt=hnh:C1430FBC3CBCAA8C369C7A54E66BA59189B13955F4068E4DA1A1992B0F0B38E0
VIN: WVGEP9BP1GD002578
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 52 53 55 56 5F
	 62 65 69 6C 6D 72
Address 01: Engine  (CNRB J623)	Labels: 059-907-401-V2.clb
	Part No SW: 7P1 907 401 C	HW: 7P0 907 401 K
	Component: 3.0TDI FSA    H21 0007
	Revision: 56H21---
	Coding: 292A4012233600050000
	Shop #: WSC 23041 444 00000
	ASAM Dataset: EV_ECM30TDI0117P1907401C 001008
	ROD: EV_ECM30TDI0117P1907401C.rod
5608 - No Communications with Steering Angle Sender (G85)
	U0126 00 [032] -
Address 02: Auto Trans  (J217)	Labels: 0C8-927-755.clb
	Part No SW: 0C8 927 755 R	HW: 0C8 927 755
	Component: AL1000 AISIN  130 3374
	Coding: 010200000C008400000000000000000000000000
	Shop #: WSC 31414 790 00001
	ASAM Dataset: EV_TCMAL991031 003118
	ROD: N/A
	VCID: 40C3D3037A6B4BC2B0928D-8015
	No ASAM data for: "EV_TCMAL991031"
023198 - ROD - Unknown faultcode
Address 03: ABS Brakes  (J104)	Labels: 7P0-907-379.clb
	Part No SW: 7P0 907 379 R	HW: 7P0 907 379 A
	Component: MK25A         H37 0521
	Revision: --------
	Coding: 5B7613C349242555DAF9C89A92DAA4607301
	ASAM Dataset: EV_MK25AXT 010001
	ROD: N/A
	VCID: 4CDBF73346239FA25CEA09-8019
	No ASAM data for: "EV_MK25AXT"
Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
	Part No SW: 4H0 907 064 GK	HW: 4H0 907 064 GK
	Component: BCM2 2.0      H37 0572
	Coding: 0D860016000000000000
	Subsystem 1 - 	Part No SW: 7P6-959-754-AR
	Component: FBSTOUAREGIDGH08 0084
	Subsystem 2 - 	Part No SW: 4H0-905-852-B
Address 08: Auto HVAC  (J255)	Labels: 7P6-907-040.clb
	Part No SW: 7P6 907 040 CN	HW: 7P6 907 040 CN
	Component: Klima 2 Zonen H23 1507
	Coding: B606200A80
	VCID: 8247990BB4E719D26606D7-80D7
0324 - Function Restriction due to Faults in Other Modules
	U1113 00 [009] -
Address 09: Cent. Elect.  (J519)	Labels: 4H-09.clb
	Part No SW: 4H0 907 063 DA	HW: 4H0 907 063 AA
	Revision: 22020001
	Coding: 26000096963C5D010020480000005D4C431C6608A2010265000000008040110000000000000000
	VCID: 6A9751AB2C9779924E36DF-803F
	Subsystem 1 - 	Part No SW: 7P0-955-119	Labels: 1Kx-955-119.clb
	Component: WWS    150612033 0021
	Coding: 004DBD
	Subsystem 2 - 	Part No SW: 7P0-955-559-E	Labels: 8K0-955-559.clb
	Component: RLFS         H10 0020
	Coding: 025223
	Subsystem 3 - 	Part No SW: 7P6-941-431-AC
	Component: E1 - LDS     H02 0040
	Subsystem 4 - 	Part No SW: 4G0-907-410-A
	Component: USHL4.2      H30 0030
	Subsystem 5 - 	Part No SW: 8K0-959-772-E
	Component: SLR-B8       H06 0007
	Coding: 952F00
	014 - Defective
Address 10: Park/Steer Assist  (J446)	Labels: 7P6-919-475.clb
	Part No SW: 7P6 919 475 D	HW: 7N0 919 475
	Component: PARKHILFE 8K  H06 0030
	Revision: --------
	Coding: 310504
	ASAM Dataset: EV_VW526ParkiAssis2 001013
	ROD: EV_VW526ParkiAssis2.rod
	VCID: 44CBDF136E7357E294BAA1-8011
Address 15: Airbags  (J234)	Labels: 7P0-959-655.clb
	Part No SW: 7P0 959 655 F	HW: 7P0 959 655 F
	Component: VW10Airbag02B H10 0044
	Revision: --------
	Coding: 000000000000000000000000000000003242
	ASAM Dataset: EV_AirbaVW10BPAVW526 002001
	ROD: N/A
	No ASAM data for: "EV_AirbaVW10BPAVW526"
	Subsystem 1 - 	Part No SW: 7P6-959-339
	Component: BF-Gewichtss.003 0005
	Serial Number: 5850000R153310M3YDªª
	Subsystem 2 - 	Serial Number: 3575LRB40513B06G20OM
	Subsystem 3 - 	Serial Number: 3585LRB40513COSA899L
	Subsystem 4 - 	Serial Number: 3517ARB405V35IMUBOOQ
	Subsystem 5 - 	Serial Number: 3527ARB405V35IMULPO
	Subsystem 6 - 	Serial Number: 3557BRB40673ERQUEOS.
Address 16: Steering wheel  (J527)	Labels: 4H0-953-568.clb
	Part No SW: 4H0 953 568 L	HW: 7P6 953 507 AF
	Revision: --------
	Coding: 0000D5
	VCID: 3C3BA7F316833722EC4AD9-8069
	Subsystem 1 - 	Part No SW: 7P6-959-542-A
	Component: E221__MFL-TASH05 0028
Address 17: Instruments  (J285)	Labels: 7P6-920-xxx-17.clb
	Part No SW: 7P6 920 983 A	HW: 7P6 920 983 A
	Component: Kombi         H13 0515
	Revision: 13240302
	Coding: 8B7733022B08CF05020004
	ASAM Dataset: EV_KombiUDSRBVW526 001022
	ROD: EV_KombiUDSRBVW526.rod
	VCID: 3D3DAAF70D99262ADB74EC-8068
Address 19: CAN Gateway  (J533)	Labels: None
	Part No SW: 7P6 907 530 M	HW: 7P6 907 530 F
	Component: GW-CAN-L-MOST H13 6042
	Revision: --------
	Coding: 000103AD00
	ASAM Dataset: EV_GatewVW526UDS 001007
	ROD: EV_GatewVW526UDS.rod
	VCID: 42C7D90B746759D2A68697-8017
	Subsystem 1 - 	Part No SW: 7P0-915-181-B
	Component: Batt_Sensor  H07 0190
	Serial Number: 32167C10035701286242
	Part No SW: 4H0 959 760 E	HW: 4H0 959 760 E
	Component: MEM-FS        H08 0156
	Revision: AA000000
	Coding: C0581B0015004001000001010101202020202121202020
	VCID: 352DB2D735A9E66A130404-8060
Address 3C: Lane Change  (J769)	Labels: 5Q0-907-566.clb
	Part No SW: 7P6 907 566 A	HW: 4H0 907 566 F
	Component: SWA Master    H06 0021
	Coding: 030221
	ROD: EV_LaneChangAssis_VW52.rod
	VCID: 3FC1D0FF0795343AC968F6-806A
Address 42: Door Elect, Driver  (J386)	Labels: None
	Part No SW: 4H0 959 793 AC	HW: 4H0 959 793 P
	Component: TSG FA        H02 0306
	Revision: --------
	Coding: 011D17205E00453005080000
	VCID: 7AB761EB5C37C912BED60F-802F
Address 46: Central Conv.  (J393)	Labels: 4H0-907-064-46.clb
	Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
	Subsystem 1 - 	Part No SW: 7P6-959-719-A
	Component: GTO BT       H20 0059
	Subsystem 2 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 3 - 	Part No SW: 7P0-959-591-D
	Component: J245 PS30.408H03 0004
	Coding: 191100
	Subsystem 4 - 	Part No SW: 7P0-959-591-E
	Component: J394 PS30.408H03 0004
	Coding: 191100
	Subsystem 5 - 	Part No SW: 3AA-962-243-E
	Component: GEB.F.HeckoefH16 0813
Address 52: Door Elect, Pass.  (J387)	Labels: None
	Part No SW: 4H0 959 792 S	HW: 4H0 959 792 M
	Component: TSG BF        H02 0306
	Revision: --------
	VCID: 48D3CB23525B6B8278C255-801D
Address 53: Parking Brake  (J540-)	Labels: 7P0-907-801.clb
	Part No SW: 7P0 907 801 F	HW: 7P0 907 801 F
	Component: EPB           H51 1201
	Revision: 00000000
	Coding: 01040200
	ROD: EV_ParkbA7.rod
	VCID: 362FB5DB28AFF5721A0E1B-8063
	Subsystem 1 -
0070 - Control Module
	U4E0450 F0 [008] - Incorrect VIN
Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
	Part No SW: 7P6 907 357 C	HW: 7P6 907 357 B
	Revision: --------
	Coding: 012A02010B000400
	ROD: EV_HeadlRegulAFSMQBMLB.rod
	Subsystem 1 - 	Part No SW: 8U0-941-329	Labels: 3D0-941-329.clb
	Component: °
	Subsystem 2 - 	Component: °
Address 56: Radio  (R)	Labels: None
	Part No SW: 4G0 035 082 G	HW: 4G0 035 082
	Component: Radio U SIRIU H66 0133
	Revision: AB001007
	Coding: 020007020100000001
	VCID: 240B7F938E336FE2B47AC1-8071
Address 5F: Information Electr.  (J794)	Labels: 4E0-035-6xx-5F.clb
	Part No SW: 7P6 035 664 K	HW: 7P6 035 664 A
	Component: H-BN-NA       H41 0933
	Revision: --------
	Coding: 010200050040E1EF51022B0E00000003F00001030000000000
	VCID: 40C3D3037A6B53C2B0928D-8015
	Subsystem 1 - 	Part No SW: 7P6-060-884-B
	Component: NAR 2015     1202
	Subsystem 2 - 	Part No SW: 7P6-919-603-L
	Component: DU8 SV Touch H56 0046
	Subsystem 3 - 	Part No SW: 7P6-919-603-L
	Subsystem 4 - 	Part No SW: 8R0-060-961-G
	Component: CD-Database  6208
Address 62: Door, Rear Left  (J388)	Labels: None
	Part No SW: 4H0 959 795 P	HW: 4H0 959 795 J
	Component: TSG HL        H03 0306
	Revision: --------
	Coding: 011817200000253005080000
Address 65: Tire Pressure  (J502)	Labels: 3Y0-907-273.clb
	Part No SW: 7P6 907 273 L	HW: 5Q0 907 273
	Component: RDKBERU30     H04 0003
	ASAM Dataset: EV_RDKBERU30 005005
	ROD: N/A
	VCID: 45CDC21765496EEA83A4B4-8010
	No ASAM data for: "EV_RDKBERU30"
Address 69: Trailer  (J345)	Labels: 4H0-907-383-V2.clb
	Part No SW: 4H0 907 383 M	HW: 4H0 907 383 K
	Component: Anhaenger     H20 0160
	Revision: 7C001003
	Coding: 0200000200000000
	ROD: EV_TrailFunctGener2Hella_VW52.rod
Address 6C: Back-up Cam.	Labels: 4L0-910-441.clb
	Part No SW: 7P6 907 441 A	HW: 4H0907441
	Component: SG Rueckfahrkamera   0020
	Revision: 00H08000	Serial Number: 525 PA8JA60388
	Coding: 0130001
	VCID: 3731B8DF2FA5947A01382E-8062
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 7P6 959 107 C	HW: 7P6 959 107
	Component: HDSG-Modul    H10 0043
	Revision: 22010001
	Coding: 0533314003
	ASAM Dataset: EV_HeckkTouar 202142
	ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right  (J389)	Labels: None
	Component: TSG HR        H03 0306
	Revision: --------
In the Passat, 2E and 46 don't really exist; VCDS (Desktop) knows this and doesn't bother; Mobile unfortunately does not yet.
Have you done another check for updates after doing these scans? VCDS-Mobile will only download the ROD files it thinks it needs (i.e. for modules that it has seen).
jhuber
C?ID=346551
Yes, I did another check for updates, and it did download more ROD Files. I did a rescan, but didn't see that anything changed.
One thing I've noticed in VCDS-Mobile...it seems that some of the screens don't have any margin. As such, the letters at the edge of the display are obscured. I am using the Chrome browser in Android 8. I don't recall noticing this problem before with any other websites with this device. A screenshot is below.
jhuber
C?ID=346551
Updated the post with a different image hosting site...hopefully it is viewable now...
Shaun
Curious, can you resize the page so it fits by two-finger pinch dragging it smaller?
jhuber
C?ID=346551
I cannot resize the screen by the two-finger pinch drag method. If I rotate the screen, the edge of the left-side letters do appear. Still very close to the edge.
