Coding support for VW UP GTi 2018
   #41
iichel
Netherlands, eastern part
C?ID=284912
I was a bit in doubt, usually if NETech says something, it's likely to be true. Happy to hear you got it figured out though.
   #42
NEtech
C?ID=56995
I have not tested it, this was factory telling the importer.
Cruise control is working :cool:
What was changed so you got it working ?
   #43
Maccaman
C?ID=119641
All the wiring is not in place from the factory! Cant believe they make different looms depending if the car has CC or not.
   #44
Oh yes. VWAG has made a science out of reducing wiring to the exact amount required for a particular configuration of car.
Maccaman
C?ID=119641
Sorry, yes I will do later today
   #47
Tricky1200
C?ID=275945
I have the same issue with my 2019 Up GTi.
If possible, I would like to test the label file for the central electrics as well.
Many thanks
Richard
Log file extract.
Tuesday,09,April,2019,19:27:31:12326
VIN: WVWZZZAAZKD147751   License Plate:
Mileage: 220km-136mi   Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 09 10 15 17 19 25 44 47 5F 61 A9
VIN: WVWZZZAAZKD147751   Mileage: 220km-136miles
Address 01: Engine (J623-DKRA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 F    HW: 04C 907 309 BA
   Component: R3 1.0l TFS   H20 6355
   Revision: D8H20000
   Coding: 00190034232401000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10TFS01104C906025F 003009
   ROD: EV_ECM10TFS01104C906025F_003.rod
   VCID: 231313308B56FA7FA3F-8076
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 R    HW: 1S0 614 517 R
   Component: EBC 460 ESP   H17 0031
   Serial number: A01XGPW
   Coding: B8BF64712BB102F81D0126FAD4AA40905F0000
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002107
   ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
   VCID: 3E25C24400F4B797AC1-806A
   Part No SW: 1S0 937 090 J    HW: 1S0 937 090 J
   Component: BCM PQ25 1MX4 H82 0762
   Revision: BW082001    Serial number: 8901 016191631
   Coding: 64B8290000010000000809C06CABACD079C0706D60CF2D602101000B0800
   Shop #: WSC 12601 025 394886
   VCID: 3A2DCE541C5C9BB7909-806E
   Subsystem 1 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29180003046740109022
   Coding: A4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0013
   Revision: --------    Serial number: 32931902100670
   Coding: 308004
   ASAM Dataset: EV_EPHVA14VW1200000 001009
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 392FD15819DA90AF993-806C
   Part No SW: 1S0 959 655 E    HW: 1S0 959 655 E
   Component: VW10Airbag02Z 010 0007
   Revision: --------    Serial number: 003EQ002MXKY
   Coding: 00000000000000000000000000000000325A
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   VCID: 40D9BCBC7A00C167DED-8014
   Serial number: 357D4RB40695OOVO1ONU
   Serial number: 358D4RB401C5I4OUEOSK
   Serial number: 3557BRB404P5LKOEBPPW
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 970 C    HW: 1S0 920 970 C
   Component: KOMBI         H12 0100
   Revision: X0012001    Serial number: 00000000000000
   Coding: 414A010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 323DE674C4AC63F7589-8066
   Part No SW: 1S0 909 901     HW: 1S0 937 090 J
   Component: GW-K-CAN TP20 H82 0762
   Revision: BW082001
   Coding: 001101
   VCID: 70B92C7C0AA011E76ED-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 970 C
   Component: IMMO          H12 0100
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6A8D3E142CFCEB37209-803E
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R2 909 144 AN    HW: 6R2 909 144 E
   Component: EPS_TRW_ALow  323 3150
   Serial number: CJ1S0459
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 045170AC2E981D47BA5-8050
   Part No SW: 5K0 035 456 E    HW: 5K0 035 456 E
   Component: KonzernAmp 8K H09 6631
   Revision: --------    Serial number: EAA101C0091095
   ASAM Dataset: EV_AudioVerst8KanalSTT3 001003
   ROD: EV_AudioVerst8KanalSTT3.rod
   VCID: 2C01F80CE6883507125-8078
   Part No SW: 1S0 035 869 B    HW: 1S0 035 869 B
   Component: MU-E-D-EU     070 7338
   Serial number: 17011900021550
   Coding: 02210100AA00000041111103018000001F000AD60001010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   VCID: 3537DD6835C274CF7DB-8060
   Part No SW: 1S0 907 534     HW: 1S0 937 090 J
   Component: Batt.regelung H82 0762
   Coding: 032B7856
   Subsystem 1 - Part No SW: 1S0 915 181 D    HW: 1S0 915 181 D
   Component: J367-BDM  H08 0270
   Serial number: 55346D40066061115976
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 1S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0003
   Serial number: 181103201418
   VCID: 73B323707B362AFF93F-8026
End----------(Elapsed Time: 00:47, VBatt start/end: 12.0V/12.0V)-----------
Dana
Western PA, USA
Tricky1200, I sent you a file via email from Support using subject: Fwd: Reply to thread 'Coding support for VW UP GTi 2018'
Tricky1200
C?ID=275945
Thanks Dana, that worked a treat.
please find attached a copy of my final scan.
Thursday,11,April,2019,17:01:03:12326
Data version: 20190215 DS296.0
Mileage: 280km-173mi   Repair Order: 11042019
VIN: WVWZZZAAZKD147751   Mileage: 280km-173miles
   Revision: D8H20000
Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-09x-V1.clb
   Coding: 7FB829002001000000080FC06CABBCD079C0706D60CF2D602101000B0800
   Coding: A4FFFF
   Coding: 308004
   Coding: 414A010000
   Revision: BW082001
   Coding: 001101
   Coding: 000700
   Coding: 032B7856
End----------(Elapsed Time: 00:49, VBatt start/end: 12.2V/12.2V)-----------
iichel
C?ID=284912
That's interesting, doesn't it come with electric windows?
   #51
Tricky1200
C?ID=275945
Hi iichel,
It does have electric windows.
Tricky
   #53
Petar001
Croatia
C?ID=361578
So for now i can confirm that
Part No SW: 1S0 937 090 F HW: 1S0 937 090
Component: BCM PQ25 1MX4 H81 0744
Revision: BW081001 Serial number: 0978 102170349
Coding: 62B8290000010000000001D06CABACD07940706D60CF2D602101000B0800
Shop #: WSC 78135 026 394918
VCID: 3634D324C84FA647205-8062
does not accept MF wheel
have tried this full coding from vw up GTI
Coding: A4FFFF
coding as accepted but MF not working.
   #54
spook
C?ID=30525
Hi, I've just got an Up GTI and I'm trying to work out the missing labels in Cent Elec. Can anyone assist me with a labels file so I can see what's going on?
Thanks!
   #55
iichel
C?ID=284912
62B8290000010000000801D02CABACD07940706D60CF2D602101000B0800
This should do the trick
I assume you fitted the wires correctly, but just to be sure, how did you correct these wires?
+30/+15/+30g to the wheel and LIN goes to what wire on the BCM?
   #56
Dana
Western PA, USA
Thanks!
Hi Gary,
I located an earlier scan from you in our email which contained this BCM:
> Coding: 64B8290000010000080809D06CABACD07940706D60CF2D602101000B0800
> Subsystem 1 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
> Component: J245 PS72.405 H04 0005
> Serial number: 0000FST0024DT3F00000
> Coding: 181000
> Subsystem 2 - Part No SW: 1K8 959 442 HW: 1K8 959 442
> Serial number: 29180001714690018327
> Coding: A4FFFF
It might not hurt to post the scan here if you need any assistance but I'll redirect that BCM to an existing file in English VCDS and send it via e-mail.
   #57
Petar001
Croatia
C?ID=361578
if you need info how to connect let me know
   #58
Alex.fergo1988
C?ID=389664
Hi guys, I’m struggling with the central electrics (09) labelling, can anyone email me the label file please... thanks in advance
   #59
Hi guys, IÂ’m struggling with the central electrics (09) labelling, can anyone email me the label file please... thanks in advance
You'll need to post a full unedited VCDS Auto-Scan so we can see which might be the correct label file.
Alex.fergo1988
C?ID=389664
Scan
Ok I’ll have to do this later, I see other people have asked and they’ve been sent it, I image the up gti is all the same through the years as the spec list is very limited
