Coding support for VW UP GTi 2018
   #61
iichel
Netherlands, eastern part
C?ID=284912
I expect all the Up! GTI's to have the 1.0 TSI engine with BMT. So they should all have the 1S0 937 090 BCM. So one label to rule them all :)
   #62
Alex.fergo1988
C?ID=389664
scan as requested
Monday,15,June,2020,19:48:26:33003
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZAAZKD125737   License Plate: AF03RFO
Mileage: 24210km-15043mi   Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 08 09 10 15 17 19 25 44 47 5F 61 A9 AD
VIN: WVWZZZAAZKD125737   Mileage: 24210km-15043miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-DKRA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 F    HW: 04C 907 309 BA
   Component: R3 1.0l TFS   H20 6355
   Revision: D8H20000
   Coding: 00190032232401000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10TFS01104C906025F 003009
   ROD: EV_ECM10TFS01104C906025F_003_VW12.rod
   VCID: 2313E85EAB5DF6A36E9-8077
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 P    HW: 1S0 614 517 P
   Component: EBC 460 ESP   H17 0030
   Serial number: A01VLJP
   Coding: B8BF64712BAF02F61D0126F8D4B040905FB000
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002107
   ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
   VCID: 3C21332236E3A95B4F3-8069
0459 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 76
                    Mileage: 23486 km
                    Date: 2020.05.15
                    Time: 18:52:52
                    DTC: 00 01 CB
   Part No SW: 1S0 907 044     HW: 1S0 907 044
   Component: Climatronic   H05 0102
   Revision: K0000000
   VCID: 6C81C3620683F9DB9F3-8039
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 1S0 937 090 J    HW: 1S0 937 090 J
   Component: BCM PQ25 1MX4 H82 0762
   Revision: BW082001    Serial number: 8901 291180367
   Coding: 64B829000001000009080FD06CEB8ED079C0706D60CF2D602101000B0900
   VCID: 3A2D353A3C57976B5DF-806F
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 051018 05  50  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.405  H04 0005
   Serial number: 0000FST00263Q3400000
   Coding: 181100
   Subsystem 3 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29180001877870098381
   Coding: A4FFFF
                    Fault Status: 00101010
                    Fault Frequency: 28
                    Reset counter: 135
                    Mileage: 24039 km
                    Date: 2020.06.13
                    Time: 13:36:16
                    Fault Frequency: 30
                    Reset counter: 135
                    Mileage: 24039 km
                    Date: 2020.06.13
                    Time: 13:36:10
                    Fault Status: 01101010
                    Reset counter: 94
                    Mileage: 24039 km
                    Date: 2020.06.13
                    Time: 13:36:17
                    Reset counter: 94
                    Mileage: 24039 km
                    Date: 2020.06.13
                    Time: 13:36:17
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0013
   Revision: --------    Serial number: 32931828200063
   Coding: 108004
   ASAM Dataset: EV_EPHVA14VW1200000 001009
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 392F2A3639D19C73545-806D
   Part No SW: 1S0 959 655 E    HW: 1S0 959 655 E
   Component: VW10Airbag02Y 010 0007
   Revision: --------    Serial number: 003EQ001KN12
   Coding: 000000000000000000000000000000003259
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 40D947D25A0BCDBB13B-8015
   Serial number: 357D4RB405P5LSE65OKC
   Serial number: 358D4RB405F5J4AU9O8W
   Serial number: 3557BRB405V59B9ED9T-
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 970 C    HW: 1S0 920 970 C
   Component: KOMBI         H12 0100
   Revision: X0012001    Serial number: 00000000000000
   Coding: 414A010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 323D1D1AE4A76F2B95F-8067
   Part No SW: 1S0 909 901     HW: 1S0 937 090 J
   Component: GW-K-CAN TP20 H82 0762
   Revision: BW082001
   Coding: 001101
   VCID: 70B9D7122AAB1D3BA3B-8025
   Part No SW: 5K0 953 234     HW: 1S0 920 970 C
   Component: IMMO          H12 0100
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6A8DC57A0CF7E7EBEDF-803F
   Part No SW: 6R2 909 144 AN    HW: 6R2 909 144 E
   Component: EPS_TRW_ALow  323 3150
   Serial number: CIAH0472
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 04518BC20E93119B773-8051
   Part No SW: 5K0 035 456 E    HW: 5K0 035 456 E
   Component: KonzernAmp 8K H09 6631
   Revision: --------    Serial number: EAA101C0086466
   ASAM Dataset: EV_AudioVerst8KanalSTT3 001003
   ROD: EV_AudioVerst8KanalSTT3.rod
   VCID: 2C010362C68339DBDF3-8079
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 1S0 035 869 B    HW: 1S0 035 869 B
   Component: MU-E-D-EU     068 7338
   Serial number: 15101800020394
   Coding: 02210100AA00000041111103018000001F000AC60001010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 3537260615C97813B0D-8061
   Part No SW: 1S0 907 534     HW: 1S0 937 090 J
   Component: Batt.regelung H82 0762
   Coding: 032B7856
   Subsystem 1 - Part No SW: 1S0 915 181 D    HW: 1S0 915 181 D
   Component: J367-BDM  H08 0270
   Serial number: 65267753466061077008
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 1S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0003
   Serial number: 180910200855
   VCID: 73B3D81E5B3D26235E9-8027
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
   Component: CV-SENSOR     H08 0460
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 2809FF72D27B15FB3BB-807D
End----------(Elapsed Time: 01:14, VBatt start/end: 12.2V/12.2V)-----------
Alex.fergo1988
C?ID=389664
You'll need to post a full unedited VCDS Auto-Scan so we can see which might be the correct label file.
Hi Dave I’ve posted a full scan on page 7
Thanks in advance
   #65
Alex.fergo1988
C?ID=389664
Now it's up to the experts (I'm not one!) to work out the correct label file.
Ahh right ok, so will they email me or something? Sorry I’m new to this
   #67
Alex.fergo1988
C?ID=389664
The answer will be posted here so anyone can see the solution.
Ok cause other people have asked and it’s been emailed to them and not posted here
   #68
Dana
Western PA, USA
Hi guys,
I was off earlier this week.
1S0-937-09x-V2.CLB will be in the next VCDS update (thanks to Niels / NEtech) but it isn't in the current version.
Alex, I'll send it to your @gmail.com email address within an hour or two.
Edit. I CC'd your 2nd email address on-file as well.
iichel
C?ID=284912
I found some more info on the Up wrt coding
Engine 01 04C 906 020 EN --> byte 3 00110032020401000000 = climatronic (label speaks about semi and automatic climate control); 00110010020401000000 = manual AC
Radio 5F 1S0 035 869 B --> byte 18 = startup screen, 00, 01, 02....0A = Welcome to VW, Cross Up, BlueMotion, E-Up, Eco-up, Beats Audio, Sound, Allstar, R-Line, Spice and GTI
   #70
Dana
Western PA, USA
Hi @iichel ,
Thanks.
In ref to:
01: 04C-906-020-CHY.CLB
I see that discrepancy here https://forums.ross-tech.com/index.php?threads/8154/
.. and in another scan with full VIN that used PR-Code PH5 Climatronic with the same type of Component: Climatronic 08 unit.
I'll tag @Sebastian to get a second opinion before I change that label.
5F: 5G0-035-MIB-ENT2.CLB
I failed to locate scans using that 02210A coding scheme. If you happen to have one, or a link to one, please let us know!
   #71
iichel
C?ID=284912
This is an example of an up! GTI with 5F and GTI start-up logo.
02210100BE00000041111101018002001F000AC40001010001
   Serial number: 08111800020362
   Coding: 02210100BE00000041111101018002001F000AC40001010001
   VCID: 353723DF05CB30FF7DD-8060
End----------(Elapsed Time: 01:14, VBatt start/end: 13.3V/13.3V)-----------
So I took out my good old VCDS and coded my own 5F to take the proof.
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0001D40001010001,to,02210100AA00000041111103018000001F0101D40001010001,(30389/123/56831),Thursday,28,April,2022,16:31:42:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0101D40001010001,to,02210100AA00000041111103018000001F0002D40001010001,(30389/123/56831),Thursday,28,April,2022,16:32:09:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0002D40001010001,to,02210100AA00000041111103018000001F0003D40001010001,(30389/123/56831),Thursday,28,April,2022,16:32:35:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0003D40001010001,to,02210100AA00000041111103018000001F0004D40001010001,(30389/123/56831),Thursday,28,April,2022,16:33:09:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0004D40001010001,to,02210100AA00000041111103018000001F0005D40001010001,(30389/123/56831),Thursday,28,April,2022,16:33:56:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0005D40001010001,to,02210100AA00000041111103018000001F0006D40001010001,(30389/123/56831),Thursday,28,April,2022,16:34:36:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0006D40001010001,to,02210100AA00000041111103018000001F0007D40001010001,(30389/123/56831),Thursday,28,April,2022,16:34:58:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0007D40001010001,to,02210100AA00000041111103018000001F0008D40001010001,(30389/123/56831),Thursday,28,April,2022,16:35:43:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0008D40001010001,to,02210100AA00000041111103018000001F0009D40001010001,(30389/123/56831),Thursday,28,April,2022,16:36:16:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F0009D40001010001,to,02210100AA00000041111103018000001F000AD40001010001,(30389/123/56831),Thursday,28,April,2022,16:37:04:11868
Address 5F,1S0 035 869 B,recoded (Long Coding),from,02210100AA00000041111103018000001F000AD40001010001,to,02210100AA00000041111103018000001F000BD40001010001,(30389/123/56831),Thursday,28,April,2022,16:37:46:11868
