Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Coding support for VW UP GTi 2018
  1. #21
    Dec 2018
    Got it, thanks 😀
  2. Likes Uwe, Dana liked this post
  3. #22
    Jan 2019
    I have the same issue with a brand new Ross-Tech HEX-V2 (3 vin) and my 2019 Up GTi.
    If possible, I would like to test the label file as well.
    Log file extract
    Friday,11,January,2019,16:27:44:42085
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    VIN: WVWZZZAAZKDx
    Mileage: 920km-571mi   Repair Order:
    Chassis Type: AA-VW12 (1S0)
    Scan: 01 03 08 09 10 15 17 19 25 44 5F 61 A9 AD
    VIN: WVWZZZAAZKDx
    AD-Brake Sensors -- Status: OK 0000
       Part No SW: 1S0 937 090 J    HW: 1S0 937 090 J
       Component: BCM PQ25 1MX4 H82 0762
       Revision: BW082001    Serial number: 8901 320180122
       Coding: 62B82B0000010000090807D06CEB8ED079C0706D60CF2D602101000B0900
       Shop #: WSC 31414 790 00001
       VCID: 3A2D30E32C55DF8790F-806E
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 201118 05  50  0106
       Coding: 0228DD
       Subsystem 2 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS72.405  H04 0005
       Serial number: 0000FST00276LWW00000
       Coding: 181100
       Subsystem 3 - Part No SW: 1K8 959 442     HW: 1K8 959 442
       Component: E221__MFL-DC1  H04 0103
       Serial number: 29180002450720078422
       Coding: A4FFFF
    Control Module Part Number: 1S0 937 090 J
      Component and/or Version: BCM PQ25 1MX4 H82 0762
               Software Coding: 62B82B0000010000090807D06CEB8ED079C0706D60CF2D602101000B0900
                Work Shop Code: WSC 31414
    Advanced Identification
         Identification: SME-RBG
         Revision: BW082001
         Date: 23.11.18
         Manufacturer number: 0005
         Test stand number: 0096
    Flash Status
         Programming Attempts(application): 0
         Successful Attempts(application): 0
         Successful Attempts(data): 0
         Programming Status: 00000000
         Flash Date: 0000.00.00
         Flash Tool Code: 00000 000 00000
    Software
         HiSpd Net: 01.01.00
    Misc.
         Hardware number: 1S0 937 090 J
         Workshop System Name: J519
         Equipment/PR Code: 0000000000000000
         Dataset Number: -----------
         Dataset Version: ----
         End of Line Equipment Level: --------------------
    VCDS Info:
           Labels: Redir Fail!
  4. #23
    Quote Originally Posted by max2100 View Post
    You can use this file with the Danish VCDS, copy it to:
    C:\NEtech\VCDS-NEZ\Labels\User
    Please post a complete Autoscan file.
  5. Likes Uwe, Dana liked this post
  6. #24
    Jan 2019
    Thanks for the quick response.
    I have now modified auto-lock, comfort-blinks and teardrop.
    I must admit that I prefer the english version.
    Translating technical terms isn't easy, and some of the danish translations are hard to understand.
    Lørdag,12,Januar,2019,17:21:13:42085
    VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
    VCDS version: NEZ 18.9.0.2  HEX-V2 CB: 0.4437.4
    Dataversion: 20181005 DS296.0
    www.vcds.dk
    Stelnummer: WVWZZZAAZKDx   Indreg.nr.:
    Kørestrækning: 920km   Reparationsordre:
    Modeltype: AA-VW12 (1S0)
    Søgt på: 01 03 08 09 10 15 17 19 25 44 5F 61 A9 AD
    Stelnummer: WVWZZZAAZKDx   Kørestrækning: 920km
    01-Motor -- Status: Fejlfunktion 0010
    03-ABS bremser -- Status: Ok 0000
    04-Styrevinkel -- Status: Ok 0000
    08-Klimaanlæg -- Status: Ok 0000
    09-Centralelektrik -- Status: Ok 0000
    10-Park.assist. -- Status: Ok 0000
    15-Airbags -- Status: Ok 0000
    17-Instrument -- Status: Ok 0000
    19-CAN Gateway -- Status: Ok 0000
    25-Startspærre -- Status: Ok 0000
    44-Servostyring -- Status: Ok 0000
    5F-Informationselek. -- Status: Ok 0000
    61-Batteriregulering -- Status: Ok 0000
    A9-Lydsvingninger -- Status: Ok 0000
    AD-Bremsesensor -- Status: Ok 0000
    Styreenhed  01: Motor (J623-DKRA)     Forklaringsfil:. NEZ\04E-907-309-V1.clb
       Styreenhedsnr: SW: 04C 906 025 F    HW: 04C 907 309 BA
       Komponent	: R3 1.0l TFS   H20 6355
       Revision: D8H20000
       Kodning	: 00190032232401000000
       Forhandler	: WSC 31414 790 00001
       ASAM datasæt: EV_ECM10TFS01104C906025F 003009
       ROD: EV_ECM10TFS01104C906025F_003.rod
       VCID: 2313ED87BB5FBE4FA37-8076
    1 fejl fundet:
    33708 - Ukendt fejlkode
              P2B63 00 [032] - -
              Periodisk - Ikke bekræftet - Testet siden sletning af hukommelse
                 Fryseramme:
                        Fejl status  : 00000001
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Kørestrækning: 115 km
                        Dato: 2019.01.04
                        Tid: 13:23:38
                        Motoromdrejningstal: 3120.50 /min
                        Normeret belastningsv糤i: 29.8 %
                        K��astighed: 121 km/t
                        K��紫etemperatur: 96 у
                        Inds.lufttemperatur: 35 у
                        Barometerstand lufttryk: 1010 mbar
                        Sp篤ing kl. 30: 12.200 V
                        Nulstillingst筬er: EOBD: 22
                        Udelufttemperatur: 5 у
                        Absolut indsugningstryk: 91 kPa abs
                        Motordrejningsmoment: 77.5 Nm
                        Br篤stof: tankniveau: 35.0 l
                        Lambdasonde B1-S1: foreskr. v糤i: 1.0000
                        Indsugningsknastaksel: B1: aktiv driftstilstand-Bits 0-7: 0
                        Indsugningsknastaksel: B1: aktiv driftstilstand-Bits 0-7: 1
                        P歸bsafbrydelse-Bits 0-7: 0
    Styreenhed  03: ABS bremser (J104)     Forklaringsfil:. NEZ\1S0-614-517.clb
       Styreenhedsnr: SW: 1S0 614 517 R    HW: 1S0 614 517 R
       Komponent	: EBC 460 ESP   H17 0031
       Serienummer: A01WKG6
       Kodning	: B9BF64712BB002F89DFE26F7D4AD40505FB000
       ASAM datasæt: EV_Brake1ESPEBC460TRW 002107
       ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
       VCID: 3E253CF330FDF3A7AC9-806A
    Ingen fejlkoder fundet.
    Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil: NEZ\1S0-907-044.clb
       Styreenhedsnr: SW: 1S0 907 044     HW: 1S0 907 044
       Komponent	: Climatronic   H05 0102
       Revision: K0000000
       VCID: 6C81C6BB1681B13752D-8038
    Styreenhed  09: Centralelektrik (J519)     Forklaringsfil:. NEZ\1S0-937-09x-V2.clb
       Styreenhedsnr: SW: 1S0 937 090 J    HW: 1S0 937 090 J
       Komponent	: BCM PQ25 1MX4 H82 0762
       Revision: BW082001    Serienummer: 8901 320180122
       Kodning	: 72B82B0000010000090807D06CEB8ED079C0706D60CF2D602101000B0900
       VCID: 3A2D30E32C55DF87901-806E
       Undersystem 1 - Styreenhedsnr:: 5K7 955 559 C  Forklaringsfil: NEZ\5K7-955-559.CLB
       Komponent	: RLS 201118 05  50  0106
       Kodning	: 0228DD
       Undersystem 2 - Styreenhedsnr: SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Komponent	: J245 PS72.405  H04 0005
       Serienummer: 0000FST00276LWW00000
       Kodning	: 181100
       Undersystem 3 - Styreenhedsnr: SW: 1K8 959 442     HW: 1K8 959 442
       Komponent	: E221__MFL-DC1  H04 0103
       Serienummer: 29180002450720078422
       Kodning	: A4FFFF
    Styreenhed  10: Park.assist. (J446)     Forklaringsfil:| NEZ\1Sx-919-475.clb
       Styreenhedsnr: SW: 1S0 919 475 B    HW: 1Q0 919 475
       Komponent	: PARKHILFE 3K  H03 0013
       Revision: --------    Serienummer: 32931833102541
       Kodning	: 108004
       ASAM datasæt: EV_EPHVA14VW1200000 001009
       ROD: EV_EPHVA14VW1200000.rod
       VCID: 392F2FEF29D3D49F99B-806C
    Styreenhed  15: Airbags (J234)     Forklaringsfil:* NEZ\5K0-959-655.clb
       Styreenhedsnr: SW: 1S0 959 655 E    HW: 1S0 959 655 E
       Komponent	: VW10Airbag02N 010 0007
       Revision: --------    Serienummer: 003EQ002382F
       Kodning	: 00000000000000000000000000000000324E
       ASAM datasæt: EV_AirbaVW10BPAVW12X 001001
       VCID: 40D9420B4A098557DE5-8014
       Crashsensor til sideairbag i f��side:
       Serienummer: 3497ARB40675KNKGQ0J2
       Crashsensor til sideairbag i passagerside:
       Serienummer: 3507ARB40675KNKGE8R+
       Crashsensor til frontairbag i f��side:
       Serienummer: 3557BRB40675LKOCPH3+
    Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\1Sx-920-xxx-17.clb-SRI1
       Styreenhedsnr: SW: 1S0 920 870 C    HW: 1S0 920 870 C
       Komponent	: KOMBI         H12 0100
       Revision: X0012001    Serienummer: 00000000000000
       Kodning	: 114A010000
       ASAM datasæt: EV_KombiUDSMM9RM10 A05808
       ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
       VCID: 313F17CFF1A31CDF21B-8064
    Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:. NEZ\6N0-909-901-6R.clb
       Styreenhedsnr: SW: 1S0 909 901     HW: 1S0 937 090 J
       Komponent	: GW-K-CAN TP20 H82 0762
       Revision: BW082001
       Kodning	: 001201
       VCID: 70B9D2CB3AA955D76E5-8024
    Styreenhed  25: Startspærre (J334)     Forklaringsfil:| NEZ\5K0-920-xxx-25.clb
       Styreenhedsnr: SW: 5K0 953 234     HW: 1S0 920 870 C
       Komponent	: IMMO          H12 0100
       Kodning	: 000000
       Forhandler	: WSC 00000 000 00000
       ASAM datasæt: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6A8DC0A31CF5AF07201-803E
    Styreenhed  44: Servostyring (J792)     Forklaringsfil:| NEZ\6Rx-909-144-V2.clb
       Styreenhedsnr: SW: 6R1 909 144 AN    HW: 6R1 909 144 E
       Komponent	: EPS_TRW_ALow  313 3150
       Serienummer: CIBT1211
       Kodning	: 000700
       ASAM datasæt: EV_SteerAssisUDSTRW 016134
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 03538D071B9F5E4F837-8056
    Styreenhed  5F: Informationselek. (J794)     Forklaringsfil:| NEZ\5G0-035-MIB-ENT2.clb
       Styreenhedsnr: SW: 1S0 035 869 B    HW: 1S0 035 869 B
       Komponent	: MU-E-D-EU     068 7338
       Serienummer: 08111800020362
       Kodning	: 02210100BE00000041111101018002001F000AC40001010001
       ASAM datasæt: EV_MUEnt4CGen2LGE 001032
       VCID: 353723DF05CB30FF7D3-8060
    Styreenhed  61: Batteriregulering (J840)     Forklaringsfil:. NEZ\1S0-907-534.clb
       Styreenhedsnr: SW: 1S0 907 534     HW: 1S0 937 090 J
       Komponent	: Batt.regelung H82 0762
       Kodning	: 032B7856
       Undersystem 1 - Styreenhedsnr: SW: 1S0 915 181 D    HW: 1S0 915 181 D
       Komponent	: J367-BDM  H08 0270
       Serienummer: 65318C01336061100578
    Styreenhed  A9: Lydsvingninger (J869)     Forklaringsfil: NEZ\4H0-907-159.clb
       Styreenhedsnr: SW: 1S0 907 159     HW: 4H0 907 159 A
       Komponent	: SAS-GEN 2     H07 0003
       Serienummer: 181026200567
       ASAM datasæt: EV_SoundActuaGen2AU64X 003010
       VCID: 73B3DDC74B3F6ECF937-8026
    Styreenhed  AD: Bremsesensor (J939)     Forklaringsfil: NEZ\1S0-907-201.clb
       Styreenhedsnr: SW: 1S0 907 201 A    HW: 1S0 907 201 A
       Komponent	: CV-SENSOR     H08 0460
       ASAM datasæt: EV_CVSen 001001
       ROD: EV_CVSen.rod
       VCID: 2809FAABC2795D17F65-807C
    Slutning------(Forløbet tid: 01:13, VBat. start/slut: 13.1V/13.1V)--------
  7. #25
    Sorry I did mean to ask for a Danish Autoscan, just the first was incomplete, it is for English here in the forum.
  8. Likes Uwe liked this post
  9. #26
    Jan 2019
    Oh, I misunderstood.
    Here's a complete english log file for anyone interested.
    And I'm still interested in testing a label file for the english VCDS.
    Sunday,13,January,2019,15:09:09:42085
    VIN: WVWZZZAAZKDx   License Plate:
    Mileage: 1090km-677mi   Repair Order:
    VIN: WVWZZZAAZKDx   Mileage: 1090km-677miles
    Address 01: Engine (J623-DKRA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 025 F    HW: 04C 907 309 BA
       Component: R3 1.0l TFS   H20 6355
       Revision: D8H20000
       Coding: 00190032232401000000
       ASAM Dataset: EV_ECM10TFS01104C906025F 003009
       VCID: 2313ED87BB5FBE4FA39-8076
    33708 - Unknown Error Code
              P2B63 00 [032] - -
                        Mileage: 115 km
                        Date: 2019.01.04
                        Time: 13:23:38
                        Engine speed: 3120.50 /min
                        Normed load value: 29.8 %
                        Vehicle speed: 121 km/h
                        Coolant temperature: 96 °C
                        Intake air temperature: 35 °C
                        Voltage terminal 30: 12.200 V
                        Unlearning counter according OBD: 20
                        Outside air temperature: 5 °C
                        Absolute intake pressure: 91 kPa abs
                        Engine torque: 77.5 Nm
                        Fuel: tank fill level: 35.0 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Intake camshaft bank1 active operating mode-Bits 0-7: 1
                        Overrun cut-off-Bits 0-7: 0
    Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
       Part No SW: 1S0 614 517 R    HW: 1S0 614 517 R
       Component: EBC 460 ESP   H17 0031
       Serial number: A01WKG6
       Coding: B9BF64712BB002F89DFE26F7D4AD40505FB000
       ASAM Dataset: EV_Brake1ESPEBC460TRW 002107
       VCID: 3E253CF330FDF3A7AC7-806A
       Part No SW: 1S0 907 044     HW: 1S0 907 044
       Component: Climatronic   H05 0102
       Revision: K0000000
       VCID: 6C81C6BB1681B137523-8038
       Coding: 7AB82B0000010000090807D06CEB8ED079C0706D60CF2D602101000B0900
       Coding: 0228DD
       Coding: 181100
       Coding: A4FFFF
    Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
       Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
       Component: PARKHILFE 3K  H03 0013
       Revision: --------    Serial number: 32931833102541
       Coding: 108004
       ASAM Dataset: EV_EPHVA14VW1200000 001009
       VCID: 392F2FEF29D3D49F995-806C
       Part No SW: 1S0 959 655 E    HW: 1S0 959 655 E
       Component: VW10Airbag02N 010 0007
       Revision: --------    Serial number: 003EQ002382F
       Coding: 00000000000000000000000000000000324E
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
       VCID: 40D9420B4A098557DEB-8014
       Serial number: 3497ARB40675KNKGQ0J2
       Serial number: 3507ARB40675KNKGE8R+
       Serial number: 3557BRB40675LKOCPH3+
    Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
       Part No SW: 1S0 920 870 C    HW: 1S0 920 870 C
       Component: KOMBI         H12 0100
       Revision: X0012001    Serial number: 00000000000000
       Coding: 114A010000
       ASAM Dataset: EV_KombiUDSMM9RM10 A05808
       VCID: 313F17CFF1A31CDF215-8064
       Part No SW: 1S0 909 901     HW: 1S0 937 090 J
       Component: GW-K-CAN TP20 H82 0762
       Revision: BW082001
       Coding: 001201
       VCID: 70B9D2CB3AA955D76EB-8024
       Part No SW: 5K0 953 234     HW: 1S0 920 870 C
       Component: IMMO          H12 0100
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       VCID: 6A8DC0A31CF5AF0720F-803E
    Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
       Part No SW: 6R1 909 144 AN    HW: 6R1 909 144 E
       Component: EPS_TRW_ALow  313 3150
       Serial number: CIBT1211
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016134
       VCID: 03538D071B9F5E4F839-8056
       Part No SW: 1S0 035 869 B    HW: 1S0 035 869 B
       Component: MU-E-D-EU     068 7338
       Serial number: 08111800020362
       Coding: 02210100BE00000041111101018002001F000AC40001010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       VCID: 353723DF05CB30FF7DD-8060
       Part No SW: 1S0 907 534     HW: 1S0 937 090 J
       Component: Batt.regelung H82 0762
       Coding: 032B7856
       Subsystem 1 - Part No SW: 1S0 915 181 D    HW: 1S0 915 181 D
       Component: J367-BDM  H08 0270
       Serial number: 65318C01336061100578
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 1S0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0003
       Serial number: 181026200567
       VCID: 73B3DDC74B3F6ECF939-8026
    Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
       Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
       Component: CV-SENSOR     H08 0460
       ASAM Dataset: EV_CVSen 001001
       ROD: EV_CVSen.rod
       VCID: 2809FAABC2795D17F6B-807C
    End----------(Elapsed Time: 01:14, VBatt start/end: 13.3V/13.3V)-----------
  10. Likes Uwe, Dana liked this post
  11. #27
    United States
    Sorry I missed that Henrik. I'll get one sent off to the address on-file shortly.
  12. Likes Uwe liked this post
  13. #28
    Jan 2019
    No problem, thanks for the updated file.
    It works fine.
    Some observations for your information.
    There are more adaptation channels available with the updated Danish label file from NETech. I have listed some of them below (please bear with me for my English translations :-)
    Channel 05: Central Locking SAFE-function
    Tooltip "SAFE-function enabled/disabled"
    My value: enabled
    Channel 16: Sunroof Setting.
    Tooltip "Unknown. Read from others: 1".
    My value: 0.
    Channel 40: Duration for heating rear window / side mirrors
    My value: 14, corresponding to 7.5 minutes according to the tooltip.
  14. Likes Uwe, Dana liked this post
  15. #29
    Feb 2019
    Do any of your UP! GTI's run cruise control?
    Trying to retrofit cruise control but no coding label available for BCM.
    Wednesday,30,January,2019,11:55:27:21341
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    VIN: WVWZZZAAZKD122196   License Plate:
    Scan: 01 03 09 15 17 19 25 44 47 5F 61 A9
    VIN: WVWZZZAAZKD122196   Mileage: 3870km-2404miles
       Revision: D8H20000
       Coding: 00190014232401000000
       VCID: 2306EC6C2A86A552E0-8076
       Part No SW: 1S0 614 517 P    HW: 1S0 614 517 P
       Component: EBC 460 ESP   H17 0030
       Serial number: A01V7ZK
       Coding: B8BF64712BAF02F31DFB26FED4AF40905F0000
       VCID: 3C343710B738FAAAC1-8068
       Revision: BW082001    Serial number: 8901 281180498
       Coding: 64B8290000010000000809D06CABACD07940706D60CF2D602101000B0800
       Shop #: WSC 12600 152 403110
       VCID: 3A383108B50CC49AD3-806E
       Subsystem 1 - Part No SW: 1K8 959 442     HW: 1K8 959 442
       Serial number: 29180002197740108384
       Coding: 94FFFF
       Component: VW10Airbag02Z 010 0007
       Revision: --------    Serial number: 003EQ001DFH3
       Coding: 00000000000000000000000000000000325A
       VCID: 40CC43E0DBD09E4A9D-8014
       Serial number: 357D4RB40555K7F46O70
       Serial number: 358D4RB404P5GNIE8O1+
       Serial number: 3557BRB40555DFD8H8F5
       Part No SW: 1S0 920 970 C    HW: 1S0 920 970 C
       Coding: 414A010000
       VCID: 32281928657C3CDA1B-8066
       Revision: BW082001
       Coding: 001101
       VCID: 70ACD320A3F04ECA2D-8024
       Part No SW: 5K0 953 234     HW: 1S0 920 970 C
       VCID: 6A98C1488D2CB41A63-803E
       Part No SW: 6R2 909 144 AN    HW: 6R2 909 144 E
       Component: EPS_TRW_ALow  323 3150
       Serial number: CIA31270
       Coding: 000700
       VCID: 04448FF08F48426AF9-8050
       Part No SW: 5K0 035 456 E    HW: 5K0 035 456 E
       Component: KonzernAmp 8K H09 6631
       Revision: --------    Serial number: EAA101C0085722
       ASAM Dataset: EV_AudioVerst8KanalSTT3 001003
       ROD: EV_AudioVerst8KanalSTT3.rod
       VCID: 2C14075047586A2A51-8078
       Serial number: 24071800020580
       Coding: 02210100AA00000041111103018000001F000AC60001010001
       VCID: 3522223494122BE23E-8060
       Coding: 032B7856
       Serial number: 65260F52586060974094
       Serial number: 180720200369
       VCID: 73A6DC2CDAE675D2D0-8026
    End----------(Elapsed Time: 00:42, VBatt start/end: 14.7V/14.7V)-----------
  16. #30
    Aug 2016
    The Hague, NL
    Byte 17 bit 7, set to 1 for CCS in pq25 (your cars platform)
  17. Likes Uwe, Dana liked this post
